Date/Time: Sat, 23 Nov 2024 08:56:12 +0000
Problem with CQG WebAPI / Connect to Data Feed Disabled
View Count: 353
[2024-08-19 19:29:25] |
LionelTrad - Posts: 7 |
Hi, I have a problem as soon as I want to connect to CQG WebAPI. Impossible to work with the computer : there is a permanent bug. in adition, the command "Connect to Data Feed" is disabled. Could you help me ? Thanks in advance Lionel |
Capture_notificationwaiting.JPG / V - Attached On 2024-08-19 19:27:17 UTC - Size: 15.84 KB - 44 views Capture_DataFeed.JPG / V - Attached On 2024-08-19 19:27:35 UTC - Size: 11.08 KB - 41 views |
[2024-08-20 13:43:46] |
The "Connect to Data Feed" is not available because you are already connected, so this is correct functioning. The notice of "Waiting to Download Historical Data" is a normal message. It means that the system is downloading the data for the symbol of that chart. Depending on how many days of data you are needing to download (particularly if this is the first time downloading data for this symbol) then this can take some time. You need to wait for that message to go away and your chart should then be showing all the data you have requested. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-20 14:32:28] |
Hi John, thank you for your reply. Anyway my computer does not work anymore as soon as I am connected to CQG WebAPI. There is permanent bug, the computer is completely blocked. The computer is ok when I use SC All Services. Could you look at my computer with a Google Meet ? I have tried everything, asking to WHselfinvest or my school. I do not know what to do. Please find enclosed my logs for 08/19 and 08/20, best regards Lionel |
log_240819.txt - Attached On 2024-08-20 14:29:22 UTC - Size: 215.77 KB - 75 views log_240820.txt - Attached On 2024-08-20 14:29:29 UTC - Size: 1.42 MB - 103 views |
[2024-08-20 19:10:59] |
There are a large number of errors in these charts, related to continuous contracts could reduce the number of days loaded in those charts: Continuous Futures Contract Charts: Preventing Error Messages by Reducing Days to Load in Chart But in terms of the data, the one thing we want you to ensure is that the following setting is set to a value of 3: Sierra Chart Server Settings: Num. Retries After Timeout (Global Settings >> Sierra Chart Server Settings >> General >> Historical Data Client) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-22 05:15:57] |
Hi John, thank you for your reply. I have done your asked modifications (See the attached picture). Anyway It is not better. There are a large number of errors in these charts... : could you give me the complete list of the errors, I would like to fix all the problems. Thanx |
Capture_SCSS.JPG / V - Attached On 2024-08-22 05:14:45 UTC - Size: 288.04 KB - 37 views |
[2024-08-22 09:43:10] |
Sierra_Chart Engineering - Posts: 17145 |
These are some of the errors: 2024-08-19 21:10:25.773 | The FDXSH17-EUREX.dly symbol may not be the active contract month.
2024-08-19 21:10:25.773 | Unable to determine transition date based on volume from files: FDXSH17-EUREX.dly, FDXSM17-EUREX.dly Reduce the amount of days loaded in the chart: Continuous Futures Contract Charts: Preventing Error Messages by Reducing Days to Load in Chart For Historical Daily Charts at this time just use one year . So use 365. ---- If you are having a connection problem to CQG: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed: Select "File >> Disconnect" Select "File >> Connect to Data Feed" After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-23 05:08:04] |
Hi John, Here is my Message log as requested. my symbol currently is : FDXSU24-EUREX 2024-08-23 06:59:15.154 | Software version: 2667 64-bit 2024-08-23 06:59:15.154 | Primary Thread ID: 14712 2024-08-23 06:59:15.154 | Usage end date: 2024-10-26 2024-08-23 06:59:15.154 | Enabled for: Advanced Features 2. 2024-08-23 06:59:15.154 | Enabled for: Sierra Chart Historical Data Service. 2024-08-23 06:59:15.154 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-08-23 06:59:15.154 | Enabled for: Delayed Denali Exchange Data Feed. 2024-08-23 06:59:15.154 | Enabled for exchange2: EUREX EOBI 2024-08-23 06:59:15.154 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-08-23 06:59:15.154 | Current selected Data/Trading service: SC Data - All Services 2024-08-23 06:59:15.154 | Custom symbol settings values: enabled 2024-08-23 06:59:15.154 | Chart Update Interval: 500 2024-08-23 06:59:15.154 | Intraday Data Storage Time Unit: 0 2024-08-23 06:59:15.154 | Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) 2024-08-23 06:59:15.154 | 2024-08-23 04:59:15 Local computer time in UTC 2024-08-23 06:59:15.154 | 2024-08-23 06:59:15 Local computer time in SC Time Zone 2024-08-23 06:59:15.154 | 2024-08-23 04:11:28 Server time in UTC 2024-08-23 06:59:15.154 | Local computer UTC time and Server UTC time difference: 5 seconds. 2024-08-23 06:59:15.154 | Notice: Your computer's clock is off by 5 seconds. Set the 'Global Settings >> NTP Settings >> NTP Client Enable' to 'Yes' or 'Global Settings -> Set System Date-Time from NTP Servers'. 2024-08-23 06:59:15.154 | Program path: C:\SierraChart\ 2024-08-23 06:59:15.154 | Data Files path: C:\SierraChart\Data\ 2024-08-23 06:59:15.154 | OS Version Number: 10.0 2024-08-23 06:59:15.154 | Locale Setting: C 2024-08-23 06:59:15.154 | DLLs: UserContributedStudies_64.dll 2024-08-23 06:59:15.154 | Allowed protected custom studies: LeTradingFr_CB_CBOT_DJ, LeTradingFr_CB_CME_SP500, LeTradingFr_CB_Eurex_Bund, LeTradingFr_CB_Eurex_Dax, LeTradingFr_CB_NQ_NQ, LeTrading_CB_EUREX_STOXXX 2024-08-23 06:59:15.154 | Crash reporter started: true 2024-08-23 06:59:15.154 | 2024-08-23 06:59:42.959 | File >> Disconnect selected. 2024-08-23 06:59:43.218 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-23 06:59:43.218 | DTC Client socket (1) | CloseSocket call. 2024-08-23 06:59:43.218 | Denali Data Feed | Disconnected from the server. 2024-08-23 06:59:43.218 | SC Data - All Services | Disconnected. 2024-08-23 06:59:43.218 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-08-23 06:59:43.245 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-08-23 06:59:43.245 | DTC Client socket (1) | Closed. 2024-08-23 06:59:58.544 | 2024-08-23 06:59:58.544 | SC Data - All Services | Connected to server complete. 2024-08-23 06:59:58.545 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-23 06:59:58.805 | Mapping FDXSU24-EUREX to FDXS202409_FUT_EUREX. Service code: eurex 2024-08-23 06:59:58.805 | Using symbol data fast lookup vector 2024-08-23 06:59:58.805 | Denali Data Feed | Starting real-time market data updates for: FDXSU24-EUREX (FDXS202409_FUT_EUREX). ID: 1 Service code: eurex 2024-08-23 06:59:58.805 | Denali Data Feed | Connecting to the server ds24.sierracharts.com. Port 443 2024-08-23 06:59:58.805 | Denali Data Feed | Requesting security definition data for: FDXSU24-EUREX (FDXS202409_FUT_EUREX). ID: 1 2024-08-23 06:59:58.805 | Added historical Intraday data request for FDXSU24-EUREX to the queue. 2024-08-23 06:59:58.805 | Intraday data recording state for symbol FDXSU24-EUREX is set to download 'Pending'. 2024-08-23 06:59:58.805 | Triggering next historical data download in queue. 2024-08-23 06:59:58.805 | DTC Client socket (1) | Creating socket. 2024-08-23 06:59:58.805 | DTC Client socket (1) | New receive buffer size: 0 2024-08-23 06:59:58.805 | DTC Client socket (1) | Connecting to IP: 149.11.224.18. 2024-08-23 06:59:58.806 | Delaying start of download for FDXSU24-EUREX. 2024-08-23 06:59:58.829 | Denali Data Feed | Network connection to server complete. 2024-08-23 06:59:58.829 | Denali Data Feed | Starting socket receive thread. 2024-08-23 06:59:58.829 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-23 06:59:58.872 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-23 06:59:58.872 | Denali Data Feed | Sending logon request message. 2024-08-23 06:59:58.875 | Mapping FDAXU24-EUREX to FDAX202409_FUT_EUREX. Service code: eurex 2024-08-23 06:59:58.875 | Denali Data Feed | Starting real-time market data updates for: FDAXU24-EUREX (FDAX202409_FUT_EUREX). ID: 2 Service code: eurex 2024-08-23 06:59:58.875 | Denali Data Feed | Requesting security definition data for: FDAXU24-EUREX (FDAX202409_FUT_EUREX). ID: 2 2024-08-23 06:59:58.875 | Added historical Intraday data request for FDAXU24-EUREX to the queue. 2024-08-23 06:59:58.875 | Intraday data recording state for symbol FDAXU24-EUREX is set to download 'Pending'. 2024-08-23 06:59:58.875 | Triggering next historical data download in queue. 2024-08-23 06:59:58.904 | Denali Data Feed | Received logon response. 2024-08-23 06:59:58.904 | Denali Data Feed | Server Name: RealTimeServer. 2024-08-23 06:59:58.904 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-23 06:59:58.904 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. 2024-08-23 06:59:58.904 | Denali Data Feed | Failed connections: 1 2024-08-23 06:59:58.904 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-23 06:59:58.904 | DTC Client socket (1) | CloseSocket call. 2024-08-23 06:59:58.904 | Denali Data Feed | Disconnected from the server. 2024-08-23 06:59:58.904 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-08-23 06:59:58.904 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-08-23 06:59:58.918 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-08-23 06:59:58.918 | DTC Client socket (1) | Closed. 2024-08-23 07:00:01.925 | Denali Data Feed | Connecting to the server ds14.sierracharts.com. Port 10048 2024-08-23 07:00:01.926 | DTC Client socket (1) | Creating socket. 2024-08-23 07:00:01.926 | DTC Client socket (1) | New receive buffer size: 0 2024-08-23 07:00:01.927 | DTC Client socket (1) | Connecting to IP: 176.9.9.252. 2024-08-23 07:00:01.954 | Denali Data Feed | Network connection to server complete. 2024-08-23 07:00:01.954 | Denali Data Feed | Starting socket receive thread. 2024-08-23 07:00:01.954 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-23 07:00:01.988 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-23 07:00:01.988 | Denali Data Feed | Sending logon request message. 2024-08-23 07:00:02.370 | Denali Data Feed | Received logon response. 2024-08-23 07:00:02.370 | Denali Data Feed | Server Name: SC Realtime Server. 2024-08-23 07:00:02.370 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-23 07:00:02.370 | Denali Data Feed | Successfully connected. 2024-08-23 07:00:02.370 | Denali Data Feed | Trading is not supported. 2024-08-23 07:00:02.370 | Denali Data Feed | MarketDepthIsSupported: 1 2024-08-23 07:00:02.370 | Denali Data Feed | Restarting real-time data updates for symbol: FDAXU24-EUREX -> FDAX202409_FUT_EUREX 2024-08-23 07:00:02.370 | Denali Data Feed | Restarting real-time data updates for symbol: FDXSU24-EUREX -> FDXS202409_FUT_EUREX 2024-08-23 07:00:02.488 | Denali Data Feed | Setting external service identifier for symbol FDAXU24-EUREX to 7296071 2024-08-23 07:00:02.488 | Denali Data Feed | Received security definition for symbol FDAXU24-EUREX 2024-08-23 07:00:02.488 | Denali Data Feed | Setting external service identifier for symbol FDXSU24-EUREX to 10451688 2024-08-23 07:00:02.488 | Denali Data Feed | Received security definition for symbol FDXSU24-EUREX 2024-08-23 07:00:07.147 | HD Request # 33 | Downloading Intraday chart data for FDXSU24-EUREX to the file FDXSU24-EUREX.scid. Service: eurex 2024-08-23 07:00:07.148 | HD Request # 33 | Download start date-time: 2024-08-23 06:59:28.000000. File last date-time: 2024-08-23 06:59:28.793001 2024-08-23 07:00:07.148 | HD Request # 33 | Using server: ds24.sierracharts.com port 10150 2024-08-23 07:00:07.148 | Socket (2) | Creating socket. 2024-08-23 07:00:07.149 | Socket (2) | New receive buffer size: 0 2024-08-23 07:00:07.149 | Socket (2) | Connecting to IP: 149.11.224.18. 2024-08-23 07:00:07.178 | HD Request # 33 | Setting DTC encoding to Binary VLS 2024-08-23 07:00:07.178 | HD Request # 33 | Sending historical data logon request message. 2024-08-23 07:00:07.193 | Socket (2) | CloseSocket call. 2024-08-23 07:00:07.193 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-08-23 07:00:07.207 | Socket (2) | Socket gracefully closed by remote side. 2024-08-23 07:00:07.207 | Socket (2) | Closed. 2024-08-23 07:00:07.209 | HD Request # 33 | Error downloading historical Intraday data for FDXSU24-EUREX. Historical data logon error: Serving data is disabled 2024-08-23 07:00:07.209 | Added historical Intraday data request for FDXSU24-EUREX to the queue. 2024-08-23 07:00:07.209 | Triggering next historical data download in queue. 2024-08-23 07:00:07.209 | Historical data download thread signaled to stop. 2024-08-23 07:00:07.209 | HD Request # 33 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for FDXSU24-EUREX 2024-08-23 07:00:07.209 | HD Request # 33 | Completion time: 0s. 2024-08-23 07:00:07.209 | 2024-08-23 07:00:07.209 | HD Request # 34 | Downloading Intraday chart data for FDXSU24-EUREX to the file FDXSU24-EUREX.scid. Service: eurex 2024-08-23 07:00:07.209 | HD Request # 34 | Download start date-time: 2024-08-23 06:59:28.000000. File last date-time: 2024-08-23 06:59:28.793001 2024-08-23 07:00:07.209 | HD Request # 34 | Using server: ds14.sierracharts.com port 10149 2024-08-23 07:00:07.209 | Socket (2) | Creating socket. 2024-08-23 07:00:07.209 | Socket (2) | New receive buffer size: 0 2024-08-23 07:00:07.209 | Socket (2) | Connecting to IP: 176.9.9.252. 2024-08-23 07:00:07.265 | HD Request # 34 | Setting DTC encoding to Binary VLS 2024-08-23 07:00:07.265 | HD Request # 34 | Sending historical data logon request message. 2024-08-23 07:00:07.415 | HD Request # 34 | Requesting Intraday data. Start date-time: 2024-08-23 06:59:28. Record interval: 0. Symbol: FDXS202409_FUT_EUREX 2024-08-23 07:00:07.441 | HD Request # 34 | Decompressing data. 2024-08-23 07:00:07.466 | HD Request # 34 | Receiving Intraday data for FDXSU24-EUREX starting at 2024-08-23 06:59:28.793000 2024-08-23 07:00:07.466 | Socket (2) | CloseSocket call. 2024-08-23 07:00:07.466 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-08-23 07:00:07.469 | Historical data download thread signaled to stop. 2024-08-23 07:00:07.469 | HD Request # 34 | Received 2 Intraday data records from 2024-08-23 06:59:28.793000 to 2024-08-23 06:59:28.793001 (0.0 seconds. Delay: 38.7 seconds) and wrote 0 records for FDXSU24-EUREX 2024-08-23 07:00:07.469 | HD Request # 34 | Add time&sales data | Remembered last file record date-time: 2024-08-23 04:59:28.793001 2024-08-23 07:00:07.469 | HD Request # 34 | Completion time: 0s. 2024-08-23 07:00:07.469 | HD Request # 34 | Intraday data download complete for FDXSU24-EUREX. Unique request ID: 19 2024-08-23 07:00:07.469 | Removing historical data download ID 19. 2024-08-23 07:00:07.469 | Real-time Intraday chart data file updates started for FDXSU24-EUREX 2024-08-23 07:00:07.469 | Intraday chart data file opened for FDXSU24-EUREX 2024-08-23 07:00:07.469 | HD Request # 34 | Enabling Intraday chart updating for symbol. 2024-08-23 07:00:07.469 | 2024-08-23 07:00:07.469 | Triggering next historical data download in queue. 2024-08-23 07:00:07.469 | HD Request # 35 | Downloading Intraday chart data for FDAXU24-EUREX to the file FDAXU24-EUREX.scid. Service: eurex 2024-08-23 07:00:07.470 | HD Request # 35 | Download start date-time: 2024-08-23 06:58:28.000000. File last date-time: 2024-08-23 06:58:28.947000 2024-08-23 07:00:07.470 | HD Request # 35 | Using server: ds24.sierracharts.com port 10150 2024-08-23 07:00:07.470 | Socket (3) | Creating socket. 2024-08-23 07:00:07.470 | Socket (3) | New receive buffer size: 0 2024-08-23 07:00:07.470 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-23 07:00:07.493 | Socket (2) | Socket gracefully closed by remote side. 2024-08-23 07:00:07.493 | Socket (2) | Closed. 2024-08-23 07:00:07.499 | HD Request # 35 | Setting DTC encoding to Binary VLS 2024-08-23 07:00:07.499 | HD Request # 35 | Sending historical data logon request message. 2024-08-23 07:00:07.507 | Chart #25 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-23 07:00:07.507 | FDXSU24-EUREX [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-23 07:00:07.513 | Socket (3) | CloseSocket call. 2024-08-23 07:00:07.513 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-23 07:00:07.527 | Socket (3) | Socket gracefully closed by remote side. 2024-08-23 07:00:07.527 | Socket (3) | Closed. 2024-08-23 07:00:10.566 | Chart #12 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-23 07:00:10.566 | HD Request # 35 | Error downloading historical Intraday data for FDAXU24-EUREX. Historical data logon error: Serving data is disabled 2024-08-23 07:00:10.566 | Added historical Intraday data request for FDAXU24-EUREX to the queue. 2024-08-23 07:00:10.566 | Triggering next historical data download in queue. 2024-08-23 07:00:10.566 | Historical data download thread signaled to stop. 2024-08-23 07:00:10.566 | HD Request # 35 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for FDAXU24-EUREX 2024-08-23 07:00:10.567 | HD Request # 35 | Completion time: 3s. 2024-08-23 07:00:10.567 | 2024-08-23 07:00:10.567 | HD Request # 36 | Downloading Intraday chart data for FDAXU24-EUREX to the file FDAXU24-EUREX.scid. Service: eurex 2024-08-23 07:00:10.567 | HD Request # 36 | Download start date-time: 2024-08-23 06:58:28.000000. File last date-time: 2024-08-23 06:58:28.947000 2024-08-23 07:00:10.567 | HD Request # 36 | Using server: ds14.sierracharts.com port 10149 2024-08-23 07:00:10.567 | Socket (2) | Creating socket. 2024-08-23 07:00:10.567 | Socket (2) | New receive buffer size: 0 2024-08-23 07:00:10.567 | Socket (2) | Connecting to IP: 176.9.9.252. 2024-08-23 07:00:10.622 | HD Request # 36 | Setting DTC encoding to Binary VLS 2024-08-23 07:00:10.622 | HD Request # 36 | Sending historical data logon request message. 2024-08-23 07:00:10.649 | HD Request # 36 | Requesting Intraday data. Start date-time: 2024-08-23 06:58:28. Record interval: 0. Symbol: FDAX202409_FUT_EUREX 2024-08-23 07:00:10.676 | HD Request # 36 | Decompressing data. 2024-08-23 07:00:10.701 | HD Request # 36 | Receiving Intraday data for FDAXU24-EUREX starting at 2024-08-23 06:58:28.947000 2024-08-23 07:00:10.701 | Socket (2) | CloseSocket call. 2024-08-23 07:00:10.701 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-08-23 07:00:10.713 | Chart #2 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-23 07:00:10.713 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-23 07:00:10.713 | Chart #2 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-23 07:00:10.713 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-23 07:00:10.713 | Historical data download thread signaled to stop. 2024-08-23 07:00:10.713 | HD Request # 36 | Timestamp of first Intraday data file record written: 2024-08-23 07:00:00.368000. 2024-08-23 07:00:10.713 | HD Request # 36 | Received 2 Intraday data records from 2024-08-23 06:58:28.947000 to 2024-08-23 07:00:00.368000 (91.4 seconds. Delay: 10.3 seconds) and wrote 1 record for FDAXU24-EUREX 2024-08-23 07:00:10.719 | HD Request # 36 | Add time&sales data | Remembered last file record date-time: 2024-08-23 05:00:00.368000 2024-08-23 07:00:10.719 | HD Request # 36 | Completion time: 0s. 2024-08-23 07:00:10.719 | HD Request # 36 | Intraday data download complete for FDAXU24-EUREX. Unique request ID: 20 2024-08-23 07:00:10.719 | Removing historical data download ID 20. 2024-08-23 07:00:10.719 | Real-time Intraday chart data file updates started for FDAXU24-EUREX 2024-08-23 07:00:10.719 | Intraday chart data file opened for FDAXU24-EUREX 2024-08-23 07:00:10.719 | HD Request # 36 | Enabling Intraday chart updating for symbol. 2024-08-23 07:00:10.719 | 2024-08-23 07:00:10.719 | No download requests in the queue to start downloads for. 2024-08-23 07:00:10.728 | Socket (2) | Socket gracefully closed by remote side. 2024-08-23 07:00:10.728 | Socket (2) | Closed. 2024-08-23 07:00:10.772 | FDXSU24-EUREX [CBV][M] 100 Volume #14 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-23 07:00:11.017 | FDXSU24-EUREX [CBV][M] 1 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-23 07:00:33.918 | Opened cached Intraday file: C:\SierraChart\Data\FDAXU24-EUREX.scid. Thread ID: 6076 2024-08-23 07:01:44.361 | Opened cached Intraday file: C:\SierraChart\Data\FDXSU24-EUREX.scid. Thread ID: 6076 2024-08-23 07:02:14.565 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-23 07:02:14.565 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-23 07:02:14.565 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-23 07:02:14.694 | FDXSU24-EUREX [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-23 07:02:20.047 | Circular chart reference detected. Charts: 12, 25. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-23 07:02:20.047 | FDXSU24-EUREX [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-23 07:02:22.940 | Circular chart reference detected. Charts: 25, 12. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-23 07:02:23.115 | FDXSU24-EUREX [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht |
[2024-08-23 22:10:27] |
There are no issues in the log that you supplied. But this is connected to "SC Data - All Services". Are you still having an issue when connecting to CQG? Make sure you translate your symbols when switching between services. When you change your service on the "Data/Trade Service Settings", you are prompted to update the symbols when you select OK to close that window. Make sure you select "Yes" to change your chart symbols to what is needed for CQG. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-24 07:44:17] |
Hi John, Make sure you translate your symbols when... : yes, it is ok. Sorry for my mistake. Here is Message log with CQG WebAPI: 2024-08-24 08:00:00.936 | Trade activity files set size: 280 2024-08-24 08:00:01.053 | Reading Internal Order ID file. 2024-08-24 08:00:01.062 | Reading Trade Orders file. 2024-08-24 08:00:01.067 | Reading Trade Positions file. 2024-08-24 08:00:01.072 | Reading Trade Account Data files. 2024-08-24 08:00:01.078 | NTP | Create NTP Client... 2024-08-24 08:00:01.078 | NTP | Start NTP Client Receive Thread. 2024-08-24 08:00:01.078 | NTP | Client | No privilege to gradual adjust system time. Set time will be used instead to step system time. * 2024-08-24 08:00:01.078 | NTP | Client | Create NTP Client Service. 2024-08-24 08:00:01.078 | NTP | Client | Start NTP Client Service. 2024-08-24 08:00:01.078 | NTP | Client | Detected that operating system is maintaining the system clock. 2024-08-24 08:00:01.078 | NTP | Client | NTP client service is taking control of system clock. 2024-08-24 08:00:01.078 | NTP | Client | Unable to get permission to adjust the system clock: Failed to adjust privileges. Windows error code 1300: L’appelant ne bénéficie pas de tous les privilèges ou groupes référencés. * 2024-08-24 08:00:01.078 | NTP | Client | Cannot adjust system clock. NTP client service is not starting. * 2024-08-24 08:00:01.078 | NTP | Stop NTP Client... 2024-08-24 08:00:01.078 | NTP | NTP Client Stopped. 2024-08-24 08:00:01.078 | NTP | Client | Unable to get permission to restore the system time: Failed to adjust privileges. Windows error code 1300: L’appelant ne bénéficie pas de tous les privilèges ou groupes référencés. * 2024-08-24 08:00:01.079 | Software version: 2667 64-bit 2024-08-24 08:00:01.079 | Primary Thread ID: 6196 2024-08-24 08:00:01.079 | Usage end date: 2024-10-26 2024-08-24 08:00:01.079 | Enabled for: Advanced Features 2. 2024-08-24 08:00:01.079 | Enabled for: Sierra Chart Historical Data Service. 2024-08-24 08:00:01.079 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-08-24 08:00:01.079 | Enabled for: Delayed Denali Exchange Data Feed. 2024-08-24 08:00:01.079 | Enabled for exchange2: EUREX EOBI 2024-08-24 08:00:01.079 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-08-24 08:00:01.079 | Current selected Data/Trading service: SC Data - All Services 2024-08-24 08:00:01.079 | Custom symbol settings values: enabled 2024-08-24 08:00:01.079 | Chart Update Interval: 500 2024-08-24 08:00:01.079 | Intraday Data Storage Time Unit: 0 2024-08-24 08:00:01.079 | Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) 2024-08-24 08:00:01.079 | 2024-08-24 06:00:01 Local computer time in UTC 2024-08-24 08:00:01.079 | 2024-08-24 08:00:01 Local computer time in SC Time Zone 2024-08-24 08:00:01.079 | 2024-08-24 06:00:01 Server time in UTC 2024-08-24 08:00:01.079 | Local computer UTC time and Server UTC time difference: 2 seconds. 2024-08-24 08:00:01.079 | Program path: C:\SierraChart\ 2024-08-24 08:00:01.079 | Data Files path: C:\SierraChart\Data\ 2024-08-24 08:00:01.079 | OS Version Number: 10.0 2024-08-24 08:00:01.079 | Locale Setting: C 2024-08-24 08:00:01.087 | DLLs: UserContributedStudies_64.dll 2024-08-24 08:00:01.087 | Allowed protected custom studies: LeTradingFr_CB_CBOT_DJ, LeTradingFr_CB_CME_SP500, LeTradingFr_CB_Eurex_Bund, LeTradingFr_CB_Eurex_Dax, LeTradingFr_CB_NQ_NQ, LeTrading_CB_EUREX_STOXXX 2024-08-24 08:00:01.087 | Crash reporter started: true 2024-08-24 08:00:01.087 | 2024-08-24 08:00:01.087 | Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. 2024-08-24 08:00:01.166 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:00:01.209 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2024-08-24 08:00:01.209 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2024-08-24 08:00:01.230 | Received 5 login tokens. 2024-08-24 08:00:01.797 | Symbol settings MD5 received. Request ID: 1. 2024-08-24 08:00:01.797 | Symbol settings are up-to-date for scdataallservices. 2024-08-24 08:00:03.592 | Requested user files to download. 2024-08-24 08:00:03.885 | File to download: LeTradingFr_CB_Eurex_Stoxx_Trading_V3.Cht. Action: 0 2024-08-24 08:00:03.885 | File to download: LeTradingFr_CB_CME_NQ_Trading_V3_Lourd.Cht. Action: 0 2024-08-24 08:00:03.885 | File to download: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. Action: 0 2024-08-24 08:00:03.886 | File to download: LeTradingFr_CB_Eurex_Bund_Trading_V3.Cht. Action: 0 2024-08-24 08:00:03.886 | File to download: LeTradingFr_CB_CME_SP500_Trading_V2.Cht. Action: 0 2024-08-24 08:00:03.886 | File to download: LeTradingFr_CB_CBOT_DJ_Trading_V2.Cht. Action: 0 2024-08-24 08:00:03.887 | User files to download complete 2024-08-24 08:00:05.607 | 2024-08-24 08:00:05.608 | SC Data - All Services | Connected to server complete. 2024-08-24 08:00:05.608 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-24 08:00:11.561 | Loading DLL: C:\SierraChart\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ffc50440000 2024-08-24 08:00:11.575 | FDXSU24-EUREX [CBV] Daily #6 | Reloading chart. 2024-08-24 08:00:11.625 | FDXSU24-EUREX [CBV] Daily #6 | Performing continuous chart historical Daily data download for symbol FDXSM21-EUREX starting at 2021-03-18. 2024-08-24 08:00:11.625 | Starting DelayedDownloadMonitoringTimer 2024-08-24 08:00:11.625 | Starting HDTimeoutTimer 2024-08-24 08:00:11.625 | Added historical Daily data request for FDXSM21-EUREX to the queue. 2024-08-24 08:00:11.625 | Triggering next historical data download in queue. 2024-08-24 08:00:11.715 | FDXSU24-EUREX [CBV] Daily #6 | Performing continuous chart historical Daily data download for symbol FDXSU24-EUREX starting at last date in file. 2024-08-24 08:00:11.715 | Added historical Daily data request for FDXSU24-EUREX to the queue. 2024-08-24 08:00:11.907 | FDXSU24-EUREX [CBV] Daily #6 | Dates not found while checking for invalid data in continuous contract data files. FDXSM21-EUREX * 2024-08-24 08:00:11.907 | FDXSU24-EUREX [CBV] Daily #6 | Waiting for historical downloads to complete with the IDs: 1, 2, 2024-08-24 08:00:11.924 | FDXSU24-EUREX [CBV] 25000 Volume #13 | Reloading chart. 2024-08-24 08:00:11.931 | Starting DelayedDownloadMonitoringTimer 2024-08-24 08:00:11.931 | Starting HDTimeoutTimer 2024-08-24 08:00:11.931 | Added historical Intraday data request for FDXSZ23-EUREX to the queue. 2024-08-24 08:00:11.931 | Triggering next historical data download in queue. 2024-08-24 08:00:11.941 | Added historical Intraday data request for FDXSH24-EUREX to the queue. 2024-08-24 08:00:11.949 | Added historical Intraday data request for FDXSM24-EUREX to the queue. 2024-08-24 08:00:11.951 | Added historical Intraday data request for FDXSU24-EUREX to the queue. 2024-08-24 08:00:12.005 | FDXSU24-EUREX [CBV] 25000 Volume #13 | Waiting for historical downloads to complete with the IDs: 2, 3, 4, 5, 6, 2024-08-24 08:00:12.014 | FDXSU24-EUREX [CBV] 10000 Volume #16 | Reloading chart. 2024-08-24 08:00:12.057 | FDXSU24-EUREX [CBV] 10000 Volume #16 | Waiting for historical downloads to complete with the IDs: 2, 4, 5, 6, 2024-08-24 08:00:12.066 | FDXSU24-EUREX [CBV] 1200 Volume #21 | Reloading chart. 2024-08-24 08:00:12.094 | FDXSU24-EUREX [CBV] 1200 Volume #21 | Waiting for historical downloads to complete with the IDs: 2, 5, 6, 2024-08-24 08:00:12.105 | FDXSU24-EUREX [CBV] 100 Volume #14 | Reloading chart. 2024-08-24 08:00:12.112 | Added historical Intraday data request for FDXSU23-EUREX to the queue. 2024-08-24 08:00:12.186 | FDXSU24-EUREX [CBV] 100 Volume #14 | Waiting for historical downloads to complete with the IDs: 2, 3, 4, 5, 6, 7, 2024-08-24 08:00:12.194 | FDXSU24-EUREX [CBV] #11 | Reloading chart. 2024-08-24 08:00:12.414 | FDXSU24-EUREX [CBV] #11 | Dates not found while checking for invalid data in continuous contract data files. FDXSM21-EUREX * 2024-08-24 08:00:12.414 | FDXSU24-EUREX [CBV] #11 | Waiting for historical downloads to complete with the IDs: 1, 2, 2024-08-24 08:00:12.420 | FDXSU24-EUREX [CBV] #1 | Reloading chart. 2024-08-24 08:00:12.523 | FDXSU24-EUREX [CBV] #1 | Waiting for historical downloads to complete with the IDs: 2, 2024-08-24 08:00:12.529 | FDXSU24-EUREX [CBV] #8 | Reloading chart. 2024-08-24 08:00:12.536 | Added historical Intraday data request for FDXSZ21-EUREX to the queue. 2024-08-24 08:00:12.544 | Added historical Intraday data request for FDXSH22-EUREX to the queue. 2024-08-24 08:00:12.553 | Added historical Intraday data request for FDXSM22-EUREX to the queue. 2024-08-24 08:00:12.561 | Added historical Intraday data request for FDXSU22-EUREX to the queue. 2024-08-24 08:00:12.569 | Added historical Intraday data request for FDXSZ22-EUREX to the queue. 2024-08-24 08:00:12.576 | Added historical Intraday data request for FDXSH23-EUREX to the queue. 2024-08-24 08:00:12.584 | Added historical Intraday data request for FDXSM23-EUREX to the queue. 2024-08-24 08:00:12.758 | FDXSU24-EUREX [CBV] #8 | Waiting for historical downloads to complete with the IDs: 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 2024-08-24 08:00:12.765 | FDXSU24-EUREX [CBV] #7 | Reloading chart. 2024-08-24 08:00:12.947 | FDXSU24-EUREX [CBV] #7 | Waiting for historical downloads to complete with the IDs: 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 2024-08-24 08:00:12.954 | FDXSU24-EUREX [CBV] #2 | Reloading chart. 2024-08-24 08:00:13.136 | FDXSU24-EUREX [CBV] #2 | Waiting for historical downloads to complete with the IDs: 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 2024-08-24 08:00:13.142 | FDXSU24-EUREX [CBV] #18 | Reloading chart. 2024-08-24 08:00:13.216 | FDXSU24-EUREX [CBV] #18 | Waiting for historical downloads to complete with the IDs: 2, 3, 4, 5, 6, 7, 2024-08-24 08:00:13.250 | FDAXU24-EUREX [CBV] #15 | Reloading chart. 2024-08-24 08:00:13.300 | Added historical Intraday data request for FDAXU24-EUREX to the queue. 2024-08-24 08:00:13.309 | FDAXU24-EUREX [CBV] #15 | Performing continuous chart historical Daily data download for symbol FDAXU24-EUREX starting at last date in file. 2024-08-24 08:00:13.309 | Added historical Daily data request for FDAXU24-EUREX to the queue. 2024-08-24 08:00:13.364 | FDAXU24-EUREX [CBV] #15 | Waiting for historical downloads to complete with the IDs: 15, 16, 2024-08-24 08:00:13.375 | FDXSU24-EUREX [CBV] Daily #5 | Reloading chart. 2024-08-24 08:00:13.591 | FDXSU24-EUREX [CBV] Daily #5 | Dates not found while checking for invalid data in continuous contract data files. FDXSM21-EUREX * 2024-08-24 08:00:13.591 | FDXSU24-EUREX [CBV] Daily #5 | Waiting for historical downloads to complete with the IDs: 1, 2, 2024-08-24 08:00:13.601 | FDXSU24-EUREX [CBV] 1 Min #3 | Reloading chart. 2024-08-24 08:00:13.675 | FDXSU24-EUREX [CBV] 1 Min #3 | Waiting for historical downloads to complete with the IDs: 2, 3, 4, 5, 6, 7, 2024-08-24 08:00:13.689 | FDXSU24-EUREX [CBV] 1 Min #17 | Reloading chart. 2024-08-24 08:00:13.763 | FDXSU24-EUREX [CBV] 1 Min #17 | Waiting for historical downloads to complete with the IDs: 2, 3, 4, 5, 6, 7, 2024-08-24 08:00:13.905 | FDXSU24-EUREX [CBV] Rev. 4t #25 | Reloading chart. 2024-08-24 08:00:13.933 | FDXSU24-EUREX [CBV] Rev. 4t #25 | Waiting for historical downloads to complete with the IDs: 2, 5, 6, 2024-08-24 08:00:13.951 | FDXSU24-EUREX [CBV] Rev. 4t #12 | Reloading chart. 2024-08-24 08:00:13.979 | FDXSU24-EUREX [CBV] Rev. 4t #12 | Waiting for historical downloads to complete with the IDs: 2, 5, 6, 2024-08-24 08:00:13.987 | FDAXU24-EUREX [CBV] #10 | Reloading chart. 2024-08-24 08:00:14.047 | FDAXU24-EUREX [CBV] #10 | Waiting for historical downloads to complete with the IDs: 15, 16, 2024-08-24 08:00:14.054 | FDXSU24-EUREX [CBV] #4 | Reloading chart. 2024-08-24 08:00:14.128 | FDXSU24-EUREX [CBV] #4 | Waiting for historical downloads to complete with the IDs: 2, 3, 4, 5, 6, 7, 2024-08-24 08:00:14.171 | Mapping FDXSM21-EUREX to FDXS202106_FUT_EUREX. Service code: eurex 2024-08-24 08:00:14.171 | Using symbol data fast lookup vector 2024-08-24 08:00:14.171 | HD Request # 1 | Downloading Historical Daily chart data for FDXSM21-EUREX. Starting date: 2021-03-18. Service: eurex 2024-08-24 08:00:14.172 | Mapping FDXSZ23-EUREX to FDXS202312_FUT_EUREX. Service code: eurex 2024-08-24 08:00:14.172 | HD Request # 2 | Downloading Intraday chart data for FDXSZ23-EUREX to the file FDXSZ23-EUREX.scid. Service: eurex 2024-08-24 08:00:14.172 | HD Request # 2 | Download start date-time: 2023-12-15 12:58:16.000000. File last date-time: 2023-12-15 12:58:16.677000 2024-08-24 08:00:14.172 | HD Request # 2 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:00:14.184 | Socket (2) | Creating socket. 2024-08-24 08:00:14.184 | Socket (2) | New receive buffer size: 0 2024-08-24 08:00:14.184 | Socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 08:00:14.214 | HD Request # 2 | Setting DTC encoding to Binary VLS 2024-08-24 08:00:14.214 | HD Request # 2 | Sending historical data logon request message. 2024-08-24 08:00:14.228 | Socket (2) | CloseSocket call. 2024-08-24 08:00:14.228 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 08:00:14.229 | HD Request # 2 | Error downloading historical Intraday data for FDXSZ23-EUREX. Historical data logon error: Serving data is disabled 2024-08-24 08:00:14.229 | Added historical Intraday data request for FDXSZ23-EUREX to the queue. 2024-08-24 08:00:14.229 | Triggering next historical data download in queue. 2024-08-24 08:00:14.229 | Historical data download thread signaled to stop. 2024-08-24 08:00:14.229 | HD Request # 2 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for FDXSZ23-EUREX 2024-08-24 08:00:14.229 | HD Request # 2 | Completion time: 0s. 2024-08-24 08:00:14.229 | 2024-08-24 08:00:14.229 | HD Request # 3 | Downloading Intraday chart data for FDXSZ23-EUREX to the file FDXSZ23-EUREX.scid. Service: eurex 2024-08-24 08:00:14.229 | HD Request # 3 | Download start date-time: 2023-12-15 12:58:16.000000. File last date-time: 2023-12-15 12:58:16.677000 2024-08-24 08:00:14.229 | HD Request # 3 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:00:14.237 | Socket (3) | Creating socket. 2024-08-24 08:00:14.238 | Socket (3) | New receive buffer size: 0 2024-08-24 08:00:14.238 | Socket (3) | Connecting to IP: 176.9.9.252. 2024-08-24 08:00:14.241 | Socket (2) | Socket gracefully closed by remote side. 2024-08-24 08:00:14.242 | Socket (2) | Closed. 2024-08-24 08:00:14.294 | HD Request # 3 | Setting DTC encoding to Binary VLS 2024-08-24 08:00:14.294 | HD Request # 3 | Sending historical data logon request message. 2024-08-24 08:00:14.446 | HD Request # 3 | Requesting Intraday data. Start date-time: 2023-12-15 12:58:16. Record interval: 0. Symbol: FDXS202312_FUT_EUREX 2024-08-24 08:00:14.458 | HD Request # 1 | Requesting historical Daily data for JMM21 starting at 2021-03-17. SC External HD service. 2024-08-24 08:00:14.472 | HD Request # 3 | Decompressing data. 2024-08-24 08:00:14.497 | HD Request # 3 | Receiving Intraday data for FDXSZ23-EUREX starting at 2023-12-15 12:58:16.677000 2024-08-24 08:00:14.497 | Socket (3) | CloseSocket call. 2024-08-24 08:00:14.497 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 08:00:14.497 | Historical data download thread signaled to stop. 2024-08-24 08:00:14.497 | HD Request # 3 | Received 1 Intraday data record from 2023-12-15 12:58:16.677000 to 2023-12-15 12:58:16.677000 (0.0 seconds. Delay: 252.8 days) and wrote 0 records for FDXSZ23-EUREX 2024-08-24 08:00:14.498 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2023-12-15 11:58:16.677000 2024-08-24 08:00:14.498 | HD Request # 3 | Completion time: 0s. 2024-08-24 08:00:14.498 | HD Request # 3 | Intraday data download complete for FDXSZ23-EUREX. Unique request ID: 3 2024-08-24 08:00:14.498 | Removing historical data download ID 3. 2024-08-24 08:00:14.498 | Real-time Intraday chart data file updates started for FDXSZ23-EUREX 2024-08-24 08:00:14.498 | Intraday chart data file opened for FDXSZ23-EUREX 2024-08-24 08:00:14.498 | HD Request # 3 | Enabling Intraday chart updating for symbol. 2024-08-24 08:00:14.498 | 2024-08-24 08:00:14.498 | Triggering next historical data download in queue. 2024-08-24 08:00:14.498 | Historical data for FDXSZ23-EUREX is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:00:14.498 | Mapping FDXSH24-EUREX to FDXS202403_FUT_EUREX. Service code: eurex 2024-08-24 08:00:14.498 | HD Request # 4 | Downloading Intraday chart data for FDXSH24-EUREX to the file FDXSH24-EUREX.scid. Service: eurex 2024-08-24 08:00:14.498 | HD Request # 4 | Download start date-time: 2024-03-15 12:58:46.000000. File last date-time: 2024-03-15 12:58:46.363000 2024-08-24 08:00:14.498 | HD Request # 4 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:00:14.498 | Socket (4) | Creating socket. 2024-08-24 08:00:14.498 | Socket (4) | New receive buffer size: 0 2024-08-24 08:00:14.498 | Socket (4) | Connecting to IP: 149.11.224.18. 2024-08-24 08:00:14.524 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 08:00:14.524 | Socket (3) | Closed. 2024-08-24 08:00:14.528 | HD Request # 4 | Setting DTC encoding to Binary VLS 2024-08-24 08:00:14.528 | HD Request # 4 | Sending historical data logon request message. 2024-08-24 08:00:14.542 | Socket (4) | CloseSocket call. 2024-08-24 08:00:14.542 | HD Request # 4 | Error downloading historical Intraday data for FDXSH24-EUREX. Historical data logon error: Serving data is disabled 2024-08-24 08:00:14.542 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 08:00:14.542 | Added historical Intraday data request for FDXSH24-EUREX to the queue. 2024-08-24 08:00:14.542 | Triggering next historical data download in queue. 2024-08-24 08:00:14.542 | Historical data download thread signaled to stop. 2024-08-24 08:00:14.542 | HD Request # 4 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for FDXSH24-EUREX 2024-08-24 08:00:14.542 | HD Request # 4 | Completion time: 0s. 2024-08-24 08:00:14.542 | 2024-08-24 08:00:14.542 | HD Request # 5 | Downloading Intraday chart data for FDXSH24-EUREX to the file FDXSH24-EUREX.scid. Service: eurex 2024-08-24 08:00:14.543 | HD Request # 5 | Download start date-time: 2024-03-15 12:58:46.000000. File last date-time: 2024-03-15 12:58:46.363000 2024-08-24 08:00:14.543 | HD Request # 5 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:00:14.543 | Socket (3) | Creating socket. 2024-08-24 08:00:14.543 | Socket (3) | New receive buffer size: 0 2024-08-24 08:00:14.543 | Socket (3) | Connecting to IP: 176.9.9.252. 2024-08-24 08:00:14.557 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 08:00:14.557 | Socket (4) | Closed. 2024-08-24 08:00:14.595 | HD Request # 5 | Setting DTC encoding to Binary VLS 2024-08-24 08:00:14.595 | HD Request # 5 | Sending historical data logon request message. 2024-08-24 08:00:14.619 | HD Request # 5 | Requesting Intraday data. Start date-time: 2024-03-15 12:58:46. Record interval: 0. Symbol: FDXS202403_FUT_EUREX 2024-08-24 08:00:14.644 | HD Request # 5 | Decompressing data. 2024-08-24 08:00:14.667 | HD Request # 5 | Receiving Intraday data for FDXSH24-EUREX starting at 2024-03-15 12:58:46.363000 2024-08-24 08:00:14.667 | Socket (3) | CloseSocket call. 2024-08-24 08:00:14.667 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 08:00:14.667 | Historical data download thread signaled to stop. 2024-08-24 08:00:14.667 | HD Request # 5 | Received 1 Intraday data record from 2024-03-15 12:58:46.363000 to 2024-03-15 12:58:46.363000 (0.0 seconds. Delay: 161.8 days) and wrote 0 records for FDXSH24-EUREX 2024-08-24 08:00:14.667 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2024-03-15 11:58:46.363000 2024-08-24 08:00:14.667 | HD Request # 5 | Completion time: 0s. 2024-08-24 08:00:14.667 | HD Request # 5 | Intraday data download complete for FDXSH24-EUREX. Unique request ID: 4 2024-08-24 08:00:14.667 | Removing historical data download ID 4. 2024-08-24 08:00:14.667 | Real-time Intraday chart data file updates started for FDXSH24-EUREX 2024-08-24 08:00:14.667 | Intraday chart data file opened for FDXSH24-EUREX 2024-08-24 08:00:14.667 | HD Request # 5 | Enabling Intraday chart updating for symbol. 2024-08-24 08:00:14.667 | 2024-08-24 08:00:14.667 | Triggering next historical data download in queue. 2024-08-24 08:00:14.667 | Historical data for FDXSH24-EUREX is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:00:14.667 | Mapping FDXSM24-EUREX to FDXS202406_FUT_EUREX. Service code: eurex 2024-08-24 08:00:14.667 | HD Request # 6 | Downloading Intraday chart data for FDXSM24-EUREX to the file FDXSM24-EUREX.scid. Service: eurex 2024-08-24 08:00:14.668 | HD Request # 6 | Download start date-time: 2024-06-21 12:56:11.000000. File last date-time: 2024-06-21 12:56:11.173000 2024-08-24 08:00:14.668 | HD Request # 6 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:00:14.668 | Socket (4) | Creating socket. 2024-08-24 08:00:14.668 | Socket (4) | New receive buffer size: 0 2024-08-24 08:00:14.668 | Socket (4) | Connecting to IP: 149.11.224.18. 2024-08-24 08:00:14.669 | HD Request # 1 | Receiving historical Daily data for FDXSM21-EUREX starting at 2021-04-30. 2024-08-24 08:00:14.670 | HD Request # 1 | Writing historical Daily data to the file FDXSM21-EUREX.dly. 2024-08-24 08:00:14.670 | HD Request # 1 | Bytes received: 1829 2024-08-24 08:00:14.670 | HD Request # 1 | Received 36 Daily data records from 2021-04-30 00:00:00 to 2021-06-18 00:00:00 (50.0 days) and wrote 36 records for FDXSM21-EUREX 2024-08-24 08:00:14.670 | HD Request # 1 | Completion time: 0s. 2024-08-24 08:00:14.670 | HD Request # 1 | Daily data download complete for FDXSM21-EUREX. Unique request ID: 1 2024-08-24 08:00:14.670 | Removing historical data download ID 1. 2024-08-24 08:00:14.670 | 2024-08-24 08:00:14.670 | Triggering next historical data download in queue. 2024-08-24 08:00:14.670 | Mapping FDXSU24-EUREX to FDXS202409_FUT_EUREX. Service code: eurex 2024-08-24 08:00:14.672 | HD Request # 7 | Downloading Historical Daily chart data for FDXSU24-EUREX. Starting date: 2024-08-20. Service: eurex 2024-08-24 08:00:14.692 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 08:00:14.692 | Socket (3) | Closed. 2024-08-24 08:00:14.697 | HD Request # 6 | Setting DTC encoding to Binary VLS 2024-08-24 08:00:14.697 | HD Request # 6 | Sending historical data logon request message. 2024-08-24 08:00:14.711 | Socket (4) | CloseSocket call. 2024-08-24 08:00:14.711 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 08:00:14.712 | HD Request # 6 | Error downloading historical Intraday data for FDXSM24-EUREX. Historical data logon error: Serving data is disabled 2024-08-24 08:00:14.712 | Added historical Intraday data request for FDXSM24-EUREX to the queue. 2024-08-24 08:00:14.712 | Triggering next historical data download in queue. 2024-08-24 08:00:14.712 | Historical data download thread signaled to stop. 2024-08-24 08:00:14.712 | HD Request # 6 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for FDXSM24-EUREX 2024-08-24 08:00:14.712 | HD Request # 6 | Completion time: 0s. 2024-08-24 08:00:14.712 | 2024-08-24 08:00:14.712 | HD Request # 8 | Downloading Intraday chart data for FDXSM24-EUREX to the file FDXSM24-EUREX.scid. Service: eurex 2024-08-24 08:00:14.712 | HD Request # 8 | Download start date-time: 2024-06-21 12:56:11.000000. File last date-time: 2024-06-21 12:56:11.173000 2024-08-24 08:00:14.712 | HD Request # 8 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:00:14.712 | Socket (3) | Creating socket. 2024-08-24 08:00:14.712 | Socket (3) | New receive buffer size: 0 2024-08-24 08:00:14.712 | Socket (3) | Connecting to IP: 176.9.9.252. 2024-08-24 08:00:14.726 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 08:00:14.726 | Socket (4) | Closed. 2024-08-24 08:00:14.767 | HD Request # 8 | Setting DTC encoding to Binary VLS 2024-08-24 08:00:14.767 | HD Request # 8 | Sending historical data logon request message. 2024-08-24 08:00:14.794 | HD Request # 8 | Requesting Intraday data. Start date-time: 2024-06-21 12:56:11. Record interval: 0. Symbol: FDXS202406_FUT_EUREX 2024-08-24 08:00:14.820 | HD Request # 8 | Decompressing data. 2024-08-24 08:00:14.845 | HD Request # 8 | Receiving Intraday data for FDXSM24-EUREX starting at 2024-06-21 12:56:11.173000 2024-08-24 08:00:14.845 | Socket (3) | CloseSocket call. 2024-08-24 08:00:14.845 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 08:00:14.845 | Historical data download thread signaled to stop. 2024-08-24 08:00:14.845 | HD Request # 8 | Received 1 Intraday data record from 2024-06-21 12:56:11.173000 to 2024-06-21 12:56:11.173000 (0.0 seconds. Delay: 63.8 days) and wrote 0 records for FDXSM24-EUREX 2024-08-24 08:00:14.845 | HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2024-06-21 10:56:11.173000 2024-08-24 08:00:14.845 | HD Request # 8 | Completion time: 0s. 2024-08-24 08:00:14.845 | HD Request # 8 | Intraday data download complete for FDXSM24-EUREX. Unique request ID: 5 2024-08-24 08:00:14.845 | Removing historical data download ID 5. 2024-08-24 08:00:14.845 | Real-time Intraday chart data file updates started for FDXSM24-EUREX 2024-08-24 08:00:14.845 | Intraday chart data file opened for FDXSM24-EUREX 2024-08-24 08:00:14.845 | HD Request # 8 | Enabling Intraday chart updating for symbol. 2024-08-24 08:00:14.845 | 2024-08-24 08:00:14.845 | Triggering next historical data download in queue. 2024-08-24 08:00:14.845 | Historical data for FDXSM24-EUREX is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:00:14.845 | HD Request # 9 | Downloading Intraday chart data for FDXSU24-EUREX to the file FDXSU24-EUREX.scid. Service: eurex 2024-08-24 08:00:14.845 | HD Request # 9 | Download start date-time: 2024-08-23 07:35:47.000000. File last date-time: 2024-08-23 07:35:47.597000 2024-08-24 08:00:14.846 | HD Request # 9 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:00:14.846 | Socket (1) | Creating socket. 2024-08-24 08:00:14.846 | Socket (1) | New receive buffer size: 0 2024-08-24 08:00:14.846 | Socket (1) | Connecting to IP: 149.11.224.18. 