Date/Time: Sat, 23 Nov 2024 12:15:01 +0000
[User Discussion] - The best solution
View Count: 85
[2024-08-21 18:08:30]
User808859 - Posts: 1
I am very excited about the features Sierra is offering. Now, I need your help and recommendations. When it comes to the optimal performance what set up would you recommend? Beginning with the Broker and FCM, continuing with the market data and trading routing. Stability and velocity are important points, you surely name others.
I want to set up my business right, therefore I would appreciate your support.
Thank you very much.
[2024-08-21 18:12:28]
If you are trading the CME Group, the for optimal performance you will want to use our Denali Exchange Data Feed for your data and our Teton Order Routing Service to route your orders. Refer to the following for information on each of these:
Note that in the documentation for our Teton Order Routing Service in the Setup Instructions at Step #2 is a list of Brokers and FCMs that work with the Teton Order Routing Service.
We have set this thread as a "User Discussion" for others to give their thoughts on your questions.
