Date/Time: Sat, 23 Nov 2024 11:55:30 +0000
Trading System Based on Alert Condition And Volume at Price Alert Threshold V2
View Count: 114
[2024-08-24 17:59:14] |
Eranox - Posts: 26 |
Hi I have set up the 'Volume at Price Alert Threshold V2' to display imbalances. I would like to integrate it into 'Trading System Based on Alert Condition' to automatically buy or sell when there is an imbalance but I don't know what I should write in the Alert Condition box. I tried with =ID9.SG60 (Volume at Price Alert Threshold V2 has id 9 and the subgraph should be 60…) but I get no order when the condition is true. Obviously auto trade is on and Trading System Based on Alert Condition is enabled.. Can you help me? Thanks ☺️ Date Time Of Last Edit: 2024-08-25 09:03:38
[2024-08-26 17:19:44] |
To get an alert when the first imbalance occurs, then you need to use SG1 (Trigger 0). When this is set to a non-zero value, then that indicates that the conditions were met in your study. Therefore, you could use an alert condition like the following: =ID9.SG1 If you are wanting an alert for a different situation, then we would need to know what it is so we can point you in the proper direction. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