2024-08-24 08:00:14.871 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 08:00:14.871 | Socket (3) | Closed. 2024-08-24 08:00:14.875 | HD Request # 9 | Setting DTC encoding to Binary VLS 2024-08-24 08:00:14.875 | HD Request # 9 | Sending historical data logon request message. 2024-08-24 08:00:14.888 | Socket (1) | CloseSocket call. 2024-08-24 08:00:14.888 | HD Request # 9 | Error downloading historical Intraday data for FDXSU24-EUREX. Historical data logon error: Serving data is disabled 2024-08-24 08:00:14.888 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:00:14.889 | Added historical Intraday data request for FDXSU24-EUREX to the queue. 2024-08-24 08:00:14.889 | Triggering next historical data download in queue. 2024-08-24 08:00:14.889 | Historical data download thread signaled to stop. 2024-08-24 08:00:14.889 | HD Request # 9 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for FDXSU24-EUREX 2024-08-24 08:00:14.889 | HD Request # 9 | Completion time: 0s. 2024-08-24 08:00:14.889 | 2024-08-24 08:00:14.889 | HD Request # 10 | Downloading Intraday chart data for FDXSU24-EUREX to the file FDXSU24-EUREX.scid. Service: eurex 2024-08-24 08:00:14.889 | HD Request # 10 | Download start date-time: 2024-08-23 07:35:47.000000. File last date-time: 2024-08-23 07:35:47.597000 2024-08-24 08:00:14.889 | HD Request # 10 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:00:14.889 | Socket (3) | Creating socket. 2024-08-24 08:00:14.889 | Socket (3) | New receive buffer size: 0 2024-08-24 08:00:14.889 | Socket (3) | Connecting to IP: 176.9.9.252. 2024-08-24 08:00:14.903 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:00:14.903 | Socket (1) | Closed. 2024-08-24 08:00:14.941 | HD Request # 10 | Setting DTC encoding to Binary VLS 2024-08-24 08:00:14.941 | HD Request # 10 | Sending historical data logon request message. 2024-08-24 08:00:14.953 | HD Request # 7 | Requesting historical Daily data for JMU24 starting at 2024-08-19. SC External HD service. 2024-08-24 08:00:14.965 | HD Request # 10 | Requesting Intraday data. Start date-time: 2024-08-23 07:35:47. Record interval: 0. Symbol: FDXS202409_FUT_EUREX 2024-08-24 08:00:14.990 | HD Request # 10 | Decompressing data. 2024-08-24 08:00:15.049 | HD Request # 10 | Receiving Intraday data for FDXSU24-EUREX starting at 2024-08-23 07:35:47.597000 2024-08-24 08:00:15.073 | Socket (3) | CloseSocket call. 2024-08-24 08:00:15.073 | Historical data download thread signaled to stop. 2024-08-24 08:00:15.073 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 08:00:15.073 | HD Request # 10 | Timestamp of first Intraday data file record written: 2024-08-23 07:36:10.120000. 2024-08-24 08:00:15.073 | HD Request # 10 | Received 12400 Intraday data records from 2024-08-23 07:35:47.597000 to 2024-08-23 22:03:41.805000 (14.5 hours. Delay: 9.9 hours) and wrote 12399 records for FDXSU24-EUREX 2024-08-24 08:00:15.078 | HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 08:00:15.078 | HD Request # 10 | Completion time: 1s. 2024-08-24 08:00:15.078 | HD Request # 10 | Intraday data download complete for FDXSU24-EUREX. Unique request ID: 6 2024-08-24 08:00:15.078 | Removing historical data download ID 6. 2024-08-24 08:00:15.078 | Real-time Intraday chart data file updates started for FDXSU24-EUREX 2024-08-24 08:00:15.078 | Intraday chart data file opened for FDXSU24-EUREX 2024-08-24 08:00:15.078 | HD Request # 10 | Enabling Intraday chart updating for symbol. 2024-08-24 08:00:15.078 | 2024-08-24 08:00:15.078 | Triggering next historical data download in queue. 2024-08-24 08:00:15.078 | Historical data for FDXSU24-EUREX is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:00:15.078 | HD Request # 7 | Receiving historical Daily data for FDXSU24-EUREX starting at 2024-08-20. 2024-08-24 08:00:15.078 | HD Request # 7 | Writing historical Daily data to the file FDXSU24-EUREX.dly. 2024-08-24 08:00:15.080 | HD Request # 7 | Bytes received: 260 2024-08-24 08:00:15.080 | HD Request # 7 | Received 5 Daily data records from 2024-08-20 00:00:00 to 2024-08-23 00:00:00 (4.0 days) and wrote 4 records for FDXSU24-EUREX 2024-08-24 08:00:15.080 | HD Request # 7 | Completion time: 1s. 2024-08-24 08:00:15.080 | HD Request # 7 | Daily data download complete for FDXSU24-EUREX. Unique request ID: 2 2024-08-24 08:00:15.080 | Removing historical data download ID 2. 2024-08-24 08:00:15.080 | 2024-08-24 08:00:15.080 | Triggering next historical data download in queue. 2024-08-24 08:00:15.080 | Mapping FDXSU23-EUREX to FDXS202309_FUT_EUREX. Service code: eurex 2024-08-24 08:00:15.080 | HD Request # 11 | Downloading Intraday chart data for FDXSU23-EUREX to the file FDXSU23-EUREX.scid. Service: eurex 2024-08-24 08:00:15.080 | HD Request # 11 | Download start date-time: 2023-09-15 12:56:31.000000. File last date-time: 2023-09-15 12:56:31.873000 2024-08-24 08:00:15.080 | HD Request # 11 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:00:15.080 | Mapping FDAXU24-EUREX to FDAX202409_FUT_EUREX. Service code: eurex 2024-08-24 08:00:15.080 | Socket (2) | Creating socket. 2024-08-24 08:00:15.080 | Socket (2) | New receive buffer size: 0 2024-08-24 08:00:15.081 | Socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 08:00:15.082 | HD Request # 12 | Downloading Historical Daily chart data for FDAXU24-EUREX. Starting date: 2024-08-20. Service: eurex 2024-08-24 08:00:15.129 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 08:00:15.129 | Socket (3) | Closed. 2024-08-24 08:00:15.149 | HD Request # 11 | Setting DTC encoding to Binary VLS 2024-08-24 08:00:15.149 | HD Request # 11 | Sending historical data logon request message. 2024-08-24 08:00:15.164 | Socket (2) | CloseSocket call. 2024-08-24 08:00:15.164 | HD Request # 11 | Error downloading historical Intraday data for FDXSU23-EUREX. Historical data logon error: Serving data is disabled 2024-08-24 08:00:15.164 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 08:00:15.164 | Added historical Intraday data request for FDXSU23-EUREX to the queue. 2024-08-24 08:00:15.164 | Triggering next historical data download in queue. 2024-08-24 08:00:15.164 | Historical data download thread signaled to stop. 2024-08-24 08:00:15.164 | HD Request # 11 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for FDXSU23-EUREX 2024-08-24 08:00:15.164 | HD Request # 11 | Completion time: 0s. 2024-08-24 08:00:15.164 | 2024-08-24 08:00:15.164 | HD Request # 13 | Downloading Intraday chart data for FDXSU23-EUREX to the file FDXSU23-EUREX.scid. Service: eurex 2024-08-24 08:00:15.164 | HD Request # 13 | Download start date-time: 2023-09-15 12:56:31.000000. File last date-time: 2023-09-15 12:56:31.873000 2024-08-24 08:00:15.164 | HD Request # 13 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:00:15.164 | Socket (3) | Creating socket. 2024-08-24 08:00:15.164 | Socket (3) | New receive buffer size: 0 2024-08-24 08:00:15.164 | Socket (3) | Connecting to IP: 176.9.9.252. 2024-08-24 08:00:15.178 | Socket (2) | Socket gracefully closed by remote side. 2024-08-24 08:00:15.178 | Socket (2) | Closed. 2024-08-24 08:00:15.184 | FDXSU24-EUREX [CBV] #11 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:00:15.185 | FDXSU24-EUREX [CBV] #11 | Reloading chart. 2024-08-24 08:00:15.185 | Unable to determine transition date based on volume from files: FDXSU12-EUREX.dly, FDXSZ12-EUREX.dly 2024-08-24 08:00:15.185 | The FDXSZ12-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.185 | Unable to determine transition date based on volume from files: FDXSZ12-EUREX.dly, FDXSH13-EUREX.dly 2024-08-24 08:00:15.185 | The FDXSH13-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.185 | Unable to determine transition date based on volume from files: FDXSH13-EUREX.dly, FDXSM13-EUREX.dly 2024-08-24 08:00:15.185 | The FDXSM13-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.185 | Unable to determine transition date based on volume from files: FDXSM13-EUREX.dly, FDXSU13-EUREX.dly 2024-08-24 08:00:15.185 | The FDXSU13-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.186 | Unable to determine transition date based on volume from files: FDXSU13-EUREX.dly, FDXSZ13-EUREX.dly 2024-08-24 08:00:15.186 | The FDXSZ13-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.186 | Unable to determine transition date based on volume from files: FDXSZ13-EUREX.dly, FDXSH14-EUREX.dly 2024-08-24 08:00:15.186 | The FDXSH14-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.186 | Unable to determine transition date based on volume from files: FDXSH14-EUREX.dly, FDXSM14-EUREX.dly 2024-08-24 08:00:15.186 | The FDXSM14-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.186 | Unable to determine transition date based on volume from files: FDXSM14-EUREX.dly, FDXSU14-EUREX.dly 2024-08-24 08:00:15.186 | The FDXSU14-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.186 | Unable to determine transition date based on volume from files: FDXSU14-EUREX.dly, FDXSZ14-EUREX.dly 2024-08-24 08:00:15.186 | The FDXSZ14-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.186 | Unable to determine transition date based on volume from files: FDXSZ14-EUREX.dly, FDXSH15-EUREX.dly 2024-08-24 08:00:15.186 | The FDXSH15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.186 | Unable to determine transition date based on volume from files: FDXSH15-EUREX.dly, FDXSM15-EUREX.dly 2024-08-24 08:00:15.186 | The FDXSM15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.186 | Unable to determine transition date based on volume from files: FDXSM15-EUREX.dly, FDXSU15-EUREX.dly 2024-08-24 08:00:15.186 | The FDXSU15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.187 | Unable to determine transition date based on volume from files: FDXSU15-EUREX.dly, FDXSZ15-EUREX.dly 2024-08-24 08:00:15.187 | The FDXSZ15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.187 | Unable to determine transition date based on volume from files: FDXSZ15-EUREX.dly, FDXSH16-EUREX.dly 2024-08-24 08:00:15.187 | The FDXSH16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.187 | Unable to determine transition date based on volume from files: FDXSH16-EUREX.dly, FDXSM16-EUREX.dly 2024-08-24 08:00:15.187 | The FDXSM16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.187 | Unable to determine transition date based on volume from files: FDXSM16-EUREX.dly, FDXSU16-EUREX.dly 2024-08-24 08:00:15.187 | The FDXSU16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.187 | Unable to determine transition date based on volume from files: FDXSU16-EUREX.dly, FDXSZ16-EUREX.dly 2024-08-24 08:00:15.187 | The FDXSZ16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.187 | Unable to determine transition date based on volume from files: FDXSZ16-EUREX.dly, FDXSH17-EUREX.dly 2024-08-24 08:00:15.187 | The FDXSH17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.187 | Unable to determine transition date based on volume from files: FDXSH17-EUREX.dly, FDXSM17-EUREX.dly 2024-08-24 08:00:15.187 | The FDXSM17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.187 | Unable to determine transition date based on volume from files: FDXSM17-EUREX.dly, FDXSU17-EUREX.dly 2024-08-24 08:00:15.187 | The FDXSU17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.187 | Unable to determine transition date based on volume from files: FDXSU17-EUREX.dly, FDXSZ17-EUREX.dly 2024-08-24 08:00:15.187 | The FDXSZ17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.188 | Unable to determine transition date based on volume from files: FDXSZ17-EUREX.dly, FDXSH18-EUREX.dly 2024-08-24 08:00:15.188 | The FDXSH18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.188 | Unable to determine transition date based on volume from files: FDXSH18-EUREX.dly, FDXSM18-EUREX.dly 2024-08-24 08:00:15.188 | The FDXSM18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.188 | Unable to determine transition date based on volume from files: FDXSM18-EUREX.dly, FDXSU18-EUREX.dly 2024-08-24 08:00:15.188 | The FDXSU18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.188 | Unable to determine transition date based on volume from files: FDXSU18-EUREX.dly, FDXSZ18-EUREX.dly 2024-08-24 08:00:15.188 | The FDXSZ18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.188 | Unable to determine transition date based on volume from files: FDXSZ18-EUREX.dly, FDXSH19-EUREX.dly 2024-08-24 08:00:15.188 | The FDXSH19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.188 | Unable to determine transition date based on volume from files: FDXSH19-EUREX.dly, FDXSM19-EUREX.dly 2024-08-24 08:00:15.188 | The FDXSM19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.188 | Unable to determine transition date based on volume from files: FDXSM19-EUREX.dly, FDXSU19-EUREX.dly 2024-08-24 08:00:15.188 | The FDXSU19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.188 | Unable to determine transition date based on volume from files: FDXSU19-EUREX.dly, FDXSZ19-EUREX.dly 2024-08-24 08:00:15.188 | The FDXSZ19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.189 | Unable to determine transition date based on volume from files: FDXSZ19-EUREX.dly, FDXSH20-EUREX.dly 2024-08-24 08:00:15.189 | The FDXSH20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.189 | Unable to determine transition date based on volume from files: FDXSH20-EUREX.dly, FDXSM20-EUREX.dly 2024-08-24 08:00:15.189 | The FDXSM20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.189 | Unable to determine transition date based on volume from files: FDXSM20-EUREX.dly, FDXSU20-EUREX.dly 2024-08-24 08:00:15.189 | The FDXSU20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.189 | Unable to determine transition date based on volume from files: FDXSU20-EUREX.dly, FDXSZ20-EUREX.dly 2024-08-24 08:00:15.189 | The FDXSZ20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.189 | Unable to determine transition date based on volume from files: FDXSZ20-EUREX.dly, FDXSH21-EUREX.dly 2024-08-24 08:00:15.189 | The FDXSH21-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.220 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2012-09-25 from file. C:\SierraChart\Data\FDXSU12-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.220 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ12-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.220 | HD Request # 13 | Setting DTC encoding to Binary VLS 2024-08-24 08:00:15.220 | HD Request # 13 | Sending historical data logon request message. 2024-08-24 08:00:15.221 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2012-12-25 from file. C:\SierraChart\Data\FDXSZ12-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.221 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.222 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2013-03-19 from file. C:\SierraChart\Data\FDXSH13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.222 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.223 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2013-06-25 from file. C:\SierraChart\Data\FDXSM13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.223 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.224 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2013-09-24 from file. C:\SierraChart\Data\FDXSU13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.224 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.224 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2013-12-24 from file. C:\SierraChart\Data\FDXSZ13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.224 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.225 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2014-03-25 from file. C:\SierraChart\Data\FDXSH14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.225 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.226 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2014-06-24 from file. C:\SierraChart\Data\FDXSM14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.226 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.227 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2014-09-23 from file. C:\SierraChart\Data\FDXSU14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.227 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.228 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2014-12-23 from file. C:\SierraChart\Data\FDXSZ14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.228 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.229 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2015-03-24 from file. C:\SierraChart\Data\FDXSH15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.229 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.230 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2015-06-23 from file. C:\SierraChart\Data\FDXSM15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.230 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.231 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2015-09-22 from file. C:\SierraChart\Data\FDXSU15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.231 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.232 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2015-12-22 from file. C:\SierraChart\Data\FDXSZ15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.232 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.232 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2016-03-22 from file. C:\SierraChart\Data\FDXSH16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.232 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.233 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2016-06-21 from file. C:\SierraChart\Data\FDXSM16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.233 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.234 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2016-09-20 from file. C:\SierraChart\Data\FDXSU16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.234 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.235 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2016-12-20 from file. C:\SierraChart\Data\FDXSZ16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.235 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.236 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2017-03-21 from file. C:\SierraChart\Data\FDXSH17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.236 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.237 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2017-06-20 from file. C:\SierraChart\Data\FDXSM17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.237 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.238 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2017-09-19 from file. C:\SierraChart\Data\FDXSU17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.238 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.239 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2017-12-19 from file. C:\SierraChart\Data\FDXSZ17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.239 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.239 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2018-03-20 from file. C:\SierraChart\Data\FDXSH18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.239 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.240 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2018-06-19 from file. C:\SierraChart\Data\FDXSM18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.240 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.241 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2018-09-25 from file. C:\SierraChart\Data\FDXSU18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.241 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.242 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2018-12-25 from file. C:\SierraChart\Data\FDXSZ18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.242 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.243 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2019-03-19 from file. C:\SierraChart\Data\FDXSH19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.243 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.244 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2019-06-25 from file. C:\SierraChart\Data\FDXSM19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.244 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.245 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2019-09-24 from file. C:\SierraChart\Data\FDXSU19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.245 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.245 | HD Request # 13 | Requesting Intraday data. Start date-time: 2023-09-15 12:56:31. Record interval: 0. Symbol: FDXS202309_FUT_EUREX 2024-08-24 08:00:15.246 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2019-12-24 from file. C:\SierraChart\Data\FDXSZ19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.246 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.247 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2020-03-24 from file. C:\SierraChart\Data\FDXSH20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.247 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.247 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2020-06-23 from file. C:\SierraChart\Data\FDXSM20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.247 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.248 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2020-09-22 from file. C:\SierraChart\Data\FDXSU20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.248 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.249 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2020-12-22 from file. C:\SierraChart\Data\FDXSZ20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.249 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH21-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.250 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2021-03-23 from file. C:\SierraChart\Data\FDXSH21-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.250 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM21-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.271 | HD Request # 13 | Decompressing data. 2024-08-24 08:00:15.296 | HD Request # 13 | Receiving Intraday data for FDXSU23-EUREX starting at 2023-09-15 12:56:31.873000 2024-08-24 08:00:15.296 | Socket (3) | CloseSocket call. 2024-08-24 08:00:15.296 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 08:00:15.322 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 08:00:15.323 | Socket (3) | Closed. 2024-08-24 08:00:15.329 | Historical data download thread signaled to stop. 2024-08-24 08:00:15.329 | HD Request # 13 | Received 1 Intraday data record from 2023-09-15 12:56:31.873000 to 2023-09-15 12:56:31.873000 (0.0 seconds. Delay: 343.8 days) and wrote 0 records for FDXSU23-EUREX 2024-08-24 08:00:15.330 | HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2023-09-15 10:56:31.873000 2024-08-24 08:00:15.330 | HD Request # 13 | Completion time: 0s. 2024-08-24 08:00:15.330 | HD Request # 13 | Intraday data download complete for FDXSU23-EUREX. Unique request ID: 7 2024-08-24 08:00:15.330 | Removing historical data download ID 7. 2024-08-24 08:00:15.330 | Real-time Intraday chart data file updates started for FDXSU23-EUREX 2024-08-24 08:00:15.330 | Intraday chart data file opened for FDXSU23-EUREX 2024-08-24 08:00:15.330 | HD Request # 13 | Enabling Intraday chart updating for symbol. 2024-08-24 08:00:15.330 | 2024-08-24 08:00:15.330 | Triggering next historical data download in queue. 2024-08-24 08:00:15.330 | Historical data for FDXSU23-EUREX is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:00:15.330 | Mapping FDXSZ21-EUREX to FDXS202112_FUT_EUREX. Service code: eurex 2024-08-24 08:00:15.330 | HD Request # 14 | Downloading Intraday chart data for FDXSZ21-EUREX to the file FDXSZ21-EUREX.scid. Service: eurex 2024-08-24 08:00:15.330 | HD Request # 14 | Download start date-time: 2021-12-17 12:57:19.000000. File last date-time: 2021-12-17 12:57:19.960000 2024-08-24 08:00:15.330 | FDXSU24-EUREX [CBV] 1 Min #17 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:00:15.330 | HD Request # 14 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:00:15.330 | Socket (2) | Creating socket. 2024-08-24 08:00:15.330 | Socket (2) | New receive buffer size: 0 2024-08-24 08:00:15.330 | Socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 08:00:15.330 | FDXSU24-EUREX [CBV] 1 Min #17 | Reloading chart. 2024-08-24 08:00:15.359 | HD Request # 14 | Setting DTC encoding to Binary VLS 2024-08-24 08:00:15.359 | HD Request # 14 | Sending historical data logon request message. 2024-08-24 08:00:15.370 | FDXSU24-EUREX [CBV] #11 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 08:00:15.372 | Socket (2) | CloseSocket call. 2024-08-24 08:00:15.372 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 08:00:15.395 | FDXSU24-EUREX [CBV] #11 | Chart data loading complete. 2024-08-24 08:00:15.395 | HD Request # 12 | Requesting historical Daily data for DYU24 starting at 2024-08-19. SC External HD service. 2024-08-24 08:00:15.395 | HD Request # 14 | Error downloading historical Intraday data for FDXSZ21-EUREX. Historical data logon error: Serving data is disabled 2024-08-24 08:00:15.395 | Added historical Intraday data request for FDXSZ21-EUREX to the queue. 2024-08-24 08:00:15.395 | Triggering next historical data download in queue. 2024-08-24 08:00:15.395 | Historical data download thread signaled to stop. 2024-08-24 08:00:15.395 | HD Request # 14 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for FDXSZ21-EUREX 2024-08-24 08:00:15.395 | HD Request # 14 | Completion time: 0s. 2024-08-24 08:00:15.395 | 2024-08-24 08:00:15.407 | Socket (2) | Socket gracefully closed by remote side. 2024-08-24 08:00:15.407 | Socket (2) | Closed. 2024-08-24 08:00:15.416 | HD Request # 15 | Downloading Intraday chart data for FDXSZ21-EUREX to the file FDXSZ21-EUREX.scid. Service: eurex 2024-08-24 08:00:15.416 | HD Request # 15 | Download start date-time: 2021-12-17 12:57:19.000000. File last date-time: 2021-12-17 12:57:19.960000 2024-08-24 08:00:15.416 | HD Request # 15 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:00:15.416 | Socket (2) | Creating socket. 2024-08-24 08:00:15.416 | Socket (2) | New receive buffer size: 0 2024-08-24 08:00:15.416 | Socket (2) | Connecting to IP: 176.9.9.252. 2024-08-24 08:00:15.421 | FDXSU24-EUREX [CBV] Daily #5 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:00:15.422 | FDXSU24-EUREX [CBV] Daily #5 | Reloading chart. 2024-08-24 08:00:15.422 | Unable to determine transition date based on volume from files: FDXSZ14-EUREX.dly, FDXSH15-EUREX.dly 2024-08-24 08:00:15.422 | The FDXSH15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.422 | Unable to determine transition date based on volume from files: FDXSH15-EUREX.dly, FDXSM15-EUREX.dly 2024-08-24 08:00:15.422 | The FDXSM15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.422 | Unable to determine transition date based on volume from files: FDXSM15-EUREX.dly, FDXSU15-EUREX.dly 2024-08-24 08:00:15.422 | The FDXSU15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.422 | Unable to determine transition date based on volume from files: FDXSU15-EUREX.dly, FDXSZ15-EUREX.dly 2024-08-24 08:00:15.422 | The FDXSZ15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.422 | Unable to determine transition date based on volume from files: FDXSZ15-EUREX.dly, FDXSH16-EUREX.dly 2024-08-24 08:00:15.422 | The FDXSH16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.423 | Unable to determine transition date based on volume from files: FDXSH16-EUREX.dly, FDXSM16-EUREX.dly 2024-08-24 08:00:15.423 | The FDXSM16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.423 | Unable to determine transition date based on volume from files: FDXSM16-EUREX.dly, FDXSU16-EUREX.dly 2024-08-24 08:00:15.423 | The FDXSU16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.423 | Unable to determine transition date based on volume from files: FDXSU16-EUREX.dly, FDXSZ16-EUREX.dly 2024-08-24 08:00:15.423 | The FDXSZ16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.423 | Unable to determine transition date based on volume from files: FDXSZ16-EUREX.dly, FDXSH17-EUREX.dly 2024-08-24 08:00:15.423 | The FDXSH17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.423 | Unable to determine transition date based on volume from files: FDXSH17-EUREX.dly, FDXSM17-EUREX.dly 2024-08-24 08:00:15.423 | The FDXSM17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.423 | Unable to determine transition date based on volume from files: FDXSM17-EUREX.dly, FDXSU17-EUREX.dly 2024-08-24 08:00:15.423 | The FDXSU17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.423 | Unable to determine transition date based on volume from files: FDXSU17-EUREX.dly, FDXSZ17-EUREX.dly 2024-08-24 08:00:15.423 | The FDXSZ17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.423 | Unable to determine transition date based on volume from files: FDXSZ17-EUREX.dly, FDXSH18-EUREX.dly 2024-08-24 08:00:15.423 | The FDXSH18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.423 | Unable to determine transition date based on volume from files: FDXSH18-EUREX.dly, FDXSM18-EUREX.dly 2024-08-24 08:00:15.423 | The FDXSM18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.424 | Unable to determine transition date based on volume from files: FDXSM18-EUREX.dly, FDXSU18-EUREX.dly 2024-08-24 08:00:15.424 | The FDXSU18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.424 | Unable to determine transition date based on volume from files: FDXSU18-EUREX.dly, FDXSZ18-EUREX.dly 2024-08-24 08:00:15.424 | The FDXSZ18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.424 | Unable to determine transition date based on volume from files: FDXSZ18-EUREX.dly, FDXSH19-EUREX.dly 2024-08-24 08:00:15.424 | The FDXSH19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.424 | Unable to determine transition date based on volume from files: FDXSH19-EUREX.dly, FDXSM19-EUREX.dly 2024-08-24 08:00:15.424 | The FDXSM19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.424 | Unable to determine transition date based on volume from files: FDXSM19-EUREX.dly, FDXSU19-EUREX.dly 2024-08-24 08:00:15.424 | The FDXSU19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.424 | Unable to determine transition date based on volume from files: FDXSU19-EUREX.dly, FDXSZ19-EUREX.dly 2024-08-24 08:00:15.424 | The FDXSZ19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.424 | Unable to determine transition date based on volume from files: FDXSZ19-EUREX.dly, FDXSH20-EUREX.dly 2024-08-24 08:00:15.424 | The FDXSH20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.425 | Unable to determine transition date based on volume from files: FDXSH20-EUREX.dly, FDXSM20-EUREX.dly 2024-08-24 08:00:15.425 | The FDXSM20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.425 | Unable to determine transition date based on volume from files: FDXSM20-EUREX.dly, FDXSU20-EUREX.dly 2024-08-24 08:00:15.425 | The FDXSU20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.425 | Unable to determine transition date based on volume from files: FDXSU20-EUREX.dly, FDXSZ20-EUREX.dly 2024-08-24 08:00:15.425 | The FDXSZ20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.425 | Unable to determine transition date based on volume from files: FDXSZ20-EUREX.dly, FDXSH21-EUREX.dly 2024-08-24 08:00:15.425 | The FDXSH21-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.459 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2014-12-23 from file. C:\SierraChart\Data\FDXSZ14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.459 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.460 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2015-03-24 from file. C:\SierraChart\Data\FDXSH15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.460 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.461 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2015-06-23 from file. C:\SierraChart\Data\FDXSM15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.461 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.462 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2015-09-22 from file. C:\SierraChart\Data\FDXSU15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.462 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.463 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2015-12-22 from file. C:\SierraChart\Data\FDXSZ15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.463 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.464 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2016-03-22 from file. C:\SierraChart\Data\FDXSH16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.464 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.464 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2016-06-21 from file. C:\SierraChart\Data\FDXSM16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.464 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.465 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2016-09-20 from file. C:\SierraChart\Data\FDXSU16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.465 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.466 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2016-12-20 from file. C:\SierraChart\Data\FDXSZ16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.466 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.467 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2017-03-21 from file. C:\SierraChart\Data\FDXSH17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.467 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.469 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2017-06-20 from file. C:\SierraChart\Data\FDXSM17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.469 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.469 | HD Request # 15 | Setting DTC encoding to Binary VLS 2024-08-24 08:00:15.469 | HD Request # 15 | Sending historical data logon request message. 2024-08-24 08:00:15.470 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2017-09-19 from file. C:\SierraChart\Data\FDXSU17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.470 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.472 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2017-12-19 from file. C:\SierraChart\Data\FDXSZ17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.472 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.473 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2018-03-20 from file. C:\SierraChart\Data\FDXSH18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.473 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.474 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2018-06-19 from file. C:\SierraChart\Data\FDXSM18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.474 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.475 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2018-09-25 from file. C:\SierraChart\Data\FDXSU18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.475 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.476 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2018-12-25 from file. C:\SierraChart\Data\FDXSZ18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.476 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.477 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2019-03-19 from file. C:\SierraChart\Data\FDXSH19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.477 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.477 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2019-06-25 from file. C:\SierraChart\Data\FDXSM19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.477 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.478 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2019-09-24 from file. C:\SierraChart\Data\FDXSU19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.478 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.479 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2019-12-24 from file. C:\SierraChart\Data\FDXSZ19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.479 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.480 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2020-03-24 from file. C:\SierraChart\Data\FDXSH20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.480 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.481 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2020-06-23 from file. C:\SierraChart\Data\FDXSM20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.481 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.482 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2020-09-22 from file. C:\SierraChart\Data\FDXSU20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.482 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.483 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2020-12-22 from file. C:\SierraChart\Data\FDXSZ20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.483 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH21-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.484 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2021-03-23 from file. C:\SierraChart\Data\FDXSH21-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.484 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM21-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.493 | HD Request # 15 | Requesting Intraday data. Start date-time: 2021-12-17 12:57:19. Record interval: 0. Symbol: FDXS202112_FUT_EUREX 2024-08-24 08:00:15.517 | HD Request # 15 | Decompressing data. 2024-08-24 08:00:15.540 | HD Request # 15 | Receiving Intraday data for FDXSZ21-EUREX starting at 2021-12-17 12:57:19.960000 2024-08-24 08:00:15.540 | Socket (2) | CloseSocket call. 2024-08-24 08:00:15.540 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 08:00:15.565 | Socket (2) | Socket gracefully closed by remote side. 2024-08-24 08:00:15.565 | Socket (2) | Closed. 2024-08-24 08:00:15.568 | Historical data download thread signaled to stop. 2024-08-24 08:00:15.568 | HD Request # 15 | Received 1 Intraday data record from 2021-12-17 12:57:19.960000 to 2021-12-17 12:57:19.960000 (0.0 seconds. Delay: 2.7 years) and wrote 0 records for FDXSZ21-EUREX 2024-08-24 08:00:15.568 | HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2021-12-17 11:57:19.960000 2024-08-24 08:00:15.568 | HD Request # 15 | Completion time: 0s. 2024-08-24 08:00:15.568 | HD Request # 15 | Intraday data download complete for FDXSZ21-EUREX. Unique request ID: 8 2024-08-24 08:00:15.568 | Removing historical data download ID 8. 2024-08-24 08:00:15.568 | Real-time Intraday chart data file updates started for FDXSZ21-EUREX 2024-08-24 08:00:15.568 | Intraday chart data file opened for FDXSZ21-EUREX 2024-08-24 08:00:15.568 | HD Request # 15 | Enabling Intraday chart updating for symbol. 2024-08-24 08:00:15.568 | 2024-08-24 08:00:15.568 | Triggering next historical data download in queue. 2024-08-24 08:00:15.568 | Historical data for FDXSZ21-EUREX is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:00:15.568 | Mapping FDXSH22-EUREX to FDXS202203_FUT_EUREX. Service code: eurex 2024-08-24 08:00:15.568 | HD Request # 16 | Downloading Intraday chart data for FDXSH22-EUREX to the file FDXSH22-EUREX.scid. Service: eurex 2024-08-24 08:00:15.569 | HD Request # 16 | Download start date-time: 2022-03-18 12:59:39.000000. File last date-time: 2022-03-18 12:59:39.526000 2024-08-24 08:00:15.569 | HD Request # 16 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:00:15.569 | FDXSU24-EUREX [CBV] Rev. 4t #25 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:00:15.569 | Socket (1) | Creating socket. 2024-08-24 08:00:15.569 | Socket (1) | New receive buffer size: 0 2024-08-24 08:00:15.569 | Socket (1) | Connecting to IP: 149.11.224.18. 2024-08-24 08:00:15.569 | FDXSU24-EUREX [CBV] Rev. 4t #25 | Reloading chart. 2024-08-24 08:00:15.580 | FDXSU24-EUREX [CBV] 25000 Volume #13 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:00:15.580 | FDXSU24-EUREX [CBV] 25000 Volume #13 | Reloading chart. 2024-08-24 08:00:15.598 | HD Request # 16 | Setting DTC encoding to Binary VLS 2024-08-24 08:00:15.598 | HD Request # 16 | Sending historical data logon request message. 2024-08-24 08:00:15.611 | Socket (1) | CloseSocket call. 2024-08-24 08:00:15.611 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:00:15.614 | HD Request # 12 | Receiving historical Daily data for FDAXU24-EUREX starting at 2024-08-20. 2024-08-24 08:00:15.614 | HD Request # 12 | Writing historical Daily data to the file FDAXU24-EUREX.dly. 2024-08-24 08:00:15.620 | HD Request # 12 | Bytes received: 265 2024-08-24 08:00:15.620 | HD Request # 12 | Received 5 Daily data records from 2024-08-20 00:00:00 to 2024-08-23 00:00:00 (4.0 days) and wrote 4 records for FDAXU24-EUREX 2024-08-24 08:00:15.620 | HD Request # 12 | Completion time: 0s. 2024-08-24 08:00:15.620 | HD Request # 12 | Daily data download complete for FDAXU24-EUREX. Unique request ID: 16 2024-08-24 08:00:15.620 | Removing historical data download ID 16. 2024-08-24 08:00:15.620 | 2024-08-24 08:00:15.620 | No download requests in the queue to start downloads for. 2024-08-24 08:00:15.626 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:00:15.626 | Socket (1) | Closed. 2024-08-24 08:00:15.642 | FDXSU24-EUREX [CBV] Daily #5 | Chart data loading complete. 2024-08-24 08:00:15.642 | HD Request # 16 | Error downloading historical Intraday data for FDXSH22-EUREX. Historical data logon error: Serving data is disabled 2024-08-24 08:00:15.642 | Added historical Intraday data request for FDXSH22-EUREX to the queue. 2024-08-24 08:00:15.642 | Triggering next historical data download in queue. 2024-08-24 08:00:15.642 | Historical data download thread signaled to stop. 2024-08-24 08:00:15.642 | HD Request # 16 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for FDXSH22-EUREX 2024-08-24 08:00:15.642 | HD Request # 16 | Completion time: 0s. 2024-08-24 08:00:15.642 | 2024-08-24 08:00:15.642 | HD Request # 17 | Downloading Intraday chart data for FDXSH22-EUREX to the file FDXSH22-EUREX.scid. Service: eurex 2024-08-24 08:00:15.642 | HD Request # 17 | Download start date-time: 2022-03-18 12:59:39.000000. File last date-time: 2022-03-18 12:59:39.526000 2024-08-24 08:00:15.642 | HD Request # 17 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:00:15.642 | FDXSU24-EUREX [CBV] #1 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:00:15.642 | Socket (1) | Creating socket. 2024-08-24 08:00:15.642 | Socket (1) | New receive buffer size: 0 2024-08-24 08:00:15.642 | Socket (1) | Connecting to IP: 176.9.9.252. 2024-08-24 08:00:15.643 | FDXSU24-EUREX [CBV] #1 | Reloading chart. 2024-08-24 08:00:15.694 | HD Request # 17 | Setting DTC encoding to Binary VLS 2024-08-24 08:00:15.694 | HD Request # 17 | Sending historical data logon request message. 2024-08-24 08:00:15.718 | HD Request # 17 | Requesting Intraday data. Start date-time: 2022-03-18 12:59:39. Record interval: 0. Symbol: FDXS202203_FUT_EUREX 2024-08-24 08:00:15.720 | FDXSU24-EUREX [CBV] Rev. 4t #12 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:00:15.721 | FDXSU24-EUREX [CBV] Rev. 4t #12 | Reloading chart. 2024-08-24 08:00:15.737 | FDXSU24-EUREX [CBV] 10000 Volume #16 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:00:15.738 | FDXSU24-EUREX [CBV] 10000 Volume #16 | Reloading chart. 2024-08-24 08:00:15.743 | HD Request # 17 | Decompressing data. 2024-08-24 08:00:15.766 | FDXSU24-EUREX [CBV] #1 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 08:00:15.766 | HD Request # 17 | Receiving Intraday data for FDXSH22-EUREX starting at 2022-03-18 12:59:39.526000 2024-08-24 08:00:15.766 | Socket (1) | CloseSocket call. 2024-08-24 08:00:15.766 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:00:15.781 | FDXSU24-EUREX [CBV] #1 | Chart data loading complete. 2024-08-24 08:00:15.781 | Historical data download thread signaled to stop. 2024-08-24 08:00:15.781 | HD Request # 17 | Received 1 Intraday data record from 2022-03-18 12:59:39.526000 to 2022-03-18 12:59:39.526000 (0.0 seconds. Delay: 2.4 years) and wrote 0 records for FDXSH22-EUREX 2024-08-24 08:00:15.781 | HD Request # 17 | Add time&sales data | Remembered last file record date-time: 2022-03-18 11:59:39.526000 2024-08-24 08:00:15.781 | HD Request # 17 | Completion time: 0s. 2024-08-24 08:00:15.781 | HD Request # 17 | Intraday data download complete for FDXSH22-EUREX. Unique request ID: 9 2024-08-24 08:00:15.781 | Removing historical data download ID 9. 2024-08-24 08:00:15.781 | Real-time Intraday chart data file updates started for FDXSH22-EUREX 2024-08-24 08:00:15.781 | Intraday chart data file opened for FDXSH22-EUREX 2024-08-24 08:00:15.781 | HD Request # 17 | Enabling Intraday chart updating for symbol. 2024-08-24 08:00:15.781 | 2024-08-24 08:00:15.781 | Triggering next historical data download in queue. 2024-08-24 08:00:15.781 | Historical data for FDXSH22-EUREX is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:00:15.791 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:00:15.791 | Socket (1) | Closed. 2024-08-24 08:00:15.795 | Mapping FDXSM22-EUREX to FDXS202206_FUT_EUREX. Service code: eurex 2024-08-24 08:00:15.795 | HD Request # 18 | Downloading Intraday chart data for FDXSM22-EUREX to the file FDXSM22-EUREX.scid. Service: eurex 2024-08-24 08:00:15.796 | HD Request # 18 | Download start date-time: 2022-06-17 12:57:27.000000. File last date-time: 2022-06-17 12:57:27.541000 2024-08-24 08:00:15.796 | HD Request # 18 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:00:15.796 | Socket (1) | Creating socket. 2024-08-24 08:00:15.796 | Socket (1) | New receive buffer size: 0 2024-08-24 08:00:15.796 | FDXSU24-EUREX [CBV] #4 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:00:15.796 | Socket (1) | Connecting to IP: 149.11.224.18. 2024-08-24 08:00:15.796 | FDXSU24-EUREX [CBV] #4 | Reloading chart. 2024-08-24 08:00:15.825 | HD Request # 18 | Setting DTC encoding to Binary VLS 2024-08-24 08:00:15.825 | HD Request # 18 | Sending historical data logon request message. 2024-08-24 08:00:15.838 | Socket (1) | CloseSocket call. 2024-08-24 08:00:15.838 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:00:15.852 | HD Request # 18 | Error downloading historical Intraday data for FDXSM22-EUREX. Historical data logon error: Serving data is disabled 2024-08-24 08:00:15.852 | Added historical Intraday data request for FDXSM22-EUREX to the queue. 2024-08-24 08:00:15.852 | Triggering next historical data download in queue. 2024-08-24 08:00:15.852 | Historical data download thread signaled to stop. 2024-08-24 08:00:15.852 | HD Request # 18 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for FDXSM22-EUREX 2024-08-24 08:00:15.852 | HD Request # 18 | Completion time: 0s. 2024-08-24 08:00:15.852 | 2024-08-24 08:00:15.852 | HD Request # 19 | Downloading Intraday chart data for FDXSM22-EUREX to the file FDXSM22-EUREX.scid. Service: eurex 2024-08-24 08:00:15.852 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:00:15.852 | Socket (1) | Closed. 2024-08-24 08:00:15.853 | HD Request # 19 | Download start date-time: 2022-06-17 12:57:27.000000. File last date-time: 2022-06-17 12:57:27.541000 2024-08-24 08:00:15.853 | HD Request # 19 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:00:15.853 | Socket (1) | Creating socket. 2024-08-24 08:00:15.853 | Socket (1) | New receive buffer size: 0 2024-08-24 08:00:15.853 | Socket (1) | Connecting to IP: 176.9.9.252. 