Date/Time: Sat, 23 Nov 2024 12:19:23 +0000
adding a daily stop limit?
View Count: 90
[2024-08-23 15:46:54]
Edmyr - Posts: 4
Can I get the procedure that works for me to add a daily stop limit?
[2024-08-26 13:23:17]
Refer to the following:
Global Profit/Loss Management
If you are using the Trading Evaluator or using Teton with certain brokers, then there is also a Server Profit/Loss Management option. Check with your broker if they support this for Teton. Refer to the following:
Server Based Profit/Loss Management
