Date/Time: Sat, 23 Nov 2024 12:05:36 +0000
Help with covery of Stand lone DOM
View Count: 132
[2024-08-21 18:16:25] |
User360283 - Posts: 504 |
Please provide link for Stand Alone documentation Thanks |
[2024-08-21 18:18:50] |
We are not certain of what you are asking, but if you are wanting the documentation off-line, then on the "Table of Contents" page, there is a link just under the main links that states "download an offline copy of the documentation". Select this to get the documentation downloaded as web pages. There is not a way to get it as a PDF, if that is what you want. The direct link to this is here: https://www.sierrachart.com/downloads/SierraChartDocumentation.zip For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-22 23:49:53] |
Thanks Got it. A question If I set Simulated Trading on the DOM are my three chats automatically ALSO the set to Simulated? |
[2024-08-23 21:56:11] |
The option for "Global Settings >> Simulation Mode On" is a global setting, so enabling this option means that all charts, in all chartbooks, in that installation of Sierra Chart are using the built-in Simulation Mode. Refer to the following for more on this: Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
