Date/Time: Sat, 23 Nov 2024 12:07:51 +0000
Numbers Bar Horizontal Spacing
View Count: 139
[2024-08-24 23:12:47]
User688525 - Posts: 257
Hello Sierra Chart,
After reading through the "Changing Bar Spacing" documentation (Working With Charts: Changing Bar Spacing), I haven't found a solution to define horizontal spacing for a Numbers Bar chart so that if the chart is "reset", the horizontal spacing defaults to a previously-defined width.
Is it possible to achieve this? Currently, if a Numbers Bar chart is reset, the horizontal spacing makes the chart unreadable, requiring one of the several manual methods listed in the "Changing Bar Spacing" documentation?
Thank you
[2024-08-26 17:38:10]
There is not a way to set a default "Width" for a Numbers Bars chart.
But as long as the Numbers Bars study is on a chart, there is nothing that should cause the bar spacing to suddenly change. So we are not sure what you are referring to in terms of a "Reset"? What exactly are you doing in this case?
[2024-08-26 18:49:07]
Hello John,
Thanks for your help.
In terms of a "Reset", this is a keyboard shortcut created for "Reset Bar Size/Spacing/Scale".
[2024-08-26 20:49:40]
Ok, we understand what you are doing. There is not an option to be able to have the Numbers Bars automatically setup in a way that makes them more readable.
[2024-08-26 21:57:30]
Ok, thank you for confirming.