2024-08-24 08:00:15.853 | FDXSU24-EUREX [CBV] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:00:15.854 | FDXSU24-EUREX [CBV] Daily #6 | Reloading chart. 2024-08-24 08:00:15.854 | Unable to determine transition date based on volume from files: FDXSU12-EUREX.dly, FDXSZ12-EUREX.dly 2024-08-24 08:00:15.854 | The FDXSZ12-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.854 | Unable to determine transition date based on volume from files: FDXSZ12-EUREX.dly, FDXSH13-EUREX.dly 2024-08-24 08:00:15.854 | The FDXSH13-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.855 | Unable to determine transition date based on volume from files: FDXSH13-EUREX.dly, FDXSM13-EUREX.dly 2024-08-24 08:00:15.855 | The FDXSM13-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.855 | Unable to determine transition date based on volume from files: FDXSM13-EUREX.dly, FDXSU13-EUREX.dly 2024-08-24 08:00:15.855 | The FDXSU13-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.855 | Unable to determine transition date based on volume from files: FDXSU13-EUREX.dly, FDXSZ13-EUREX.dly 2024-08-24 08:00:15.855 | The FDXSZ13-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.855 | Unable to determine transition date based on volume from files: FDXSZ13-EUREX.dly, FDXSH14-EUREX.dly 2024-08-24 08:00:15.855 | The FDXSH14-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.855 | Unable to determine transition date based on volume from files: FDXSH14-EUREX.dly, FDXSM14-EUREX.dly 2024-08-24 08:00:15.855 | The FDXSM14-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.856 | Unable to determine transition date based on volume from files: FDXSM14-EUREX.dly, FDXSU14-EUREX.dly 2024-08-24 08:00:15.856 | The FDXSU14-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.856 | Unable to determine transition date based on volume from files: FDXSU14-EUREX.dly, FDXSZ14-EUREX.dly 2024-08-24 08:00:15.856 | The FDXSZ14-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.856 | Unable to determine transition date based on volume from files: FDXSZ14-EUREX.dly, FDXSH15-EUREX.dly 2024-08-24 08:00:15.856 | The FDXSH15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.856 | Unable to determine transition date based on volume from files: FDXSH15-EUREX.dly, FDXSM15-EUREX.dly 2024-08-24 08:00:15.856 | The FDXSM15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.856 | Unable to determine transition date based on volume from files: FDXSM15-EUREX.dly, FDXSU15-EUREX.dly 2024-08-24 08:00:15.856 | The FDXSU15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.857 | Unable to determine transition date based on volume from files: FDXSU15-EUREX.dly, FDXSZ15-EUREX.dly 2024-08-24 08:00:15.857 | The FDXSZ15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.857 | Unable to determine transition date based on volume from files: FDXSZ15-EUREX.dly, FDXSH16-EUREX.dly 2024-08-24 08:00:15.857 | The FDXSH16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.857 | Unable to determine transition date based on volume from files: FDXSH16-EUREX.dly, FDXSM16-EUREX.dly 2024-08-24 08:00:15.857 | The FDXSM16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.857 | Unable to determine transition date based on volume from files: FDXSM16-EUREX.dly, FDXSU16-EUREX.dly 2024-08-24 08:00:15.857 | The FDXSU16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.857 | Unable to determine transition date based on volume from files: FDXSU16-EUREX.dly, FDXSZ16-EUREX.dly 2024-08-24 08:00:15.857 | The FDXSZ16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.857 | Unable to determine transition date based on volume from files: FDXSZ16-EUREX.dly, FDXSH17-EUREX.dly 2024-08-24 08:00:15.857 | The FDXSH17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.858 | Unable to determine transition date based on volume from files: FDXSH17-EUREX.dly, FDXSM17-EUREX.dly 2024-08-24 08:00:15.858 | The FDXSM17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.858 | Unable to determine transition date based on volume from files: FDXSM17-EUREX.dly, FDXSU17-EUREX.dly 2024-08-24 08:00:15.858 | The FDXSU17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.858 | Unable to determine transition date based on volume from files: FDXSU17-EUREX.dly, FDXSZ17-EUREX.dly 2024-08-24 08:00:15.858 | The FDXSZ17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.858 | Unable to determine transition date based on volume from files: FDXSZ17-EUREX.dly, FDXSH18-EUREX.dly 2024-08-24 08:00:15.858 | The FDXSH18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.858 | Unable to determine transition date based on volume from files: FDXSH18-EUREX.dly, FDXSM18-EUREX.dly 2024-08-24 08:00:15.858 | The FDXSM18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.858 | Unable to determine transition date based on volume from files: FDXSM18-EUREX.dly, FDXSU18-EUREX.dly 2024-08-24 08:00:15.858 | The FDXSU18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.859 | Unable to determine transition date based on volume from files: FDXSU18-EUREX.dly, FDXSZ18-EUREX.dly 2024-08-24 08:00:15.859 | The FDXSZ18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.859 | Unable to determine transition date based on volume from files: FDXSZ18-EUREX.dly, FDXSH19-EUREX.dly 2024-08-24 08:00:15.859 | The FDXSH19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.859 | Unable to determine transition date based on volume from files: FDXSH19-EUREX.dly, FDXSM19-EUREX.dly 2024-08-24 08:00:15.859 | The FDXSM19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.859 | Unable to determine transition date based on volume from files: FDXSM19-EUREX.dly, FDXSU19-EUREX.dly 2024-08-24 08:00:15.859 | The FDXSU19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.859 | Unable to determine transition date based on volume from files: FDXSU19-EUREX.dly, FDXSZ19-EUREX.dly 2024-08-24 08:00:15.859 | The FDXSZ19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.859 | Unable to determine transition date based on volume from files: FDXSZ19-EUREX.dly, FDXSH20-EUREX.dly 2024-08-24 08:00:15.859 | The FDXSH20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.860 | Unable to determine transition date based on volume from files: FDXSH20-EUREX.dly, FDXSM20-EUREX.dly 2024-08-24 08:00:15.860 | The FDXSM20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.860 | Unable to determine transition date based on volume from files: FDXSM20-EUREX.dly, FDXSU20-EUREX.dly 2024-08-24 08:00:15.860 | The FDXSU20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.860 | Unable to determine transition date based on volume from files: FDXSU20-EUREX.dly, FDXSZ20-EUREX.dly 2024-08-24 08:00:15.860 | The FDXSZ20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.860 | Unable to determine transition date based on volume from files: FDXSZ20-EUREX.dly, FDXSH21-EUREX.dly 2024-08-24 08:00:15.860 | The FDXSH21-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:15.906 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2012-09-25 from file. C:\SierraChart\Data\FDXSU12-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.906 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ12-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.907 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2012-12-25 from file. C:\SierraChart\Data\FDXSZ12-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.907 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.908 | HD Request # 19 | Setting DTC encoding to Binary VLS 2024-08-24 08:00:15.908 | HD Request # 19 | Sending historical data logon request message. 2024-08-24 08:00:15.908 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2013-03-19 from file. C:\SierraChart\Data\FDXSH13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.908 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.910 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2013-06-25 from file. C:\SierraChart\Data\FDXSM13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.910 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.911 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2013-09-24 from file. C:\SierraChart\Data\FDXSU13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.911 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.912 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2013-12-24 from file. C:\SierraChart\Data\FDXSZ13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.912 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.913 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2014-03-25 from file. C:\SierraChart\Data\FDXSH14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.913 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.915 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2014-06-24 from file. C:\SierraChart\Data\FDXSM14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.915 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.916 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2014-09-23 from file. C:\SierraChart\Data\FDXSU14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.916 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.917 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2014-12-23 from file. C:\SierraChart\Data\FDXSZ14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.917 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.918 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2015-03-24 from file. C:\SierraChart\Data\FDXSH15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.918 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.919 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2015-06-23 from file. C:\SierraChart\Data\FDXSM15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.919 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.921 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2015-09-22 from file. C:\SierraChart\Data\FDXSU15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.921 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.922 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2015-12-22 from file. C:\SierraChart\Data\FDXSZ15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.922 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.923 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2016-03-22 from file. C:\SierraChart\Data\FDXSH16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.923 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.924 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2016-06-21 from file. C:\SierraChart\Data\FDXSM16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.924 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.926 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2016-09-20 from file. C:\SierraChart\Data\FDXSU16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.926 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.927 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2016-12-20 from file. C:\SierraChart\Data\FDXSZ16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.927 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.928 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2017-03-21 from file. C:\SierraChart\Data\FDXSH17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.928 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.929 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2017-06-20 from file. C:\SierraChart\Data\FDXSM17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.929 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.930 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2017-09-19 from file. C:\SierraChart\Data\FDXSU17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.930 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.931 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2017-12-19 from file. C:\SierraChart\Data\FDXSZ17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.932 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.933 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2018-03-20 from file. C:\SierraChart\Data\FDXSH18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.933 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.934 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2018-06-19 from file. C:\SierraChart\Data\FDXSM18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.934 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.934 | HD Request # 19 | Requesting Intraday data. Start date-time: 2022-06-17 12:57:27. Record interval: 0. Symbol: FDXS202206_FUT_EUREX 2024-08-24 08:00:15.935 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2018-09-25 from file. C:\SierraChart\Data\FDXSU18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.935 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.936 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2018-12-25 from file. C:\SierraChart\Data\FDXSZ18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.936 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.937 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2019-03-19 from file. C:\SierraChart\Data\FDXSH19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.937 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.939 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2019-06-25 from file. C:\SierraChart\Data\FDXSM19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.939 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.940 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2019-09-24 from file. C:\SierraChart\Data\FDXSU19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.940 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.941 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2019-12-24 from file. C:\SierraChart\Data\FDXSZ19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.941 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.942 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2020-03-24 from file. C:\SierraChart\Data\FDXSH20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.942 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.943 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2020-06-23 from file. C:\SierraChart\Data\FDXSM20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.943 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.944 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2020-09-22 from file. C:\SierraChart\Data\FDXSU20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.945 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.946 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2020-12-22 from file. C:\SierraChart\Data\FDXSZ20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.946 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH21-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.947 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2021-03-23 from file. C:\SierraChart\Data\FDXSH21-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.947 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM21-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:15.961 | HD Request # 19 | Decompressing data. 2024-08-24 08:00:15.986 | HD Request # 19 | Receiving Intraday data for FDXSM22-EUREX starting at 2022-06-17 12:57:27.541000 2024-08-24 08:00:15.986 | Socket (1) | CloseSocket call. 2024-08-24 08:00:15.986 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:00:16.012 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:00:16.013 | Socket (1) | Closed. 2024-08-24 08:00:16.069 | Historical data download thread signaled to stop. 2024-08-24 08:00:16.069 | HD Request # 19 | Received 1 Intraday data record from 2022-06-17 12:57:27.541000 to 2022-06-17 12:57:27.541000 (0.0 seconds. Delay: 2.2 years) and wrote 0 records for FDXSM22-EUREX 2024-08-24 08:00:16.069 | HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2022-06-17 10:57:27.541000 2024-08-24 08:00:16.069 | HD Request # 19 | Completion time: 1s. 2024-08-24 08:00:16.069 | HD Request # 19 | Intraday data download complete for FDXSM22-EUREX. Unique request ID: 10 2024-08-24 08:00:16.069 | Removing historical data download ID 10. 2024-08-24 08:00:16.069 | Real-time Intraday chart data file updates started for FDXSM22-EUREX 2024-08-24 08:00:16.069 | Intraday chart data file opened for FDXSM22-EUREX 2024-08-24 08:00:16.069 | HD Request # 19 | Enabling Intraday chart updating for symbol. 2024-08-24 08:00:16.069 | 2024-08-24 08:00:16.069 | Triggering next historical data download in queue. 2024-08-24 08:00:16.069 | Historical data for FDXSM22-EUREX is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:00:16.069 | Mapping FDXSU22-EUREX to FDXS202209_FUT_EUREX. Service code: eurex 2024-08-24 08:00:16.069 | HD Request # 20 | Downloading Intraday chart data for FDXSU22-EUREX to the file FDXSU22-EUREX.scid. Service: eurex 2024-08-24 08:00:16.069 | HD Request # 20 | Download start date-time: 2022-09-16 12:59:53.000000. File last date-time: 2022-09-16 12:59:53.075000 2024-08-24 08:00:16.070 | HD Request # 20 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:00:16.070 | Socket (1) | Creating socket. 2024-08-24 08:00:16.070 | FDXSU24-EUREX [CBV] 1200 Volume #21 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:00:16.070 | Socket (1) | New receive buffer size: 0 2024-08-24 08:00:16.070 | Socket (1) | Connecting to IP: 149.11.224.18. 2024-08-24 08:00:16.070 | FDXSU24-EUREX [CBV] 1200 Volume #21 | Reloading chart. 2024-08-24 08:00:16.088 | FDXSU24-EUREX [CBV] 100 Volume #14 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:00:16.089 | FDXSU24-EUREX [CBV] 100 Volume #14 | Reloading chart. 2024-08-24 08:00:16.098 | HD Request # 20 | Setting DTC encoding to Binary VLS 2024-08-24 08:00:16.098 | HD Request # 20 | Sending historical data logon request message. 2024-08-24 08:00:16.112 | Socket (1) | CloseSocket call. 2024-08-24 08:00:16.112 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:00:16.126 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:00:16.126 | Socket (1) | Closed. 2024-08-24 08:00:16.143 | HD Request # 20 | Error downloading historical Intraday data for FDXSU22-EUREX. Historical data logon error: Serving data is disabled 2024-08-24 08:00:16.143 | Added historical Intraday data request for FDXSU22-EUREX to the queue. 2024-08-24 08:00:16.143 | Triggering next historical data download in queue. 2024-08-24 08:00:16.143 | Historical data download thread signaled to stop. 2024-08-24 08:00:16.143 | HD Request # 20 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for FDXSU22-EUREX 2024-08-24 08:00:16.143 | HD Request # 20 | Completion time: 0s. 2024-08-24 08:00:16.143 | 2024-08-24 08:00:16.236 | FDXSU24-EUREX [CBV] Daily #6 | Chart data loading complete. 2024-08-24 08:00:16.236 | HD Request # 21 | Downloading Intraday chart data for FDXSU22-EUREX to the file FDXSU22-EUREX.scid. Service: eurex 2024-08-24 08:00:16.237 | HD Request # 21 | Download start date-time: 2022-09-16 12:59:53.000000. File last date-time: 2022-09-16 12:59:53.075000 2024-08-24 08:00:16.237 | HD Request # 21 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:00:16.237 | Socket (1) | Creating socket. 2024-08-24 08:00:16.237 | Socket (1) | New receive buffer size: 0 2024-08-24 08:00:16.237 | Socket (1) | Connecting to IP: 176.9.9.252. 2024-08-24 08:00:16.237 | FDXSU24-EUREX [CBV] 1 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:00:16.237 | FDXSU24-EUREX [CBV] 1 Min #3 | Reloading chart. 2024-08-24 08:00:16.292 | HD Request # 21 | Setting DTC encoding to Binary VLS 2024-08-24 08:00:16.292 | HD Request # 21 | Sending historical data logon request message. 2024-08-24 08:00:16.295 | FDXSU24-EUREX [CBV] #18 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:00:16.295 | FDXSU24-EUREX [CBV] #18 | Reloading chart. 2024-08-24 08:00:16.318 | HD Request # 21 | Requesting Intraday data. Start date-time: 2022-09-16 12:59:53. Record interval: 0. Symbol: FDXS202209_FUT_EUREX 2024-08-24 08:00:16.345 | HD Request # 21 | Decompressing data. 2024-08-24 08:00:16.370 | HD Request # 21 | Receiving Intraday data for FDXSU22-EUREX starting at 2022-09-16 12:59:53.075000 2024-08-24 08:00:16.370 | Socket (1) | CloseSocket call. 2024-08-24 08:00:16.370 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:00:16.388 | Historical data download thread signaled to stop. 2024-08-24 08:00:16.388 | HD Request # 21 | Received 1 Intraday data record from 2022-09-16 12:59:53.075000 to 2022-09-16 12:59:53.075000 (0.0 seconds. Delay: 707.8 days) and wrote 0 records for FDXSU22-EUREX 2024-08-24 08:00:16.388 | HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2022-09-16 10:59:53.075000 2024-08-24 08:00:16.388 | HD Request # 21 | Completion time: 0s. 2024-08-24 08:00:16.388 | HD Request # 21 | Intraday data download complete for FDXSU22-EUREX. Unique request ID: 11 2024-08-24 08:00:16.388 | Removing historical data download ID 11. 2024-08-24 08:00:16.388 | Real-time Intraday chart data file updates started for FDXSU22-EUREX 2024-08-24 08:00:16.388 | Intraday chart data file opened for FDXSU22-EUREX 2024-08-24 08:00:16.388 | HD Request # 21 | Enabling Intraday chart updating for symbol. 2024-08-24 08:00:16.388 | 2024-08-24 08:00:16.388 | Triggering next historical data download in queue. 2024-08-24 08:00:16.388 | Historical data for FDXSU22-EUREX is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:00:16.388 | Mapping FDXSZ22-EUREX to FDXS202212_FUT_EUREX. Service code: eurex 2024-08-24 08:00:16.388 | HD Request # 22 | Downloading Intraday chart data for FDXSZ22-EUREX to the file FDXSZ22-EUREX.scid. Service: eurex 2024-08-24 08:00:16.388 | HD Request # 22 | Download start date-time: 2022-12-16 12:57:36.000000. File last date-time: 2022-12-16 12:57:36.094000 2024-08-24 08:00:16.388 | HD Request # 22 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:00:16.388 | Socket (2) | Creating socket. 2024-08-24 08:00:16.388 | Socket (2) | New receive buffer size: 0 2024-08-24 08:00:16.388 | Socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 08:00:16.397 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:00:16.397 | Socket (1) | Closed. 2024-08-24 08:00:16.421 | HD Request # 22 | Setting DTC encoding to Binary VLS 2024-08-24 08:00:16.421 | HD Request # 22 | Sending historical data logon request message. 2024-08-24 08:00:16.434 | Socket (2) | CloseSocket call. 2024-08-24 08:00:16.434 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 08:00:16.448 | Socket (2) | Socket gracefully closed by remote side. 2024-08-24 08:00:16.449 | Socket (2) | Closed. 2024-08-24 08:00:16.575 | HD Request # 22 | Error downloading historical Intraday data for FDXSZ22-EUREX. Historical data logon error: Serving data is disabled 2024-08-24 08:00:16.575 | Added historical Intraday data request for FDXSZ22-EUREX to the queue. 2024-08-24 08:00:16.575 | Triggering next historical data download in queue. 2024-08-24 08:00:16.575 | Historical data download thread signaled to stop. 2024-08-24 08:00:16.575 | HD Request # 22 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for FDXSZ22-EUREX 2024-08-24 08:00:16.575 | HD Request # 22 | Completion time: 0s. 2024-08-24 08:00:16.575 | 2024-08-24 08:00:16.575 | HD Request # 23 | Downloading Intraday chart data for FDXSZ22-EUREX to the file FDXSZ22-EUREX.scid. Service: eurex 2024-08-24 08:00:16.575 | HD Request # 23 | Download start date-time: 2022-12-16 12:57:36.000000. File last date-time: 2022-12-16 12:57:36.094000 2024-08-24 08:00:16.575 | HD Request # 23 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:00:16.575 | Socket (1) | Creating socket. 2024-08-24 08:00:16.575 | Socket (1) | New receive buffer size: 0 2024-08-24 08:00:16.575 | Socket (1) | Connecting to IP: 176.9.9.252. 2024-08-24 08:00:16.577 | FDXSU24-EUREX [CBV] #11 | Reloading chart. 2024-08-24 08:00:16.643 | HD Request # 23 | Setting DTC encoding to Binary VLS 2024-08-24 08:00:16.643 | HD Request # 23 | Sending historical data logon request message. 2024-08-24 08:00:16.668 | HD Request # 23 | Requesting Intraday data. Start date-time: 2022-12-16 12:57:36. Record interval: 0. Symbol: FDXS202212_FUT_EUREX 2024-08-24 08:00:16.694 | HD Request # 23 | Decompressing data. 2024-08-24 08:00:16.718 | HD Request # 23 | Receiving Intraday data for FDXSZ22-EUREX starting at 2022-12-16 12:57:36.094000 2024-08-24 08:00:16.718 | Socket (1) | CloseSocket call. 2024-08-24 08:00:16.718 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:00:16.743 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:00:16.743 | Socket (1) | Closed. 2024-08-24 08:00:17.015 | FDXSU24-EUREX [CBV] #11 | Dates not found while checking for invalid data in continuous contract data files. FDXSM21-EUREX * 2024-08-24 08:00:17.015 | Unable to determine transition date based on volume from files: FDXSU12-EUREX.dly, FDXSZ12-EUREX.dly 2024-08-24 08:00:17.015 | The FDXSZ12-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.015 | Unable to determine transition date based on volume from files: FDXSZ12-EUREX.dly, FDXSH13-EUREX.dly 2024-08-24 08:00:17.015 | The FDXSH13-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.016 | Unable to determine transition date based on volume from files: FDXSH13-EUREX.dly, FDXSM13-EUREX.dly 2024-08-24 08:00:17.016 | The FDXSM13-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.016 | Unable to determine transition date based on volume from files: FDXSM13-EUREX.dly, FDXSU13-EUREX.dly 2024-08-24 08:00:17.016 | The FDXSU13-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.016 | Unable to determine transition date based on volume from files: FDXSU13-EUREX.dly, FDXSZ13-EUREX.dly 2024-08-24 08:00:17.016 | The FDXSZ13-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.016 | Unable to determine transition date based on volume from files: FDXSZ13-EUREX.dly, FDXSH14-EUREX.dly 2024-08-24 08:00:17.016 | The FDXSH14-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.016 | Unable to determine transition date based on volume from files: FDXSH14-EUREX.dly, FDXSM14-EUREX.dly 2024-08-24 08:00:17.016 | The FDXSM14-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.016 | Unable to determine transition date based on volume from files: FDXSM14-EUREX.dly, FDXSU14-EUREX.dly 2024-08-24 08:00:17.016 | The FDXSU14-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.017 | Unable to determine transition date based on volume from files: FDXSU14-EUREX.dly, FDXSZ14-EUREX.dly 2024-08-24 08:00:17.017 | The FDXSZ14-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.017 | Unable to determine transition date based on volume from files: FDXSZ14-EUREX.dly, FDXSH15-EUREX.dly 2024-08-24 08:00:17.017 | The FDXSH15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.017 | Unable to determine transition date based on volume from files: FDXSH15-EUREX.dly, FDXSM15-EUREX.dly 2024-08-24 08:00:17.017 | The FDXSM15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.017 | Unable to determine transition date based on volume from files: FDXSM15-EUREX.dly, FDXSU15-EUREX.dly 2024-08-24 08:00:17.017 | The FDXSU15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.017 | Unable to determine transition date based on volume from files: FDXSU15-EUREX.dly, FDXSZ15-EUREX.dly 2024-08-24 08:00:17.017 | The FDXSZ15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.017 | Unable to determine transition date based on volume from files: FDXSZ15-EUREX.dly, FDXSH16-EUREX.dly 2024-08-24 08:00:17.017 | The FDXSH16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.018 | Unable to determine transition date based on volume from files: FDXSH16-EUREX.dly, FDXSM16-EUREX.dly 2024-08-24 08:00:17.018 | The FDXSM16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.018 | Unable to determine transition date based on volume from files: FDXSM16-EUREX.dly, FDXSU16-EUREX.dly 2024-08-24 08:00:17.018 | The FDXSU16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.018 | Unable to determine transition date based on volume from files: FDXSU16-EUREX.dly, FDXSZ16-EUREX.dly 2024-08-24 08:00:17.018 | The FDXSZ16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.018 | Unable to determine transition date based on volume from files: FDXSZ16-EUREX.dly, FDXSH17-EUREX.dly 2024-08-24 08:00:17.018 | The FDXSH17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.018 | Unable to determine transition date based on volume from files: FDXSH17-EUREX.dly, FDXSM17-EUREX.dly 2024-08-24 08:00:17.018 | The FDXSM17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.018 | Unable to determine transition date based on volume from files: FDXSM17-EUREX.dly, FDXSU17-EUREX.dly 2024-08-24 08:00:17.018 | The FDXSU17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.019 | Unable to determine transition date based on volume from files: FDXSU17-EUREX.dly, FDXSZ17-EUREX.dly 2024-08-24 08:00:17.019 | The FDXSZ17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.019 | Unable to determine transition date based on volume from files: FDXSZ17-EUREX.dly, FDXSH18-EUREX.dly 2024-08-24 08:00:17.019 | The FDXSH18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.019 | Unable to determine transition date based on volume from files: FDXSH18-EUREX.dly, FDXSM18-EUREX.dly 2024-08-24 08:00:17.019 | The FDXSM18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.019 | Unable to determine transition date based on volume from files: FDXSM18-EUREX.dly, FDXSU18-EUREX.dly 2024-08-24 08:00:17.019 | The FDXSU18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.019 | Unable to determine transition date based on volume from files: FDXSU18-EUREX.dly, FDXSZ18-EUREX.dly 2024-08-24 08:00:17.019 | The FDXSZ18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.019 | Unable to determine transition date based on volume from files: FDXSZ18-EUREX.dly, FDXSH19-EUREX.dly 2024-08-24 08:00:17.019 | The FDXSH19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.019 | Unable to determine transition date based on volume from files: FDXSH19-EUREX.dly, FDXSM19-EUREX.dly 2024-08-24 08:00:17.019 | The FDXSM19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.020 | Unable to determine transition date based on volume from files: FDXSM19-EUREX.dly, FDXSU19-EUREX.dly 2024-08-24 08:00:17.020 | The FDXSU19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.020 | Unable to determine transition date based on volume from files: FDXSU19-EUREX.dly, FDXSZ19-EUREX.dly 2024-08-24 08:00:17.020 | The FDXSZ19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.020 | Unable to determine transition date based on volume from files: FDXSZ19-EUREX.dly, FDXSH20-EUREX.dly 2024-08-24 08:00:17.020 | The FDXSH20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.020 | Unable to determine transition date based on volume from files: FDXSH20-EUREX.dly, FDXSM20-EUREX.dly 2024-08-24 08:00:17.020 | The FDXSM20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.020 | Unable to determine transition date based on volume from files: FDXSM20-EUREX.dly, FDXSU20-EUREX.dly 2024-08-24 08:00:17.020 | The FDXSU20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.020 | Unable to determine transition date based on volume from files: FDXSU20-EUREX.dly, FDXSZ20-EUREX.dly 2024-08-24 08:00:17.020 | The FDXSZ20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.021 | Unable to determine transition date based on volume from files: FDXSZ20-EUREX.dly, FDXSH21-EUREX.dly 2024-08-24 08:00:17.021 | The FDXSH21-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:00:17.065 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2012-09-25 from file. C:\SierraChart\Data\FDXSU12-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.065 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ12-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.066 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2012-12-25 from file. C:\SierraChart\Data\FDXSZ12-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.066 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.067 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2013-03-19 from file. C:\SierraChart\Data\FDXSH13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.067 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.068 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2013-06-25 from file. C:\SierraChart\Data\FDXSM13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.068 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.069 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2013-09-24 from file. C:\SierraChart\Data\FDXSU13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.069 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.071 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2013-12-24 from file. C:\SierraChart\Data\FDXSZ13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.071 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.072 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2014-03-25 from file. C:\SierraChart\Data\FDXSH14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.072 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.073 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2014-06-24 from file. C:\SierraChart\Data\FDXSM14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.073 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.074 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2014-09-23 from file. C:\SierraChart\Data\FDXSU14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.074 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.076 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2014-12-23 from file. C:\SierraChart\Data\FDXSZ14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.076 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.077 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2015-03-24 from file. C:\SierraChart\Data\FDXSH15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.077 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.078 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2015-06-23 from file. C:\SierraChart\Data\FDXSM15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.078 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.079 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2015-09-22 from file. C:\SierraChart\Data\FDXSU15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.079 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.080 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2015-12-22 from file. C:\SierraChart\Data\FDXSZ15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.080 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.082 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2016-03-22 from file. C:\SierraChart\Data\FDXSH16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.082 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.083 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2016-06-21 from file. C:\SierraChart\Data\FDXSM16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.083 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.084 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2016-09-20 from file. C:\SierraChart\Data\FDXSU16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.084 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.085 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2016-12-20 from file. C:\SierraChart\Data\FDXSZ16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.085 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.086 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2017-03-21 from file. C:\SierraChart\Data\FDXSH17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.086 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.088 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2017-06-20 from file. C:\SierraChart\Data\FDXSM17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.088 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.089 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2017-09-19 from file. C:\SierraChart\Data\FDXSU17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.089 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.090 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2017-12-19 from file. C:\SierraChart\Data\FDXSZ17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.090 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.091 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2018-03-20 from file. C:\SierraChart\Data\FDXSH18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.091 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.093 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2018-06-19 from file. C:\SierraChart\Data\FDXSM18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.093 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.094 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2018-09-25 from file. C:\SierraChart\Data\FDXSU18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.094 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.095 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2018-12-25 from file. C:\SierraChart\Data\FDXSZ18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.095 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.096 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2019-03-19 from file. C:\SierraChart\Data\FDXSH19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.096 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.098 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2019-06-25 from file. C:\SierraChart\Data\FDXSM19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.098 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.099 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2019-09-24 from file. C:\SierraChart\Data\FDXSU19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.099 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.100 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2019-12-24 from file. C:\SierraChart\Data\FDXSZ19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.100 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.101 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2020-03-24 from file. C:\SierraChart\Data\FDXSH20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.101 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.103 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2020-06-23 from file. C:\SierraChart\Data\FDXSM20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.103 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.104 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2020-09-22 from file. C:\SierraChart\Data\FDXSU20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.104 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.105 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2020-12-22 from file. C:\SierraChart\Data\FDXSZ20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.105 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH21-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.106 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 2021-03-23 from file. C:\SierraChart\Data\FDXSH21-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.106 | FDXSU24-EUREX [CBV] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM21-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:00:17.220 | Historical data download thread signaled to stop. 2024-08-24 08:00:17.220 | HD Request # 23 | Received 1 Intraday data record from 2022-12-16 12:57:36.094000 to 2022-12-16 12:57:36.094000 (0.0 seconds. Delay: 616.8 days) and wrote 0 records for FDXSZ22-EUREX 2024-08-24 08:00:17.220 | HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2022-12-16 11:57:36.094000 2024-08-24 08:00:17.220 | HD Request # 23 | Completion time: 1s. 2024-08-24 08:00:17.220 | HD Request # 23 | Intraday data download complete for FDXSZ22-EUREX. Unique request ID: 12 2024-08-24 08:00:17.220 | Removing historical data download ID 12. 2024-08-24 08:00:17.220 | Real-time Intraday chart data file updates started for FDXSZ22-EUREX 2024-08-24 08:00:17.220 | Intraday chart data file opened for FDXSZ22-EUREX 2024-08-24 08:00:17.220 | HD Request # 23 | Enabling Intraday chart updating for symbol. 2024-08-24 08:00:17.220 | 2024-08-24 08:00:17.220 | Triggering next historical data download in queue. 2024-08-24 08:00:17.220 | Historical data for FDXSZ22-EUREX is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:00:17.231 | FDXSU24-EUREX [CBV] 1200 Volume #21 | Chart data loading complete. 2024-08-24 08:00:17.239 | FDXSU24-EUREX [CBV] 10000 Volume #16 | Chart data loading complete. 2024-08-24 08:00:17.240 | FDXSU24-EUREX [CBV] Rev. 4t #25 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 08:00:22.807 | FDXSU24-EUREX [CBV] Rev. 4t #25 | Chart data loading complete. 2024-08-24 08:00:22.808 | FDXSU24-EUREX [CBV] Rev. 4t #12 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 08:00:25.657 | Chart #12 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:00:25.657 | FDXSU24-EUREX [CBV] Rev. 4t #12 | Chart data loading complete. 2024-08-24 08:00:25.658 | Mapping FDXSH23-EUREX to FDXS202303_FUT_EUREX. Service code: eurex 2024-08-24 08:00:25.658 | HD Request # 24 | Downloading Intraday chart data for FDXSH23-EUREX to the file FDXSH23-EUREX.scid. Service: eurex 2024-08-24 08:00:25.658 | HD Request # 24 | Download start date-time: 2023-03-17 12:58:00.000000. File last date-time: 2023-03-17 12:58:00.041000 2024-08-24 08:00:25.658 | HD Request # 24 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:00:25.658 | Socket (1) | Creating socket. 2024-08-24 08:00:25.658 | Socket (1) | New receive buffer size: 0 2024-08-24 08:00:25.658 | Socket (1) | Connecting to IP: 149.11.224.18. 2024-08-24 08:00:25.663 | FDXSU24-EUREX [CBV] 25000 Volume #13 | Chart data loading complete. 2024-08-24 08:00:25.687 | HD Request # 24 | Setting DTC encoding to Binary VLS 2024-08-24 08:00:25.687 | HD Request # 24 | Sending historical data logon request message. 2024-08-24 08:00:25.701 | Socket (1) | CloseSocket call. 2024-08-24 08:00:25.701 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:00:25.715 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:00:25.715 | Socket (1) | Closed. 2024-08-24 08:00:30.984 | Chart #25 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:00:33.796 | Chart #12 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:00:33.797 | FDXSU24-EUREX [CBV] #11 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 08:00:33.817 | FDXSU24-EUREX [CBV] #11 | Chart data loading complete. 2024-08-24 08:00:33.964 | FDXSU24-EUREX [CBV] #4 | Chart data loading complete. 2024-08-24 08:00:34.084 | FDXSU24-EUREX [CBV] #18 | Chart data loading complete. 2024-08-24 08:02:42.773 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:02:42.773 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:02:42.773 | FDXSU24-EUREX [CBV] 1 Min #3 | Chart data loading complete. 2024-08-24 08:02:42.789 | FDXSU24-EUREX [CBV] 100 Volume #14 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 08:02:42.980 | FDXSU24-EUREX [CBV] 100 Volume #14 | Chart data loading complete. 2024-08-24 08:02:42.982 | FDXSU24-EUREX [CBV] 1 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 08:02:49.897 | FDXSU24-EUREX [CBV] 1 Min #17 | Chart data loading complete. 2024-08-24 08:02:49.916 | HD Request # 24 | Error downloading historical Intraday data for FDXSH23-EUREX. Historical data logon error: Serving data is disabled 2024-08-24 08:02:49.916 | Added historical Intraday data request for FDXSH23-EUREX to the queue. 2024-08-24 08:02:49.916 | Triggering next historical data download in queue. 2024-08-24 08:02:49.916 | Historical data download thread signaled to stop. 2024-08-24 08:02:49.916 | HD Request # 24 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for FDXSH23-EUREX 2024-08-24 08:02:49.916 | HD Request # 24 | Completion time: 2m 24s. 2024-08-24 08:02:49.916 | 2024-08-24 08:02:57.376 | HD Request # 25 | Downloading Intraday chart data for FDXSH23-EUREX to the file FDXSH23-EUREX.scid. Service: eurex 2024-08-24 08:02:57.376 | HD Request # 25 | Download start date-time: 2023-03-17 12:58:00.000000. File last date-time: 2023-03-17 12:58:00.041000 2024-08-24 08:02:57.376 | HD Request # 25 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:02:57.376 | Socket (1) | Creating socket. 2024-08-24 08:02:57.376 | Socket (1) | New receive buffer size: 0 2024-08-24 08:02:57.376 | Socket (1) | Connecting to IP: 176.9.9.252. 2024-08-24 08:02:57.431 | FDXSU24-EUREX [CBV] 1 Min #17 | Reloading chart. 2024-08-24 08:02:57.432 | HD Request # 25 | Setting DTC encoding to Binary VLS 2024-08-24 08:02:57.432 | HD Request # 25 | Sending historical data logon request message. 2024-08-24 08:02:57.547 | FDXSU24-EUREX [CBV] Daily #5 | Reloading chart. 2024-08-24 08:02:57.616 | HD Request # 25 | Requesting Intraday data. Start date-time: 2023-03-17 12:58:00. Record interval: 0. Symbol: FDXS202303_FUT_EUREX 2024-08-24 08:02:57.643 | HD Request # 25 | Decompressing data. 2024-08-24 08:02:57.668 | HD Request # 25 | Receiving Intraday data for FDXSH23-EUREX starting at 2023-03-17 12:58:00.041000 2024-08-24 08:02:57.668 | Socket (1) | CloseSocket call. 2024-08-24 08:02:57.668 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:02:57.703 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:02:57.703 | Socket (1) | Closed. 