Date/Time: Sat, 23 Nov 2024 12:39:04 +0000
Teton Order routing in case of lost internet connection
View Count: 152
[2024-08-25 06:28:14]
Tmaximus1 - Posts: 1
I the past have used Sierra Chart with CQG order routing through Amp Futures. One time while I had a trade open I lost my internet connection. I was able to close the trade using the CQG mobile app.
My question is if I were to switch to Teton routing is there anyway to access an open trade in the case of a lost connection since Sierra Chart does have any mobile access ?
[2024-08-25 07:17:53]
Sierra_Chart Engineering - Posts: 17145
Yes. Refer to:
Sierra Chart Teton Futures Order Routing: Web-Based Trading Panel
[2024-08-25 13:47:39]
ondafringe - Posts: 283
You should also be able to reconnect using your mobile device hotspot.
