Date/Time: Sat, 23 Nov 2024 12:47:11 +0000
Trade Account Monitor window not remembering modified column order
View Count: 81
[2024-08-23 11:57:40]
vortega23 - Posts: 7
The Trade Account Monitor window allows me to reorder the columns via drag-and-drop, which is great. I like to move the Currency field away from view, since I only trade one currency; on the other hand, I like to bring the DailyP/L% field within view, so I put it next to DailyProfit/Loss. So far, so good. The problem is that this window does not have a File menu that allows me to save the order of the columns I have set, nor does it save this order when I select "Save All" from the main menu, and so every time I launch Sierra Chart, the columns are in the original order, not the one I set. I checked the documentation:
Trading Information Windows: Trade Account Monitor (Account Balances) Window
and searched the support board for anything relevant, but didn't find anything. So please add either an option to save the column order as I have set it, or change "Save All" to include saving the column order on the Trade Account Monitor window. Thanks in advance.
[2024-08-23 15:20:45]
Sierra_Chart Engineering - Posts: 17145
We will check on this. The columns should be saved. Both the order of the columns and the width.
