Date/Time: Sat, 23 Nov 2024 11:55:56 +0000
It is not adding up my points right
View Count: 86
[2024-08-23 15:30:26] |
JoeThanksG - Posts: 6 |
I'm having a problem in Sim mode I make my entries of 2 Lots add 1 Positive When I remove positive the first 1 it gives me my points when I remove the second 1 sometimes it gives me my points, sometimes it doesn't when I removed the last 1 it doesn't give me my points The same I enter 1 lot add 1 more lot when I exit the 2 lots (positive) I only get the points for 1 When I lose Negative it adds everything up right I would be happier if it would do it when I win (positive) but the truth is I wanted it to add everything right I don't know if it's; my Internet > but I don't think so, in the Sim mode it is supposed to do all in my computer right or do I have something set wrong All I know is I'm ready to go LIVE I don't want this happening, when I go to live Sincerely, JV PS. I never had this problem with Jigsaw, Quantower, Tradovate, SmartTrader or IG Broker |
[2024-08-23 18:22:05] |
Sierra_Chart Engineering - Posts: 17145 |
We are not understanding this. We need to have a clear reference to specifically what you are referring to in Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
