Date/Time: Sat, 23 Nov 2024 09:20:52 +0000
Question re Integration with Trading Platforms
View Count: 191
[2024-08-20 05:17:59] |
User38606 - Posts: 106 |
Hi. Can I ask: what is the current FX trading platform / services that I can connect to Sierra? I remember before it was LMAX. Is it still supported? Or which ones do you currently suggest? Thank you |
[2024-08-20 15:20:18] |
We do still have connectivity with LMAX. We believe that Interactive Brokers, whom we also have connectivity with, also has FX trading, but you would need to check with them for sure. Refer to the following: LMAX Trading Service Interactive Brokers Trading Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-27 14:42:00] |
asked a basic question in the open ticket (setting up LMAX demo) and did not get my answer.... You have setup my account (demo) but I still cannot connect to LMAX demo. Is that due to my package? I am package 3. Do I need to change the package to connect Sierra to my LMAX demo account? Thank you Date Time Of Last Edit: 2024-08-27 16:32:58
[2024-08-27 16:45:44] |
Yes, you need to be on one of the "Integrated" packages in order to be able to connect to trading/data services. Refer to the following for information on the packages: Description of Service Packages and Pricing: Packages And refer to the following for how to change your package: Sierra Chart Purchase and License Information: Changing Package For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
