Date/Time: Sat, 23 Nov 2024 11:58:47 +0000
Calculating price percentage
View Count: 96
[2024-08-23 15:35:51] |
Shlomi.B - Posts: 42 |
couldnt find anything while searching this in support but was wondering if there is a tool that can measure the distance between two price points and give a percentage calculation. for example, draw a line between $100 and $110 and the line will register/ spit out 10% Thank you in advance. |
[2024-08-26 13:20:32] |
The "Chart Calculator" drawing tool can do this. One of the display options for this tool is "Show Percent Change". Refer to the following: Chart Drawing Tools: Chart Calculator For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
