Date/Time: Sat, 23 Nov 2024 12:51:16 +0000
Flatten button not working as before.
View Count: 110
[2024-08-23 19:50:23]
UserCD - Posts: 11
Ok I had another occurrance:
1) I hit Flatten - trade does not close out.
2) I hit again and eventually it closes out - with loss greater than it should be.
Snippets of logs attached.
imageScreenshot 2024-08-24 040843 - Trade activity Log.png / V - Attached On 2024-08-23 19:50:12 UTC - Size: 3.19 KB - 28 views
imageScreenshot 2024-08-24 040606 - Service Log.png / V - Attached On 2024-08-23 19:50:16 UTC - Size: 9.44 KB - 29 views
[2024-08-23 19:59:01]
Refer to the following:
Global Trade Settings Windows: Hold Market Order Until Pending Cancel Orders Are Confirmed (Global Settings >> General Trade Settings >> General)
[2024-08-23 20:21:30]
Sierra_Chart Engineering - Posts: 17145
If you use Teton order routing you are not going to have this problem at all. Use Teton order routing:
You are paying extra money for CQG and getting a substandard level of service. Using CQG makes no sense at all. You are paying CQG for absolutely nothing. You are wasting money with them. And having a substandard level of service.
[2024-08-23 20:25:04]
UserCD - Posts: 11
Will check this out and report back
