Date/Time: Sat, 23 Nov 2024 11:46:42 +0000
color bar based on alert condition
View Count: 126
[2024-08-21 08:52:36]
User220939 - Posts: 36
Hello, I use the study color bar based on alert condition to color a candle when the delta % difference is greater or less than 0.20. It works on some candles but not all, and I can't figure out why.
THANKS
imageCapture d’écran 2024-06-12 191751.jpg / V - Attached On 2024-08-21 08:48:36 UTC - Size: 90.9 KB - 45 views
[2024-08-22 15:57:40]
The statement "greater or less than 0.20" does not make any sense. It will be either greater than or less than 0.20 most of the time, except when it happens to be exactly equal to 0.20. We think this is just a grammatical error, but check your alert condition just in case.
Also, refer to the following regarding settings alert conditions on the Numbers Bars Calculated Values studies:
Numbers Bars: Referencing Numbers Bars Calculated Values Subgraphs in Alert Formulas