2024-08-24 08:02:57.779 | FDXSU24-EUREX [CBV] Daily #5 | Dates not found while checking for invalid data in continuous contract data files. FDXSM21-EUREX * 2024-08-24 08:02:57.779 | Unable to determine transition date based on volume from files: FDXSZ14-EUREX.dly, FDXSH15-EUREX.dly 2024-08-24 08:02:57.779 | The FDXSH15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.779 | Unable to determine transition date based on volume from files: FDXSH15-EUREX.dly, FDXSM15-EUREX.dly 2024-08-24 08:02:57.779 | The FDXSM15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.779 | Unable to determine transition date based on volume from files: FDXSM15-EUREX.dly, FDXSU15-EUREX.dly 2024-08-24 08:02:57.779 | The FDXSU15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.780 | Unable to determine transition date based on volume from files: FDXSU15-EUREX.dly, FDXSZ15-EUREX.dly 2024-08-24 08:02:57.780 | The FDXSZ15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.780 | Unable to determine transition date based on volume from files: FDXSZ15-EUREX.dly, FDXSH16-EUREX.dly 2024-08-24 08:02:57.780 | The FDXSH16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.780 | Unable to determine transition date based on volume from files: FDXSH16-EUREX.dly, FDXSM16-EUREX.dly 2024-08-24 08:02:57.780 | The FDXSM16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.780 | Unable to determine transition date based on volume from files: FDXSM16-EUREX.dly, FDXSU16-EUREX.dly 2024-08-24 08:02:57.780 | The FDXSU16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.780 | Unable to determine transition date based on volume from files: FDXSU16-EUREX.dly, FDXSZ16-EUREX.dly 2024-08-24 08:02:57.780 | The FDXSZ16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.780 | Unable to determine transition date based on volume from files: FDXSZ16-EUREX.dly, FDXSH17-EUREX.dly 2024-08-24 08:02:57.780 | The FDXSH17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.780 | Unable to determine transition date based on volume from files: FDXSH17-EUREX.dly, FDXSM17-EUREX.dly 2024-08-24 08:02:57.780 | The FDXSM17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.780 | Unable to determine transition date based on volume from files: FDXSM17-EUREX.dly, FDXSU17-EUREX.dly 2024-08-24 08:02:57.780 | The FDXSU17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.780 | Unable to determine transition date based on volume from files: FDXSU17-EUREX.dly, FDXSZ17-EUREX.dly 2024-08-24 08:02:57.780 | The FDXSZ17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.781 | Unable to determine transition date based on volume from files: FDXSZ17-EUREX.dly, FDXSH18-EUREX.dly 2024-08-24 08:02:57.781 | The FDXSH18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.781 | Unable to determine transition date based on volume from files: FDXSH18-EUREX.dly, FDXSM18-EUREX.dly 2024-08-24 08:02:57.781 | The FDXSM18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.781 | Unable to determine transition date based on volume from files: FDXSM18-EUREX.dly, FDXSU18-EUREX.dly 2024-08-24 08:02:57.781 | The FDXSU18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.781 | Unable to determine transition date based on volume from files: FDXSU18-EUREX.dly, FDXSZ18-EUREX.dly 2024-08-24 08:02:57.781 | The FDXSZ18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.781 | Unable to determine transition date based on volume from files: FDXSZ18-EUREX.dly, FDXSH19-EUREX.dly 2024-08-24 08:02:57.781 | The FDXSH19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.781 | Unable to determine transition date based on volume from files: FDXSH19-EUREX.dly, FDXSM19-EUREX.dly 2024-08-24 08:02:57.781 | The FDXSM19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.781 | Unable to determine transition date based on volume from files: FDXSM19-EUREX.dly, FDXSU19-EUREX.dly 2024-08-24 08:02:57.781 | The FDXSU19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.781 | Unable to determine transition date based on volume from files: FDXSU19-EUREX.dly, FDXSZ19-EUREX.dly 2024-08-24 08:02:57.781 | The FDXSZ19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.782 | Unable to determine transition date based on volume from files: FDXSZ19-EUREX.dly, FDXSH20-EUREX.dly 2024-08-24 08:02:57.782 | The FDXSH20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.782 | Unable to determine transition date based on volume from files: FDXSH20-EUREX.dly, FDXSM20-EUREX.dly 2024-08-24 08:02:57.782 | The FDXSM20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.782 | Unable to determine transition date based on volume from files: FDXSM20-EUREX.dly, FDXSU20-EUREX.dly 2024-08-24 08:02:57.782 | The FDXSU20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.782 | Unable to determine transition date based on volume from files: FDXSU20-EUREX.dly, FDXSZ20-EUREX.dly 2024-08-24 08:02:57.782 | The FDXSZ20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.782 | Unable to determine transition date based on volume from files: FDXSZ20-EUREX.dly, FDXSH21-EUREX.dly 2024-08-24 08:02:57.782 | The FDXSH21-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:57.814 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2014-12-23 from file. C:\SierraChart\Data\FDXSZ14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.814 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.815 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2015-03-24 from file. C:\SierraChart\Data\FDXSH15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.815 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.815 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2015-06-23 from file. C:\SierraChart\Data\FDXSM15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.815 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.816 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2015-09-22 from file. C:\SierraChart\Data\FDXSU15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.816 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.817 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2015-12-22 from file. C:\SierraChart\Data\FDXSZ15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.817 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.818 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2016-03-22 from file. C:\SierraChart\Data\FDXSH16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.818 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.819 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2016-06-21 from file. C:\SierraChart\Data\FDXSM16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.819 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.820 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2016-09-20 from file. C:\SierraChart\Data\FDXSU16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.820 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.821 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2016-12-20 from file. C:\SierraChart\Data\FDXSZ16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.821 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.822 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2017-03-21 from file. C:\SierraChart\Data\FDXSH17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.822 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.823 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2017-06-20 from file. C:\SierraChart\Data\FDXSM17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.823 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.823 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2017-09-19 from file. C:\SierraChart\Data\FDXSU17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.823 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.824 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2017-12-19 from file. C:\SierraChart\Data\FDXSZ17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.824 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.825 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2018-03-20 from file. C:\SierraChart\Data\FDXSH18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.825 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.826 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2018-06-19 from file. C:\SierraChart\Data\FDXSM18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.826 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.827 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2018-09-25 from file. C:\SierraChart\Data\FDXSU18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.827 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.828 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2018-12-25 from file. C:\SierraChart\Data\FDXSZ18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.828 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.829 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2019-03-19 from file. C:\SierraChart\Data\FDXSH19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.829 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.830 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2019-06-25 from file. C:\SierraChart\Data\FDXSM19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.830 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.831 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2019-09-24 from file. C:\SierraChart\Data\FDXSU19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.831 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.832 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2019-12-24 from file. C:\SierraChart\Data\FDXSZ19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.832 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.833 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2020-03-24 from file. C:\SierraChart\Data\FDXSH20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.833 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.834 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2020-06-23 from file. C:\SierraChart\Data\FDXSM20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.834 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.835 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2020-09-22 from file. C:\SierraChart\Data\FDXSU20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.835 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.835 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2020-12-22 from file. C:\SierraChart\Data\FDXSZ20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.835 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH21-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.836 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 2021-03-23 from file. C:\SierraChart\Data\FDXSH21-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.836 | FDXSU24-EUREX [CBV] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM21-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:57.917 | Historical data download thread signaled to stop. 2024-08-24 08:02:57.917 | HD Request # 25 | Received 1 Intraday data record from 2023-03-17 12:58:00.041000 to 2023-03-17 12:58:00.041000 (0.0 seconds. Delay: 525.8 days) and wrote 0 records for FDXSH23-EUREX 2024-08-24 08:02:57.917 | HD Request # 25 | Add time&sales data | Remembered last file record date-time: 2023-03-17 11:58:00.041000 2024-08-24 08:02:57.917 | HD Request # 25 | Completion time: 0s. 2024-08-24 08:02:57.917 | HD Request # 25 | Intraday data download complete for FDXSH23-EUREX. Unique request ID: 13 2024-08-24 08:02:57.917 | Removing historical data download ID 13. 2024-08-24 08:02:57.917 | Real-time Intraday chart data file updates started for FDXSH23-EUREX 2024-08-24 08:02:57.917 | Intraday chart data file opened for FDXSH23-EUREX 2024-08-24 08:02:57.917 | HD Request # 25 | Enabling Intraday chart updating for symbol. 2024-08-24 08:02:57.917 | 2024-08-24 08:02:57.917 | Triggering next historical data download in queue. 2024-08-24 08:02:57.917 | Historical data for FDXSH23-EUREX is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:02:57.917 | Mapping FDXSM23-EUREX to FDXS202306_FUT_EUREX. Service code: eurex 2024-08-24 08:02:57.918 | HD Request # 26 | Downloading Intraday chart data for FDXSM23-EUREX to the file FDXSM23-EUREX.scid. Service: eurex 2024-08-24 08:02:57.918 | HD Request # 26 | Download start date-time: 2023-06-16 12:59:52.000000. File last date-time: 2023-06-16 12:59:52.501000 2024-08-24 08:02:57.918 | HD Request # 26 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:02:57.918 | Socket (1) | Creating socket. 2024-08-24 08:02:57.918 | Socket (1) | New receive buffer size: 0 2024-08-24 08:02:57.918 | Socket (1) | Connecting to IP: 149.11.224.18. 2024-08-24 08:02:57.935 | FDXSU24-EUREX [CBV] Rev. 4t #25 | Reloading chart. 2024-08-24 08:02:57.948 | HD Request # 26 | Setting DTC encoding to Binary VLS 2024-08-24 08:02:57.948 | HD Request # 26 | Sending historical data logon request message. 2024-08-24 08:02:57.962 | Socket (1) | CloseSocket call. 2024-08-24 08:02:57.962 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:02:57.985 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:02:57.985 | Socket (1) | Closed. 2024-08-24 08:02:58.005 | FDXSU24-EUREX [CBV] Daily #5 | Chart data loading complete. 2024-08-24 08:02:58.005 | HD Request # 26 | Error downloading historical Intraday data for FDXSM23-EUREX. Historical data logon error: Serving data is disabled 2024-08-24 08:02:58.005 | Added historical Intraday data request for FDXSM23-EUREX to the queue. 2024-08-24 08:02:58.005 | Triggering next historical data download in queue. 2024-08-24 08:02:58.005 | Historical data download thread signaled to stop. 2024-08-24 08:02:58.005 | HD Request # 26 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for FDXSM23-EUREX 2024-08-24 08:02:58.005 | HD Request # 26 | Completion time: 1s. 2024-08-24 08:02:58.005 | 2024-08-24 08:02:58.005 | HD Request # 27 | Downloading Intraday chart data for FDXSM23-EUREX to the file FDXSM23-EUREX.scid. Service: eurex 2024-08-24 08:02:58.006 | HD Request # 27 | Download start date-time: 2023-06-16 12:59:52.000000. File last date-time: 2023-06-16 12:59:52.501000 2024-08-24 08:02:58.006 | HD Request # 27 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:02:58.006 | Socket (1) | Creating socket. 2024-08-24 08:02:58.006 | Socket (1) | New receive buffer size: 0 2024-08-24 08:02:58.006 | Socket (1) | Connecting to IP: 176.9.9.252. 2024-08-24 08:02:58.006 | FDXSU24-EUREX [CBV] 25000 Volume #13 | Reloading chart. 2024-08-24 08:02:58.057 | HD Request # 27 | Setting DTC encoding to Binary VLS 2024-08-24 08:02:58.057 | HD Request # 27 | Sending historical data logon request message. 2024-08-24 08:02:58.082 | HD Request # 27 | Requesting Intraday data. Start date-time: 2023-06-16 12:59:52. Record interval: 0. Symbol: FDXS202306_FUT_EUREX 2024-08-24 08:02:58.101 | FDXSU24-EUREX [CBV] #1 | Reloading chart. 2024-08-24 08:02:58.109 | HD Request # 27 | Decompressing data. 2024-08-24 08:02:58.132 | HD Request # 27 | Receiving Intraday data for FDXSM23-EUREX starting at 2023-06-16 12:59:52.501000 2024-08-24 08:02:58.132 | Socket (1) | CloseSocket call. 2024-08-24 08:02:58.132 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:02:58.158 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:02:58.158 | Socket (1) | Closed. 2024-08-24 08:02:58.277 | Historical data download thread signaled to stop. 2024-08-24 08:02:58.277 | HD Request # 27 | Received 1 Intraday data record from 2023-06-16 12:59:52.501000 to 2023-06-16 12:59:52.501000 (0.0 seconds. Delay: 434.8 days) and wrote 0 records for FDXSM23-EUREX 2024-08-24 08:02:58.278 | HD Request # 27 | Add time&sales data | Remembered last file record date-time: 2023-06-16 10:59:52.501000 2024-08-24 08:02:58.278 | HD Request # 27 | Completion time: 0s. 2024-08-24 08:02:58.278 | HD Request # 27 | Intraday data download complete for FDXSM23-EUREX. Unique request ID: 14 2024-08-24 08:02:58.278 | Removing historical data download ID 14. 2024-08-24 08:02:58.278 | Real-time Intraday chart data file updates started for FDXSM23-EUREX 2024-08-24 08:02:58.278 | Intraday chart data file opened for FDXSM23-EUREX 2024-08-24 08:02:58.278 | HD Request # 27 | Enabling Intraday chart updating for symbol. 2024-08-24 08:02:58.278 | 2024-08-24 08:02:58.278 | Triggering next historical data download in queue. 2024-08-24 08:02:58.278 | Historical data for FDXSM23-EUREX is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:02:58.278 | HD Request # 28 | Downloading Intraday chart data for FDAXU24-EUREX to the file FDAXU24-EUREX.scid. Service: eurex 2024-08-24 08:02:58.278 | HD Request # 28 | Download start date-time: 2024-08-23 07:35:42.000000. File last date-time: 2024-08-23 07:35:42.544004 2024-08-24 08:02:58.278 | HD Request # 28 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:02:58.278 | Socket (1) | Creating socket. 2024-08-24 08:02:58.278 | Socket (1) | New receive buffer size: 0 2024-08-24 08:02:58.278 | Socket (1) | Connecting to IP: 149.11.224.18. 2024-08-24 08:02:58.300 | FDXSU24-EUREX [CBV] Rev. 4t #12 | Reloading chart. 2024-08-24 08:02:58.317 | HD Request # 28 | Setting DTC encoding to Binary VLS 2024-08-24 08:02:58.317 | HD Request # 28 | Sending historical data logon request message. 2024-08-24 08:02:58.330 | Socket (1) | CloseSocket call. 2024-08-24 08:02:58.330 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:02:58.340 | FDXSU24-EUREX [CBV] #1 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 08:02:58.354 | FDXSU24-EUREX [CBV] #1 | Chart data loading complete. 2024-08-24 08:02:58.354 | HD Request # 28 | Error downloading historical Intraday data for FDAXU24-EUREX. Historical data logon error: Serving data is disabled 2024-08-24 08:02:58.354 | Added historical Intraday data request for FDAXU24-EUREX to the queue. 2024-08-24 08:02:58.354 | Triggering next historical data download in queue. 2024-08-24 08:02:58.354 | Historical data download thread signaled to stop. 2024-08-24 08:02:58.354 | HD Request # 28 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for FDAXU24-EUREX 2024-08-24 08:02:58.354 | HD Request # 28 | Completion time: 0s. 2024-08-24 08:02:58.354 | 2024-08-24 08:02:58.357 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:02:58.357 | Socket (1) | Closed. 2024-08-24 08:02:58.365 | HD Request # 29 | Downloading Intraday chart data for FDAXU24-EUREX to the file FDAXU24-EUREX.scid. Service: eurex 2024-08-24 08:02:58.365 | HD Request # 29 | Download start date-time: 2024-08-23 07:35:42.000000. File last date-time: 2024-08-23 07:35:42.544004 2024-08-24 08:02:58.366 | HD Request # 29 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:02:58.366 | Socket (1) | Creating socket. 2024-08-24 08:02:58.366 | Socket (1) | New receive buffer size: 0 2024-08-24 08:02:58.366 | Socket (1) | Connecting to IP: 176.9.9.252. 2024-08-24 08:02:58.368 | FDXSU24-EUREX [CBV] 10000 Volume #16 | Reloading chart. 2024-08-24 08:02:58.453 | FDXSU24-EUREX [CBV] #4 | Reloading chart. 2024-08-24 08:02:58.454 | HD Request # 29 | Setting DTC encoding to Binary VLS 2024-08-24 08:02:58.454 | HD Request # 29 | Sending historical data logon request message. 2024-08-24 08:02:58.479 | HD Request # 29 | Requesting Intraday data. Start date-time: 2024-08-23 07:35:42. Record interval: 0. Symbol: FDAX202409_FUT_EUREX 2024-08-24 08:02:58.518 | HD Request # 29 | Decompressing data. 2024-08-24 08:02:58.577 | HD Request # 29 | Receiving Intraday data for FDAXU24-EUREX starting at 2024-08-23 07:35:42.544000 2024-08-24 08:02:58.605 | FDXSU24-EUREX [CBV] Daily #6 | Reloading chart. 2024-08-24 08:02:58.701 | HD Request # 29 | Timestamp of first Intraday data file record written: 2024-08-23 07:35:50.276000. 2024-08-24 08:02:58.703 | Socket (1) | CloseSocket call. 2024-08-24 08:02:58.703 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:02:58.730 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:02:58.731 | Socket (1) | Closed. 2024-08-24 08:02:58.927 | FDXSU24-EUREX [CBV] Daily #6 | Dates not found while checking for invalid data in continuous contract data files. FDXSM21-EUREX * 2024-08-24 08:02:58.927 | Unable to determine transition date based on volume from files: FDXSU12-EUREX.dly, FDXSZ12-EUREX.dly 2024-08-24 08:02:58.927 | The FDXSZ12-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.927 | Unable to determine transition date based on volume from files: FDXSZ12-EUREX.dly, FDXSH13-EUREX.dly 2024-08-24 08:02:58.927 | The FDXSH13-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.927 | Unable to determine transition date based on volume from files: FDXSH13-EUREX.dly, FDXSM13-EUREX.dly 2024-08-24 08:02:58.927 | The FDXSM13-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.927 | Unable to determine transition date based on volume from files: FDXSM13-EUREX.dly, FDXSU13-EUREX.dly 2024-08-24 08:02:58.927 | The FDXSU13-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.928 | Unable to determine transition date based on volume from files: FDXSU13-EUREX.dly, FDXSZ13-EUREX.dly 2024-08-24 08:02:58.928 | The FDXSZ13-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.928 | Unable to determine transition date based on volume from files: FDXSZ13-EUREX.dly, FDXSH14-EUREX.dly 2024-08-24 08:02:58.928 | The FDXSH14-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.928 | Unable to determine transition date based on volume from files: FDXSH14-EUREX.dly, FDXSM14-EUREX.dly 2024-08-24 08:02:58.928 | The FDXSM14-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.928 | Unable to determine transition date based on volume from files: FDXSM14-EUREX.dly, FDXSU14-EUREX.dly 2024-08-24 08:02:58.928 | The FDXSU14-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.928 | Unable to determine transition date based on volume from files: FDXSU14-EUREX.dly, FDXSZ14-EUREX.dly 2024-08-24 08:02:58.928 | The FDXSZ14-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.928 | Unable to determine transition date based on volume from files: FDXSZ14-EUREX.dly, FDXSH15-EUREX.dly 2024-08-24 08:02:58.928 | The FDXSH15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.928 | Unable to determine transition date based on volume from files: FDXSH15-EUREX.dly, FDXSM15-EUREX.dly 2024-08-24 08:02:58.928 | The FDXSM15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.929 | Unable to determine transition date based on volume from files: FDXSM15-EUREX.dly, FDXSU15-EUREX.dly 2024-08-24 08:02:58.929 | The FDXSU15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.929 | Unable to determine transition date based on volume from files: FDXSU15-EUREX.dly, FDXSZ15-EUREX.dly 2024-08-24 08:02:58.929 | The FDXSZ15-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.929 | Unable to determine transition date based on volume from files: FDXSZ15-EUREX.dly, FDXSH16-EUREX.dly 2024-08-24 08:02:58.929 | The FDXSH16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.929 | Unable to determine transition date based on volume from files: FDXSH16-EUREX.dly, FDXSM16-EUREX.dly 2024-08-24 08:02:58.929 | The FDXSM16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.929 | Unable to determine transition date based on volume from files: FDXSM16-EUREX.dly, FDXSU16-EUREX.dly 2024-08-24 08:02:58.929 | The FDXSU16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.929 | Unable to determine transition date based on volume from files: FDXSU16-EUREX.dly, FDXSZ16-EUREX.dly 2024-08-24 08:02:58.929 | The FDXSZ16-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.930 | Unable to determine transition date based on volume from files: FDXSZ16-EUREX.dly, FDXSH17-EUREX.dly 2024-08-24 08:02:58.930 | The FDXSH17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.930 | Unable to determine transition date based on volume from files: FDXSH17-EUREX.dly, FDXSM17-EUREX.dly 2024-08-24 08:02:58.930 | The FDXSM17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.930 | Unable to determine transition date based on volume from files: FDXSM17-EUREX.dly, FDXSU17-EUREX.dly 2024-08-24 08:02:58.930 | The FDXSU17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.930 | Unable to determine transition date based on volume from files: FDXSU17-EUREX.dly, FDXSZ17-EUREX.dly 2024-08-24 08:02:58.930 | The FDXSZ17-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.930 | Unable to determine transition date based on volume from files: FDXSZ17-EUREX.dly, FDXSH18-EUREX.dly 2024-08-24 08:02:58.930 | The FDXSH18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.930 | Unable to determine transition date based on volume from files: FDXSH18-EUREX.dly, FDXSM18-EUREX.dly 2024-08-24 08:02:58.930 | The FDXSM18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.931 | Unable to determine transition date based on volume from files: FDXSM18-EUREX.dly, FDXSU18-EUREX.dly 2024-08-24 08:02:58.931 | The FDXSU18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.931 | Unable to determine transition date based on volume from files: FDXSU18-EUREX.dly, FDXSZ18-EUREX.dly 2024-08-24 08:02:58.931 | The FDXSZ18-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.931 | Unable to determine transition date based on volume from files: FDXSZ18-EUREX.dly, FDXSH19-EUREX.dly 2024-08-24 08:02:58.931 | The FDXSH19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.931 | Unable to determine transition date based on volume from files: FDXSH19-EUREX.dly, FDXSM19-EUREX.dly 2024-08-24 08:02:58.931 | The FDXSM19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.931 | Unable to determine transition date based on volume from files: FDXSM19-EUREX.dly, FDXSU19-EUREX.dly 2024-08-24 08:02:58.931 | The FDXSU19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.931 | Unable to determine transition date based on volume from files: FDXSU19-EUREX.dly, FDXSZ19-EUREX.dly 2024-08-24 08:02:58.931 | The FDXSZ19-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.931 | Unable to determine transition date based on volume from files: FDXSZ19-EUREX.dly, FDXSH20-EUREX.dly 2024-08-24 08:02:58.931 | The FDXSH20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.932 | Unable to determine transition date based on volume from files: FDXSH20-EUREX.dly, FDXSM20-EUREX.dly 2024-08-24 08:02:58.932 | The FDXSM20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.932 | Unable to determine transition date based on volume from files: FDXSM20-EUREX.dly, FDXSU20-EUREX.dly 2024-08-24 08:02:58.932 | The FDXSU20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.932 | Unable to determine transition date based on volume from files: FDXSU20-EUREX.dly, FDXSZ20-EUREX.dly 2024-08-24 08:02:58.932 | The FDXSZ20-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.932 | Unable to determine transition date based on volume from files: FDXSZ20-EUREX.dly, FDXSH21-EUREX.dly 2024-08-24 08:02:58.932 | The FDXSH21-EUREX.dly symbol may not be the active contract month. 2024-08-24 08:02:58.976 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2012-09-25 from file. C:\SierraChart\Data\FDXSU12-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.976 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ12-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.977 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2012-12-25 from file. C:\SierraChart\Data\FDXSZ12-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.977 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.978 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2013-03-19 from file. C:\SierraChart\Data\FDXSH13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.978 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.979 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2013-06-25 from file. C:\SierraChart\Data\FDXSM13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.979 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.981 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2013-09-24 from file. C:\SierraChart\Data\FDXSU13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.981 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.982 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2013-12-24 from file. C:\SierraChart\Data\FDXSZ13-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.982 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.983 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2014-03-25 from file. C:\SierraChart\Data\FDXSH14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.983 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.984 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2014-06-24 from file. C:\SierraChart\Data\FDXSM14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.984 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.985 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2014-09-23 from file. C:\SierraChart\Data\FDXSU14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.985 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.987 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2014-12-23 from file. C:\SierraChart\Data\FDXSZ14-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.987 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.988 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2015-03-24 from file. C:\SierraChart\Data\FDXSH15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.988 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.989 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2015-06-23 from file. C:\SierraChart\Data\FDXSM15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.989 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.990 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2015-09-22 from file. C:\SierraChart\Data\FDXSU15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.990 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.991 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2015-12-22 from file. C:\SierraChart\Data\FDXSZ15-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.991 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.993 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2016-03-22 from file. C:\SierraChart\Data\FDXSH16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.993 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.994 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2016-06-21 from file. C:\SierraChart\Data\FDXSM16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.994 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.995 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2016-09-20 from file. C:\SierraChart\Data\FDXSU16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.995 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.996 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2016-12-20 from file. C:\SierraChart\Data\FDXSZ16-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.996 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.997 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2017-03-21 from file. C:\SierraChart\Data\FDXSH17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.997 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.998 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2017-06-20 from file. C:\SierraChart\Data\FDXSM17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:58.998 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.000 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2017-09-19 from file. C:\SierraChart\Data\FDXSU17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.000 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.001 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2017-12-19 from file. C:\SierraChart\Data\FDXSZ17-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.001 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.002 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2018-03-20 from file. C:\SierraChart\Data\FDXSH18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.002 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.003 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2018-06-19 from file. C:\SierraChart\Data\FDXSM18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.003 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.004 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2018-09-25 from file. C:\SierraChart\Data\FDXSU18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.004 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.006 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2018-12-25 from file. C:\SierraChart\Data\FDXSZ18-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.006 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.007 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2019-03-19 from file. C:\SierraChart\Data\FDXSH19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.007 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.008 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2019-06-25 from file. C:\SierraChart\Data\FDXSM19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.008 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.009 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2019-09-24 from file. C:\SierraChart\Data\FDXSU19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.009 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.010 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2019-12-24 from file. C:\SierraChart\Data\FDXSZ19-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.010 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.011 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2020-03-24 from file. C:\SierraChart\Data\FDXSH20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.011 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.013 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2020-06-23 from file. C:\SierraChart\Data\FDXSM20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.013 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSU20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.014 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2020-09-22 from file. C:\SierraChart\Data\FDXSU20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.014 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSZ20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.015 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2020-12-22 from file. C:\SierraChart\Data\FDXSZ20-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.015 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSH21-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.016 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 2021-03-23 from file. C:\SierraChart\Data\FDXSH21-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.016 | FDXSU24-EUREX [CBV] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\FDXSM21-EUREX.dly. Error: No Data for read. End of file. 2024-08-24 08:02:59.128 | Historical data download thread signaled to stop. 2024-08-24 08:02:59.128 | HD Request # 29 | Received 33885 Intraday data records from 2024-08-23 07:35:42.544000 to 2024-08-23 22:03:41.805000 (14.5 hours. Delay: 10.0 hours) and wrote 33880 records for FDAXU24-EUREX 2024-08-24 08:02:59.135 | HD Request # 29 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 08:02:59.135 | HD Request # 29 | Completion time: 1s. 2024-08-24 08:02:59.135 | HD Request # 29 | Intraday data download complete for FDAXU24-EUREX. Unique request ID: 15 2024-08-24 08:02:59.135 | Removing historical data download ID 15. 2024-08-24 08:02:59.135 | Real-time Intraday chart data file updates started for FDAXU24-EUREX 2024-08-24 08:02:59.135 | Intraday chart data file opened for FDAXU24-EUREX 2024-08-24 08:02:59.135 | HD Request # 29 | Enabling Intraday chart updating for symbol. 2024-08-24 08:02:59.135 | 2024-08-24 08:02:59.135 | No download requests in the queue to start downloads for. 2024-08-24 08:02:59.135 | Historical data for FDAXU24-EUREX is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:02:59.136 | FDXSU24-EUREX [CBV] Rev. 4t #25 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 08:03:04.732 | Chart #25 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:03:04.732 | FDXSU24-EUREX [CBV] Rev. 4t #25 | Chart data loading complete. 2024-08-24 08:03:11.026 | FDXSU24-EUREX [CBV] Daily #6 | Chart data loading complete. 2024-08-24 08:03:11.033 | FDXSU24-EUREX [CBV] 25000 Volume #13 | Chart data loading complete. 2024-08-24 08:03:11.038 | FDXSU24-EUREX [CBV] 10000 Volume #16 | Chart data loading complete. 2024-08-24 08:03:11.039 | FDXSU24-EUREX [CBV] Rev. 4t #12 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 08:03:14.088 | Chart #12 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:03:14.088 | FDXSU24-EUREX [CBV] Rev. 4t #12 | Chart data loading complete. 2024-08-24 08:03:14.089 | FDXSU24-EUREX [CBV] 1 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 08:03:21.135 | FDXSU24-EUREX [CBV] 1 Min #17 | Chart data loading complete. 2024-08-24 08:03:21.286 | FDXSU24-EUREX [CBV] #4 | Chart data loading complete. 2024-08-24 08:03:30.969 | FDXSU24-EUREX [CBV] 1200 Volume #21 | Reloading chart. 2024-08-24 08:03:31.015 | FDXSU24-EUREX [CBV] 100 Volume #14 | Reloading chart. 2024-08-24 08:03:31.131 | FDXSU24-EUREX [CBV] 1 Min #3 | Reloading chart. 2024-08-24 08:03:31.255 | FDXSU24-EUREX [CBV] #18 | Reloading chart. 2024-08-24 08:03:31.396 | FDXSU24-EUREX [CBV] 1200 Volume #21 | Chart data loading complete. 2024-08-24 08:03:31.396 | Denali Data Feed | Starting real-time market data updates for: FDXSU24-EUREX (FDXS202409_FUT_EUREX). ID: 5 Service code: eurex 2024-08-24 08:03:31.397 | Denali Data Feed | Connecting to the server ds14.sierracharts.com. Port 10048 2024-08-24 08:03:31.398 | DTC Client socket (1) | Creating socket. 2024-08-24 08:03:31.398 | DTC Client socket (1) | New receive buffer size: 0 2024-08-24 08:03:31.398 | DTC Client socket (1) | Connecting to IP: 176.9.9.252. 2024-08-24 08:03:31.398 | Denali Data Feed | Requesting security definition data for: FDXSU24-EUREX (FDXS202409_FUT_EUREX). ID: 5 2024-08-24 08:03:31.401 | FDXSU24-EUREX [CBV] #7 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:03:31.401 | FDXSU24-EUREX [CBV] #7 | Reloading chart. 2024-08-24 08:03:31.504 | Denali Data Feed | Network connection to server complete. 2024-08-24 08:03:31.504 | Denali Data Feed | Starting socket receive thread. 2024-08-24 08:03:31.504 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 08:03:31.504 | FDAXU24-EUREX [CBV] #15 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:03:31.505 | FDAXU24-EUREX [CBV] #15 | Reloading chart. 2024-08-24 08:03:31.618 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 08:03:31.618 | Denali Data Feed | Sending logon request message. 2024-08-24 08:03:31.651 | FDXSU24-EUREX [CBV] #2 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:03:31.651 | FDXSU24-EUREX [CBV] #2 | Reloading chart. 2024-08-24 08:03:31.794 | FDAXU24-EUREX [CBV] #10 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:03:31.794 | FDAXU24-EUREX [CBV] #10 | Reloading chart. 2024-08-24 08:03:31.914 | FDXSU24-EUREX [CBV] #8 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:03:31.914 | FDXSU24-EUREX [CBV] #8 | Reloading chart. 2024-08-24 08:03:32.078 | Denali Data Feed | Received logon response. 2024-08-24 08:03:32.078 | Denali Data Feed | Server Name: SC Realtime Server. 2024-08-24 08:03:32.078 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 08:03:32.078 | Denali Data Feed | Successfully connected. 2024-08-24 08:03:32.078 | Denali Data Feed | Trading is not supported. 2024-08-24 08:03:32.078 | Denali Data Feed | MarketDepthIsSupported: 1 2024-08-24 08:03:32.078 | Added historical Intraday data request for FDXSU24-EUREX to the queue. 2024-08-24 08:03:32.078 | Intraday data recording state for symbol FDXSU24-EUREX is set to download 'Pending'. 2024-08-24 08:03:32.078 | Triggering next historical data download in queue. 2024-08-24 08:03:32.078 | Denali Data Feed | Restarting real-time data updates for symbol: FDXSU24-EUREX -> FDXS202409_FUT_EUREX 2024-08-24 08:03:32.078 | Delaying start of download for FDXSU24-EUREX. 2024-08-24 08:03:32.143 | FDXSU24-EUREX [CBV] #7 | Reloading chart. 2024-08-24 08:03:32.440 | FDXSU24-EUREX [CBV] #7 | Waiting for historical downloads to complete with the IDs: 17, 2024-08-24 08:03:32.440 | Denali Data Feed | Real-time data for symbol FDXSU24-EUREX is currently unavailable. 2024-08-24 08:03:32.440 | Denali Data Feed | Setting external service identifier for symbol FDXSU24-EUREX to 10451688 2024-08-24 08:03:32.440 | Denali Data Feed | Received security definition for symbol FDXSU24-EUREX 2024-08-24 08:03:32.446 | FDAXU24-EUREX [CBV] #15 | Reloading chart. 2024-08-24 08:03:32.759 | FDXSU24-EUREX [CBV] #2 | Reloading chart. 2024-08-24 08:03:33.075 | FDXSU24-EUREX [CBV] #2 | Waiting for historical downloads to complete with the IDs: 17, 2024-08-24 08:03:33.098 | FDAXU24-EUREX [CBV] #10 | Reloading chart. 2024-08-24 08:03:33.417 | FDXSU24-EUREX [CBV] #8 | Reloading chart. 2024-08-24 08:03:33.730 | FDXSU24-EUREX [CBV] #8 | Waiting for historical downloads to complete with the IDs: 17, 2024-08-24 08:03:33.777 | Denali Data Feed | Starting real-time market data updates for: FDAXU24-EUREX (FDAX202409_FUT_EUREX). ID: 7 Service code: eurex 2024-08-24 08:03:33.777 | Denali Data Feed | Requesting security definition data for: FDAXU24-EUREX (FDAX202409_FUT_EUREX). ID: 7 2024-08-24 08:03:34.106 | FDXSU24-EUREX [CBV][M] #18 | Chart data loading complete. 2024-08-24 08:05:40.686 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:05:40.686 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:05:40.686 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:05:40.686 | FDXSU24-EUREX [CBV][M] 1 Min #3 | Chart data loading complete. 2024-08-24 08:05:40.686 | Denali Data Feed | Real-time data for symbol FDAXU24-EUREX is currently unavailable. 2024-08-24 08:05:40.686 | Denali Data Feed | Setting external service identifier for symbol FDAXU24-EUREX to 7296071 2024-08-24 08:05:40.686 | Denali Data Feed | Received security definition for symbol FDAXU24-EUREX 2024-08-24 08:05:40.688 | FDXSU24-EUREX [CBV][M] 100 Volume #14 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 08:05:40.866 | FDXSU24-EUREX [CBV][M] 100 Volume #14 | Chart data loading complete. 2024-08-24 08:05:41.063 | FDAXU24-EUREX [CBV][M] #15 | Chart data loading complete. 2024-08-24 08:05:41.215 | FDAXU24-EUREX [CBV][M] #10 | Chart data loading complete. 2024-08-24 08:05:41.633 | FDXSU24-EUREX [CBV] #7 | Chart data loading complete. 2024-08-24 08:05:41.634 | FDXSU24-EUREX [CBV] #8 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 08:05:42.169 | FDXSU24-EUREX [CBV] #8 | Chart data loading complete. 2024-08-24 08:05:42.719 | Chart #2 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:05:42.719 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:05:42.719 | Chart #2 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:05:42.719 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:05:42.719 | FDXSU24-EUREX [CBV] #2 | Chart data loading complete. 2024-08-24 08:05:43.515 | FDXSU24-EUREX [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:05:46.569 | FDXSU24-EUREX [CBV][M] 1 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:07:54.285 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:07:54.287 | FDXSU24-EUREX [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:08:01.044 | FDXSU24-EUREX [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:08:06.525 | Circular chart reference detected. Charts: 12, 25. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-24 08:08:06.526 | HD Request # 30 | Downloading Intraday chart data for FDXSU24-EUREX to the file FDXSU24-EUREX.scid. Service: eurex 2024-08-24 08:08:06.526 | HD Request # 30 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 08:08:06.526 | HD Request # 30 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:08:06.526 | Socket (2) | Creating socket. 2024-08-24 08:08:06.526 | Socket (2) | New receive buffer size: 0 2024-08-24 08:08:06.526 | Socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 08:08:06.539 | FDXSU24-EUREX [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:08:06.559 | HD Request # 30 | Setting DTC encoding to Binary VLS 2024-08-24 08:08:06.559 | HD Request # 30 | Sending historical data logon request message. 2024-08-24 08:08:06.573 | Socket (2) | CloseSocket call. 2024-08-24 08:08:06.573 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 08:08:06.587 | Socket (2) | Socket gracefully closed by remote side. 2024-08-24 08:08:06.587 | Socket (2) | Closed. 2024-08-24 08:08:09.538 | Circular chart reference detected. Charts: 25, 12. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-24 08:08:09.538 | HD Request # 30 | Error downloading historical Intraday data for FDXSU24-EUREX. Historical data logon error: Serving data is disabled 2024-08-24 08:08:09.539 | Added historical Intraday data request for FDXSU24-EUREX to the queue. 2024-08-24 08:08:09.539 | Triggering next historical data download in queue. 2024-08-24 08:08:09.539 | Historical data download thread signaled to stop. 2024-08-24 08:08:09.539 | HD Request # 30 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for FDXSU24-EUREX 2024-08-24 08:08:09.539 | HD Request # 30 | Completion time: 3s. 2024-08-24 08:08:09.539 | 2024-08-24 08:08:09.539 | HD Request # 31 | Downloading Intraday chart data for FDXSU24-EUREX to the file FDXSU24-EUREX.scid. Service: eurex 2024-08-24 08:08:09.540 | HD Request # 31 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 08:08:09.540 | HD Request # 31 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:08:09.540 | Socket (2) | Creating socket. 2024-08-24 08:08:09.540 | Socket (2) | New receive buffer size: 0 2024-08-24 08:08:09.540 | Socket (2) | Connecting to IP: 176.9.9.252. 2024-08-24 08:08:09.597 | HD Request # 31 | Setting DTC encoding to Binary VLS 2024-08-24 08:08:09.597 | HD Request # 31 | Sending historical data logon request message. 2024-08-24 08:08:09.753 | HD Request # 31 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDXS202409_FUT_EUREX 2024-08-24 08:08:09.779 | HD Request # 31 | Decompressing data. 2024-08-24 08:08:09.804 | HD Request # 31 | Receiving Intraday data for FDXSU24-EUREX starting at 2024-08-23 22:03:41.805000 2024-08-24 08:08:09.804 | Socket (2) | CloseSocket call. 2024-08-24 08:08:09.804 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 08:08:09.804 | Historical data download thread signaled to stop. 2024-08-24 08:08:09.804 | HD Request # 31 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 10.1 hours) and wrote 0 records for FDXSU24-EUREX 2024-08-24 08:08:09.806 | HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 08:08:09.806 | HD Request # 31 | Completion time: 0s. 2024-08-24 08:08:09.806 | HD Request # 31 | Intraday data download complete for FDXSU24-EUREX. Unique request ID: 17 2024-08-24 08:08:09.806 | Removing historical data download ID 17. 2024-08-24 08:08:09.806 | Real-time Intraday chart data file updates started for FDXSU24-EUREX 2024-08-24 08:08:09.806 | Intraday chart data file opened for FDXSU24-EUREX 2024-08-24 08:08:09.806 | HD Request # 31 | Enabling Intraday chart updating for symbol. 2024-08-24 08:08:09.806 | 2024-08-24 08:08:09.806 | No download requests in the queue to start downloads for. 2024-08-24 08:08:09.831 | Socket (2) | Socket gracefully closed by remote side. 2024-08-24 08:08:09.831 | Socket (2) | Closed. 2024-08-24 08:08:09.919 | FDXSU24-EUREX [CBV] #8 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:08:09.933 | FDXSU24-EUREX [CBV] #8 | Reloading chart. 2024-08-24 08:08:10.073 | Chart #12 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:08:10.196 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:08:10.196 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:08:10.196 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:08:10.196 | FDXSU24-EUREX [CBV] #7 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:08:10.200 | FDXSU24-EUREX [CBV] #7 | Reloading chart. 2024-08-24 08:08:10.335 | Chart #25 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:08:10.346 | FDXSU24-EUREX [CBV] #2 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:08:10.350 | FDXSU24-EUREX [CBV] #2 | Reloading chart. 2024-08-24 08:08:10.463 | FDXSU24-EUREX [CBV] #8 | Reloading chart. 2024-08-24 08:08:10.765 | FDXSU24-EUREX [CBV] #7 | Reloading chart. 2024-08-24 08:08:11.113 | FDXSU24-EUREX [CBV] #2 | Reloading chart. 2024-08-24 08:08:13.987 | FDXSU24-EUREX [CBV][M] #8 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 08:08:14.515 | FDXSU24-EUREX [CBV][M] #8 | Chart data loading complete. 2024-08-24 08:08:15.462 | FDXSU24-EUREX [CBV][M] #7 | Chart data loading complete. 2024-08-24 08:08:16.011 | Chart #2 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:08:16.011 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:08:16.011 | Chart #2 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:08:16.011 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:08:16.011 | FDXSU24-EUREX [CBV][M] #2 | Chart data loading complete. 2024-08-24 08:08:16.148 | FDXSU24-EUREX [CBV][M] 1 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:10:30.876 | FDXSU24-EUREX [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:10:37.698 | FDXSU24-EUREX [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:10:43.223 | FDXSU24-EUREX [CBV][M] 100 Volume #14 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:10:43.444 | FDXSU24-EUREX [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:10:46.443 | Circular chart reference detected. Charts: 25, 12. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-24 08:57:01.299 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 08:57:01.299 | DTC Client socket (1) | CloseSocket call. 2024-08-24 08:57:01.299 | Denali Data Feed | Disconnected from the server. 