Date/Time: Sat, 23 Nov 2024 11:46:50 +0000
DOM Replay
View Count: 148
[2024-08-19 20:40:32] |
User749040 - Posts: 37 |
Hello SC Support, I've read a lot of threads on this but none seems to fix my issue. I want to replay the DOM from moments ago, so I have one SC running that's a different download than the original one I'm using. Not a sub instance but a different download. On that one I do my replays, and would like to go like an hour or so back. This Sierra is running all day like my original one where I trade. Whenever I want to go back and see the DOM Pulling and stacking and the limit orders, they are empty. I've referred to the documentation and I can say that I've done everything that's needed. I have loaded more days than needed on the DOM, I'm using Replay on all charts in chartbook, I'm recording the depth data, I have set multiple days on everything historic that but I don't need that because I just want to go back a couple of hours. It works however if I right click and have "Download Depth Data From Date-Time" and then go back in the replay, however I don't think I should always do that especially if I'm going back a few hours. I might be missing something and it's not a big deal but I'd like to just go back click replay and go with it instead of downloading the data again and I think there is a way to do it I just might be missing it. Thank you. |
[2024-08-20 14:03:02] |
It sounds like the Market Depth data is not being saved while it is coming in. Refer to the third bullet at the top of this section: Replaying Charts: Replaying of Market Depth Data As the instructions state for editing the symbol settings, make sure the option for "Use Custom Symbol Settings Values" is enabled (has a checkmark) or else the setting to store the Market Depth data for that symbol will not be used. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
