Date/Time: Sat, 23 Nov 2024 11:38:03 +0000
[User Discussion] - enquiry
View Count: 160
[2024-08-20 01:33:14] |
User527324 - Posts: 20 |
Hi please find attached pic, i am using study subgraph above/below and wants to only see numbers +30 to -30 as a minimum value. how can i do that? thanks
Attachment Deleted. |
[2024-08-20 15:15:01] |
You would need to use the "Color Bar Based on Alert Condition" to color the values you do not want to view the same as the background. Refer to the following: Color Bar Based on Alert Condition For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-21 00:29:33] |
Hi i want to show Bid & Ask Depth bars when its above +300 -300. how can i use the color bar based on alert condition? thanks |
[2024-08-22 15:28:06] |
Set the "Color Bar Based on Alert Condition" study to have the "Based On" set to the "Bid & Ask Depth Bars" and make sure the Region is set correctly. Then just enter the appropriate condition and set the color as you need. Refer to the following: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study Chart Studies: Settings and Inputs Tab >> Chart Region For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
