Date/Time: Sat, 23 Nov 2024 12:42:07 +0000
Symbol Settings
View Count: 120
[2024-08-23 03:38:36] |
User841161 - Posts: 221 |
2 of the ETF's (xlc-NQTV, xlre-NQTV) are not listed in the symbol settings. There are quotes for them, but no settings for them.
[2024-08-23 13:43:53] |
Sierra_Chart Engineering - Posts: 17145 |
There are not settings for specific symbols. Only symbol patterns. This is normal.
[2024-08-23 14:14:27] |
Can I just manually add them into the symbol settings, for they are the only 2 of the major ETF's that are not in there. That way to have name Descriptions to them when in Study Summary.
[2024-08-26 13:11:57] |
Yes, you can create Symbol Settings for those if you want. It would be best to copy an existing symbol setting and modify from there. Refer to the following: Global Symbol Settings: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
