Date/Time: Sat, 23 Nov 2024 12:56:57 +0000
market profile problem
View Count: 160
[2024-08-21 18:16:27] |
User516525 - Posts: 2 |
good morning, my market profile is no longer displayed? I didn't touch anything. I just added credit to my account. So if I understand correctly, you don't have to pay for it to work... I installed the latest version, closed and reopened it several times ... and nothing happened (see attachment). What can I do? |
Capture d’écran 2024-08-21 à 17.04.34.png / V - Attached On 2024-08-21 18:16:23 UTC - Size: 86.79 KB - 45 views |
[2024-08-22 09:14:56] |
User431178 - Posts: 540 |
Check your settings. You have a daily TPO with a block size of 1 day, so only possible to have 1 block per price. |
[2024-08-23 10:27:58] |
Sierra_Chart Engineering - Posts: 17145 |
Regarding post #1, post an image following these instructions: Provide an image of the chart or Trade DOM, by following these *exact* instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
