Date/Time: Sat, 23 Nov 2024 12:15:38 +0000
DOM execution prices always remain centered
View Count: 84
[2024-08-21 17:33:08]
User959382 - Posts: 10
Sorry but I need help, I've searched everywhere but I can't find a solution. I need to be able to ensure that the DOM execution prices always remain centered, not that they scroll up and down, but that the current price is always in the center, in short, I would like the scroll to be stopped, and not to go up and down. How can I do it? I'm sending a picture of the dom, see? the current price is at the top, I would always like it in the center.
A thousand thanks
Francesco Amoriello
imageScreenshot_2024_08_21-3.png / V - Attached On 2024-08-21 17:33:03 UTC - Size: 91.67 KB - 23 views
[2024-08-21 17:35:15]
You need to set your scale settings to be "Constant Range" with a "Constant Range Scale Mode" of "Re-Center to the Last Price on Every Update". Refer to the following:
Chart Scale and Scale Adjusting: Constant Range Scale Modes >> Re-Center To The Last Price On Every Update
