Date/Time: Sat, 23 Nov 2024 12:15:36 +0000
control bar 2-8
View Count: 83
[2024-08-21 14:20:33] |
User282298 - Posts: 9 |
Hi on my main screen when i choose custom control bar 2-8, it doesnt pop up like it should on my smaller trading windows it does how do i fix this? thanks |
[2024-08-21 15:43:10] |
Sierra_Chart Engineering - Posts: 17145 |
You need to use these commands: Control Bar: Window >> Control Bars >> Control Bar [1-12] And then refer to: Control Bar: Unable to Make Control Bar Visible Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-08-21 15:43:27
