Date/Time: Sat, 23 Nov 2024 11:56:56 +0000
Application can't be opened
View Count: 110
[2024-08-23 18:03:44] |
User568543 - Posts: 5 |
Everytime I try to download the software I get a message that "the application can't be opened." I am on a new MacBook pro running Sonoma 14.6.1
[2024-08-24 02:43:39] |
Sierra_Chart Engineering - Posts: 17145 |
Maybe another user who uses Mac is able to help you. We are not sure of the solution.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-08-24 02:43:46
[2024-08-26 14:37:37] |
Sierra Chart does not have a native MAC application, it is only available for Windows. If you want to run Sierra Chart on a MAC, you need to use a Windows emulator.
