Date/Time: Sat, 23 Nov 2024 12:15:32 +0000
[Programming Help] - How often CPP programs get executed
View Count: 168
[2024-08-21 16:11:10]
User935839 - Posts: 2
Hi guys
I'm confused on how often CPP programs get executed during live/playback session. i come from Ninjatrader c# trading and it was easy to know how often code get executed (each new tick/each bar close ... ) . However i dont get it in Sierra,, like i want my code to get executed every chart bar close, i trying that just to see how often it get called :
if(sc.GetBarHasClosedStatus(sc.Index)==BHCS_BAR_HAS_NOT_CLOSED)
  {sc.AddMessageToLog("to execute only once per bar", true);}
  // return;//do not do any processing if the bar at the current index has not closed
the result on logs is like having new log each +/-9 seconds ,,, which is not really coherent ... i just want my code to get executed at very moment of bar close whatever the timeframe on my chart is .
i wish my question is clear enough and u can help me ,
Thanks a lot
[2024-08-21 17:07:24]
Sierra_Chart Engineering - Posts: 17145
Refer to:
Working with ACSIL Arrays and Understanding Looping: When the Study Function is Called
If you want the study function to be guaranteed to be called when a bar closes, and not at the time a new bar is added to the chart, then you need to use this variable:
ACSIL Interface Members - Variables and Arrays: sc.UpdateAlways
[2024-08-21 17:52:16]
Guys, stupid to say , but i cant achieve to write one log message each time bar closes, whatever the timeframe is ... i tried all different combinations of flags (sc.AutoLoop, sc.UpdateAlways , sc.UpdateStartIndex..). but cant achieve it, looks like the program executes randomly which is weird
[2024-08-21 18:22:52]
The most reliable way to know a chart bar closes is when a new one is added. So if a chart bar at index 99 closes, you will know that, when a chart bar at index 100 is added. The sc.ArraySize would change from 100 to 101.
Date Time Of Last Edit: 2024-08-21 18:23:17
[2024-08-22 00:36:33]
ForgivingComputers.com - Posts: 960
Since you used sc.Index, that implies you are using
sc.AutoLoop = 1;
In which case you do not specify the index for the status function.
This is what you need:
if(sc.GetBarHasClosedStatus()==BHCS_BAR_HAS_NOT_CLOSED)
else