2024-08-24 08:57:01.299 | SC Data - All Services | Disconnected. | Number times message added: 1 2024-08-24 08:57:01.299 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:01.325 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:57:01.325 | DTC Client socket (1) | Closed. 2024-08-24 08:57:01.368 | Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 2. 2024-08-24 08:57:01.368 | Current selected Data/Trading service: CQG WebAPI 2024-08-24 08:57:02.060 | Symbol settings MD5 received. Request ID: 2. 2024-08-24 08:57:02.060 | Requested symbol settings for service code cqg. Request ID: 3. 2024-08-24 08:57:02.970 | Symbol settings received. Request ID: 3. 2024-08-24 08:57:09.163 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-08-24 08:57:09.437 | F.US.FDXSU24 [CBV][M] #2 | Reloading chart. 2024-08-24 08:57:09.448 | Added historical Intraday data request for F.US.FDXSZ21 to the queue. 2024-08-24 08:57:09.448 | Triggering next historical data download in queue. 2024-08-24 08:57:09.467 | Added historical Intraday data request for F.US.FDXSH22 to the queue. 2024-08-24 08:57:09.481 | Added historical Intraday data request for F.US.FDXSM22 to the queue. 2024-08-24 08:57:09.496 | Added historical Intraday data request for F.US.FDXSU22 to the queue. 2024-08-24 08:57:09.509 | Added historical Intraday data request for F.US.FDXSZ22 to the queue. 2024-08-24 08:57:09.523 | Added historical Intraday data request for F.US.FDXSH23 to the queue. 2024-08-24 08:57:09.538 | Added historical Intraday data request for F.US.FDXSM23 to the queue. 2024-08-24 08:57:09.551 | Added historical Intraday data request for F.US.FDXSU23 to the queue. 2024-08-24 08:57:09.565 | Added historical Intraday data request for F.US.FDXSZ23 to the queue. 2024-08-24 08:57:09.579 | Added historical Intraday data request for F.US.FDXSH24 to the queue. 2024-08-24 08:57:09.594 | Added historical Intraday data request for F.US.FDXSM24 to the queue. 2024-08-24 08:57:09.601 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 08:57:09.607 | F.US.FDXSU24 [CBV][M] #2 | Performing continuous chart historical Daily data download for symbol F.US.FDXSU24 starting at last date in file. 2024-08-24 08:57:09.607 | Added historical Daily data request for F.US.FDXSU24 to the queue. 2024-08-24 08:57:09.607 | Triggering next historical data download in queue. 2024-08-24 08:57:09.773 | F.US.FDXSU24 [CBV][M] #2 | Waiting for historical downloads to complete with the IDs: 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 2024-08-24 08:57:09.774 | Mapping F.US.FDXSZ21 to FDXS202112_FUT_EUREX. Service code: eurex 2024-08-24 08:57:09.774 | HD Request # 32 | Downloading Intraday chart data for F.US.FDXSZ21 to the file F.US.FDXSZ21.scid. Service: eurex 2024-08-24 08:57:09.774 | HD Request # 32 | Download start date-time: 2021-12-17 12:57:19.000000. File last date-time: 2021-12-17 12:57:19.960000 2024-08-24 08:57:09.774 | HD Request # 32 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:57:09.774 | Mapping F.US.FDXSU24 to FDXS202409_FUT_EUREX. Service code: eurex 2024-08-24 08:57:09.774 | Socket (1) | Creating socket. 2024-08-24 08:57:09.774 | Socket (1) | New receive buffer size: 0 2024-08-24 08:57:09.774 | Socket (1) | Connecting to IP: 149.11.224.18. 2024-08-24 08:57:09.776 | HD Request # 33 | Downloading Historical Daily chart data for F.US.FDXSU24. Starting date: 2024-08-19. Service: cqg 2024-08-24 08:57:09.808 | HD Request # 32 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:09.808 | HD Request # 32 | Sending historical data logon request message. 2024-08-24 08:57:09.813 | F.US.FDXSU24 [CBV][M] #8 | Reloading chart. 2024-08-24 08:57:09.822 | Socket (1) | CloseSocket call. 2024-08-24 08:57:09.822 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:09.836 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:57:09.836 | Socket (1) | Closed. 2024-08-24 08:57:09.996 | F.US.FDXSU24 [CBV][M] #8 | Waiting for historical downloads to complete with the IDs: 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 2024-08-24 08:57:09.996 | HD Request # 32 | Error downloading historical Intraday data for F.US.FDXSZ21. Historical data logon error: Serving data is disabled 2024-08-24 08:57:09.996 | Added historical Intraday data request for F.US.FDXSZ21 to the queue. 2024-08-24 08:57:09.996 | Triggering next historical data download in queue. 2024-08-24 08:57:09.996 | Historical data download thread signaled to stop. 2024-08-24 08:57:09.996 | HD Request # 32 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSZ21 2024-08-24 08:57:09.996 | HD Request # 32 | Completion time: 0s. 2024-08-24 08:57:09.996 | 2024-08-24 08:57:09.996 | HD Request # 34 | Downloading Intraday chart data for F.US.FDXSZ21 to the file F.US.FDXSZ21.scid. Service: eurex 2024-08-24 08:57:09.997 | HD Request # 34 | Download start date-time: 2021-12-17 12:57:19.000000. File last date-time: 2021-12-17 12:57:19.960000 2024-08-24 08:57:09.997 | HD Request # 34 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:57:09.997 | Socket (1) | Creating socket. 2024-08-24 08:57:09.997 | Socket (1) | New receive buffer size: 0 2024-08-24 08:57:09.997 | Socket (1) | Connecting to IP: 176.9.9.252. 2024-08-24 08:57:10.005 | F.US.DDU24 [CBV][M] #10 | Reloading chart. 2024-08-24 08:57:10.013 | Added historical Intraday data request for F.US.DDZ23 to the queue. 2024-08-24 08:57:10.013 | Triggering next historical data download in queue. 2024-08-24 08:57:10.029 | Added historical Intraday data request for F.US.DDH24 to the queue. 2024-08-24 08:57:10.048 | Added historical Intraday data request for F.US.DDM24 to the queue. 2024-08-24 08:57:10.057 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 08:57:10.062 | HD Request # 34 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:10.062 | HD Request # 34 | Sending historical data logon request message. 2024-08-24 08:57:10.066 | F.US.DDU24 [CBV][M] #10 | Performing continuous chart historical Daily data download for symbol F.US.DDU24 starting at last date in file. 2024-08-24 08:57:10.066 | Added historical Daily data request for F.US.DDU24 to the queue. 2024-08-24 08:57:10.066 | Triggering next historical data download in queue. 2024-08-24 08:57:10.120 | F.US.DDU24 [CBV][M] #10 | Waiting for historical downloads to complete with the IDs: 31, 32, 33, 34, 35, 2024-08-24 08:57:10.126 | F.US.FDXSU24 [CBV][M] 1 Min #3 | Reloading chart. 2024-08-24 08:57:10.199 | F.US.FDXSU24 [CBV][M] 1 Min #3 | Waiting for historical downloads to complete with the IDs: 25, 26, 27, 28, 29, 30, 2024-08-24 08:57:10.208 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Reloading chart. 2024-08-24 08:57:10.218 | HD Request # 34 | Requesting Intraday data. Start date-time: 2021-12-17 12:57:19. Record interval: 0. Symbol: FDXS202112_FUT_EUREX 2024-08-24 08:57:10.243 | HD Request # 34 | Decompressing data. 2024-08-24 08:57:10.266 | HD Request # 34 | Receiving Intraday data for F.US.FDXSZ21 starting at 2021-12-17 12:57:19.960000 2024-08-24 08:57:10.266 | Socket (1) | CloseSocket call. 2024-08-24 08:57:10.266 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:10.282 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Waiting for historical downloads to complete with the IDs: 25, 26, 27, 28, 29, 30, 2024-08-24 08:57:10.282 | HD Request # 33 | Requesting historical Daily data for JMU24 starting at 2024-08-18. SC External HD service. 2024-08-24 08:57:10.282 | Historical data download thread signaled to stop. 2024-08-24 08:57:10.282 | HD Request # 34 | Received 1 Intraday data record from 2021-12-17 12:57:19.960000 to 2021-12-17 12:57:19.960000 (0.0 seconds. Delay: 2.7 years) and wrote 0 records for F.US.FDXSZ21 2024-08-24 08:57:10.282 | HD Request # 34 | Completion time: 1s. 2024-08-24 08:57:10.282 | HD Request # 34 | Intraday data download complete for F.US.FDXSZ21. Unique request ID: 18 2024-08-24 08:57:10.282 | Removing historical data download ID 18. 2024-08-24 08:57:10.282 | Real-time Intraday chart data file updates started for F.US.FDXSZ21 2024-08-24 08:57:10.282 | Intraday chart data file opened for F.US.FDXSZ21 2024-08-24 08:57:10.282 | HD Request # 34 | Enabling Intraday chart updating for symbol. 2024-08-24 08:57:10.282 | 2024-08-24 08:57:10.282 | Triggering next historical data download in queue. 2024-08-24 08:57:10.282 | Historical data for F.US.FDXSZ21 is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:57:10.282 | Mapping F.US.FDXSH22 to FDXS202203_FUT_EUREX. Service code: eurex 2024-08-24 08:57:10.282 | HD Request # 35 | Downloading Intraday chart data for F.US.FDXSH22 to the file F.US.FDXSH22.scid. Service: eurex 2024-08-24 08:57:10.283 | HD Request # 35 | Download start date-time: 2022-03-18 12:59:39.000000. File last date-time: 2022-03-18 12:59:39.526000 2024-08-24 08:57:10.283 | HD Request # 35 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:57:10.283 | Socket (4) | Creating socket. 2024-08-24 08:57:10.283 | Socket (4) | New receive buffer size: 0 2024-08-24 08:57:10.283 | Socket (4) | Connecting to IP: 149.11.224.18. 2024-08-24 08:57:10.296 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:57:10.296 | Socket (1) | Closed. 2024-08-24 08:57:10.303 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Reloading chart. 2024-08-24 08:57:10.315 | HD Request # 35 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:10.315 | HD Request # 35 | Sending historical data logon request message. 2024-08-24 08:57:10.329 | Socket (4) | CloseSocket call. 2024-08-24 08:57:10.329 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:10.331 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Waiting for historical downloads to complete with the IDs: 28, 29, 30, 2024-08-24 08:57:10.331 | HD Request # 35 | Error downloading historical Intraday data for F.US.FDXSH22. Historical data logon error: Serving data is disabled 2024-08-24 08:57:10.331 | Added historical Intraday data request for F.US.FDXSH22 to the queue. 2024-08-24 08:57:10.331 | Triggering next historical data download in queue. 2024-08-24 08:57:10.331 | Historical data download thread signaled to stop. 2024-08-24 08:57:10.331 | HD Request # 35 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSH22 2024-08-24 08:57:10.331 | HD Request # 35 | Completion time: 0s. 2024-08-24 08:57:10.331 | 2024-08-24 08:57:10.331 | HD Request # 36 | Downloading Intraday chart data for F.US.FDXSH22 to the file F.US.FDXSH22.scid. Service: eurex 2024-08-24 08:57:10.331 | HD Request # 36 | Download start date-time: 2022-03-18 12:59:39.000000. File last date-time: 2022-03-18 12:59:39.526000 2024-08-24 08:57:10.332 | HD Request # 36 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:57:10.332 | Socket (1) | Creating socket. 2024-08-24 08:57:10.332 | Socket (1) | New receive buffer size: 0 2024-08-24 08:57:10.332 | Socket (1) | Connecting to IP: 176.9.9.252. 2024-08-24 08:57:10.332 | F.US.FDXSU24 [CBV][M] 10000 Volume #16 | Reloading chart. 2024-08-24 08:57:10.346 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 08:57:10.346 | Socket (4) | Closed. 2024-08-24 08:57:10.375 | F.US.FDXSU24 [CBV][M] 10000 Volume #16 | Waiting for historical downloads to complete with the IDs: 27, 28, 29, 30, 2024-08-24 08:57:10.376 | F.US.FDXSU24 [CBV][M] 25000 Volume #13 | Reloading chart. 2024-08-24 08:57:10.388 | HD Request # 36 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:10.388 | HD Request # 36 | Sending historical data logon request message. 2024-08-24 08:57:10.412 | HD Request # 36 | Requesting Intraday data. Start date-time: 2022-03-18 12:59:39. Record interval: 0. Symbol: FDXS202203_FUT_EUREX 2024-08-24 08:57:10.435 | F.US.FDXSU24 [CBV][M] 25000 Volume #13 | Waiting for historical downloads to complete with the IDs: 26, 27, 28, 29, 30, 2024-08-24 08:57:10.438 | HD Request # 36 | Decompressing data. 2024-08-24 08:57:10.438 | F.US.FDXSU24 [CBV][M] #4 | Reloading chart. 2024-08-24 08:57:10.462 | HD Request # 36 | Receiving Intraday data for F.US.FDXSH22 starting at 2022-03-18 12:59:39.526000 2024-08-24 08:57:10.462 | Socket (1) | CloseSocket call. 2024-08-24 08:57:10.462 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:10.488 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:57:10.488 | Socket (1) | Closed. 2024-08-24 08:57:10.513 | F.US.FDXSU24 [CBV][M] #4 | Waiting for historical downloads to complete with the IDs: 25, 26, 27, 28, 29, 30, 2024-08-24 08:57:10.513 | Historical data download thread signaled to stop. 2024-08-24 08:57:10.513 | HD Request # 36 | Received 1 Intraday data record from 2022-03-18 12:59:39.526000 to 2022-03-18 12:59:39.526000 (0.0 seconds. Delay: 2.4 years) and wrote 0 records for F.US.FDXSH22 2024-08-24 08:57:10.513 | HD Request # 36 | Completion time: 0s. 2024-08-24 08:57:10.513 | HD Request # 36 | Intraday data download complete for F.US.FDXSH22. Unique request ID: 19 2024-08-24 08:57:10.513 | Removing historical data download ID 19. 2024-08-24 08:57:10.513 | Real-time Intraday chart data file updates started for F.US.FDXSH22 2024-08-24 08:57:10.513 | Intraday chart data file opened for F.US.FDXSH22 2024-08-24 08:57:10.513 | HD Request # 36 | Enabling Intraday chart updating for symbol. 2024-08-24 08:57:10.513 | 2024-08-24 08:57:10.513 | Triggering next historical data download in queue. 2024-08-24 08:57:10.513 | Historical data for F.US.FDXSH22 is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:57:10.513 | HD Request # 33 | Receiving historical Daily data for F.US.FDXSU24 starting at 2024-08-19. 2024-08-24 08:57:10.513 | HD Request # 33 | Writing historical Daily data to the file F.US.FDXSU24.dly. 2024-08-24 08:57:10.514 | HD Request # 33 | Bytes received: 260 2024-08-24 08:57:10.514 | HD Request # 33 | Received 5 Daily data records from 2024-08-19 00:00:00 to 2024-08-23 00:00:00 (5.0 days) and wrote 5 records for F.US.FDXSU24 2024-08-24 08:57:10.515 | HD Request # 33 | Completion time: 1s. 2024-08-24 08:57:10.515 | HD Request # 33 | Daily data download complete for F.US.FDXSU24. Unique request ID: 30 2024-08-24 08:57:10.515 | Removing historical data download ID 30. 2024-08-24 08:57:10.515 | 2024-08-24 08:57:10.515 | Triggering next historical data download in queue. 2024-08-24 08:57:10.515 | Mapping F.US.FDXSM22 to FDXS202206_FUT_EUREX. Service code: eurex 2024-08-24 08:57:10.515 | HD Request # 37 | Downloading Intraday chart data for F.US.FDXSM22 to the file F.US.FDXSM22.scid. Service: eurex 2024-08-24 08:57:10.515 | HD Request # 37 | Download start date-time: 2022-06-17 12:57:27.000000. File last date-time: 2022-06-17 12:57:27.541000 2024-08-24 08:57:10.515 | HD Request # 37 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:57:10.515 | Mapping F.US.DDU24 to FDAX202409_FUT_EUREX. Service code: eurex 2024-08-24 08:57:10.515 | Socket (1) | Creating socket. 2024-08-24 08:57:10.515 | Socket (1) | New receive buffer size: 0 2024-08-24 08:57:10.515 | Socket (1) | Connecting to IP: 149.11.224.18. 2024-08-24 08:57:10.517 | HD Request # 38 | Downloading Historical Daily chart data for F.US.DDU24. Starting date: 2024-08-19. Service: cqg 2024-08-24 08:57:10.520 | F.US.FDXSU24 [CBV][M] #18 | Reloading chart. 2024-08-24 08:57:10.549 | HD Request # 37 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:10.549 | HD Request # 37 | Sending historical data logon request message. 2024-08-24 08:57:10.563 | Socket (1) | CloseSocket call. 2024-08-24 08:57:10.563 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:10.577 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:57:10.577 | Socket (1) | Closed. 2024-08-24 08:57:10.595 | F.US.FDXSU24 [CBV][M] #18 | Waiting for historical downloads to complete with the IDs: 25, 26, 27, 28, 29, 2024-08-24 08:57:10.596 | HD Request # 37 | Error downloading historical Intraday data for F.US.FDXSM22. Historical data logon error: Serving data is disabled 2024-08-24 08:57:10.596 | Added historical Intraday data request for F.US.FDXSM22 to the queue. 2024-08-24 08:57:10.596 | Triggering next historical data download in queue. 2024-08-24 08:57:10.597 | Historical data download thread signaled to stop. 2024-08-24 08:57:10.597 | HD Request # 37 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSM22 2024-08-24 08:57:10.597 | HD Request # 37 | Completion time: 0s. 2024-08-24 08:57:10.597 | 2024-08-24 08:57:10.597 | HD Request # 39 | Downloading Intraday chart data for F.US.FDXSM22 to the file F.US.FDXSM22.scid. Service: eurex 2024-08-24 08:57:10.597 | HD Request # 39 | Download start date-time: 2022-06-17 12:57:27.000000. File last date-time: 2022-06-17 12:57:27.541000 2024-08-24 08:57:10.597 | HD Request # 39 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:57:10.597 | Socket (1) | Creating socket. 2024-08-24 08:57:10.597 | Socket (1) | New receive buffer size: 0 2024-08-24 08:57:10.597 | Socket (1) | Connecting to IP: 176.9.9.252. 2024-08-24 08:57:10.599 | F.US.FDXSU24 [CBV][M] #1 | Reloading chart. 2024-08-24 08:57:10.654 | HD Request # 39 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:10.654 | HD Request # 39 | Sending historical data logon request message. 2024-08-24 08:57:10.678 | HD Request # 39 | Requesting Intraday data. Start date-time: 2022-06-17 12:57:27. Record interval: 0. Symbol: FDXS202206_FUT_EUREX 2024-08-24 08:57:10.702 | HD Request # 39 | Decompressing data. 2024-08-24 08:57:10.725 | HD Request # 39 | Receiving Intraday data for F.US.FDXSM22 starting at 2022-06-17 12:57:27.541000 2024-08-24 08:57:10.725 | Socket (1) | CloseSocket call. 2024-08-24 08:57:10.725 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:10.750 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:57:10.750 | Socket (1) | Closed. 2024-08-24 08:57:10.763 | Historical data download thread signaled to stop. 2024-08-24 08:57:10.763 | HD Request # 39 | Received 1 Intraday data record from 2022-06-17 12:57:27.541000 to 2022-06-17 12:57:27.541000 (0.0 seconds. Delay: 2.2 years) and wrote 0 records for F.US.FDXSM22 2024-08-24 08:57:10.763 | HD Request # 39 | Completion time: 0s. 2024-08-24 08:57:10.763 | HD Request # 39 | Intraday data download complete for F.US.FDXSM22. Unique request ID: 20 2024-08-24 08:57:10.763 | Removing historical data download ID 20. 2024-08-24 08:57:10.763 | Real-time Intraday chart data file updates started for F.US.FDXSM22 2024-08-24 08:57:10.763 | Intraday chart data file opened for F.US.FDXSM22 2024-08-24 08:57:10.763 | HD Request # 39 | Enabling Intraday chart updating for symbol. 2024-08-24 08:57:10.763 | 2024-08-24 08:57:10.763 | Triggering next historical data download in queue. 2024-08-24 08:57:10.763 | Historical data for F.US.FDXSM22 is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:57:10.764 | Mapping F.US.FDXSU22 to FDXS202209_FUT_EUREX. Service code: eurex 2024-08-24 08:57:10.764 | HD Request # 40 | Downloading Intraday chart data for F.US.FDXSU22 to the file F.US.FDXSU22.scid. Service: eurex 2024-08-24 08:57:10.764 | HD Request # 40 | Download start date-time: 2022-09-16 12:59:53.000000. File last date-time: 2022-09-16 12:59:53.075000 2024-08-24 08:57:10.764 | HD Request # 40 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:57:10.764 | Socket (1) | Creating socket. 2024-08-24 08:57:10.764 | Socket (1) | New receive buffer size: 0 2024-08-24 08:57:10.764 | Socket (1) | Connecting to IP: 149.11.224.18. 2024-08-24 08:57:10.766 | F.US.FDXSU24 [CBV][M] Daily #6 | Reloading chart. 2024-08-24 08:57:10.793 | HD Request # 40 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:10.793 | HD Request # 40 | Sending historical data logon request message. 2024-08-24 08:57:10.805 | F.US.FDXSU24 [CBV][M] Daily #6 | Performing continuous chart historical Daily data download for symbol F.US.FDXSM21 starting at 2021-03-18. 2024-08-24 08:57:10.805 | Added historical Daily data request for F.US.FDXSM21 to the queue. 2024-08-24 08:57:10.814 | Triggering next historical data download in queue. 2024-08-24 08:57:10.814 | Socket (1) | CloseSocket call. 2024-08-24 08:57:10.814 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:10.828 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:57:10.828 | Socket (1) | Closed. 2024-08-24 08:57:11.053 | F.US.FDXSU24 [CBV][M] Daily #6 | Dates not found while checking for invalid data in continuous contract data files. F.US.FDXSM21 * 2024-08-24 08:57:11.053 | F.US.FDXSU24 [CBV][M] Daily #6 | Waiting for historical downloads to complete with the IDs: 36, 2024-08-24 08:57:11.055 | F.US.FDXSU24 [CBV][M] #1 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 08:57:11.064 | F.US.FDXSU24 [CBV][M] #1 | Chart data loading complete. 2024-08-24 08:57:11.064 | HD Request # 40 | Error downloading historical Intraday data for F.US.FDXSU22. Historical data logon error: Serving data is disabled 2024-08-24 08:57:11.064 | Added historical Intraday data request for F.US.FDXSU22 to the queue. 2024-08-24 08:57:11.064 | Triggering next historical data download in queue. 2024-08-24 08:57:11.064 | Historical data download thread signaled to stop. 2024-08-24 08:57:11.064 | HD Request # 40 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSU22 2024-08-24 08:57:11.064 | HD Request # 40 | Completion time: 1s. 2024-08-24 08:57:11.064 | 2024-08-24 08:57:11.064 | HD Request # 38 | Requesting historical Daily data for DYU24 starting at 2024-08-18. SC External HD service. 2024-08-24 08:57:11.073 | HD Request # 41 | Downloading Intraday chart data for F.US.FDXSU22 to the file F.US.FDXSU22.scid. Service: eurex 2024-08-24 08:57:11.074 | HD Request # 41 | Download start date-time: 2022-09-16 12:59:53.000000. File last date-time: 2022-09-16 12:59:53.075000 2024-08-24 08:57:11.074 | HD Request # 41 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:57:11.074 | Socket (5) | Creating socket. 2024-08-24 08:57:11.074 | Socket (5) | New receive buffer size: 0 2024-08-24 08:57:11.074 | Socket (5) | Connecting to IP: 176.9.9.252. 2024-08-24 08:57:11.076 | F.US.FDXSU24 [CBV][M] #11 | Reloading chart. 2024-08-24 08:57:11.126 | HD Request # 41 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:11.126 | HD Request # 41 | Sending historical data logon request message. 2024-08-24 08:57:11.150 | HD Request # 41 | Requesting Intraday data. Start date-time: 2022-09-16 12:59:53. Record interval: 0. Symbol: FDXS202209_FUT_EUREX 2024-08-24 08:57:11.174 | HD Request # 41 | Decompressing data. 2024-08-24 08:57:11.197 | HD Request # 41 | Receiving Intraday data for F.US.FDXSU22 starting at 2022-09-16 12:59:53.075000 2024-08-24 08:57:11.197 | Socket (5) | CloseSocket call. 2024-08-24 08:57:11.197 | Socket (5) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:11.221 | Socket (5) | Socket gracefully closed by remote side. 2024-08-24 08:57:11.221 | Socket (5) | Closed. 2024-08-24 08:57:11.298 | F.US.FDXSU24 [CBV][M] #11 | Dates not found while checking for invalid data in continuous contract data files. F.US.FDXSM21 * 2024-08-24 08:57:11.298 | F.US.FDXSU24 [CBV][M] #11 | Waiting for historical downloads to complete with the IDs: 36, 2024-08-24 08:57:11.298 | Historical data download thread signaled to stop. 2024-08-24 08:57:11.298 | HD Request # 41 | Received 1 Intraday data record from 2022-09-16 12:59:53.075000 to 2022-09-16 12:59:53.075000 (0.0 seconds. Delay: 707.8 days) and wrote 0 records for F.US.FDXSU22 2024-08-24 08:57:11.298 | HD Request # 41 | Completion time: 0s. 2024-08-24 08:57:11.298 | HD Request # 41 | Intraday data download complete for F.US.FDXSU22. Unique request ID: 21 2024-08-24 08:57:11.298 | Removing historical data download ID 21. 2024-08-24 08:57:11.298 | Real-time Intraday chart data file updates started for F.US.FDXSU22 2024-08-24 08:57:11.298 | Intraday chart data file opened for F.US.FDXSU22 2024-08-24 08:57:11.298 | HD Request # 41 | Enabling Intraday chart updating for symbol. 2024-08-24 08:57:11.298 | 2024-08-24 08:57:11.298 | Triggering next historical data download in queue. 2024-08-24 08:57:11.298 | Historical data for F.US.FDXSU22 is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:57:11.298 | Mapping F.US.FDXSZ22 to FDXS202212_FUT_EUREX. Service code: eurex 2024-08-24 08:57:11.298 | HD Request # 42 | Downloading Intraday chart data for F.US.FDXSZ22 to the file F.US.FDXSZ22.scid. Service: eurex 2024-08-24 08:57:11.298 | HD Request # 42 | Download start date-time: 2022-12-16 12:57:36.000000. File last date-time: 2022-12-16 12:57:36.094000 2024-08-24 08:57:11.298 | HD Request # 42 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:57:11.298 | Socket (5) | Creating socket. 2024-08-24 08:57:11.298 | Socket (5) | New receive buffer size: 0 2024-08-24 08:57:11.298 | Socket (5) | Connecting to IP: 149.11.224.18. 2024-08-24 08:57:11.300 | F.US.FDXSU24 [CBV][M] Daily #5 | Reloading chart. 2024-08-24 08:57:11.329 | HD Request # 42 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:11.329 | HD Request # 42 | Sending historical data logon request message. 2024-08-24 08:57:11.343 | Socket (5) | CloseSocket call. 2024-08-24 08:57:11.343 | Socket (5) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:11.357 | Socket (5) | Socket gracefully closed by remote side. 2024-08-24 08:57:11.357 | Socket (5) | Closed. 2024-08-24 08:57:11.518 | F.US.FDXSU24 [CBV][M] Daily #5 | Dates not found while checking for invalid data in continuous contract data files. F.US.FDXSM21 * 2024-08-24 08:57:11.518 | F.US.FDXSU24 [CBV][M] Daily #5 | Waiting for historical downloads to complete with the IDs: 36, 2024-08-24 08:57:11.518 | HD Request # 42 | Error downloading historical Intraday data for F.US.FDXSZ22. Historical data logon error: Serving data is disabled 2024-08-24 08:57:11.518 | Added historical Intraday data request for F.US.FDXSZ22 to the queue. 2024-08-24 08:57:11.518 | Triggering next historical data download in queue. 2024-08-24 08:57:11.518 | Historical data download thread signaled to stop. 2024-08-24 08:57:11.518 | HD Request # 42 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSZ22 2024-08-24 08:57:11.518 | HD Request # 42 | Completion time: 0s. 2024-08-24 08:57:11.518 | 2024-08-24 08:57:11.518 | HD Request # 38 | Receiving historical Daily data for F.US.DDU24 starting at 2024-08-19. 2024-08-24 08:57:11.518 | HD Request # 38 | Writing historical Daily data to the file F.US.DDU24.dly. 2024-08-24 08:57:11.523 | HD Request # 38 | Bytes received: 265 2024-08-24 08:57:11.523 | HD Request # 38 | Received 5 Daily data records from 2024-08-19 00:00:00 to 2024-08-23 00:00:00 (5.0 days) and wrote 5 records for F.US.DDU24 2024-08-24 08:57:11.524 | HD Request # 38 | Completion time: 1s. 2024-08-24 08:57:11.524 | HD Request # 38 | Daily data download complete for F.US.DDU24. Unique request ID: 35 2024-08-24 08:57:11.524 | Removing historical data download ID 35. 2024-08-24 08:57:11.524 | 2024-08-24 08:57:11.524 | Triggering next historical data download in queue. 2024-08-24 08:57:11.524 | HD Request # 43 | Downloading Intraday chart data for F.US.FDXSZ22 to the file F.US.FDXSZ22.scid. Service: eurex 2024-08-24 08:57:11.524 | HD Request # 43 | Download start date-time: 2022-12-16 12:57:36.000000. File last date-time: 2022-12-16 12:57:36.094000 2024-08-24 08:57:11.524 | HD Request # 43 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:57:11.524 | Mapping F.US.FDXSM21 to FDXS202106_FUT_EUREX. Service code: eurex 2024-08-24 08:57:11.524 | Socket (5) | Creating socket. 2024-08-24 08:57:11.524 | HD Request # 44 | Downloading Historical Daily chart data for F.US.FDXSM21. Starting date: 2021-03-18. Service: cqg 2024-08-24 08:57:11.524 | Socket (5) | New receive buffer size: 0 2024-08-24 08:57:11.524 | Socket (5) | Connecting to IP: 176.9.9.252. 2024-08-24 08:57:11.529 | F.US.FDXSU24 [CBV][M] #7 | Reloading chart. 2024-08-24 08:57:11.575 | HD Request # 43 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:11.575 | HD Request # 43 | Sending historical data logon request message. 2024-08-24 08:57:11.599 | HD Request # 43 | Requesting Intraday data. Start date-time: 2022-12-16 12:57:36. Record interval: 0. Symbol: FDXS202212_FUT_EUREX 2024-08-24 08:57:11.624 | HD Request # 43 | Decompressing data. 2024-08-24 08:57:11.647 | HD Request # 43 | Receiving Intraday data for F.US.FDXSZ22 starting at 2022-12-16 12:57:36.094000 2024-08-24 08:57:11.647 | Socket (5) | CloseSocket call. 2024-08-24 08:57:11.647 | Socket (5) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:11.672 | Socket (5) | Socket gracefully closed by remote side. 2024-08-24 08:57:11.672 | Socket (5) | Closed. 2024-08-24 08:57:11.716 | F.US.FDXSU24 [CBV][M] #7 | Waiting for historical downloads to complete with the IDs: 22, 23, 24, 25, 26, 27, 28, 29, 2024-08-24 08:57:11.716 | Historical data download thread signaled to stop. 2024-08-24 08:57:11.716 | HD Request # 43 | Received 1 Intraday data record from 2022-12-16 12:57:36.094000 to 2022-12-16 12:57:36.094000 (0.0 seconds. Delay: 616.8 days) and wrote 0 records for F.US.FDXSZ22 2024-08-24 08:57:11.716 | HD Request # 43 | Completion time: 0s. 2024-08-24 08:57:11.716 | HD Request # 43 | Intraday data download complete for F.US.FDXSZ22. Unique request ID: 22 2024-08-24 08:57:11.716 | Removing historical data download ID 22. 2024-08-24 08:57:11.716 | Real-time Intraday chart data file updates started for F.US.FDXSZ22 2024-08-24 08:57:11.716 | Intraday chart data file opened for F.US.FDXSZ22 2024-08-24 08:57:11.716 | HD Request # 43 | Enabling Intraday chart updating for symbol. 2024-08-24 08:57:11.716 | 2024-08-24 08:57:11.716 | Triggering next historical data download in queue. 2024-08-24 08:57:11.716 | Historical data for F.US.FDXSZ22 is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:57:11.716 | Mapping F.US.FDXSH23 to FDXS202303_FUT_EUREX. Service code: eurex 2024-08-24 08:57:11.716 | HD Request # 45 | Downloading Intraday chart data for F.US.FDXSH23 to the file F.US.FDXSH23.scid. Service: eurex 2024-08-24 08:57:11.716 | HD Request # 45 | Download start date-time: 2023-03-17 12:58:00.000000. File last date-time: 2023-03-17 12:58:00.041000 2024-08-24 08:57:11.716 | HD Request # 45 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:57:11.716 | Socket (5) | Creating socket. 2024-08-24 08:57:11.716 | Socket (5) | New receive buffer size: 0 2024-08-24 08:57:11.716 | Socket (5) | Connecting to IP: 149.11.224.18. 2024-08-24 08:57:11.725 | F.US.FDXSU24 [CBV][M] 1200 Volume #21 | Reloading chart. 2024-08-24 08:57:11.745 | HD Request # 45 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:11.745 | HD Request # 45 | Sending historical data logon request message. 2024-08-24 08:57:11.754 | F.US.FDXSU24 [CBV][M] 1200 Volume #21 | Waiting for historical downloads to complete with the IDs: 28, 29, 2024-08-24 08:57:11.758 | F.US.DDU24 [CBV][M] #15 | Reloading chart. 2024-08-24 08:57:11.759 | Socket (5) | CloseSocket call. 2024-08-24 08:57:11.759 | Socket (5) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:11.773 | Socket (5) | Socket gracefully closed by remote side. 2024-08-24 08:57:11.773 | Socket (5) | Closed. 2024-08-24 08:57:11.820 | F.US.DDU24 [CBV][M] #15 | Waiting for historical downloads to complete with the IDs: 31, 32, 33, 34, 2024-08-24 08:57:11.820 | HD Request # 45 | Error downloading historical Intraday data for F.US.FDXSH23. Historical data logon error: Serving data is disabled 2024-08-24 08:57:11.820 | Added historical Intraday data request for F.US.FDXSH23 to the queue. 2024-08-24 08:57:11.820 | Triggering next historical data download in queue. 2024-08-24 08:57:11.820 | Historical data download thread signaled to stop. 2024-08-24 08:57:11.820 | HD Request # 45 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSH23 2024-08-24 08:57:11.820 | HD Request # 45 | Completion time: 0s. 2024-08-24 08:57:11.820 | 2024-08-24 08:57:11.820 | HD Request # 46 | Downloading Intraday chart data for F.US.FDXSH23 to the file F.US.FDXSH23.scid. Service: eurex 2024-08-24 08:57:11.821 | HD Request # 46 | Download start date-time: 2023-03-17 12:58:00.000000. File last date-time: 2023-03-17 12:58:00.041000 2024-08-24 08:57:11.821 | HD Request # 46 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:57:11.821 | Socket (5) | Creating socket. 2024-08-24 08:57:11.821 | Socket (5) | New receive buffer size: 0 2024-08-24 08:57:11.821 | Socket (5) | Connecting to IP: 176.9.9.252. 2024-08-24 08:57:11.828 | F.US.FDXSU24 [CBV][M] 100 Volume #14 | Reloading chart. 2024-08-24 08:57:11.874 | HD Request # 46 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:11.874 | HD Request # 46 | Sending historical data logon request message. 2024-08-24 08:57:11.900 | HD Request # 46 | Requesting Intraday data. Start date-time: 2023-03-17 12:58:00. Record interval: 0. Symbol: FDXS202303_FUT_EUREX 2024-08-24 08:57:11.906 | F.US.FDXSU24 [CBV][M] 100 Volume #14 | Waiting for historical downloads to complete with the IDs: 25, 26, 27, 28, 29, 2024-08-24 08:57:11.925 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Reloading chart. 2024-08-24 08:57:11.925 | HD Request # 46 | Decompressing data. 2024-08-24 08:57:11.949 | HD Request # 46 | Receiving Intraday data for F.US.FDXSH23 starting at 2023-03-17 12:58:00.041000 2024-08-24 08:57:11.949 | Socket (5) | CloseSocket call. 2024-08-24 08:57:11.949 | Socket (5) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:11.954 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Waiting for historical downloads to complete with the IDs: 28, 29, 2024-08-24 08:57:11.954 | Historical data download thread signaled to stop. 2024-08-24 08:57:11.954 | HD Request # 46 | Received 1 Intraday data record from 2023-03-17 12:58:00.041000 to 2023-03-17 12:58:00.041000 (0.0 seconds. Delay: 525.8 days) and wrote 0 records for F.US.FDXSH23 2024-08-24 08:57:11.954 | HD Request # 46 | Completion time: 0s. 2024-08-24 08:57:11.954 | HD Request # 46 | Intraday data download complete for F.US.FDXSH23. Unique request ID: 23 2024-08-24 08:57:11.954 | Removing historical data download ID 23. 2024-08-24 08:57:11.954 | Real-time Intraday chart data file updates started for F.US.FDXSH23 2024-08-24 08:57:11.954 | Intraday chart data file opened for F.US.FDXSH23 2024-08-24 08:57:11.954 | HD Request # 46 | Enabling Intraday chart updating for symbol. 2024-08-24 08:57:11.954 | 2024-08-24 08:57:11.954 | Triggering next historical data download in queue. 2024-08-24 08:57:11.954 | Historical data for F.US.FDXSH23 is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:57:11.954 | Mapping F.US.FDXSM23 to FDXS202306_FUT_EUREX. Service code: eurex 2024-08-24 08:57:11.954 | HD Request # 47 | Downloading Intraday chart data for F.US.FDXSM23 to the file F.US.FDXSM23.scid. Service: eurex 2024-08-24 08:57:11.954 | HD Request # 47 | Download start date-time: 2023-06-16 12:59:52.000000. File last date-time: 2023-06-16 12:59:52.501000 2024-08-24 08:57:11.954 | HD Request # 47 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:57:11.954 | Socket (7) | Creating socket. 2024-08-24 08:57:11.954 | Socket (7) | New receive buffer size: 0 2024-08-24 08:57:11.954 | Socket (7) | Connecting to IP: 149.11.224.18. 2024-08-24 08:57:11.956 | HD Request # 44 | Requesting historical Daily data for JMM21 starting at 2021-03-17. SC External HD service. 2024-08-24 08:57:11.956 | 2024-08-24 08:57:11.956 | CQG WebAPI | Connecting to server api.cqg.com 2024-08-24 08:57:11.956 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-08-24 08:57:11.975 | Socket (5) | Socket gracefully closed by remote side. 2024-08-24 08:57:11.975 | Socket (5) | Closed. 2024-08-24 08:57:11.984 | HD Request # 47 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:11.984 | HD Request # 47 | Sending historical data logon request message. 2024-08-24 08:57:11.997 | Socket (7) | CloseSocket call. 2024-08-24 08:57:11.997 | HD Request # 47 | Error downloading historical Intraday data for F.US.FDXSM23. Historical data logon error: Serving data is disabled 2024-08-24 08:57:11.997 | Socket (7) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:11.997 | Added historical Intraday data request for F.US.FDXSM23 to the queue. 2024-08-24 08:57:11.997 | Triggering next historical data download in queue. 2024-08-24 08:57:11.997 | Historical data download thread signaled to stop. 2024-08-24 08:57:11.997 | HD Request # 47 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSM23 2024-08-24 08:57:11.997 | HD Request # 47 | Completion time: 0s. 2024-08-24 08:57:11.997 | 2024-08-24 08:57:11.997 | HD Request # 48 | Downloading Intraday chart data for F.US.FDXSM23 to the file F.US.FDXSM23.scid. Service: eurex 2024-08-24 08:57:11.997 | HD Request # 48 | Download start date-time: 2023-06-16 12:59:52.000000. File last date-time: 2023-06-16 12:59:52.501000 2024-08-24 08:57:11.998 | HD Request # 48 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:57:11.998 | Socket (1) | Creating socket. 2024-08-24 08:57:11.998 | Socket (1) | New receive buffer size: 0 2024-08-24 08:57:11.998 | Socket (1) | Connecting to IP: 176.9.9.252. 2024-08-24 08:57:12.019 | Socket (7) | Socket gracefully closed by remote side. 2024-08-24 08:57:12.019 | Socket (7) | Closed. 2024-08-24 08:57:12.058 | HD Request # 48 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:12.058 | HD Request # 48 | Sending historical data logon request message. 2024-08-24 08:57:12.061 | HD Request # 44 | Receiving historical Daily data for F.US.FDXSM21 starting at 2021-04-30. 2024-08-24 08:57:12.062 | HD Request # 44 | Writing historical Daily data to the file F.US.FDXSM21.dly. 2024-08-24 08:57:12.062 | HD Request # 44 | Bytes received: 1829 2024-08-24 08:57:12.062 | HD Request # 44 | Received 36 Daily data records from 2021-04-30 00:00:00 to 2021-06-18 00:00:00 (50.0 days) and wrote 36 records for F.US.FDXSM21 2024-08-24 08:57:12.063 | HD Request # 44 | Completion time: 1s. 2024-08-24 08:57:12.063 | HD Request # 44 | Daily data download complete for F.US.FDXSM21. Unique request ID: 36 2024-08-24 08:57:12.063 | Removing historical data download ID 36. 2024-08-24 08:57:12.063 | 2024-08-24 08:57:12.063 | No download requests in the queue to start downloads for. 2024-08-24 08:57:12.076 | F.US.FDXSU24 [CBV][M] #11 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:57:12.081 | F.US.FDXSU24 [CBV][M] #11 | Reloading chart. 2024-08-24 08:57:12.082 | Unable to determine transition date based on volume from files: F.US.FDXSU12.dly, F.US.FDXSZ12.dly 2024-08-24 08:57:12.082 | The F.US.FDXSZ12.dly symbol may not be the active contract month. 2024-08-24 08:57:12.082 | HD Request # 48 | Requesting Intraday data. Start date-time: 2023-06-16 12:59:52. Record interval: 0. Symbol: FDXS202306_FUT_EUREX 2024-08-24 08:57:12.082 | Unable to determine transition date based on volume from files: F.US.FDXSZ12.dly, F.US.FDXSH13.dly 2024-08-24 08:57:12.082 | The F.US.FDXSH13.dly symbol may not be the active contract month. 2024-08-24 08:57:12.083 | Unable to determine transition date based on volume from files: F.US.FDXSH13.dly, F.US.FDXSM13.dly 2024-08-24 08:57:12.083 | The F.US.FDXSM13.dly symbol may not be the active contract month. 2024-08-24 08:57:12.084 | Unable to determine transition date based on volume from files: F.US.FDXSM13.dly, F.US.FDXSU13.dly 2024-08-24 08:57:12.084 | The F.US.FDXSU13.dly symbol may not be the active contract month. 2024-08-24 08:57:12.084 | Unable to determine transition date based on volume from files: F.US.FDXSU13.dly, F.US.FDXSZ13.dly 2024-08-24 08:57:12.084 | The F.US.FDXSZ13.dly symbol may not be the active contract month. 2024-08-24 08:57:12.085 | Unable to determine transition date based on volume from files: F.US.FDXSZ13.dly, F.US.FDXSH14.dly 2024-08-24 08:57:12.085 | The F.US.FDXSH14.dly symbol may not be the active contract month. 2024-08-24 08:57:12.085 | Unable to determine transition date based on volume from files: F.US.FDXSH14.dly, F.US.FDXSM14.dly 2024-08-24 08:57:12.085 | The F.US.FDXSM14.dly symbol may not be the active contract month. 2024-08-24 08:57:12.086 | Unable to determine transition date based on volume from files: F.US.FDXSM14.dly, F.US.FDXSU14.dly 2024-08-24 08:57:12.086 | The F.US.FDXSU14.dly symbol may not be the active contract month. 2024-08-24 08:57:12.087 | Unable to determine transition date based on volume from files: F.US.FDXSU14.dly, F.US.FDXSZ14.dly 2024-08-24 08:57:12.087 | The F.US.FDXSZ14.dly symbol may not be the active contract month. 2024-08-24 08:57:12.087 | Unable to determine transition date based on volume from files: F.US.FDXSZ14.dly, F.US.FDXSH15.dly 2024-08-24 08:57:12.087 | The F.US.FDXSH15.dly symbol may not be the active contract month. 2024-08-24 08:57:12.088 | Unable to determine transition date based on volume from files: F.US.FDXSH15.dly, F.US.FDXSM15.dly 2024-08-24 08:57:12.088 | The F.US.FDXSM15.dly symbol may not be the active contract month. 2024-08-24 08:57:12.089 | Unable to determine transition date based on volume from files: F.US.FDXSM15.dly, F.US.FDXSU15.dly 2024-08-24 08:57:12.089 | The F.US.FDXSU15.dly symbol may not be the active contract month. 2024-08-24 08:57:12.089 | Unable to determine transition date based on volume from files: F.US.FDXSU15.dly, F.US.FDXSZ15.dly 2024-08-24 08:57:12.089 | The F.US.FDXSZ15.dly symbol may not be the active contract month. 2024-08-24 08:57:12.090 | Unable to determine transition date based on volume from files: F.US.FDXSZ15.dly, F.US.FDXSH16.dly 2024-08-24 08:57:12.090 | The F.US.FDXSH16.dly symbol may not be the active contract month. 2024-08-24 08:57:12.091 | Unable to determine transition date based on volume from files: F.US.FDXSH16.dly, F.US.FDXSM16.dly 2024-08-24 08:57:12.091 | The F.US.FDXSM16.dly symbol may not be the active contract month. 2024-08-24 08:57:12.091 | Unable to determine transition date based on volume from files: F.US.FDXSM16.dly, F.US.FDXSU16.dly 2024-08-24 08:57:12.091 | The F.US.FDXSU16.dly symbol may not be the active contract month. 2024-08-24 08:57:12.092 | Unable to determine transition date based on volume from files: F.US.FDXSU16.dly, F.US.FDXSZ16.dly 2024-08-24 08:57:12.092 | The F.US.FDXSZ16.dly symbol may not be the active contract month. 2024-08-24 08:57:12.092 | Unable to determine transition date based on volume from files: F.US.FDXSZ16.dly, F.US.FDXSH17.dly 2024-08-24 08:57:12.092 | The F.US.FDXSH17.dly symbol may not be the active contract month. 2024-08-24 08:57:12.093 | Unable to determine transition date based on volume from files: F.US.FDXSH17.dly, F.US.FDXSM17.dly 2024-08-24 08:57:12.093 | The F.US.FDXSM17.dly symbol may not be the active contract month. 2024-08-24 08:57:12.094 | Unable to determine transition date based on volume from files: F.US.FDXSM17.dly, F.US.FDXSU17.dly 2024-08-24 08:57:12.094 | The F.US.FDXSU17.dly symbol may not be the active contract month. 2024-08-24 08:57:12.094 | Unable to determine transition date based on volume from files: F.US.FDXSU17.dly, F.US.FDXSZ17.dly 2024-08-24 08:57:12.094 | The F.US.FDXSZ17.dly symbol may not be the active contract month. 2024-08-24 08:57:12.095 | Unable to determine transition date based on volume from files: F.US.FDXSZ17.dly, F.US.FDXSH18.dly 2024-08-24 08:57:12.095 | The F.US.FDXSH18.dly symbol may not be the active contract month. 2024-08-24 08:57:12.095 | Unable to determine transition date based on volume from files: F.US.FDXSH18.dly, F.US.FDXSM18.dly 2024-08-24 08:57:12.095 | The F.US.FDXSM18.dly symbol may not be the active contract month. 2024-08-24 08:57:12.096 | Unable to determine transition date based on volume from files: F.US.FDXSM18.dly, F.US.FDXSU18.dly 2024-08-24 08:57:12.096 | The F.US.FDXSU18.dly symbol may not be the active contract month. 2024-08-24 08:57:12.097 | Unable to determine transition date based on volume from files: F.US.FDXSU18.dly, F.US.FDXSZ18.dly 2024-08-24 08:57:12.097 | The F.US.FDXSZ18.dly symbol may not be the active contract month. 2024-08-24 08:57:12.097 | Unable to determine transition date based on volume from files: F.US.FDXSZ18.dly, F.US.FDXSH19.dly 2024-08-24 08:57:12.097 | The F.US.FDXSH19.dly symbol may not be the active contract month. 2024-08-24 08:57:12.098 | Unable to determine transition date based on volume from files: F.US.FDXSH19.dly, F.US.FDXSM19.dly 2024-08-24 08:57:12.098 | The F.US.FDXSM19.dly symbol may not be the active contract month. 2024-08-24 08:57:12.098 | Unable to determine transition date based on volume from files: F.US.FDXSM19.dly, F.US.FDXSU19.dly 2024-08-24 08:57:12.098 | The F.US.FDXSU19.dly symbol may not be the active contract month. 2024-08-24 08:57:12.098 | Unable to determine transition date based on volume from files: F.US.FDXSU19.dly, F.US.FDXSZ19.dly 2024-08-24 08:57:12.098 | The F.US.FDXSZ19.dly symbol may not be the active contract month. 2024-08-24 08:57:12.099 | Unable to determine transition date based on volume from files: F.US.FDXSZ19.dly, F.US.FDXSH20.dly 2024-08-24 08:57:12.099 | The F.US.FDXSH20.dly symbol may not be the active contract month. 2024-08-24 08:57:12.099 | Unable to determine transition date based on volume from files: F.US.FDXSH20.dly, F.US.FDXSM20.dly 2024-08-24 08:57:12.099 | The F.US.FDXSM20.dly symbol may not be the active contract month. 2024-08-24 08:57:12.099 | Unable to determine transition date based on volume from files: F.US.FDXSM20.dly, F.US.FDXSU20.dly 2024-08-24 08:57:12.099 | The F.US.FDXSU20.dly symbol may not be the active contract month. 2024-08-24 08:57:12.100 | Unable to determine transition date based on volume from files: F.US.FDXSU20.dly, F.US.FDXSZ20.dly 2024-08-24 08:57:12.100 | The F.US.FDXSZ20.dly symbol may not be the active contract month. 2024-08-24 08:57:12.100 | Unable to determine transition date based on volume from files: F.US.FDXSZ20.dly, F.US.FDXSH21.dly 2024-08-24 08:57:12.100 | The F.US.FDXSH21.dly symbol may not be the active contract month. 2024-08-24 08:57:12.106 | HD Request # 48 | Decompressing data. 2024-08-24 08:57:12.129 | HD Request # 48 | Receiving Intraday data for F.US.FDXSM23 starting at 2023-06-16 12:59:52.501000 2024-08-24 08:57:12.129 | Socket (1) | CloseSocket call. 2024-08-24 08:57:12.129 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:12.152 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2012-09-25 from file. C:\SierraChart\Data\F.US.FDXSU12.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.152 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ12.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.153 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2012-12-25 from file. C:\SierraChart\Data\F.US.FDXSZ12.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.153 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.154 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2013-03-19 from file. C:\SierraChart\Data\F.US.FDXSH13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.154 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.154 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:57:12.154 | Socket (1) | Closed. 