Date/Time: Sat, 23 Nov 2024 12:10:16 +0000
Switching between footprint chart and regular candlestick chart
View Count: 100
[2024-08-25 03:05:54] |
Gambit - Posts: 1 |
Hello! I was wondering if there was a way to switch between footprint candles and regular candles. For example, if I zoom in enough, the candles turn into footprint candles, but when I zoom back out, they turn back to regular candles.
[2024-08-26 17:45:10] |
There is not built in way to do this. You could create a custom study that adds/removes the Numbers Bars study based on the Bar Spacing. Refer to the following: ACSIL Interface Members - Variables and Arrays: sc.ChartBarSpacing https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
