Date/Time: Sat, 23 Nov 2024 12:10:13 +0000
Is it possible to increase the depth of book?
View Count: 75
[2024-08-20 15:28:34] |
User616706 - Posts: 1 |
Dear Sieera Support, Yesterday I upgraded the data feed at sierra to the CME with Market Depth for non-professional trading accounts. Unfortunately I only see 100 levels for the Nasdaq. is it possible to see more levels? Thank you very much for your support. Best Regards EA |
[2024-08-20 17:09:14] |
You can have up to 1400 levels for that product. You have a setting somewhere that is restricting it. Refer to the following: File Menu: Not Receiving the Full Number of Market Depth Levels For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