2024-08-24 08:57:12.155 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2013-06-25 from file. C:\SierraChart\Data\F.US.FDXSM13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.155 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.156 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2013-09-24 from file. C:\SierraChart\Data\F.US.FDXSU13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.156 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.157 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2013-12-24 from file. C:\SierraChart\Data\F.US.FDXSZ13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.157 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.158 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2014-03-25 from file. C:\SierraChart\Data\F.US.FDXSH14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.158 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.158 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2014-06-24 from file. C:\SierraChart\Data\F.US.FDXSM14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.158 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.159 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2014-09-23 from file. C:\SierraChart\Data\F.US.FDXSU14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.159 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.160 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2014-12-23 from file. C:\SierraChart\Data\F.US.FDXSZ14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.160 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.161 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2015-03-24 from file. C:\SierraChart\Data\F.US.FDXSH15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.161 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.162 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2015-06-23 from file. C:\SierraChart\Data\F.US.FDXSM15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.162 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.163 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2015-09-22 from file. C:\SierraChart\Data\F.US.FDXSU15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.163 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.164 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2015-12-22 from file. C:\SierraChart\Data\F.US.FDXSZ15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.164 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.165 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2016-03-22 from file. C:\SierraChart\Data\F.US.FDXSH16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.165 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.165 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2016-06-21 from file. C:\SierraChart\Data\F.US.FDXSM16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.165 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.166 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2016-09-20 from file. C:\SierraChart\Data\F.US.FDXSU16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.166 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.167 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2016-12-20 from file. C:\SierraChart\Data\F.US.FDXSZ16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.167 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.168 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2017-03-21 from file. C:\SierraChart\Data\F.US.FDXSH17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.168 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.169 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2017-06-20 from file. C:\SierraChart\Data\F.US.FDXSM17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.169 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.170 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2017-09-19 from file. C:\SierraChart\Data\F.US.FDXSU17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.170 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.171 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2017-12-19 from file. C:\SierraChart\Data\F.US.FDXSZ17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.171 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.172 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2018-03-20 from file. C:\SierraChart\Data\F.US.FDXSH18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.172 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.172 | CQG WebSocket socket (9) | Creating socket. Using TLS 1.2. 2024-08-24 08:57:12.172 | CQG WebSocket socket (9) | New receive buffer size: 0 2024-08-24 08:57:12.172 | CQG WebSocket socket (9) | Connecting to IP: 195.166.124.175. 2024-08-24 08:57:12.172 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2018-06-19 from file. C:\SierraChart\Data\F.US.FDXSM18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.172 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.173 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2018-09-25 from file. C:\SierraChart\Data\F.US.FDXSU18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.173 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.174 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2018-12-25 from file. C:\SierraChart\Data\F.US.FDXSZ18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.174 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.175 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2019-03-19 from file. C:\SierraChart\Data\F.US.FDXSH19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.175 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.176 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2019-06-25 from file. C:\SierraChart\Data\F.US.FDXSM19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.176 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.177 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2019-09-24 from file. C:\SierraChart\Data\F.US.FDXSU19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.177 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.178 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2019-12-24 from file. C:\SierraChart\Data\F.US.FDXSZ19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.178 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.179 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2020-03-24 from file. C:\SierraChart\Data\F.US.FDXSH20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.179 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.179 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2020-06-23 from file. C:\SierraChart\Data\F.US.FDXSM20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.179 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.180 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2020-09-22 from file. C:\SierraChart\Data\F.US.FDXSU20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.180 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.181 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2020-12-22 from file. C:\SierraChart\Data\F.US.FDXSZ20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.181 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH21.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.182 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2021-03-23 from file. C:\SierraChart\Data\F.US.FDXSH21.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.182 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM21.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.264 | Historical data download thread signaled to stop. 2024-08-24 08:57:12.264 | HD Request # 48 | Received 1 Intraday data record from 2023-06-16 12:59:52.501000 to 2023-06-16 12:59:52.501000 (0.0 seconds. Delay: 434.8 days) and wrote 0 records for F.US.FDXSM23 2024-08-24 08:57:12.264 | HD Request # 48 | Completion time: 1s. 2024-08-24 08:57:12.264 | HD Request # 48 | Intraday data download complete for F.US.FDXSM23. Unique request ID: 24 2024-08-24 08:57:12.264 | Removing historical data download ID 24. 2024-08-24 08:57:12.264 | Real-time Intraday chart data file updates started for F.US.FDXSM23 2024-08-24 08:57:12.264 | Intraday chart data file opened for F.US.FDXSM23 2024-08-24 08:57:12.264 | HD Request # 48 | Enabling Intraday chart updating for symbol. 2024-08-24 08:57:12.264 | 2024-08-24 08:57:12.264 | Triggering next historical data download in queue. 2024-08-24 08:57:12.264 | Historical data for F.US.FDXSM23 is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:57:12.264 | CQG WebSocket | Opening WebSocket. 2024-08-24 08:57:12.264 | CQG WebSocket | Sending WebSocket handshake. 2024-08-24 08:57:12.264 | Mapping F.US.FDXSU23 to FDXS202309_FUT_EUREX. Service code: eurex 2024-08-24 08:57:12.264 | HD Request # 49 | Downloading Intraday chart data for F.US.FDXSU23 to the file F.US.FDXSU23.scid. Service: eurex 2024-08-24 08:57:12.264 | HD Request # 49 | Download start date-time: 2023-09-15 12:56:31.000000. File last date-time: 2023-09-15 12:56:31.873000 2024-08-24 08:57:12.264 | HD Request # 49 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:57:12.264 | Socket (1) | Creating socket. 2024-08-24 08:57:12.264 | Socket (1) | New receive buffer size: 0 2024-08-24 08:57:12.264 | Socket (1) | Connecting to IP: 149.11.224.18. 2024-08-24 08:57:12.265 | F.US.FDXSU24 [CBV][M] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:57:12.266 | F.US.FDXSU24 [CBV][M] Daily #6 | Reloading chart. 2024-08-24 08:57:12.266 | Unable to determine transition date based on volume from files: F.US.FDXSU12.dly, F.US.FDXSZ12.dly 2024-08-24 08:57:12.266 | The F.US.FDXSZ12.dly symbol may not be the active contract month. 2024-08-24 08:57:12.266 | Unable to determine transition date based on volume from files: F.US.FDXSZ12.dly, F.US.FDXSH13.dly 2024-08-24 08:57:12.266 | The F.US.FDXSH13.dly symbol may not be the active contract month. 2024-08-24 08:57:12.266 | Unable to determine transition date based on volume from files: F.US.FDXSH13.dly, F.US.FDXSM13.dly 2024-08-24 08:57:12.266 | The F.US.FDXSM13.dly symbol may not be the active contract month. 2024-08-24 08:57:12.267 | Unable to determine transition date based on volume from files: F.US.FDXSM13.dly, F.US.FDXSU13.dly 2024-08-24 08:57:12.267 | The F.US.FDXSU13.dly symbol may not be the active contract month. 2024-08-24 08:57:12.267 | Unable to determine transition date based on volume from files: F.US.FDXSU13.dly, F.US.FDXSZ13.dly 2024-08-24 08:57:12.267 | The F.US.FDXSZ13.dly symbol may not be the active contract month. 2024-08-24 08:57:12.267 | Unable to determine transition date based on volume from files: F.US.FDXSZ13.dly, F.US.FDXSH14.dly 2024-08-24 08:57:12.267 | The F.US.FDXSH14.dly symbol may not be the active contract month. 2024-08-24 08:57:12.267 | Unable to determine transition date based on volume from files: F.US.FDXSH14.dly, F.US.FDXSM14.dly 2024-08-24 08:57:12.267 | The F.US.FDXSM14.dly symbol may not be the active contract month. 2024-08-24 08:57:12.267 | Unable to determine transition date based on volume from files: F.US.FDXSM14.dly, F.US.FDXSU14.dly 2024-08-24 08:57:12.267 | The F.US.FDXSU14.dly symbol may not be the active contract month. 2024-08-24 08:57:12.267 | Unable to determine transition date based on volume from files: F.US.FDXSU14.dly, F.US.FDXSZ14.dly 2024-08-24 08:57:12.267 | The F.US.FDXSZ14.dly symbol may not be the active contract month. 2024-08-24 08:57:12.267 | Unable to determine transition date based on volume from files: F.US.FDXSZ14.dly, F.US.FDXSH15.dly 2024-08-24 08:57:12.267 | The F.US.FDXSH15.dly symbol may not be the active contract month. 2024-08-24 08:57:12.267 | Unable to determine transition date based on volume from files: F.US.FDXSH15.dly, F.US.FDXSM15.dly 2024-08-24 08:57:12.267 | The F.US.FDXSM15.dly symbol may not be the active contract month. 2024-08-24 08:57:12.267 | Unable to determine transition date based on volume from files: F.US.FDXSM15.dly, F.US.FDXSU15.dly 2024-08-24 08:57:12.267 | The F.US.FDXSU15.dly symbol may not be the active contract month. 2024-08-24 08:57:12.268 | Unable to determine transition date based on volume from files: F.US.FDXSU15.dly, F.US.FDXSZ15.dly 2024-08-24 08:57:12.268 | The F.US.FDXSZ15.dly symbol may not be the active contract month. 2024-08-24 08:57:12.268 | Unable to determine transition date based on volume from files: F.US.FDXSZ15.dly, F.US.FDXSH16.dly 2024-08-24 08:57:12.268 | The F.US.FDXSH16.dly symbol may not be the active contract month. 2024-08-24 08:57:12.268 | Unable to determine transition date based on volume from files: F.US.FDXSH16.dly, F.US.FDXSM16.dly 2024-08-24 08:57:12.268 | The F.US.FDXSM16.dly symbol may not be the active contract month. 2024-08-24 08:57:12.268 | Unable to determine transition date based on volume from files: F.US.FDXSM16.dly, F.US.FDXSU16.dly 2024-08-24 08:57:12.268 | The F.US.FDXSU16.dly symbol may not be the active contract month. 2024-08-24 08:57:12.268 | Unable to determine transition date based on volume from files: F.US.FDXSU16.dly, F.US.FDXSZ16.dly 2024-08-24 08:57:12.268 | The F.US.FDXSZ16.dly symbol may not be the active contract month. 2024-08-24 08:57:12.268 | Unable to determine transition date based on volume from files: F.US.FDXSZ16.dly, F.US.FDXSH17.dly 2024-08-24 08:57:12.268 | The F.US.FDXSH17.dly symbol may not be the active contract month. 2024-08-24 08:57:12.268 | Unable to determine transition date based on volume from files: F.US.FDXSH17.dly, F.US.FDXSM17.dly 2024-08-24 08:57:12.268 | The F.US.FDXSM17.dly symbol may not be the active contract month. 2024-08-24 08:57:12.268 | Unable to determine transition date based on volume from files: F.US.FDXSM17.dly, F.US.FDXSU17.dly 2024-08-24 08:57:12.268 | The F.US.FDXSU17.dly symbol may not be the active contract month. 2024-08-24 08:57:12.269 | Unable to determine transition date based on volume from files: F.US.FDXSU17.dly, F.US.FDXSZ17.dly 2024-08-24 08:57:12.269 | The F.US.FDXSZ17.dly symbol may not be the active contract month. 2024-08-24 08:57:12.269 | Unable to determine transition date based on volume from files: F.US.FDXSZ17.dly, F.US.FDXSH18.dly 2024-08-24 08:57:12.269 | The F.US.FDXSH18.dly symbol may not be the active contract month. 2024-08-24 08:57:12.269 | Unable to determine transition date based on volume from files: F.US.FDXSH18.dly, F.US.FDXSM18.dly 2024-08-24 08:57:12.269 | The F.US.FDXSM18.dly symbol may not be the active contract month. 2024-08-24 08:57:12.269 | Unable to determine transition date based on volume from files: F.US.FDXSM18.dly, F.US.FDXSU18.dly 2024-08-24 08:57:12.269 | The F.US.FDXSU18.dly symbol may not be the active contract month. 2024-08-24 08:57:12.269 | Unable to determine transition date based on volume from files: F.US.FDXSU18.dly, F.US.FDXSZ18.dly 2024-08-24 08:57:12.269 | The F.US.FDXSZ18.dly symbol may not be the active contract month. 2024-08-24 08:57:12.269 | Unable to determine transition date based on volume from files: F.US.FDXSZ18.dly, F.US.FDXSH19.dly 2024-08-24 08:57:12.269 | The F.US.FDXSH19.dly symbol may not be the active contract month. 2024-08-24 08:57:12.269 | Unable to determine transition date based on volume from files: F.US.FDXSH19.dly, F.US.FDXSM19.dly 2024-08-24 08:57:12.269 | The F.US.FDXSM19.dly symbol may not be the active contract month. 2024-08-24 08:57:12.269 | Unable to determine transition date based on volume from files: F.US.FDXSM19.dly, F.US.FDXSU19.dly 2024-08-24 08:57:12.269 | The F.US.FDXSU19.dly symbol may not be the active contract month. 2024-08-24 08:57:12.269 | Unable to determine transition date based on volume from files: F.US.FDXSU19.dly, F.US.FDXSZ19.dly 2024-08-24 08:57:12.269 | The F.US.FDXSZ19.dly symbol may not be the active contract month. 2024-08-24 08:57:12.270 | Unable to determine transition date based on volume from files: F.US.FDXSZ19.dly, F.US.FDXSH20.dly 2024-08-24 08:57:12.270 | The F.US.FDXSH20.dly symbol may not be the active contract month. 2024-08-24 08:57:12.270 | Unable to determine transition date based on volume from files: F.US.FDXSH20.dly, F.US.FDXSM20.dly 2024-08-24 08:57:12.270 | The F.US.FDXSM20.dly symbol may not be the active contract month. 2024-08-24 08:57:12.270 | Unable to determine transition date based on volume from files: F.US.FDXSM20.dly, F.US.FDXSU20.dly 2024-08-24 08:57:12.270 | The F.US.FDXSU20.dly symbol may not be the active contract month. 2024-08-24 08:57:12.270 | Unable to determine transition date based on volume from files: F.US.FDXSU20.dly, F.US.FDXSZ20.dly 2024-08-24 08:57:12.270 | The F.US.FDXSZ20.dly symbol may not be the active contract month. 2024-08-24 08:57:12.270 | Unable to determine transition date based on volume from files: F.US.FDXSZ20.dly, F.US.FDXSH21.dly 2024-08-24 08:57:12.270 | The F.US.FDXSH21.dly symbol may not be the active contract month. 2024-08-24 08:57:12.292 | HD Request # 49 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:12.292 | HD Request # 49 | Sending historical data logon request message. 2024-08-24 08:57:12.302 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2012-09-25 from file. C:\SierraChart\Data\F.US.FDXSU12.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.302 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ12.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.303 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2012-12-25 from file. C:\SierraChart\Data\F.US.FDXSZ12.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.303 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.304 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2013-03-19 from file. C:\SierraChart\Data\F.US.FDXSH13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.304 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.305 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2013-06-25 from file. C:\SierraChart\Data\F.US.FDXSM13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.305 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.306 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2013-09-24 from file. C:\SierraChart\Data\F.US.FDXSU13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.306 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.306 | Socket (1) | CloseSocket call. 2024-08-24 08:57:12.306 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:12.307 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2013-12-24 from file. C:\SierraChart\Data\F.US.FDXSZ13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.307 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.308 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2014-03-25 from file. C:\SierraChart\Data\F.US.FDXSH14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.308 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.308 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2014-06-24 from file. C:\SierraChart\Data\F.US.FDXSM14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.308 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.309 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2014-09-23 from file. C:\SierraChart\Data\F.US.FDXSU14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.309 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.310 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2014-12-23 from file. C:\SierraChart\Data\F.US.FDXSZ14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.310 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.311 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2015-03-24 from file. C:\SierraChart\Data\F.US.FDXSH15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.311 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.312 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2015-06-23 from file. C:\SierraChart\Data\F.US.FDXSM15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.312 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.313 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2015-09-22 from file. C:\SierraChart\Data\F.US.FDXSU15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.313 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.314 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2015-12-22 from file. C:\SierraChart\Data\F.US.FDXSZ15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.314 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.315 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2016-03-22 from file. C:\SierraChart\Data\F.US.FDXSH16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.315 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.315 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2016-06-21 from file. C:\SierraChart\Data\F.US.FDXSM16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.315 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.316 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2016-09-20 from file. C:\SierraChart\Data\F.US.FDXSU16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.316 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.317 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2016-12-20 from file. C:\SierraChart\Data\F.US.FDXSZ16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.317 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.318 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2017-03-21 from file. C:\SierraChart\Data\F.US.FDXSH17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.318 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.319 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2017-06-20 from file. C:\SierraChart\Data\F.US.FDXSM17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.319 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.320 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:57:12.320 | Socket (1) | Closed. 2024-08-24 08:57:12.320 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2017-09-19 from file. C:\SierraChart\Data\F.US.FDXSU17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.320 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.321 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2017-12-19 from file. C:\SierraChart\Data\F.US.FDXSZ17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.321 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.322 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2018-03-20 from file. C:\SierraChart\Data\F.US.FDXSH18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.322 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.323 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2018-06-19 from file. C:\SierraChart\Data\F.US.FDXSM18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.323 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.323 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2018-09-25 from file. C:\SierraChart\Data\F.US.FDXSU18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.323 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.324 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2018-12-25 from file. C:\SierraChart\Data\F.US.FDXSZ18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.324 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.325 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2019-03-19 from file. C:\SierraChart\Data\F.US.FDXSH19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.325 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.326 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2019-06-25 from file. C:\SierraChart\Data\F.US.FDXSM19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.326 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.327 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2019-09-24 from file. C:\SierraChart\Data\F.US.FDXSU19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.327 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.328 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2019-12-24 from file. C:\SierraChart\Data\F.US.FDXSZ19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.328 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.329 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2020-03-24 from file. C:\SierraChart\Data\F.US.FDXSH20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.329 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.330 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2020-06-23 from file. C:\SierraChart\Data\F.US.FDXSM20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.330 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.331 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2020-09-22 from file. C:\SierraChart\Data\F.US.FDXSU20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.331 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.331 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2020-12-22 from file. C:\SierraChart\Data\F.US.FDXSZ20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.331 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH21.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.332 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2021-03-23 from file. C:\SierraChart\Data\F.US.FDXSH21.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.332 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM21.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.412 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2024-08-24 08:57:12.412 | CQG WebSocket | Server header | Connection: Upgrade 2024-08-24 08:57:12.412 | CQG WebSocket | Server header | Sec-WebSocket-Accept: 3Hp7I+qFjHzH/K7IVcagoahZd6I= 2024-08-24 08:57:12.412 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2024-08-24 08:57:12.412 | CQG WebSocket | Server header | Upgrade: websocket 2024-08-24 08:57:12.412 | CQG WebSocket | Server header | 2024-08-24 08:57:12.412 | CQG WebSocket | Web socket state is now open. 2024-08-24 08:57:12.412 | CQG WebAPI | WebSocket connected. 2024-08-24 08:57:12.412 | CQG WebAPI | Sending market data logon message. 2024-08-24 08:57:12.413 | F.US.FDXSU24 [CBV][M] #11 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 08:57:12.433 | F.US.FDXSU24 [CBV][M] #11 | Chart data loading complete. 2024-08-24 08:57:12.433 | HD Request # 49 | Error downloading historical Intraday data for F.US.FDXSU23. Historical data logon error: Serving data is disabled 2024-08-24 08:57:12.433 | Added historical Intraday data request for F.US.FDXSU23 to the queue. 2024-08-24 08:57:12.433 | Triggering next historical data download in queue. 2024-08-24 08:57:12.434 | Historical data download thread signaled to stop. 2024-08-24 08:57:12.434 | HD Request # 49 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSU23 2024-08-24 08:57:12.434 | HD Request # 49 | Completion time: 0s. 2024-08-24 08:57:12.434 | 2024-08-24 08:57:12.455 | HD Request # 50 | Downloading Intraday chart data for F.US.FDXSU23 to the file F.US.FDXSU23.scid. Service: eurex 2024-08-24 08:57:12.455 | HD Request # 50 | Download start date-time: 2023-09-15 12:56:31.000000. File last date-time: 2023-09-15 12:56:31.873000 2024-08-24 08:57:12.455 | HD Request # 50 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:57:12.455 | Socket (1) | Creating socket. 2024-08-24 08:57:12.455 | Socket (1) | New receive buffer size: 0 2024-08-24 08:57:12.455 | Socket (1) | Connecting to IP: 176.9.9.252. 2024-08-24 08:57:12.460 | F.US.FDXSU24 [CBV][M] Daily #6 | Chart data loading complete. 2024-08-24 08:57:12.460 | F.US.FDXSU24 [CBV][M] Daily #5 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:57:12.461 | F.US.FDXSU24 [CBV][M] Daily #5 | Reloading chart. 2024-08-24 08:57:12.461 | Unable to determine transition date based on volume from files: F.US.FDXSZ14.dly, F.US.FDXSH15.dly 2024-08-24 08:57:12.461 | The F.US.FDXSH15.dly symbol may not be the active contract month. 2024-08-24 08:57:12.461 | Unable to determine transition date based on volume from files: F.US.FDXSH15.dly, F.US.FDXSM15.dly 2024-08-24 08:57:12.461 | The F.US.FDXSM15.dly symbol may not be the active contract month. 2024-08-24 08:57:12.461 | Unable to determine transition date based on volume from files: F.US.FDXSM15.dly, F.US.FDXSU15.dly 2024-08-24 08:57:12.461 | The F.US.FDXSU15.dly symbol may not be the active contract month. 2024-08-24 08:57:12.461 | Unable to determine transition date based on volume from files: F.US.FDXSU15.dly, F.US.FDXSZ15.dly 2024-08-24 08:57:12.461 | The F.US.FDXSZ15.dly symbol may not be the active contract month. 2024-08-24 08:57:12.461 | Unable to determine transition date based on volume from files: F.US.FDXSZ15.dly, F.US.FDXSH16.dly 2024-08-24 08:57:12.461 | The F.US.FDXSH16.dly symbol may not be the active contract month. 2024-08-24 08:57:12.461 | Unable to determine transition date based on volume from files: F.US.FDXSH16.dly, F.US.FDXSM16.dly 2024-08-24 08:57:12.461 | The F.US.FDXSM16.dly symbol may not be the active contract month. 2024-08-24 08:57:12.461 | Unable to determine transition date based on volume from files: F.US.FDXSM16.dly, F.US.FDXSU16.dly 2024-08-24 08:57:12.461 | The F.US.FDXSU16.dly symbol may not be the active contract month. 2024-08-24 08:57:12.461 | Unable to determine transition date based on volume from files: F.US.FDXSU16.dly, F.US.FDXSZ16.dly 2024-08-24 08:57:12.461 | The F.US.FDXSZ16.dly symbol may not be the active contract month. 2024-08-24 08:57:12.462 | Unable to determine transition date based on volume from files: F.US.FDXSZ16.dly, F.US.FDXSH17.dly 2024-08-24 08:57:12.462 | The F.US.FDXSH17.dly symbol may not be the active contract month. 2024-08-24 08:57:12.462 | Unable to determine transition date based on volume from files: F.US.FDXSH17.dly, F.US.FDXSM17.dly 2024-08-24 08:57:12.462 | The F.US.FDXSM17.dly symbol may not be the active contract month. 2024-08-24 08:57:12.462 | Unable to determine transition date based on volume from files: F.US.FDXSM17.dly, F.US.FDXSU17.dly 2024-08-24 08:57:12.462 | The F.US.FDXSU17.dly symbol may not be the active contract month. 2024-08-24 08:57:12.462 | Unable to determine transition date based on volume from files: F.US.FDXSU17.dly, F.US.FDXSZ17.dly 2024-08-24 08:57:12.462 | The F.US.FDXSZ17.dly symbol may not be the active contract month. 2024-08-24 08:57:12.462 | Unable to determine transition date based on volume from files: F.US.FDXSZ17.dly, F.US.FDXSH18.dly 2024-08-24 08:57:12.462 | The F.US.FDXSH18.dly symbol may not be the active contract month. 2024-08-24 08:57:12.462 | Unable to determine transition date based on volume from files: F.US.FDXSH18.dly, F.US.FDXSM18.dly 2024-08-24 08:57:12.462 | The F.US.FDXSM18.dly symbol may not be the active contract month. 2024-08-24 08:57:12.462 | Unable to determine transition date based on volume from files: F.US.FDXSM18.dly, F.US.FDXSU18.dly 2024-08-24 08:57:12.462 | The F.US.FDXSU18.dly symbol may not be the active contract month. 2024-08-24 08:57:12.462 | Unable to determine transition date based on volume from files: F.US.FDXSU18.dly, F.US.FDXSZ18.dly 2024-08-24 08:57:12.462 | The F.US.FDXSZ18.dly symbol may not be the active contract month. 2024-08-24 08:57:12.462 | Unable to determine transition date based on volume from files: F.US.FDXSZ18.dly, F.US.FDXSH19.dly 2024-08-24 08:57:12.462 | The F.US.FDXSH19.dly symbol may not be the active contract month. 2024-08-24 08:57:12.463 | Unable to determine transition date based on volume from files: F.US.FDXSH19.dly, F.US.FDXSM19.dly 2024-08-24 08:57:12.463 | The F.US.FDXSM19.dly symbol may not be the active contract month. 2024-08-24 08:57:12.463 | Unable to determine transition date based on volume from files: F.US.FDXSM19.dly, F.US.FDXSU19.dly 2024-08-24 08:57:12.463 | The F.US.FDXSU19.dly symbol may not be the active contract month. 2024-08-24 08:57:12.463 | Unable to determine transition date based on volume from files: F.US.FDXSU19.dly, F.US.FDXSZ19.dly 2024-08-24 08:57:12.463 | The F.US.FDXSZ19.dly symbol may not be the active contract month. 2024-08-24 08:57:12.463 | Unable to determine transition date based on volume from files: F.US.FDXSZ19.dly, F.US.FDXSH20.dly 2024-08-24 08:57:12.463 | The F.US.FDXSH20.dly symbol may not be the active contract month. 2024-08-24 08:57:12.463 | Unable to determine transition date based on volume from files: F.US.FDXSH20.dly, F.US.FDXSM20.dly 2024-08-24 08:57:12.463 | The F.US.FDXSM20.dly symbol may not be the active contract month. 2024-08-24 08:57:12.463 | Unable to determine transition date based on volume from files: F.US.FDXSM20.dly, F.US.FDXSU20.dly 2024-08-24 08:57:12.463 | The F.US.FDXSU20.dly symbol may not be the active contract month. 2024-08-24 08:57:12.463 | Unable to determine transition date based on volume from files: F.US.FDXSU20.dly, F.US.FDXSZ20.dly 2024-08-24 08:57:12.463 | The F.US.FDXSZ20.dly symbol may not be the active contract month. 2024-08-24 08:57:12.463 | Unable to determine transition date based on volume from files: F.US.FDXSZ20.dly, F.US.FDXSH21.dly 2024-08-24 08:57:12.463 | The F.US.FDXSH21.dly symbol may not be the active contract month. 2024-08-24 08:57:12.494 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2014-12-23 from file. C:\SierraChart\Data\F.US.FDXSZ14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.494 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.495 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2015-03-24 from file. C:\SierraChart\Data\F.US.FDXSH15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.495 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.496 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2015-06-23 from file. C:\SierraChart\Data\F.US.FDXSM15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.496 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.497 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2015-09-22 from file. C:\SierraChart\Data\F.US.FDXSU15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.497 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.498 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2015-12-22 from file. C:\SierraChart\Data\F.US.FDXSZ15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.498 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.499 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2016-03-22 from file. C:\SierraChart\Data\F.US.FDXSH16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.499 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.500 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2016-06-21 from file. C:\SierraChart\Data\F.US.FDXSM16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.500 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.500 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2016-09-20 from file. C:\SierraChart\Data\F.US.FDXSU16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.500 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.501 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2016-12-20 from file. C:\SierraChart\Data\F.US.FDXSZ16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.501 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.502 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2017-03-21 from file. C:\SierraChart\Data\F.US.FDXSH17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.502 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.503 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2017-06-20 from file. C:\SierraChart\Data\F.US.FDXSM17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.503 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.504 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2017-09-19 from file. C:\SierraChart\Data\F.US.FDXSU17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.504 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.505 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2017-12-19 from file. C:\SierraChart\Data\F.US.FDXSZ17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.505 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.506 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2018-03-20 from file. C:\SierraChart\Data\F.US.FDXSH18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.506 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.507 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2018-06-19 from file. C:\SierraChart\Data\F.US.FDXSM18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.507 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.507 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2018-09-25 from file. C:\SierraChart\Data\F.US.FDXSU18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.507 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.508 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2018-12-25 from file. C:\SierraChart\Data\F.US.FDXSZ18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.508 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.509 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2019-03-19 from file. C:\SierraChart\Data\F.US.FDXSH19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.509 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.510 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2019-06-25 from file. C:\SierraChart\Data\F.US.FDXSM19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.510 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.510 | HD Request # 50 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:12.510 | HD Request # 50 | Sending historical data logon request message. 2024-08-24 08:57:12.511 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2019-09-24 from file. C:\SierraChart\Data\F.US.FDXSU19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.511 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.512 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2019-12-24 from file. C:\SierraChart\Data\F.US.FDXSZ19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.512 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.513 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2020-03-24 from file. C:\SierraChart\Data\F.US.FDXSH20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.513 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.514 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2020-06-23 from file. C:\SierraChart\Data\F.US.FDXSM20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.514 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.515 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2020-09-22 from file. C:\SierraChart\Data\F.US.FDXSU20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.515 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.516 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2020-12-22 from file. C:\SierraChart\Data\F.US.FDXSZ20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.516 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH21.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.517 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2021-03-23 from file. C:\SierraChart\Data\F.US.FDXSH21.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.517 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM21.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.536 | HD Request # 50 | Requesting Intraday data. Start date-time: 2023-09-15 12:56:31. Record interval: 0. Symbol: FDXS202309_FUT_EUREX 2024-08-24 08:57:12.561 | HD Request # 50 | Decompressing data. 2024-08-24 08:57:12.585 | HD Request # 50 | Receiving Intraday data for F.US.FDXSU23 starting at 2023-09-15 12:56:31.873000 2024-08-24 08:57:12.585 | Socket (1) | CloseSocket call. 2024-08-24 08:57:12.585 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:12.596 | Historical data download thread signaled to stop. 2024-08-24 08:57:12.596 | HD Request # 50 | Received 1 Intraday data record from 2023-09-15 12:56:31.873000 to 2023-09-15 12:56:31.873000 (0.0 seconds. Delay: 343.8 days) and wrote 0 records for F.US.FDXSU23 2024-08-24 08:57:12.596 | HD Request # 50 | Completion time: 0s. 2024-08-24 08:57:12.596 | HD Request # 50 | Intraday data download complete for F.US.FDXSU23. Unique request ID: 25 2024-08-24 08:57:12.596 | Removing historical data download ID 25. 2024-08-24 08:57:12.596 | Real-time Intraday chart data file updates started for F.US.FDXSU23 2024-08-24 08:57:12.596 | Intraday chart data file opened for F.US.FDXSU23 2024-08-24 08:57:12.596 | HD Request # 50 | Enabling Intraday chart updating for symbol. 2024-08-24 08:57:12.596 | 2024-08-24 08:57:12.596 | Triggering next historical data download in queue. 2024-08-24 08:57:12.596 | Historical data for F.US.FDXSU23 is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:57:12.596 | Mapping F.US.FDXSZ23 to FDXS202312_FUT_EUREX. Service code: eurex 2024-08-24 08:57:12.596 | HD Request # 51 | Downloading Intraday chart data for F.US.FDXSZ23 to the file F.US.FDXSZ23.scid. Service: eurex 2024-08-24 08:57:12.597 | HD Request # 51 | Download start date-time: 2023-12-15 12:58:16.000000. File last date-time: 2023-12-15 12:58:16.677000 2024-08-24 08:57:12.597 | HD Request # 51 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:57:12.597 | Socket (2) | Creating socket. 2024-08-24 08:57:12.597 | Socket (2) | New receive buffer size: 0 2024-08-24 08:57:12.597 | Socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 08:57:12.602 | F.US.FDXSU24 [CBV][M] #11 | Reloading chart. 2024-08-24 08:57:12.611 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:57:12.611 | Socket (1) | Closed. 2024-08-24 08:57:12.627 | HD Request # 51 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:12.627 | HD Request # 51 | Sending historical data logon request message. 2024-08-24 08:57:12.641 | Socket (2) | CloseSocket call. 2024-08-24 08:57:12.641 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:12.656 | Socket (2) | Socket gracefully closed by remote side. 2024-08-24 08:57:12.656 | Socket (2) | Closed. 2024-08-24 08:57:12.824 | F.US.FDXSU24 [CBV][M] #11 | Dates not found while checking for invalid data in continuous contract data files. F.US.FDXSM21 * 2024-08-24 08:57:12.824 | Unable to determine transition date based on volume from files: F.US.FDXSU12.dly, F.US.FDXSZ12.dly 2024-08-24 08:57:12.824 | The F.US.FDXSZ12.dly symbol may not be the active contract month. 2024-08-24 08:57:12.824 | Unable to determine transition date based on volume from files: F.US.FDXSZ12.dly, F.US.FDXSH13.dly 2024-08-24 08:57:12.824 | The F.US.FDXSH13.dly symbol may not be the active contract month. 2024-08-24 08:57:12.824 | Unable to determine transition date based on volume from files: F.US.FDXSH13.dly, F.US.FDXSM13.dly 2024-08-24 08:57:12.824 | The F.US.FDXSM13.dly symbol may not be the active contract month. 2024-08-24 08:57:12.824 | Unable to determine transition date based on volume from files: F.US.FDXSM13.dly, F.US.FDXSU13.dly 2024-08-24 08:57:12.824 | The F.US.FDXSU13.dly symbol may not be the active contract month. 2024-08-24 08:57:12.824 | Unable to determine transition date based on volume from files: F.US.FDXSU13.dly, F.US.FDXSZ13.dly 2024-08-24 08:57:12.824 | The F.US.FDXSZ13.dly symbol may not be the active contract month. 2024-08-24 08:57:12.824 | Unable to determine transition date based on volume from files: F.US.FDXSZ13.dly, F.US.FDXSH14.dly 2024-08-24 08:57:12.824 | The F.US.FDXSH14.dly symbol may not be the active contract month. 2024-08-24 08:57:12.824 | Unable to determine transition date based on volume from files: F.US.FDXSH14.dly, F.US.FDXSM14.dly 2024-08-24 08:57:12.824 | The F.US.FDXSM14.dly symbol may not be the active contract month. 2024-08-24 08:57:12.825 | Unable to determine transition date based on volume from files: F.US.FDXSM14.dly, F.US.FDXSU14.dly 2024-08-24 08:57:12.825 | The F.US.FDXSU14.dly symbol may not be the active contract month. 2024-08-24 08:57:12.825 | Unable to determine transition date based on volume from files: F.US.FDXSU14.dly, F.US.FDXSZ14.dly 2024-08-24 08:57:12.825 | The F.US.FDXSZ14.dly symbol may not be the active contract month. 2024-08-24 08:57:12.825 | Unable to determine transition date based on volume from files: F.US.FDXSZ14.dly, F.US.FDXSH15.dly 2024-08-24 08:57:12.825 | The F.US.FDXSH15.dly symbol may not be the active contract month. 2024-08-24 08:57:12.825 | Unable to determine transition date based on volume from files: F.US.FDXSH15.dly, F.US.FDXSM15.dly 2024-08-24 08:57:12.825 | The F.US.FDXSM15.dly symbol may not be the active contract month. 2024-08-24 08:57:12.825 | Unable to determine transition date based on volume from files: F.US.FDXSM15.dly, F.US.FDXSU15.dly 2024-08-24 08:57:12.825 | The F.US.FDXSU15.dly symbol may not be the active contract month. 2024-08-24 08:57:12.825 | Unable to determine transition date based on volume from files: F.US.FDXSU15.dly, F.US.FDXSZ15.dly 2024-08-24 08:57:12.825 | The F.US.FDXSZ15.dly symbol may not be the active contract month. 2024-08-24 08:57:12.825 | Unable to determine transition date based on volume from files: F.US.FDXSZ15.dly, F.US.FDXSH16.dly 2024-08-24 08:57:12.825 | The F.US.FDXSH16.dly symbol may not be the active contract month. 2024-08-24 08:57:12.825 | Unable to determine transition date based on volume from files: F.US.FDXSH16.dly, F.US.FDXSM16.dly 2024-08-24 08:57:12.825 | The F.US.FDXSM16.dly symbol may not be the active contract month. 2024-08-24 08:57:12.825 | Unable to determine transition date based on volume from files: F.US.FDXSM16.dly, F.US.FDXSU16.dly 2024-08-24 08:57:12.825 | The F.US.FDXSU16.dly symbol may not be the active contract month. 2024-08-24 08:57:12.826 | Unable to determine transition date based on volume from files: F.US.FDXSU16.dly, F.US.FDXSZ16.dly 2024-08-24 08:57:12.826 | The F.US.FDXSZ16.dly symbol may not be the active contract month. 2024-08-24 08:57:12.826 | Unable to determine transition date based on volume from files: F.US.FDXSZ16.dly, F.US.FDXSH17.dly 2024-08-24 08:57:12.826 | The F.US.FDXSH17.dly symbol may not be the active contract month. 2024-08-24 08:57:12.826 | Unable to determine transition date based on volume from files: F.US.FDXSH17.dly, F.US.FDXSM17.dly 2024-08-24 08:57:12.826 | The F.US.FDXSM17.dly symbol may not be the active contract month. 2024-08-24 08:57:12.826 | Unable to determine transition date based on volume from files: F.US.FDXSM17.dly, F.US.FDXSU17.dly 2024-08-24 08:57:12.826 | The F.US.FDXSU17.dly symbol may not be the active contract month. 2024-08-24 08:57:12.826 | Unable to determine transition date based on volume from files: F.US.FDXSU17.dly, F.US.FDXSZ17.dly 2024-08-24 08:57:12.826 | The F.US.FDXSZ17.dly symbol may not be the active contract month. 2024-08-24 08:57:12.826 | Unable to determine transition date based on volume from files: F.US.FDXSZ17.dly, F.US.FDXSH18.dly 2024-08-24 08:57:12.826 | The F.US.FDXSH18.dly symbol may not be the active contract month. 2024-08-24 08:57:12.826 | Unable to determine transition date based on volume from files: F.US.FDXSH18.dly, F.US.FDXSM18.dly 2024-08-24 08:57:12.826 | The F.US.FDXSM18.dly symbol may not be the active contract month. 2024-08-24 08:57:12.826 | Unable to determine transition date based on volume from files: F.US.FDXSM18.dly, F.US.FDXSU18.dly 2024-08-24 08:57:12.826 | The F.US.FDXSU18.dly symbol may not be the active contract month. 2024-08-24 08:57:12.826 | Unable to determine transition date based on volume from files: F.US.FDXSU18.dly, F.US.FDXSZ18.dly 2024-08-24 08:57:12.826 | The F.US.FDXSZ18.dly symbol may not be the active contract month. 2024-08-24 08:57:12.827 | Unable to determine transition date based on volume from files: F.US.FDXSZ18.dly, F.US.FDXSH19.dly 2024-08-24 08:57:12.827 | The F.US.FDXSH19.dly symbol may not be the active contract month. 2024-08-24 08:57:12.827 | Unable to determine transition date based on volume from files: F.US.FDXSH19.dly, F.US.FDXSM19.dly 2024-08-24 08:57:12.827 | The F.US.FDXSM19.dly symbol may not be the active contract month. 2024-08-24 08:57:12.827 | Unable to determine transition date based on volume from files: F.US.FDXSM19.dly, F.US.FDXSU19.dly 2024-08-24 08:57:12.827 | The F.US.FDXSU19.dly symbol may not be the active contract month. 2024-08-24 08:57:12.827 | Unable to determine transition date based on volume from files: F.US.FDXSU19.dly, F.US.FDXSZ19.dly 2024-08-24 08:57:12.827 | The F.US.FDXSZ19.dly symbol may not be the active contract month. 2024-08-24 08:57:12.827 | Unable to determine transition date based on volume from files: F.US.FDXSZ19.dly, F.US.FDXSH20.dly 2024-08-24 08:57:12.827 | The F.US.FDXSH20.dly symbol may not be the active contract month. 2024-08-24 08:57:12.827 | Unable to determine transition date based on volume from files: F.US.FDXSH20.dly, F.US.FDXSM20.dly 2024-08-24 08:57:12.827 | The F.US.FDXSM20.dly symbol may not be the active contract month. 