Date/Time: Sat, 23 Nov 2024 12:14:20 +0000
[User Discussion] - Huge USDX.scid file size
View Count: 116
[2024-08-23 23:38:01] |
User14953 - Posts: 235 |
This USDX.scid file is 7 times bigger than the old contract ES file, 450MB v 65MB. Can Sierra be configured to use a reduced size of USDX.scid file? |
[2024-08-24 02:46:55] |
Sierra_Chart Engineering - Posts: 17145 |
We will work on compressing this data. Allow about a week. At that time re-download the data: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download" from the main Sierra Chart menu. You just need to do this once per symbol and not for each chart. This command is on the main Sierra Chart menu at the top. Only use it from that location. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
