Date/Time: Sat, 23 Nov 2024 12:50:10 +0000
Stand AloneDOM keeps setting me to Sim from Live
View Count: 103
[2024-08-23 15:28:24] |
User360283 - Posts: 504 |
I set it to LIVE and it says I SIM is disabled. Then I make a trade make a profit But DOM now say SUM enabled and NO REL PROFIT Verified with Broker - NO LIVE TRADES! Help please Thanks |
[2024-08-23 16:53:51] |
Sierra_Chart Engineering - Posts: 17145 |
You need to set Sierra Chart to the Trading service you are using. Who is your broker? Do you know if the broker set you up on Teton order routing? Or CQG? Or what? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-08-23 16:53:57
[2024-08-23 17:01:00] |
Which service is best for Sierra?
[2024-08-23 17:38:36] |
The best is Teton order routing: Sierra Chart Teton Futures Order Routing Contact your broker and have them set you up on Teton order routing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-23 18:02:41] |
Where do I set the data feed in Sierra?
[2024-08-23 18:10:09] |
You are all set with the Denali Data Feed. Nothing more you need to do with that. To get set up with Teton order routing just follow through the instructions here: Sierra Chart Teton Futures Order Routing: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