2024-08-24 08:57:12.827 | Unable to determine transition date based on volume from files: F.US.FDXSM20.dly, F.US.FDXSU20.dly 2024-08-24 08:57:12.827 | The F.US.FDXSU20.dly symbol may not be the active contract month. 2024-08-24 08:57:12.827 | Unable to determine transition date based on volume from files: F.US.FDXSU20.dly, F.US.FDXSZ20.dly 2024-08-24 08:57:12.827 | The F.US.FDXSZ20.dly symbol may not be the active contract month. 2024-08-24 08:57:12.827 | Unable to determine transition date based on volume from files: F.US.FDXSZ20.dly, F.US.FDXSH21.dly 2024-08-24 08:57:12.827 | The F.US.FDXSH21.dly symbol may not be the active contract month. 2024-08-24 08:57:12.859 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2012-09-25 from file. C:\SierraChart\Data\F.US.FDXSU12.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.859 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ12.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.859 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2012-12-25 from file. C:\SierraChart\Data\F.US.FDXSZ12.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.859 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.860 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2013-03-19 from file. C:\SierraChart\Data\F.US.FDXSH13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.860 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.861 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2013-06-25 from file. C:\SierraChart\Data\F.US.FDXSM13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.861 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.862 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2013-09-24 from file. C:\SierraChart\Data\F.US.FDXSU13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.862 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.863 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2013-12-24 from file. C:\SierraChart\Data\F.US.FDXSZ13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.863 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.864 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2014-03-25 from file. C:\SierraChart\Data\F.US.FDXSH14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.864 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.865 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2014-06-24 from file. C:\SierraChart\Data\F.US.FDXSM14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.865 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.866 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2014-09-23 from file. C:\SierraChart\Data\F.US.FDXSU14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.866 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.867 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2014-12-23 from file. C:\SierraChart\Data\F.US.FDXSZ14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.867 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.867 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2015-03-24 from file. C:\SierraChart\Data\F.US.FDXSH15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.867 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.868 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2015-06-23 from file. C:\SierraChart\Data\F.US.FDXSM15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.868 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.869 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2015-09-22 from file. C:\SierraChart\Data\F.US.FDXSU15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.869 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.870 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2015-12-22 from file. C:\SierraChart\Data\F.US.FDXSZ15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.870 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.871 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2016-03-22 from file. C:\SierraChart\Data\F.US.FDXSH16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.871 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.872 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2016-06-21 from file. C:\SierraChart\Data\F.US.FDXSM16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.872 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.873 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2016-09-20 from file. C:\SierraChart\Data\F.US.FDXSU16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.873 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.874 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2016-12-20 from file. C:\SierraChart\Data\F.US.FDXSZ16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.874 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.874 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2017-03-21 from file. C:\SierraChart\Data\F.US.FDXSH17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.874 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.875 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2017-06-20 from file. C:\SierraChart\Data\F.US.FDXSM17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.875 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.876 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2017-09-19 from file. C:\SierraChart\Data\F.US.FDXSU17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.876 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.877 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2017-12-19 from file. C:\SierraChart\Data\F.US.FDXSZ17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.877 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.878 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2018-03-20 from file. C:\SierraChart\Data\F.US.FDXSH18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.878 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.879 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2018-06-19 from file. C:\SierraChart\Data\F.US.FDXSM18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.879 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.880 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2018-09-25 from file. C:\SierraChart\Data\F.US.FDXSU18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.880 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.881 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2018-12-25 from file. C:\SierraChart\Data\F.US.FDXSZ18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.881 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.882 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2019-03-19 from file. C:\SierraChart\Data\F.US.FDXSH19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.882 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.882 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2019-06-25 from file. C:\SierraChart\Data\F.US.FDXSM19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.882 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.883 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2019-09-24 from file. C:\SierraChart\Data\F.US.FDXSU19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.883 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.884 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2019-12-24 from file. C:\SierraChart\Data\F.US.FDXSZ19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.884 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.885 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2020-03-24 from file. C:\SierraChart\Data\F.US.FDXSH20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.885 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.886 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2020-06-23 from file. C:\SierraChart\Data\F.US.FDXSM20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.886 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.887 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2020-09-22 from file. C:\SierraChart\Data\F.US.FDXSU20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.887 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.888 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2020-12-22 from file. C:\SierraChart\Data\F.US.FDXSZ20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.888 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH21.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.889 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 2021-03-23 from file. C:\SierraChart\Data\F.US.FDXSH21.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.889 | F.US.FDXSU24 [CBV][M] #11 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM21.dly. Error: No Data for read. End of file. 2024-08-24 08:57:12.986 | F.US.FDXSU24 [CBV][M] Daily #5 | Chart data loading complete. 2024-08-24 08:57:12.986 | CQG WebAPI | Base Time: 2024-08-04T06:16:49. 2024-08-04 06:16:49 2024-08-24 08:57:12.986 | CQG WebAPI | Logon successful. Session Token = xkHZEtoDg+tN7Mv7bGaNX+MPG5goPPox/x+qMForIUIA4KjO5te7s4N9hCG5g7/YSNffI5U9jrO 2024-08-24 08:57:12.986 | CQG WebAPI | Connected to server complete. 2024-08-24 08:57:12.987 | No download requests in the queue to start downloads for. 2024-08-24 08:57:12.987 | Triggering next historical data download in queue. 2024-08-24 08:57:12.987 | No download requests in the queue to start downloads for. | Number times message added: 1 2024-08-24 08:57:12.987 | Updated verified funded futures trading account ending date to: 2024-09-23 06:57:12 2024-08-24 08:57:12.992 | CQG WebAPI | Sending Trade Accounts request message. 2024-08-24 08:57:12.992 | HD Request # 51 | Error downloading historical Intraday data for F.US.FDXSZ23. Historical data logon error: Serving data is disabled 2024-08-24 08:57:12.992 | Added historical Intraday data request for F.US.FDXSZ23 to the queue. 2024-08-24 08:57:12.992 | Historical data download thread signaled to stop. 2024-08-24 08:57:12.992 | HD Request # 51 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSZ23 2024-08-24 08:57:12.992 | HD Request # 51 | Completion time: 0s. 2024-08-24 08:57:12.992 | 2024-08-24 08:57:12.992 | Mapping F.US.FDXSZ23 to FDXS202312_FUT_EUREX. Service code: eurex 2024-08-24 08:57:12.992 | Using symbol data fast lookup vector 2024-08-24 08:57:12.992 | HD Request # 52 | Downloading Intraday chart data for F.US.FDXSZ23 to the file F.US.FDXSZ23.scid. Service: eurex 2024-08-24 08:57:12.992 | HD Request # 52 | Download start date-time: 2023-12-15 12:58:16.000000. File last date-time: 2023-12-15 12:58:16.677000 2024-08-24 08:57:12.992 | HD Request # 52 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:57:12.993 | Socket (1) | Creating socket. 2024-08-24 08:57:12.993 | Socket (1) | New receive buffer size: 0 2024-08-24 08:57:12.993 | Socket (1) | Connecting to IP: 176.9.9.252. 2024-08-24 08:57:12.994 | Mapping F.US.FDXSU24 to FDXS202409_FUT_EUREX. Service code: eurex 2024-08-24 08:57:12.994 | Denali Data Feed | Starting real-time market data updates for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 2 Service code: eurex 2024-08-24 08:57:12.994 | Denali Data Feed | Connecting to the server ds24.sierracharts.com. Port 443 2024-08-24 08:57:12.994 | CQG WebAPI | Sending symbol resolution request for F.US.FDXSU24. ID: 982654 2024-08-24 08:57:12.994 | Denali Data Feed | Requesting security definition data for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 2 2024-08-24 08:57:12.994 | DTC Client socket (2) | Creating socket. 2024-08-24 08:57:12.994 | DTC Client socket (2) | New receive buffer size: 0 2024-08-24 08:57:12.994 | DTC Client socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 08:57:12.995 | F.US.FDXSU24 [CBV][M] Daily #6 | Reloading chart. 2024-08-24 08:57:13.050 | HD Request # 52 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:13.050 | HD Request # 52 | Sending historical data logon request message. 2024-08-24 08:57:13.075 | HD Request # 52 | Requesting Intraday data. Start date-time: 2023-12-15 12:58:16. Record interval: 0. Symbol: FDXS202312_FUT_EUREX 2024-08-24 08:57:13.101 | HD Request # 52 | Decompressing data. 2024-08-24 08:57:13.126 | HD Request # 52 | Receiving Intraday data for F.US.FDXSZ23 starting at 2023-12-15 12:58:16.677000 2024-08-24 08:57:13.126 | Socket (1) | CloseSocket call. 2024-08-24 08:57:13.126 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:13.153 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:57:13.153 | Socket (1) | Closed. 2024-08-24 08:57:13.216 | F.US.FDXSU24 [CBV][M] Daily #6 | Dates not found while checking for invalid data in continuous contract data files. F.US.FDXSM21 * 2024-08-24 08:57:13.216 | Unable to determine transition date based on volume from files: F.US.FDXSU12.dly, F.US.FDXSZ12.dly 2024-08-24 08:57:13.216 | The F.US.FDXSZ12.dly symbol may not be the active contract month. 2024-08-24 08:57:13.216 | Unable to determine transition date based on volume from files: F.US.FDXSZ12.dly, F.US.FDXSH13.dly 2024-08-24 08:57:13.216 | The F.US.FDXSH13.dly symbol may not be the active contract month. 2024-08-24 08:57:13.216 | Unable to determine transition date based on volume from files: F.US.FDXSH13.dly, F.US.FDXSM13.dly 2024-08-24 08:57:13.216 | The F.US.FDXSM13.dly symbol may not be the active contract month. 2024-08-24 08:57:13.216 | Unable to determine transition date based on volume from files: F.US.FDXSM13.dly, F.US.FDXSU13.dly 2024-08-24 08:57:13.216 | The F.US.FDXSU13.dly symbol may not be the active contract month. 2024-08-24 08:57:13.216 | Unable to determine transition date based on volume from files: F.US.FDXSU13.dly, F.US.FDXSZ13.dly 2024-08-24 08:57:13.216 | The F.US.FDXSZ13.dly symbol may not be the active contract month. 2024-08-24 08:57:13.217 | Unable to determine transition date based on volume from files: F.US.FDXSZ13.dly, F.US.FDXSH14.dly 2024-08-24 08:57:13.217 | The F.US.FDXSH14.dly symbol may not be the active contract month. 2024-08-24 08:57:13.217 | Unable to determine transition date based on volume from files: F.US.FDXSH14.dly, F.US.FDXSM14.dly 2024-08-24 08:57:13.217 | The F.US.FDXSM14.dly symbol may not be the active contract month. 2024-08-24 08:57:13.217 | Unable to determine transition date based on volume from files: F.US.FDXSM14.dly, F.US.FDXSU14.dly 2024-08-24 08:57:13.217 | The F.US.FDXSU14.dly symbol may not be the active contract month. 2024-08-24 08:57:13.217 | Unable to determine transition date based on volume from files: F.US.FDXSU14.dly, F.US.FDXSZ14.dly 2024-08-24 08:57:13.217 | The F.US.FDXSZ14.dly symbol may not be the active contract month. 2024-08-24 08:57:13.217 | Unable to determine transition date based on volume from files: F.US.FDXSZ14.dly, F.US.FDXSH15.dly 2024-08-24 08:57:13.217 | The F.US.FDXSH15.dly symbol may not be the active contract month. 2024-08-24 08:57:13.217 | Unable to determine transition date based on volume from files: F.US.FDXSH15.dly, F.US.FDXSM15.dly 2024-08-24 08:57:13.217 | The F.US.FDXSM15.dly symbol may not be the active contract month. 2024-08-24 08:57:13.217 | Unable to determine transition date based on volume from files: F.US.FDXSM15.dly, F.US.FDXSU15.dly 2024-08-24 08:57:13.217 | The F.US.FDXSU15.dly symbol may not be the active contract month. 2024-08-24 08:57:13.217 | Unable to determine transition date based on volume from files: F.US.FDXSU15.dly, F.US.FDXSZ15.dly 2024-08-24 08:57:13.217 | The F.US.FDXSZ15.dly symbol may not be the active contract month. 2024-08-24 08:57:13.217 | Unable to determine transition date based on volume from files: F.US.FDXSZ15.dly, F.US.FDXSH16.dly 2024-08-24 08:57:13.217 | The F.US.FDXSH16.dly symbol may not be the active contract month. 2024-08-24 08:57:13.218 | Unable to determine transition date based on volume from files: F.US.FDXSH16.dly, F.US.FDXSM16.dly 2024-08-24 08:57:13.218 | The F.US.FDXSM16.dly symbol may not be the active contract month. 2024-08-24 08:57:13.218 | Unable to determine transition date based on volume from files: F.US.FDXSM16.dly, F.US.FDXSU16.dly 2024-08-24 08:57:13.218 | The F.US.FDXSU16.dly symbol may not be the active contract month. 2024-08-24 08:57:13.218 | Unable to determine transition date based on volume from files: F.US.FDXSU16.dly, F.US.FDXSZ16.dly 2024-08-24 08:57:13.218 | The F.US.FDXSZ16.dly symbol may not be the active contract month. 2024-08-24 08:57:13.218 | Unable to determine transition date based on volume from files: F.US.FDXSZ16.dly, F.US.FDXSH17.dly 2024-08-24 08:57:13.218 | The F.US.FDXSH17.dly symbol may not be the active contract month. 2024-08-24 08:57:13.218 | Unable to determine transition date based on volume from files: F.US.FDXSH17.dly, F.US.FDXSM17.dly 2024-08-24 08:57:13.218 | The F.US.FDXSM17.dly symbol may not be the active contract month. 2024-08-24 08:57:13.218 | Unable to determine transition date based on volume from files: F.US.FDXSM17.dly, F.US.FDXSU17.dly 2024-08-24 08:57:13.218 | The F.US.FDXSU17.dly symbol may not be the active contract month. 2024-08-24 08:57:13.218 | Unable to determine transition date based on volume from files: F.US.FDXSU17.dly, F.US.FDXSZ17.dly 2024-08-24 08:57:13.218 | The F.US.FDXSZ17.dly symbol may not be the active contract month. 2024-08-24 08:57:13.218 | Unable to determine transition date based on volume from files: F.US.FDXSZ17.dly, F.US.FDXSH18.dly 2024-08-24 08:57:13.218 | The F.US.FDXSH18.dly symbol may not be the active contract month. 2024-08-24 08:57:13.218 | Unable to determine transition date based on volume from files: F.US.FDXSH18.dly, F.US.FDXSM18.dly 2024-08-24 08:57:13.218 | The F.US.FDXSM18.dly symbol may not be the active contract month. 2024-08-24 08:57:13.219 | Unable to determine transition date based on volume from files: F.US.FDXSM18.dly, F.US.FDXSU18.dly 2024-08-24 08:57:13.219 | The F.US.FDXSU18.dly symbol may not be the active contract month. 2024-08-24 08:57:13.219 | Unable to determine transition date based on volume from files: F.US.FDXSU18.dly, F.US.FDXSZ18.dly 2024-08-24 08:57:13.219 | The F.US.FDXSZ18.dly symbol may not be the active contract month. 2024-08-24 08:57:13.219 | Unable to determine transition date based on volume from files: F.US.FDXSZ18.dly, F.US.FDXSH19.dly 2024-08-24 08:57:13.219 | The F.US.FDXSH19.dly symbol may not be the active contract month. 2024-08-24 08:57:13.219 | Unable to determine transition date based on volume from files: F.US.FDXSH19.dly, F.US.FDXSM19.dly 2024-08-24 08:57:13.219 | The F.US.FDXSM19.dly symbol may not be the active contract month. 2024-08-24 08:57:13.219 | Unable to determine transition date based on volume from files: F.US.FDXSM19.dly, F.US.FDXSU19.dly 2024-08-24 08:57:13.219 | The F.US.FDXSU19.dly symbol may not be the active contract month. 2024-08-24 08:57:13.219 | Unable to determine transition date based on volume from files: F.US.FDXSU19.dly, F.US.FDXSZ19.dly 2024-08-24 08:57:13.219 | The F.US.FDXSZ19.dly symbol may not be the active contract month. 2024-08-24 08:57:13.219 | Unable to determine transition date based on volume from files: F.US.FDXSZ19.dly, F.US.FDXSH20.dly 2024-08-24 08:57:13.219 | The F.US.FDXSH20.dly symbol may not be the active contract month. 2024-08-24 08:57:13.219 | Unable to determine transition date based on volume from files: F.US.FDXSH20.dly, F.US.FDXSM20.dly 2024-08-24 08:57:13.219 | The F.US.FDXSM20.dly symbol may not be the active contract month. 2024-08-24 08:57:13.219 | Unable to determine transition date based on volume from files: F.US.FDXSM20.dly, F.US.FDXSU20.dly 2024-08-24 08:57:13.219 | The F.US.FDXSU20.dly symbol may not be the active contract month. 2024-08-24 08:57:13.220 | Unable to determine transition date based on volume from files: F.US.FDXSU20.dly, F.US.FDXSZ20.dly 2024-08-24 08:57:13.220 | The F.US.FDXSZ20.dly symbol may not be the active contract month. 2024-08-24 08:57:13.220 | Unable to determine transition date based on volume from files: F.US.FDXSZ20.dly, F.US.FDXSH21.dly 2024-08-24 08:57:13.220 | The F.US.FDXSH21.dly symbol may not be the active contract month. 2024-08-24 08:57:13.250 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2012-09-25 from file. C:\SierraChart\Data\F.US.FDXSU12.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.250 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ12.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.251 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2012-12-25 from file. C:\SierraChart\Data\F.US.FDXSZ12.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.251 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.252 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2013-03-19 from file. C:\SierraChart\Data\F.US.FDXSH13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.252 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.253 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2013-06-25 from file. C:\SierraChart\Data\F.US.FDXSM13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.253 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.254 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2013-09-24 from file. C:\SierraChart\Data\F.US.FDXSU13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.254 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.255 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2013-12-24 from file. C:\SierraChart\Data\F.US.FDXSZ13.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.255 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.256 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2014-03-25 from file. C:\SierraChart\Data\F.US.FDXSH14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.256 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.257 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2014-06-24 from file. C:\SierraChart\Data\F.US.FDXSM14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.257 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.257 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2014-09-23 from file. C:\SierraChart\Data\F.US.FDXSU14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.257 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.258 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2014-12-23 from file. C:\SierraChart\Data\F.US.FDXSZ14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.258 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.259 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2015-03-24 from file. C:\SierraChart\Data\F.US.FDXSH15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.259 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.260 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2015-06-23 from file. C:\SierraChart\Data\F.US.FDXSM15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.260 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.261 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2015-09-22 from file. C:\SierraChart\Data\F.US.FDXSU15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.261 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.262 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2015-12-22 from file. C:\SierraChart\Data\F.US.FDXSZ15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.262 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.263 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2016-03-22 from file. C:\SierraChart\Data\F.US.FDXSH16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.263 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.264 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2016-06-21 from file. C:\SierraChart\Data\F.US.FDXSM16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.264 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.264 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2016-09-20 from file. C:\SierraChart\Data\F.US.FDXSU16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.264 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.265 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2016-12-20 from file. C:\SierraChart\Data\F.US.FDXSZ16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.265 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.266 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2017-03-21 from file. C:\SierraChart\Data\F.US.FDXSH17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.266 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.267 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2017-06-20 from file. C:\SierraChart\Data\F.US.FDXSM17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.267 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.268 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2017-09-19 from file. C:\SierraChart\Data\F.US.FDXSU17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.268 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.269 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2017-12-19 from file. C:\SierraChart\Data\F.US.FDXSZ17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.269 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.270 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2018-03-20 from file. C:\SierraChart\Data\F.US.FDXSH18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.270 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.271 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2018-06-19 from file. C:\SierraChart\Data\F.US.FDXSM18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.271 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.271 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2018-09-25 from file. C:\SierraChart\Data\F.US.FDXSU18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.271 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.272 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2018-12-25 from file. C:\SierraChart\Data\F.US.FDXSZ18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.272 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.273 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2019-03-19 from file. C:\SierraChart\Data\F.US.FDXSH19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.273 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.274 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2019-06-25 from file. C:\SierraChart\Data\F.US.FDXSM19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.274 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.275 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2019-09-24 from file. C:\SierraChart\Data\F.US.FDXSU19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.275 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.276 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2019-12-24 from file. C:\SierraChart\Data\F.US.FDXSZ19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.276 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.277 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2020-03-24 from file. C:\SierraChart\Data\F.US.FDXSH20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.277 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.277 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2020-06-23 from file. C:\SierraChart\Data\F.US.FDXSM20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.277 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.278 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2020-09-22 from file. C:\SierraChart\Data\F.US.FDXSU20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.278 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.279 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2020-12-22 from file. C:\SierraChart\Data\F.US.FDXSZ20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.279 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH21.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.280 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 2021-03-23 from file. C:\SierraChart\Data\F.US.FDXSH21.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.280 | F.US.FDXSU24 [CBV][M] Daily #6 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM21.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.360 | F.US.FDXSU24 [CBV][M] #11 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 08:57:13.380 | F.US.FDXSU24 [CBV][M] #11 | Chart data loading complete. 2024-08-24 08:57:13.380 | CQG WebAPI | Received symbol resolution report for symbol F.US.FDXSU24. Search Symbol: F.US.FDXSU24. Request ID: 982654. Contract ID: 1. 2024-08-24 08:57:13.380 | CQG WebAPI | Brokerage name: WH Selfinvest France. Account Name: LWHF0931 2024-08-24 08:57:13.380 | Updated verified funded futures trading account ending date to: 2024-09-23 06:57:13 2024-08-24 08:57:13.380 | CQG WebAPI | Sending collateral subscribe request. 2024-08-24 08:57:13.380 | Denali Data Feed | Network connection to server complete. 2024-08-24 08:57:13.380 | Denali Data Feed | Starting socket receive thread. 2024-08-24 08:57:13.380 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 08:57:13.380 | Historical data download thread signaled to stop. 2024-08-24 08:57:13.380 | HD Request # 52 | Received 1 Intraday data record from 2023-12-15 12:58:16.677000 to 2023-12-15 12:58:16.677000 (0.0 seconds. Delay: 252.8 days) and wrote 0 records for F.US.FDXSZ23 2024-08-24 08:57:13.380 | HD Request # 52 | Add time&sales data | Remembered last file record date-time: 2023-12-15 11:58:16.677000 2024-08-24 08:57:13.380 | HD Request # 52 | Completion time: 1s. 2024-08-24 08:57:13.380 | HD Request # 52 | Intraday data download complete for F.US.FDXSZ23. Unique request ID: 26 2024-08-24 08:57:13.380 | Removing historical data download ID 26. 2024-08-24 08:57:13.380 | Real-time Intraday chart data file updates started for F.US.FDXSZ23 2024-08-24 08:57:13.380 | Intraday chart data file opened for F.US.FDXSZ23 2024-08-24 08:57:13.380 | HD Request # 52 | Enabling Intraday chart updating for symbol. 2024-08-24 08:57:13.380 | 2024-08-24 08:57:13.380 | Triggering next historical data download in queue. 2024-08-24 08:57:13.380 | Historical data for F.US.FDXSZ23 is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:57:13.401 | Mapping F.US.FDXSH24 to FDXS202403_FUT_EUREX. Service code: eurex 2024-08-24 08:57:13.401 | HD Request # 53 | Downloading Intraday chart data for F.US.FDXSH24 to the file F.US.FDXSH24.scid. Service: eurex 2024-08-24 08:57:13.401 | HD Request # 53 | Download start date-time: 2024-03-15 12:58:46.000000. File last date-time: 2024-03-15 12:58:46.363000 2024-08-24 08:57:13.401 | HD Request # 53 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:57:13.401 | Socket (1) | Creating socket. 2024-08-24 08:57:13.401 | Socket (1) | New receive buffer size: 0 2024-08-24 08:57:13.401 | Socket (1) | Connecting to IP: 149.11.224.18. 2024-08-24 08:57:13.406 | F.US.FDXSU24 [CBV][M] Daily #6 | Chart data loading complete. 2024-08-24 08:57:13.411 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 08:57:13.411 | Denali Data Feed | Sending logon request message. 2024-08-24 08:57:13.412 | F.US.FDXSU24 [CBV][M] Daily #5 | Reloading chart. 2024-08-24 08:57:13.431 | HD Request # 53 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:13.431 | HD Request # 53 | Sending historical data logon request message. 2024-08-24 08:57:13.445 | Socket (1) | CloseSocket call. 2024-08-24 08:57:13.445 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:13.459 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:57:13.459 | Socket (1) | Closed. 2024-08-24 08:57:13.506 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-08-24 08:57:13.629 | F.US.FDXSU24 [CBV][M] Daily #5 | Dates not found while checking for invalid data in continuous contract data files. F.US.FDXSM21 * 2024-08-24 08:57:13.629 | Unable to determine transition date based on volume from files: F.US.FDXSZ14.dly, F.US.FDXSH15.dly 2024-08-24 08:57:13.629 | The F.US.FDXSH15.dly symbol may not be the active contract month. 2024-08-24 08:57:13.630 | Unable to determine transition date based on volume from files: F.US.FDXSH15.dly, F.US.FDXSM15.dly 2024-08-24 08:57:13.630 | The F.US.FDXSM15.dly symbol may not be the active contract month. 2024-08-24 08:57:13.630 | Unable to determine transition date based on volume from files: F.US.FDXSM15.dly, F.US.FDXSU15.dly 2024-08-24 08:57:13.630 | The F.US.FDXSU15.dly symbol may not be the active contract month. 2024-08-24 08:57:13.630 | Unable to determine transition date based on volume from files: F.US.FDXSU15.dly, F.US.FDXSZ15.dly 2024-08-24 08:57:13.630 | The F.US.FDXSZ15.dly symbol may not be the active contract month. 2024-08-24 08:57:13.630 | Unable to determine transition date based on volume from files: F.US.FDXSZ15.dly, F.US.FDXSH16.dly 2024-08-24 08:57:13.630 | The F.US.FDXSH16.dly symbol may not be the active contract month. 2024-08-24 08:57:13.630 | Unable to determine transition date based on volume from files: F.US.FDXSH16.dly, F.US.FDXSM16.dly 2024-08-24 08:57:13.630 | The F.US.FDXSM16.dly symbol may not be the active contract month. 2024-08-24 08:57:13.630 | Unable to determine transition date based on volume from files: F.US.FDXSM16.dly, F.US.FDXSU16.dly 2024-08-24 08:57:13.630 | The F.US.FDXSU16.dly symbol may not be the active contract month. 2024-08-24 08:57:13.630 | Unable to determine transition date based on volume from files: F.US.FDXSU16.dly, F.US.FDXSZ16.dly 2024-08-24 08:57:13.630 | The F.US.FDXSZ16.dly symbol may not be the active contract month. 2024-08-24 08:57:13.630 | Unable to determine transition date based on volume from files: F.US.FDXSZ16.dly, F.US.FDXSH17.dly 2024-08-24 08:57:13.630 | The F.US.FDXSH17.dly symbol may not be the active contract month. 2024-08-24 08:57:13.630 | Unable to determine transition date based on volume from files: F.US.FDXSH17.dly, F.US.FDXSM17.dly 2024-08-24 08:57:13.630 | The F.US.FDXSM17.dly symbol may not be the active contract month. 2024-08-24 08:57:13.631 | Unable to determine transition date based on volume from files: F.US.FDXSM17.dly, F.US.FDXSU17.dly 2024-08-24 08:57:13.631 | The F.US.FDXSU17.dly symbol may not be the active contract month. 2024-08-24 08:57:13.631 | Unable to determine transition date based on volume from files: F.US.FDXSU17.dly, F.US.FDXSZ17.dly 2024-08-24 08:57:13.631 | The F.US.FDXSZ17.dly symbol may not be the active contract month. 2024-08-24 08:57:13.631 | Unable to determine transition date based on volume from files: F.US.FDXSZ17.dly, F.US.FDXSH18.dly 2024-08-24 08:57:13.631 | The F.US.FDXSH18.dly symbol may not be the active contract month. 2024-08-24 08:57:13.631 | Unable to determine transition date based on volume from files: F.US.FDXSH18.dly, F.US.FDXSM18.dly 2024-08-24 08:57:13.631 | The F.US.FDXSM18.dly symbol may not be the active contract month. 2024-08-24 08:57:13.631 | Unable to determine transition date based on volume from files: F.US.FDXSM18.dly, F.US.FDXSU18.dly 2024-08-24 08:57:13.631 | The F.US.FDXSU18.dly symbol may not be the active contract month. 2024-08-24 08:57:13.631 | Unable to determine transition date based on volume from files: F.US.FDXSU18.dly, F.US.FDXSZ18.dly 2024-08-24 08:57:13.631 | The F.US.FDXSZ18.dly symbol may not be the active contract month. 2024-08-24 08:57:13.631 | Unable to determine transition date based on volume from files: F.US.FDXSZ18.dly, F.US.FDXSH19.dly 2024-08-24 08:57:13.631 | The F.US.FDXSH19.dly symbol may not be the active contract month. 2024-08-24 08:57:13.631 | Unable to determine transition date based on volume from files: F.US.FDXSH19.dly, F.US.FDXSM19.dly 2024-08-24 08:57:13.631 | The F.US.FDXSM19.dly symbol may not be the active contract month. 2024-08-24 08:57:13.631 | Unable to determine transition date based on volume from files: F.US.FDXSM19.dly, F.US.FDXSU19.dly 2024-08-24 08:57:13.631 | The F.US.FDXSU19.dly symbol may not be the active contract month. 2024-08-24 08:57:13.632 | Unable to determine transition date based on volume from files: F.US.FDXSU19.dly, F.US.FDXSZ19.dly 2024-08-24 08:57:13.632 | The F.US.FDXSZ19.dly symbol may not be the active contract month. 2024-08-24 08:57:13.632 | Unable to determine transition date based on volume from files: F.US.FDXSZ19.dly, F.US.FDXSH20.dly 2024-08-24 08:57:13.632 | The F.US.FDXSH20.dly symbol may not be the active contract month. 2024-08-24 08:57:13.632 | Unable to determine transition date based on volume from files: F.US.FDXSH20.dly, F.US.FDXSM20.dly 2024-08-24 08:57:13.632 | The F.US.FDXSM20.dly symbol may not be the active contract month. 2024-08-24 08:57:13.632 | Unable to determine transition date based on volume from files: F.US.FDXSM20.dly, F.US.FDXSU20.dly 2024-08-24 08:57:13.632 | The F.US.FDXSU20.dly symbol may not be the active contract month. 2024-08-24 08:57:13.632 | Unable to determine transition date based on volume from files: F.US.FDXSU20.dly, F.US.FDXSZ20.dly 2024-08-24 08:57:13.632 | The F.US.FDXSZ20.dly symbol may not be the active contract month. 2024-08-24 08:57:13.632 | Unable to determine transition date based on volume from files: F.US.FDXSZ20.dly, F.US.FDXSH21.dly 2024-08-24 08:57:13.632 | The F.US.FDXSH21.dly symbol may not be the active contract month. 2024-08-24 08:57:13.663 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2014-12-23 from file. C:\SierraChart\Data\F.US.FDXSZ14.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.663 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.664 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2015-03-24 from file. C:\SierraChart\Data\F.US.FDXSH15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.664 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.665 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2015-06-23 from file. C:\SierraChart\Data\F.US.FDXSM15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.665 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.666 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2015-09-22 from file. C:\SierraChart\Data\F.US.FDXSU15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.666 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.666 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2015-12-22 from file. C:\SierraChart\Data\F.US.FDXSZ15.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.666 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.667 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2016-03-22 from file. C:\SierraChart\Data\F.US.FDXSH16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.667 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.668 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2016-06-21 from file. C:\SierraChart\Data\F.US.FDXSM16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.668 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.669 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2016-09-20 from file. C:\SierraChart\Data\F.US.FDXSU16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.669 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.670 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2016-12-20 from file. C:\SierraChart\Data\F.US.FDXSZ16.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.670 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.671 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2017-03-21 from file. C:\SierraChart\Data\F.US.FDXSH17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.671 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.672 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2017-06-20 from file. C:\SierraChart\Data\F.US.FDXSM17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.672 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.673 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2017-09-19 from file. C:\SierraChart\Data\F.US.FDXSU17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.673 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.673 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2017-12-19 from file. C:\SierraChart\Data\F.US.FDXSZ17.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.673 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.674 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2018-03-20 from file. C:\SierraChart\Data\F.US.FDXSH18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.674 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.675 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2018-06-19 from file. C:\SierraChart\Data\F.US.FDXSM18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.675 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.676 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2018-09-25 from file. C:\SierraChart\Data\F.US.FDXSU18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.676 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.677 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2018-12-25 from file. C:\SierraChart\Data\F.US.FDXSZ18.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.677 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.678 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2019-03-19 from file. C:\SierraChart\Data\F.US.FDXSH19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.678 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.679 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2019-06-25 from file. C:\SierraChart\Data\F.US.FDXSM19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.679 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.679 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2019-09-24 from file. C:\SierraChart\Data\F.US.FDXSU19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.679 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.680 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2019-12-24 from file. C:\SierraChart\Data\F.US.FDXSZ19.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.680 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.681 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2020-03-24 from file. C:\SierraChart\Data\F.US.FDXSH20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.681 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.682 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2020-06-23 from file. C:\SierraChart\Data\F.US.FDXSM20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.682 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSU20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.683 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2020-09-22 from file. C:\SierraChart\Data\F.US.FDXSU20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.683 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSZ20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.684 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2020-12-22 from file. C:\SierraChart\Data\F.US.FDXSZ20.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.684 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSH21.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.685 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 2021-03-23 from file. C:\SierraChart\Data\F.US.FDXSH21.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.685 | F.US.FDXSU24 [CBV][M] Daily #5 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\Data\F.US.FDXSM21.dly. Error: No Data for read. End of file. 2024-08-24 08:57:13.763 | HD Request # 53 | Error downloading historical Intraday data for F.US.FDXSH24. Historical data logon error: Serving data is disabled 2024-08-24 08:57:13.763 | Added historical Intraday data request for F.US.FDXSH24 to the queue. 2024-08-24 08:57:13.763 | Triggering next historical data download in queue. 2024-08-24 08:57:13.763 | Historical data download thread signaled to stop. 2024-08-24 08:57:13.763 | HD Request # 53 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSH24 2024-08-24 08:57:13.763 | HD Request # 53 | Completion time: 0s. 2024-08-24 08:57:13.763 | 2024-08-24 08:57:13.763 | DTC Client socket (2) | CloseSocket call. 2024-08-24 08:57:13.763 | HD Request # 54 | Downloading Intraday chart data for F.US.FDXSH24 to the file F.US.FDXSH24.scid. Service: eurex 2024-08-24 08:57:13.763 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-08-24 08:57:13.763 | DTC Client socket (2) | Closed. 2024-08-24 08:57:13.763 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-08-24 08:57:13.764 | HD Request # 54 | Download start date-time: 2024-03-15 12:58:46.000000. File last date-time: 2024-03-15 12:58:46.363000 2024-08-24 08:57:13.764 | Denali Data Feed | Received logon response. 2024-08-24 08:57:13.764 | Denali Data Feed | Server Name: RealTimeServer. 2024-08-24 08:57:13.764 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 08:57:13.764 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. 2024-08-24 08:57:13.764 | Denali Data Feed | Failed connections: 1 2024-08-24 08:57:13.764 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 08:57:13.764 | HD Request # 54 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:57:13.764 | Socket (1) | Creating socket. 2024-08-24 08:57:13.764 | Socket (1) | New receive buffer size: 0 2024-08-24 08:57:13.764 | Socket (1) | Connecting to IP: 176.9.9.252. 2024-08-24 08:57:13.764 | DTC Client socket (0) | CloseSocket call. 2024-08-24 08:57:13.764 | Denali Data Feed | Disconnected from the server. 2024-08-24 08:57:13.764 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-08-24 08:57:13.767 | CQG WebAPI | Sending positions subscribe request. RequestID: 982656 2024-08-24 08:57:13.768 | CQG WebAPI | Sending orders subscribe request. RequestID: 982657 2024-08-24 08:57:13.806 | F.US.FDXSU24 [CBV][M] Daily #5 | Chart data loading complete. 2024-08-24 08:57:13.817 | HD Request # 54 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:13.817 | HD Request # 54 | Sending historical data logon request message. 2024-08-24 08:57:13.842 | HD Request # 54 | Requesting Intraday data. Start date-time: 2024-03-15 12:58:46. Record interval: 0. Symbol: FDXS202403_FUT_EUREX 2024-08-24 08:57:13.866 | HD Request # 54 | Decompressing data. 2024-08-24 08:57:13.889 | HD Request # 54 | Receiving Intraday data for F.US.FDXSH24 starting at 2024-03-15 12:58:46.363000 2024-08-24 08:57:13.889 | Socket (1) | CloseSocket call. 2024-08-24 08:57:13.890 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:13.890 | Historical data download thread signaled to stop. 2024-08-24 08:57:13.890 | HD Request # 54 | Received 1 Intraday data record from 2024-03-15 12:58:46.363000 to 2024-03-15 12:58:46.363000 (0.0 seconds. Delay: 161.8 days) and wrote 0 records for F.US.FDXSH24 2024-08-24 08:57:13.891 | HD Request # 54 | Add time&sales data | Remembered last file record date-time: 2024-03-15 11:58:46.363000 2024-08-24 08:57:13.891 | HD Request # 54 | Completion time: 0s. 2024-08-24 08:57:13.891 | HD Request # 54 | Intraday data download complete for F.US.FDXSH24. Unique request ID: 27 2024-08-24 08:57:13.891 | Removing historical data download ID 27. 2024-08-24 08:57:13.891 | Real-time Intraday chart data file updates started for F.US.FDXSH24 2024-08-24 08:57:13.891 | Intraday chart data file opened for F.US.FDXSH24 2024-08-24 08:57:13.891 | HD Request # 54 | Enabling Intraday chart updating for symbol. 2024-08-24 08:57:13.891 | 2024-08-24 08:57:13.891 | Triggering next historical data download in queue. 2024-08-24 08:57:13.891 | Historical data for F.US.FDXSH24 is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:57:13.892 | Mapping F.US.FDXSM24 to FDXS202406_FUT_EUREX. Service code: eurex 2024-08-24 08:57:13.892 | HD Request # 55 | Downloading Intraday chart data for F.US.FDXSM24 to the file F.US.FDXSM24.scid. Service: eurex 2024-08-24 08:57:13.893 | HD Request # 55 | Download start date-time: 2024-06-21 12:56:11.000000. File last date-time: 2024-06-21 12:56:11.173000 2024-08-24 08:57:13.893 | HD Request # 55 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:57:13.893 | Socket (2) | Creating socket. 