Date/Time: Sat, 23 Nov 2024 12:52:42 +0000
[Programming Help] - Trade Statistics.
View Count: 112
[2024-08-19 20:28:53]
Gravity369 - Posts: 17
I am trying to use the sc.GetTradeStatisticsV2 function and was wondering if I need to use a separate function write to a .csv file or will the function automatically write into a csv?
I am new to Acsil.
[2024-08-19 20:31:08]
That function just gets the data, as noted in the description for it here:
sc.GetTradeStatisticsForSymbolV2()
It is up to you to write the file as you want it. You can use the ACSIL functions to write a file if you want. Refer to the following:
sc.OpenFile()
