Date/Time: Sat, 23 Nov 2024 12:03:26 +0000
Unable to connect Teton/Denali
View Count: 104
[2024-08-23 22:31:33] |
User290496 - Posts: 62 |
Hi, I am unable to connect to Teton and/or Denali- I get the error message in the attached screenshot. "Secondary instance is not allowing connections to this server". I was logged in and using the service just fine when this suddenly happened. Never had an issue like this. No other instance of Sierra installed anywhere. I tried shutting Sierra down and restarting- same issue occurs when I start Sierra back up. ***** Edit at 20:35 EST ***** It just reconnected by itself. I didn't touch anything and just left it on. For some reason I lost connectivity earlier on as described above for over an hour. Date Time Of Last Edit: 2024-08-24 00:36:35
Screenshot 2024-08-23 182431 - Copy.png / V - Attached On 2024-08-23 22:28:52 UTC - Size: 15.55 KB - 34 views |
[2024-08-24 02:44:42] |
Sierra_Chart Engineering - Posts: 17145 |
This was the result of maintenance that was being done earlier this evening.
