Date/Time: Sat, 23 Nov 2024 08:54:16 +0000
Chart not updating during first minutes of market hours
View Count: 117
[2024-08-23 19:36:00]
marc22991 - Posts: 8
Good afternoon: For the past few days my chart does not update prior to market open even though I have the app set up to start updating at 9:25am EST. The issue persists for minutes after market open unless I manually reconnect. Every time I reconnect manually the chart is updated but no further real time data is loaded. After a few attempts and repeating the same process, the app will finally start working correctly again. Please advise. Thank you!
[2024-08-26 14:23:54]
What is one symbol for which you are having this issue?
[2024-08-26 18:08:02]
AMD-NQTV
[2024-08-26 20:44:47]
We need to see your Message Log right after you have this occurrence where the data is not flowing. Do not reconnect, just wait a few minutes, then get us the Message Log by following these instructions:
[2024-08-27 14:12:28]
I have attached two log files, first at 9:31am and the second at 10:05am. I did not attempt to connect manually.
attachmentlog_09-31am.txt - Attached On 2024-08-27 14:11:30 UTC - Size: 40.85 KB - 78 views
attachmentlog_10-05am.txt - Attached On 2024-08-27 14:11:35 UTC - Size: 40.85 KB - 65 views
[2024-08-27 16:22:34]
You need to update your Sierra Chart to the latest version. Follow these instructions:
[2024-08-28 15:20:15]
That worked, new version installed and it seems to be running just fine. I will use it for the next couple of days and get back in touch if the problem persists. Thanks for your assistance!