2024-08-24 08:57:13.893 | Socket (2) | New receive buffer size: 0 2024-08-24 08:57:13.893 | Socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 08:57:13.915 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:57:13.915 | Socket (1) | Closed. 2024-08-24 08:57:13.927 | HD Request # 55 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:13.927 | HD Request # 55 | Sending historical data logon request message. 2024-08-24 08:57:13.941 | Socket (2) | CloseSocket call. 2024-08-24 08:57:13.941 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:13.941 | HD Request # 55 | Error downloading historical Intraday data for F.US.FDXSM24. Historical data logon error: Serving data is disabled 2024-08-24 08:57:13.941 | Added historical Intraday data request for F.US.FDXSM24 to the queue. 2024-08-24 08:57:13.941 | Triggering next historical data download in queue. 2024-08-24 08:57:13.941 | Historical data download thread signaled to stop. 2024-08-24 08:57:13.942 | HD Request # 55 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSM24 2024-08-24 08:57:13.942 | HD Request # 55 | Completion time: 0s. 2024-08-24 08:57:13.942 | 2024-08-24 08:57:13.942 | HD Request # 56 | Downloading Intraday chart data for F.US.FDXSM24 to the file F.US.FDXSM24.scid. Service: eurex 2024-08-24 08:57:13.942 | HD Request # 56 | Download start date-time: 2024-06-21 12:56:11.000000. File last date-time: 2024-06-21 12:56:11.173000 2024-08-24 08:57:13.943 | HD Request # 56 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:57:13.943 | Socket (1) | Creating socket. 2024-08-24 08:57:13.943 | Socket (1) | New receive buffer size: 0 2024-08-24 08:57:13.943 | Socket (1) | Connecting to IP: 176.9.9.252. 2024-08-24 08:57:13.957 | Socket (2) | Socket gracefully closed by remote side. 2024-08-24 08:57:13.957 | Socket (2) | Closed. 2024-08-24 08:57:14.001 | HD Request # 56 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:14.001 | HD Request # 56 | Sending historical data logon request message. 2024-08-24 08:57:14.027 | HD Request # 56 | Requesting Intraday data. Start date-time: 2024-06-21 12:56:11. Record interval: 0. Symbol: FDXS202406_FUT_EUREX 2024-08-24 08:57:14.054 | HD Request # 56 | Decompressing data. 2024-08-24 08:57:14.079 | HD Request # 56 | Receiving Intraday data for F.US.FDXSM24 starting at 2024-06-21 12:56:11.173000 2024-08-24 08:57:14.079 | Socket (1) | CloseSocket call. 2024-08-24 08:57:14.079 | Socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:14.079 | Historical data download thread signaled to stop. 2024-08-24 08:57:14.079 | HD Request # 56 | Received 1 Intraday data record from 2024-06-21 12:56:11.173000 to 2024-06-21 12:56:11.173000 (0.0 seconds. Delay: 63.8 days) and wrote 0 records for F.US.FDXSM24 2024-08-24 08:57:14.080 | HD Request # 56 | Add time&sales data | Remembered last file record date-time: 2024-06-21 10:56:11.173000 2024-08-24 08:57:14.080 | HD Request # 56 | Completion time: 1s. 2024-08-24 08:57:14.080 | HD Request # 56 | Intraday data download complete for F.US.FDXSM24. Unique request ID: 28 2024-08-24 08:57:14.080 | Removing historical data download ID 28. 2024-08-24 08:57:14.080 | Real-time Intraday chart data file updates started for F.US.FDXSM24 2024-08-24 08:57:14.080 | Intraday chart data file opened for F.US.FDXSM24 2024-08-24 08:57:14.080 | HD Request # 56 | Enabling Intraday chart updating for symbol. 2024-08-24 08:57:14.080 | 2024-08-24 08:57:14.080 | Triggering next historical data download in queue. 2024-08-24 08:57:14.080 | Historical data for F.US.FDXSM24 is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-08-24 08:57:14.080 | Delaying start of download for F.US.FDXSU24. 2024-08-24 08:57:14.105 | Socket (1) | Socket gracefully closed by remote side. 2024-08-24 08:57:14.105 | Socket (1) | Closed. 2024-08-24 08:57:16.780 | Denali Data Feed | Connecting to the server ds14.sierracharts.com. Port 443 2024-08-24 08:57:16.781 | DTC Client socket (1) | Creating socket. 2024-08-24 08:57:16.781 | DTC Client socket (1) | New receive buffer size: 0 2024-08-24 08:57:16.781 | DTC Client socket (1) | Connecting to IP: 176.9.9.252. 2024-08-24 08:57:16.807 | Denali Data Feed | Network connection to server complete. 2024-08-24 08:57:16.807 | Denali Data Feed | Starting socket receive thread. 2024-08-24 08:57:16.808 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 08:57:16.835 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 08:57:16.835 | Denali Data Feed | Sending logon request message. 2024-08-24 08:57:17.210 | Denali Data Feed | Received logon response. 2024-08-24 08:57:17.210 | Denali Data Feed | Server Name: SC Realtime Server. 2024-08-24 08:57:17.210 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 08:57:17.210 | Denali Data Feed | Successfully connected. 2024-08-24 08:57:17.210 | Denali Data Feed | Trading is not supported. 2024-08-24 08:57:17.210 | Denali Data Feed | MarketDepthIsSupported: 1 2024-08-24 08:57:17.210 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.FDXSU24 -> FDXS202409_FUT_EUREX 2024-08-24 08:57:17.335 | Denali Data Feed | Real-time data for symbol F.US.FDXSU24 is currently unavailable. 2024-08-24 08:57:17.335 | Denali Data Feed | Setting external service identifier for symbol F.US.FDXSU24 to 10451688 2024-08-24 08:57:17.335 | Denali Data Feed | Received security definition for symbol F.US.FDXSU24 2024-08-24 08:57:22.298 | HD Request # 57 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 08:57:22.300 | HD Request # 57 | Download start date-time: 2024-08-22 07:01:30.000000. File last date-time: 2024-08-22 07:01:30.015000 2024-08-24 08:57:22.300 | HD Request # 57 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:57:22.300 | Socket (2) | Creating socket. 2024-08-24 08:57:22.300 | Socket (2) | New receive buffer size: 0 2024-08-24 08:57:22.300 | Socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 08:57:22.330 | HD Request # 57 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:22.330 | HD Request # 57 | Sending historical data logon request message. 2024-08-24 08:57:22.343 | Socket (2) | CloseSocket call. 2024-08-24 08:57:22.344 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:22.344 | HD Request # 57 | Error downloading historical Intraday data for F.US.FDXSU24. Historical data logon error: Serving data is disabled 2024-08-24 08:57:22.344 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 08:57:22.344 | Triggering next historical data download in queue. 2024-08-24 08:57:22.345 | Historical data download thread signaled to stop. 2024-08-24 08:57:22.345 | HD Request # 57 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSU24 2024-08-24 08:57:22.345 | HD Request # 57 | Completion time: 0s. 2024-08-24 08:57:22.345 | 2024-08-24 08:57:22.345 | HD Request # 58 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 08:57:22.346 | HD Request # 58 | Download start date-time: 2024-08-22 07:01:30.000000. File last date-time: 2024-08-22 07:01:30.015000 2024-08-24 08:57:22.347 | HD Request # 58 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:57:22.347 | Socket (3) | Creating socket. 2024-08-24 08:57:22.347 | Socket (3) | New receive buffer size: 0 2024-08-24 08:57:22.347 | Socket (3) | Connecting to IP: 176.9.9.252. 2024-08-24 08:57:22.358 | Socket (2) | Socket gracefully closed by remote side. 2024-08-24 08:57:22.358 | Socket (2) | Closed. 2024-08-24 08:57:22.404 | HD Request # 58 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:22.404 | HD Request # 58 | Sending historical data logon request message. 2024-08-24 08:57:22.429 | HD Request # 58 | Requesting Intraday data. Start date-time: 2024-08-22 07:01:30. Record interval: 0. Symbol: FDXS202409_FUT_EUREX 2024-08-24 08:57:22.457 | HD Request # 58 | Decompressing data. 2024-08-24 08:57:22.531 | HD Request # 58 | Receiving Intraday data for F.US.FDXSU24 starting at 2024-08-22 07:01:30.015000 2024-08-24 08:57:22.578 | Socket (3) | CloseSocket call. 2024-08-24 08:57:22.578 | Historical data download thread signaled to stop. 2024-08-24 08:57:22.578 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:22.578 | HD Request # 58 | Timestamp of first Intraday data file record written: 2024-08-22 07:03:11.884000. 2024-08-24 08:57:22.578 | HD Request # 58 | Received 22779 Intraday data records from 2024-08-22 07:01:30.015000 to 2024-08-23 22:03:41.805000 (39.0 hours. Delay: 10.9 hours) and wrote 22778 records for F.US.FDXSU24 2024-08-24 08:57:22.587 | HD Request # 58 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 08:57:22.587 | HD Request # 58 | Completion time: 0s. 2024-08-24 08:57:22.587 | HD Request # 58 | Intraday data download complete for F.US.FDXSU24. Unique request ID: 29 2024-08-24 08:57:22.587 | Removing historical data download ID 29. 2024-08-24 08:57:22.587 | Real-time Intraday chart data file updates started for F.US.FDXSU24 2024-08-24 08:57:22.587 | Intraday chart data file opened for F.US.FDXSU24 2024-08-24 08:57:22.587 | HD Request # 58 | Enabling Intraday chart updating for symbol. 2024-08-24 08:57:22.587 | 2024-08-24 08:57:22.587 | Triggering next historical data download in queue. 2024-08-24 08:57:22.587 | Mapping F.US.DDZ23 to FDAX202312_FUT_EUREX. Service code: eurex 2024-08-24 08:57:22.587 | HD Request # 59 | Downloading Intraday chart data for F.US.DDZ23 to the file F.US.DDZ23.scid. Service: eurex 2024-08-24 08:57:22.587 | HD Request # 59 | Download start date-time: 2023-12-15 12:56:03.000000. File last date-time: 2023-12-15 12:56:03.082001 2024-08-24 08:57:22.587 | HD Request # 59 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:57:22.587 | Socket (2) | Creating socket. 2024-08-24 08:57:22.587 | Socket (2) | New receive buffer size: 0 2024-08-24 08:57:22.587 | Socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 08:57:22.605 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 08:57:22.605 | Socket (3) | Closed. 2024-08-24 08:57:22.620 | HD Request # 59 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:22.620 | HD Request # 59 | Sending historical data logon request message. 2024-08-24 08:57:22.634 | Socket (2) | CloseSocket call. 2024-08-24 08:57:22.634 | HD Request # 59 | Error downloading historical Intraday data for F.US.DDZ23. Historical data logon error: Serving data is disabled 2024-08-24 08:57:22.634 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:22.634 | Added historical Intraday data request for F.US.DDZ23 to the queue. 2024-08-24 08:57:22.634 | Triggering next historical data download in queue. 2024-08-24 08:57:22.634 | Historical data download thread signaled to stop. 2024-08-24 08:57:22.634 | HD Request # 59 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DDZ23 2024-08-24 08:57:22.634 | HD Request # 59 | Completion time: 0s. 2024-08-24 08:57:22.634 | 2024-08-24 08:57:22.634 | HD Request # 60 | Downloading Intraday chart data for F.US.DDZ23 to the file F.US.DDZ23.scid. Service: eurex 2024-08-24 08:57:22.634 | HD Request # 60 | Download start date-time: 2023-12-15 12:56:03.000000. File last date-time: 2023-12-15 12:56:03.082001 2024-08-24 08:57:22.634 | HD Request # 60 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:57:22.634 | Socket (3) | Creating socket. 2024-08-24 08:57:22.634 | Socket (3) | New receive buffer size: 0 2024-08-24 08:57:22.634 | Socket (3) | Connecting to IP: 176.9.9.252. 2024-08-24 08:57:22.656 | Socket (2) | Socket gracefully closed by remote side. 2024-08-24 08:57:22.656 | Socket (2) | Closed. 2024-08-24 08:57:22.683 | F.US.FDXSU24 [CBV][M] #18 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:57:22.684 | F.US.FDXSU24 [CBV][M] #18 | Reloading chart. 2024-08-24 08:57:22.697 | HD Request # 60 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:22.697 | HD Request # 60 | Sending historical data logon request message. 2024-08-24 08:57:22.723 | HD Request # 60 | Requesting Intraday data. Start date-time: 2023-12-15 12:56:03. Record interval: 0. Symbol: FDAX202312_FUT_EUREX 2024-08-24 08:57:22.748 | HD Request # 60 | Decompressing data. 2024-08-24 08:57:22.750 | F.US.FDXSU24 [CBV][M] #7 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:57:22.751 | F.US.FDXSU24 [CBV][M] #7 | Reloading chart. 2024-08-24 08:57:22.772 | HD Request # 60 | Receiving Intraday data for F.US.DDZ23 starting at 2023-12-15 12:56:03.081000 2024-08-24 08:57:22.772 | Socket (3) | CloseSocket call. 2024-08-24 08:57:22.772 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:22.798 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 08:57:22.798 | Socket (3) | Closed. 2024-08-24 08:57:22.861 | Historical data download thread signaled to stop. 2024-08-24 08:57:22.861 | HD Request # 60 | Received 3 Intraday data records from 2023-12-15 12:56:03.081000 to 2023-12-15 12:56:03.082001 (0.0 seconds. Delay: 252.8 days) and wrote 0 records for F.US.DDZ23 2024-08-24 08:57:22.861 | HD Request # 60 | Add time&sales data | Remembered last file record date-time: 2023-12-15 11:56:03.082001 2024-08-24 08:57:22.861 | HD Request # 60 | Completion time: 0s. 2024-08-24 08:57:22.861 | HD Request # 60 | Intraday data download complete for F.US.DDZ23. Unique request ID: 31 2024-08-24 08:57:22.861 | Removing historical data download ID 31. 2024-08-24 08:57:22.861 | Real-time Intraday chart data file updates started for F.US.DDZ23 2024-08-24 08:57:22.861 | Intraday chart data file opened for F.US.DDZ23 2024-08-24 08:57:22.861 | HD Request # 60 | Enabling Intraday chart updating for symbol. 2024-08-24 08:57:22.861 | 2024-08-24 08:57:22.861 | Triggering next historical data download in queue. 2024-08-24 08:57:22.861 | Mapping F.US.DDH24 to FDAX202403_FUT_EUREX. Service code: eurex 2024-08-24 08:57:22.861 | HD Request # 61 | Downloading Intraday chart data for F.US.DDH24 to the file F.US.DDH24.scid. Service: eurex 2024-08-24 08:57:22.861 | HD Request # 61 | Download start date-time: 2024-03-15 12:59:54.000000. File last date-time: 2024-03-15 12:59:54.128000 2024-08-24 08:57:22.861 | HD Request # 61 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:57:22.861 | Socket (2) | Creating socket. 2024-08-24 08:57:22.862 | Socket (2) | New receive buffer size: 0 2024-08-24 08:57:22.862 | Socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 08:57:22.862 | F.US.FDXSU24 [CBV][M] 1 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:57:22.862 | F.US.FDXSU24 [CBV][M] 1 Min #3 | Reloading chart. 2024-08-24 08:57:22.893 | HD Request # 61 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:22.893 | HD Request # 61 | Sending historical data logon request message. 2024-08-24 08:57:22.906 | Socket (2) | CloseSocket call. 2024-08-24 08:57:22.906 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:22.913 | HD Request # 61 | Error downloading historical Intraday data for F.US.DDH24. Historical data logon error: Serving data is disabled 2024-08-24 08:57:22.913 | Added historical Intraday data request for F.US.DDH24 to the queue. 2024-08-24 08:57:22.913 | Triggering next historical data download in queue. 2024-08-24 08:57:22.913 | Historical data download thread signaled to stop. 2024-08-24 08:57:22.914 | HD Request # 61 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DDH24 2024-08-24 08:57:22.914 | HD Request # 61 | Completion time: 0s. 2024-08-24 08:57:22.914 | 2024-08-24 08:57:22.914 | HD Request # 62 | Downloading Intraday chart data for F.US.DDH24 to the file F.US.DDH24.scid. Service: eurex 2024-08-24 08:57:22.914 | HD Request # 62 | Download start date-time: 2024-03-15 12:59:54.000000. File last date-time: 2024-03-15 12:59:54.128000 2024-08-24 08:57:22.914 | HD Request # 62 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:57:22.914 | Socket (3) | Creating socket. 2024-08-24 08:57:22.914 | Socket (3) | New receive buffer size: 0 2024-08-24 08:57:22.914 | Socket (3) | Connecting to IP: 176.9.9.252. 2024-08-24 08:57:22.915 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:57:22.916 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Reloading chart. 2024-08-24 08:57:22.925 | Socket (2) | Socket gracefully closed by remote side. 2024-08-24 08:57:22.925 | Socket (2) | Closed. 2024-08-24 08:57:22.968 | F.US.FDXSU24 [CBV][M] 1200 Volume #21 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:57:22.968 | F.US.FDXSU24 [CBV][M] 1200 Volume #21 | Reloading chart. 2024-08-24 08:57:22.970 | HD Request # 62 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:22.970 | HD Request # 62 | Sending historical data logon request message. 2024-08-24 08:57:22.983 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:57:22.984 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Reloading chart. 2024-08-24 08:57:22.996 | HD Request # 62 | Requesting Intraday data. Start date-time: 2024-03-15 12:59:54. Record interval: 0. Symbol: FDAX202403_FUT_EUREX 2024-08-24 08:57:22.998 | F.US.FDXSU24 [CBV][M] 100 Volume #14 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:57:22.999 | F.US.FDXSU24 [CBV][M] 100 Volume #14 | Reloading chart. 2024-08-24 08:57:23.022 | HD Request # 62 | Decompressing data. 2024-08-24 08:57:23.047 | HD Request # 62 | Receiving Intraday data for F.US.DDH24 starting at 2024-03-15 12:59:54.128000 2024-08-24 08:57:23.047 | Socket (3) | CloseSocket call. 2024-08-24 08:57:23.047 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:23.062 | Historical data download thread signaled to stop. 2024-08-24 08:57:23.062 | HD Request # 62 | Received 1 Intraday data record from 2024-03-15 12:59:54.128000 to 2024-03-15 12:59:54.128000 (0.0 seconds. Delay: 161.8 days) and wrote 0 records for F.US.DDH24 2024-08-24 08:57:23.063 | HD Request # 62 | Add time&sales data | Remembered last file record date-time: 2024-03-15 11:59:54.128000 2024-08-24 08:57:23.063 | HD Request # 62 | Completion time: 1s. 2024-08-24 08:57:23.063 | HD Request # 62 | Intraday data download complete for F.US.DDH24. Unique request ID: 32 2024-08-24 08:57:23.063 | Removing historical data download ID 32. 2024-08-24 08:57:23.063 | Real-time Intraday chart data file updates started for F.US.DDH24 2024-08-24 08:57:23.063 | Intraday chart data file opened for F.US.DDH24 2024-08-24 08:57:23.063 | HD Request # 62 | Enabling Intraday chart updating for symbol. 2024-08-24 08:57:23.063 | 2024-08-24 08:57:23.063 | Triggering next historical data download in queue. 2024-08-24 08:57:23.063 | Mapping F.US.DDM24 to FDAX202406_FUT_EUREX. Service code: eurex 2024-08-24 08:57:23.063 | HD Request # 63 | Downloading Intraday chart data for F.US.DDM24 to the file F.US.DDM24.scid. Service: eurex 2024-08-24 08:57:23.063 | HD Request # 63 | Download start date-time: 2024-06-21 12:59:57.000000. File last date-time: 2024-06-21 12:59:57.123000 2024-08-24 08:57:23.063 | HD Request # 63 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:57:23.063 | Socket (2) | Creating socket. 2024-08-24 08:57:23.063 | Socket (2) | New receive buffer size: 0 2024-08-24 08:57:23.063 | Socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 08:57:23.063 | F.US.FDXSU24 [CBV][M] #8 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:57:23.064 | F.US.FDXSU24 [CBV][M] #8 | Reloading chart. 2024-08-24 08:57:23.085 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 08:57:23.085 | Socket (3) | Closed. 2024-08-24 08:57:23.103 | HD Request # 63 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:23.103 | HD Request # 63 | Sending historical data logon request message. 2024-08-24 08:57:23.117 | Socket (2) | CloseSocket call. 2024-08-24 08:57:23.117 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:23.132 | Socket (2) | Socket gracefully closed by remote side. 2024-08-24 08:57:23.132 | Socket (2) | Closed. 2024-08-24 08:57:23.233 | HD Request # 63 | Error downloading historical Intraday data for F.US.DDM24. Historical data logon error: Serving data is disabled 2024-08-24 08:57:23.233 | Added historical Intraday data request for F.US.DDM24 to the queue. 2024-08-24 08:57:23.233 | Triggering next historical data download in queue. 2024-08-24 08:57:23.233 | Historical data download thread signaled to stop. 2024-08-24 08:57:23.233 | HD Request # 63 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DDM24 2024-08-24 08:57:23.233 | HD Request # 63 | Completion time: 0s. 2024-08-24 08:57:23.233 | 2024-08-24 08:57:23.233 | HD Request # 64 | Downloading Intraday chart data for F.US.DDM24 to the file F.US.DDM24.scid. Service: eurex 2024-08-24 08:57:23.233 | HD Request # 64 | Download start date-time: 2024-06-21 12:59:57.000000. File last date-time: 2024-06-21 12:59:57.123000 2024-08-24 08:57:23.233 | HD Request # 64 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:57:23.233 | Socket (2) | Creating socket. 2024-08-24 08:57:23.233 | Socket (2) | New receive buffer size: 0 2024-08-24 08:57:23.233 | Socket (2) | Connecting to IP: 176.9.9.252. 2024-08-24 08:57:23.233 | F.US.FDXSU24 [CBV][M] 10000 Volume #16 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:57:23.234 | F.US.FDXSU24 [CBV][M] 10000 Volume #16 | Reloading chart. 2024-08-24 08:57:23.267 | F.US.FDXSU24 [CBV][M] 25000 Volume #13 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:57:23.267 | F.US.FDXSU24 [CBV][M] 25000 Volume #13 | Reloading chart. 2024-08-24 08:57:23.287 | HD Request # 64 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:23.287 | HD Request # 64 | Sending historical data logon request message. 2024-08-24 08:57:23.311 | HD Request # 64 | Requesting Intraday data. Start date-time: 2024-06-21 12:59:57. Record interval: 0. Symbol: FDAX202406_FUT_EUREX 2024-08-24 08:57:23.336 | HD Request # 64 | Decompressing data. 2024-08-24 08:57:23.354 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:57:23.355 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Reloading chart. 2024-08-24 08:57:23.359 | HD Request # 64 | Receiving Intraday data for F.US.DDM24 starting at 2024-06-21 12:59:57.123000 2024-08-24 08:57:23.359 | Socket (2) | CloseSocket call. 2024-08-24 08:57:23.359 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:23.385 | Socket (2) | Socket gracefully closed by remote side. 2024-08-24 08:57:23.385 | Socket (2) | Closed. 2024-08-24 08:57:23.416 | Historical data download thread signaled to stop. 2024-08-24 08:57:23.416 | HD Request # 64 | Received 1 Intraday data record from 2024-06-21 12:59:57.123000 to 2024-06-21 12:59:57.123000 (0.0 seconds. Delay: 63.8 days) and wrote 0 records for F.US.DDM24 2024-08-24 08:57:23.416 | HD Request # 64 | Add time&sales data | Remembered last file record date-time: 2024-06-21 10:59:57.123000 2024-08-24 08:57:23.416 | HD Request # 64 | Completion time: 0s. 2024-08-24 08:57:23.416 | HD Request # 64 | Intraday data download complete for F.US.DDM24. Unique request ID: 33 2024-08-24 08:57:23.416 | Removing historical data download ID 33. 2024-08-24 08:57:23.416 | Real-time Intraday chart data file updates started for F.US.DDM24 2024-08-24 08:57:23.416 | Intraday chart data file opened for F.US.DDM24 2024-08-24 08:57:23.416 | HD Request # 64 | Enabling Intraday chart updating for symbol. 2024-08-24 08:57:23.416 | 2024-08-24 08:57:23.416 | Triggering next historical data download in queue. 2024-08-24 08:57:23.416 | Mapping F.US.DDU24 to FDAX202409_FUT_EUREX. Service code: eurex 2024-08-24 08:57:23.416 | HD Request # 65 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 08:57:23.417 | HD Request # 65 | Download start date-time: 2024-08-22 06:56:27.000000. File last date-time: 2024-08-22 06:56:27.003000 2024-08-24 08:57:23.417 | HD Request # 65 | Using server: ds24.sierracharts.com port 10150 2024-08-24 08:57:23.417 | Socket (2) | Creating socket. 2024-08-24 08:57:23.417 | Socket (2) | New receive buffer size: 0 2024-08-24 08:57:23.417 | Socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 08:57:23.417 | F.US.FDXSU24 [CBV][M] #2 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:57:23.417 | F.US.FDXSU24 [CBV][M] #2 | Reloading chart. 2024-08-24 08:57:23.446 | HD Request # 65 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:23.446 | HD Request # 65 | Sending historical data logon request message. 2024-08-24 08:57:23.459 | Socket (2) | CloseSocket call. 2024-08-24 08:57:23.459 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:23.473 | Socket (2) | Socket gracefully closed by remote side. 2024-08-24 08:57:23.473 | Socket (2) | Closed. 2024-08-24 08:57:23.613 | HD Request # 65 | Error downloading historical Intraday data for F.US.DDU24. Historical data logon error: Serving data is disabled 2024-08-24 08:57:23.613 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 08:57:23.613 | Triggering next historical data download in queue. 2024-08-24 08:57:23.613 | Historical data download thread signaled to stop. 2024-08-24 08:57:23.613 | HD Request # 65 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DDU24 2024-08-24 08:57:23.613 | HD Request # 65 | Completion time: 0s. 2024-08-24 08:57:23.613 | 2024-08-24 08:57:23.613 | HD Request # 66 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 08:57:23.613 | HD Request # 66 | Download start date-time: 2024-08-22 06:56:27.000000. File last date-time: 2024-08-22 06:56:27.003000 2024-08-24 08:57:23.613 | HD Request # 66 | Using server: ds14.sierracharts.com port 10149 2024-08-24 08:57:23.614 | Socket (2) | Creating socket. 2024-08-24 08:57:23.614 | Socket (2) | New receive buffer size: 0 2024-08-24 08:57:23.614 | Socket (2) | Connecting to IP: 176.9.9.252. 2024-08-24 08:57:23.614 | F.US.FDXSU24 [CBV][M] #4 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:57:23.614 | F.US.FDXSU24 [CBV][M] #4 | Reloading chart. 2024-08-24 08:57:23.671 | HD Request # 66 | Setting DTC encoding to Binary VLS 2024-08-24 08:57:23.671 | HD Request # 66 | Sending historical data logon request message. 2024-08-24 08:57:23.698 | HD Request # 66 | Requesting Intraday data. Start date-time: 2024-08-22 06:56:27. Record interval: 0. Symbol: FDAX202409_FUT_EUREX 2024-08-24 08:57:23.724 | HD Request # 66 | Decompressing data. 2024-08-24 08:57:23.733 | F.US.FDXSU24 [CBV][M] #18 | Reloading chart. 2024-08-24 08:57:23.802 | HD Request # 66 | Receiving Intraday data for F.US.DDU24 starting at 2024-08-22 06:56:27.003000 2024-08-24 08:57:23.873 | HD Request # 66 | Timestamp of first Intraday data file record written: 2024-08-22 07:00:54.031000. 2024-08-24 08:57:23.914 | Socket (2) | CloseSocket call. 2024-08-24 08:57:23.936 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 08:57:23.968 | Socket (2) | Socket gracefully closed by remote side. 2024-08-24 08:57:23.968 | Socket (2) | Closed. 2024-08-24 08:57:24.067 | Historical data download thread signaled to stop. 2024-08-24 08:57:24.068 | HD Request # 66 | Received 59952 Intraday data records from 2024-08-22 06:56:27.003000 to 2024-08-23 22:03:41.805000 (39.1 hours. Delay: 10.9 hours) and wrote 59951 records for F.US.DDU24 2024-08-24 08:57:24.075 | HD Request # 66 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 08:57:24.075 | HD Request # 66 | Completion time: 1s. 2024-08-24 08:57:24.075 | HD Request # 66 | Intraday data download complete for F.US.DDU24. Unique request ID: 34 2024-08-24 08:57:24.075 | Removing historical data download ID 34. 2024-08-24 08:57:24.075 | Real-time Intraday chart data file updates started for F.US.DDU24 2024-08-24 08:57:24.075 | Intraday chart data file opened for F.US.DDU24 2024-08-24 08:57:24.075 | HD Request # 66 | Enabling Intraday chart updating for symbol. 2024-08-24 08:57:24.075 | 2024-08-24 08:57:24.075 | No download requests in the queue to start downloads for. 2024-08-24 08:57:24.085 | F.US.FDXSU24 [CBV][M] 1200 Volume #21 | Chart data loading complete. 2024-08-24 08:57:24.096 | F.US.DDU24 [CBV][M] #10 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 08:57:24.097 | F.US.DDU24 [CBV][M] #10 | Reloading chart. 2024-08-24 08:57:24.321 | F.US.FDXSU24 [CBV][M] #7 | Reloading chart. 2024-08-24 08:57:25.263 | F.US.FDXSU24 [CBV][M] 10000 Volume #16 | Chart data loading complete. 2024-08-24 08:57:25.264 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 08:57:32.485 | Chart #25 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:57:32.485 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Chart data loading complete. 2024-08-24 08:57:37.863 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 08:57:40.771 | Chart #12 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:57:40.771 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Chart data loading complete. 2024-08-24 08:57:40.777 | F.US.FDXSU24 [CBV][M] 25000 Volume #13 | Chart data loading complete. 2024-08-24 08:57:40.906 | F.US.FDXSU24 [CBV][M] #18 | Chart data loading complete. 2024-08-24 08:59:47.354 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:59:47.354 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:59:47.354 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:59:47.354 | F.US.FDXSU24 [CBV][M] 1 Min #3 | Chart data loading complete. 2024-08-24 08:59:47.363 | F.US.FDXSU24 [CBV][M] 100 Volume #14 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 08:59:47.543 | F.US.FDXSU24 [CBV][M] 100 Volume #14 | Chart data loading complete. 2024-08-24 08:59:47.691 | F.US.FDXSU24 [CBV][M] #4 | Chart data loading complete. 2024-08-24 08:59:47.692 | F.US.FDXSU24 [CBV][M] 1 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 08:59:54.417 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Chart data loading complete. 2024-08-24 08:59:54.573 | F.US.DDU24 [CBV][M] #10 | Chart data loading complete. 2024-08-24 08:59:54.984 | F.US.FDXSU24 [CBV][M] #7 | Chart data loading complete. 2024-08-24 08:59:54.985 | F.US.FDXSU24 [CBV][M] #8 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 08:59:55.497 | F.US.FDXSU24 [CBV][M] #8 | Chart data loading complete. 2024-08-24 08:59:56.046 | Chart #2 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:59:56.046 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:59:56.046 | Chart #2 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:59:56.046 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 08:59:56.046 | F.US.FDXSU24 [CBV][M] #2 | Chart data loading complete. 2024-08-24 09:00:06.587 | F.US.FDXSU24 [CBV][M] 1 Min #3 | Reloading chart. 2024-08-24 09:00:06.741 | F.US.DDU24 [CBV][M] #15 | Download is complete for all contract months in chart. Proceeding with data load. 2024-08-24 09:00:06.742 | F.US.DDU24 [CBV][M] #15 | Reloading chart. 2024-08-24 09:00:06.866 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Reloading chart. 2024-08-24 09:00:06.983 | F.US.FDXSU24 [CBV][M] 1200 Volume #21 | Reloading chart. 2024-08-24 09:00:07.044 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Reloading chart. 2024-08-24 09:00:07.100 | F.US.FDXSU24 [CBV][M] 100 Volume #14 | Reloading chart. 2024-08-24 09:00:07.224 | F.US.FDXSU24 [CBV][M] #8 | Reloading chart. 2024-08-24 09:00:07.673 | F.US.FDXSU24 [CBV][M] 1200 Volume #21 | Chart data loading complete. 2024-08-24 09:00:07.679 | F.US.FDXSU24 [CBV][M] 10000 Volume #16 | Reloading chart. 2024-08-24 09:00:07.759 | F.US.FDXSU24 [CBV][M] 25000 Volume #13 | Reloading chart. 2024-08-24 09:00:07.912 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Reloading chart. 2024-08-24 09:00:07.982 | F.US.FDXSU24 [CBV][M] #2 | Reloading chart. 2024-08-24 09:00:08.472 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 09:00:14.517 | Chart #25 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:00:14.517 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Chart data loading complete. 2024-08-24 09:00:19.821 | F.US.FDXSU24 [CBV][M] 10000 Volume #16 | Chart data loading complete. 2024-08-24 09:02:26.527 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:02:26.527 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:02:26.527 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:02:26.527 | F.US.FDXSU24 [CBV][M] 1 Min #3 | Chart data loading complete. 2024-08-24 09:02:26.546 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 09:02:29.600 | Chart #12 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:02:29.601 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Chart data loading complete. 2024-08-24 09:02:29.613 | F.US.FDXSU24 [CBV][M] 25000 Volume #13 | Chart data loading complete. 2024-08-24 09:02:29.613 | F.US.FDXSU24 [CBV][M] 100 Volume #14 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 09:02:29.803 | F.US.FDXSU24 [CBV][M] 100 Volume #14 | Chart data loading complete. 2024-08-24 09:02:29.953 | F.US.DDU24 [CBV][M] #15 | Chart data loading complete. 2024-08-24 09:02:29.954 | F.US.FDXSU24 [CBV][M] 1 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 09:02:37.033 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Chart data loading complete. 2024-08-24 09:02:37.034 | F.US.FDXSU24 [CBV][M] #8 | StartDateTimeForLoadingOrderFills: 2024-08-09 00:00:00 2024-08-24 09:02:37.599 | F.US.FDXSU24 [CBV][M] #8 | Chart data loading complete. 2024-08-24 09:02:38.269 | Chart #2 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:02:38.269 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:02:38.269 | Chart #2 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:02:38.269 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:02:38.269 | F.US.FDXSU24 [CBV][M] #2 | Chart data loading complete. 2024-08-24 09:02:49.036 | F.US.FDXSU24 [CBV][M] #4 | Reloading chart. 2024-08-24 09:02:49.167 | F.US.DDU24 [CBV][M] #10 | Reloading chart. 2024-08-24 09:02:49.345 | CQG WebSocket | Timeout waiting for pong message from server. 2024-08-24 09:02:49.345 | CQG WebAPI | WebSocket closed. 2024-08-24 09:02:49.345 | Connection to the external service has been lost. 2024-08-24 09:02:49.602 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. 2024-08-24 09:02:49.613 | F.US.DDU24 [CBV][M] #15 | Reloading chart. 2024-08-24 09:02:49.959 | CQG WebAPI | Sending Web API Logoff message. 2024-08-24 09:02:49.959 | CQG WebSocket socket (9) | CloseSocket call. 2024-08-24 09:02:49.959 | CQG WebSocket | WebSocket closed. 2024-08-24 09:02:49.959 | CQG WebAPI | WebSocket closed. 2024-08-24 09:02:49.959 | CQG WebAPI | Disconnected. 2024-08-24 09:02:49.959 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-08-24 09:02:49.959 | CQG WebSocket socket (9) | Write in progress. Shutdown being delayed. PendingSize=0 2024-08-24 09:02:49.968 | CQG WebSocket socket (9) | Write has completed. Shutdown being performed. 2024-08-24 09:02:49.968 | CQG WebSocket socket (9) | Shutdown started. Waiting for graceful close. 2024-08-24 09:02:49.983 | CQG WebSocket socket (9) | Socket gracefully closed by remote side. 2024-08-24 09:02:49.983 | CQG WebSocket socket (9) | Closed. 2024-08-24 09:02:50.253 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"Funded Trading Account Status Expiration Date Extended"}. Success=true 2024-08-24 09:02:50.807 | F.US.FDXSU24 [CBV][M] #4 | Chart data loading complete. 2024-08-24 09:02:51.506 | F.US.DDU24 [CBV][M] #10 | Chart data loading complete. 2024-08-24 09:02:51.953 | F.US.DDU24 [CBV][M] #15 | Chart data loading complete. 2024-08-24 09:02:51.957 | 2024-08-24 09:02:51.957 | CQG WebAPI | Connecting to server api.cqg.com 2024-08-24 09:02:51.957 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-08-24 09:02:52.056 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:02:52.060 | CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. 2024-08-24 09:02:52.060 | CQG WebSocket socket (2) | New receive buffer size: 0 2024-08-24 09:02:52.060 | CQG WebSocket socket (2) | Connecting to IP: 195.166.124.175. 2024-08-24 09:02:57.089 | CQG WebSocket socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:02:57.520 | Circular chart reference detected. Charts: 12, 25. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-24 09:02:57.525 | CQG WebSocket | Opening WebSocket. 2024-08-24 09:02:57.525 | CQG WebSocket | Sending WebSocket handshake. 2024-08-24 09:02:57.525 | CQG WebSocket socket (2) | CloseSocket call. 2024-08-24 09:02:57.525 | CQG WebSocket | Network socket for WebSocket has been closed by remote side or error. 2024-08-24 09:02:57.525 | CQG WebAPI | WebSocket closed. 2024-08-24 09:02:57.525 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-08-24 09:02:57.525 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-08-24 09:02:57.525 | CQG WebSocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 2024-08-24 09:02:57.535 | CQG WebSocket socket (2) | Write has completed. Shutdown being performed. 2024-08-24 09:02:57.535 | CQG WebSocket socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-08-24 09:02:57.535 | CQG WebSocket socket (2) | Closed. 2024-08-24 09:02:57.567 | F.US.FDXSU24 [CBV][M] 1 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:05:05.481 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:05:05.481 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:05:05.481 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:05:05.648 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:05:12.562 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:05:15.533 | Circular chart reference detected. Charts: 25, 12. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-24 09:05:15.599 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:05:21.058 | Circular chart reference detected. Charts: 12, 25. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-24 09:05:21.175 | CQG WebSocket socket (0) | CloseSocket call. 2024-08-24 09:05:21.175 | CQG WebAPI | Disconnected. 2024-08-24 09:05:21.175 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-08-24 09:05:23.176 | 2024-08-24 09:05:23.176 | CQG WebAPI | Connecting to server api.cqg.com 2024-08-24 09:05:23.176 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-08-24 09:05:23.176 | CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. 2024-08-24 09:05:23.176 | CQG WebSocket socket (2) | New receive buffer size: 0 2024-08-24 09:05:23.176 | CQG WebSocket socket (2) | Connecting to IP: 195.166.124.175. 2024-08-24 09:05:23.245 | CQG WebSocket | Opening WebSocket. 2024-08-24 09:05:23.245 | CQG WebSocket | Sending WebSocket handshake. 2024-08-24 09:05:23.276 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2024-08-24 09:05:23.276 | CQG WebSocket | Server header | Connection: Upgrade 2024-08-24 09:05:23.276 | CQG WebSocket | Server header | Sec-WebSocket-Accept: bRITsfoNFuuoX+v7t+rAM/VN7/U= 2024-08-24 09:05:23.276 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2024-08-24 09:05:23.276 | CQG WebSocket | Server header | Upgrade: websocket 2024-08-24 09:05:23.276 | CQG WebSocket | Server header | 2024-08-24 09:05:23.276 | CQG WebSocket | Web socket state is now open. 2024-08-24 09:05:23.276 | CQG WebAPI | WebSocket connected. 2024-08-24 09:05:23.276 | CQG WebAPI | Sending market data logon message. 2024-08-24 09:05:23.505 | CQG WebAPI | Base Time: 2024-08-04T06:16:49. 2024-08-04 06:16:49 2024-08-24 09:05:23.505 | CQG WebAPI | Logon successful. Session Token = kGLrrdHz0ehsNsXeECRZwOByqgtf3Yvu5i0NUOOcK3IlQlGHTAk6m/zhGbxEmUFEuU2M4e4TFrq 2024-08-24 09:05:23.505 | CQG WebAPI | Connected to server complete. 2024-08-24 09:05:23.505 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:05:23.506 | DTC Client socket (1) | CloseSocket call. 2024-08-24 09:05:23.506 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:05:23.506 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 09:05:23.507 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-24 09:05:23.507 | Updated verified funded futures trading account ending date to: 2024-09-23 07:05:23 2024-08-24 09:05:23.534 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-08-24 09:05:23.534 | DTC Client socket (1) | Closed. 2024-08-24 09:05:23.824 | CQG WebAPI | Sending Trade Accounts request message. 2024-08-24 09:05:23.825 | Mapping F.US.FDXSU24 to FDXS202409_FUT_EUREX. Service code: eurex 2024-08-24 09:05:23.825 | Using symbol data fast lookup vector 2024-08-24 09:05:23.825 | Denali Data Feed | Starting real-time market data updates for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 1 Service code: eurex 2024-08-24 09:05:23.825 | Denali Data Feed | Connecting to the server ds24.sierracharts.com. Port 443 2024-08-24 09:05:23.825 | CQG WebAPI | Sending symbol resolution request for F.US.FDXSU24. ID: 982659 2024-08-24 09:05:23.825 | Denali Data Feed | Requesting security definition data for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 1 2024-08-24 09:05:23.825 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:05:23.825 | Intraday data recording state for symbol F.US.FDXSU24 is set to download 'Pending'. 2024-08-24 09:05:23.825 | Triggering next historical data download in queue. 2024-08-24 09:05:23.825 | DTC Client socket (1) | Creating socket. 2024-08-24 09:05:23.825 | DTC Client socket (1) | New receive buffer size: 0 2024-08-24 09:05:23.825 | DTC Client socket (1) | Connecting to IP: 149.11.224.18. 2024-08-24 09:05:23.839 | Delaying start of download for F.US.FDXSU24. 2024-08-24 09:05:23.839 | CQG WebAPI | Received symbol resolution report for symbol F.US.FDXSU24. Search Symbol: F.US.FDXSU24. Request ID: 982659. Contract ID: 1. 2024-08-24 09:05:23.839 | CQG WebAPI | Brokerage name: WH Selfinvest France. Account Name: LWHF0931 2024-08-24 09:05:23.839 | Updated verified funded futures trading account ending date to: 2024-09-23 07:05:23 2024-08-24 09:05:23.839 | CQG WebAPI | Sending collateral subscribe request. 2024-08-24 09:05:23.871 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:05:23.871 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:05:23.871 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:05:23.915 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:05:23.915 | Denali Data Feed | Sending logon request message. 2024-08-24 09:05:23.998 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-08-24 09:05:24.054 | DTC Client socket (1) | CloseSocket call. 2024-08-24 09:05:24.054 | DTC Client socket (1) | Signaling for receive thread to end. Bytes in receive buffer: 167 2024-08-24 09:05:24.054 | Denali Data Feed | Received logon response. 2024-08-24 09:05:24.054 | Denali Data Feed | Server Name: RealTimeServer. 2024-08-24 09:05:24.054 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:05:24.054 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. 2024-08-24 09:05:24.054 | Denali Data Feed | Failed connections: 1 2024-08-24 09:05:24.054 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-08-24 09:05:24.054 | DTC Client socket (1) | Closed. 2024-08-24 09:05:24.054 | DTC Client socket (0) | CloseSocket call. 2024-08-24 09:05:24.054 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-08-24 09:05:24.054 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:05:24.054 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-08-24 09:05:24.132 | CQG WebAPI | Sending positions subscribe request. RequestID: 982661 2024-08-24 09:05:24.132 | CQG WebAPI | Sending orders subscribe request. RequestID: 982662 2024-08-24 09:05:24.132 | Mapping F.US.DDU24 to FDAX202409_FUT_EUREX. Service code: eurex 2024-08-24 09:05:24.132 | Denali Data Feed | Starting real-time market data updates for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 2 Service code: eurex 2024-08-24 09:05:24.132 | CQG WebAPI | Sending symbol resolution request for F.US.DDU24. ID: 982663 2024-08-24 09:05:24.132 | Denali Data Feed | Requesting security definition data for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 2 2024-08-24 09:05:24.132 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:05:24.132 | Intraday data recording state for symbol F.US.DDU24 is set to download 'Pending'. 2024-08-24 09:05:24.132 | Triggering next historical data download in queue. 2024-08-24 09:05:24.150 | CQG WebAPI | Received symbol resolution report for symbol F.US.DDU24. Search Symbol: F.US.DDU24. Request ID: 982663. Contract ID: 2. 2024-08-24 09:05:27.055 | Denali Data Feed | Connecting to the server ds14.sierracharts.com. Port 443 2024-08-24 09:05:27.056 | DTC Client socket (1) | Creating socket. 2024-08-24 09:05:27.056 | DTC Client socket (1) | New receive buffer size: 0 2024-08-24 09:05:27.056 | DTC Client socket (1) | Connecting to IP: 176.9.9.252. 2024-08-24 09:05:27.095 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:05:27.095 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:05:27.095 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:05:27.151 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:05:27.151 | Denali Data Feed | Sending logon request message. 2024-08-24 09:05:27.525 | Denali Data Feed | Received logon response. 2024-08-24 09:05:27.525 | Denali Data Feed | Server Name: SC Realtime Server. 2024-08-24 09:05:27.525 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:05:27.525 | Denali Data Feed | Successfully connected. 2024-08-24 09:05:27.525 | Denali Data Feed | Trading is not supported. 2024-08-24 09:05:27.525 | Denali Data Feed | MarketDepthIsSupported: 1 2024-08-24 09:05:27.525 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.DDU24 -> FDAX202409_FUT_EUREX 2024-08-24 09:05:27.525 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.FDXSU24 -> FDXS202409_FUT_EUREX 2024-08-24 09:05:27.650 | Denali Data Feed | Real-time data for symbol F.US.DDU24 is currently unavailable. 2024-08-24 09:05:27.650 | Denali Data Feed | Setting external service identifier for symbol F.US.DDU24 to 7296071 2024-08-24 09:05:27.650 | Denali Data Feed | Received security definition for symbol F.US.DDU24 2024-08-24 09:05:27.650 | Denali Data Feed | Real-time data for symbol F.US.FDXSU24 is currently unavailable. 2024-08-24 09:05:27.650 | Denali Data Feed | Setting external service identifier for symbol F.US.FDXSU24 to 10451688 2024-08-24 09:05:27.650 | Denali Data Feed | Received security definition for symbol F.US.FDXSU24 2024-08-24 09:05:32.070 | HD Request # 67 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:05:32.072 | HD Request # 67 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:05:32.072 | HD Request # 67 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:05:32.072 | Socket (3) | Creating socket. 2024-08-24 09:05:32.072 | Socket (3) | New receive buffer size: 0 2024-08-24 09:05:32.072 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:05:32.102 | HD Request # 67 | Setting DTC encoding to Binary VLS 2024-08-24 09:05:32.102 | HD Request # 67 | Sending historical data logon request message. 2024-08-24 09:05:32.116 | Socket (3) | CloseSocket call. 2024-08-24 09:05:32.116 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:05:32.130 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:05:32.130 | Socket (3) | Closed. 2024-08-24 09:05:32.165 | HD Request # 67 | Error downloading historical Intraday data for F.US.FDXSU24. Historical data logon error: Serving data is disabled 2024-08-24 09:05:32.165 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:05:32.165 | Triggering next historical data download in queue. 2024-08-24 09:05:32.165 | Historical data download thread signaled to stop. 2024-08-24 09:05:32.165 | HD Request # 67 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSU24 2024-08-24 09:05:32.165 | HD Request # 67 | Completion time: 0s. 2024-08-24 09:05:32.165 | 2024-08-24 09:05:32.165 | HD Request # 68 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:05:32.165 | HD Request # 68 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:05:32.165 | HD Request # 68 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:05:32.165 | Socket (3) | Creating socket. 2024-08-24 09:05:32.166 | Socket (3) | New receive buffer size: 0 2024-08-24 09:05:32.166 | Socket (3) | Connecting to IP: 176.9.9.252. 2024-08-24 09:05:32.221 | HD Request # 68 | Setting DTC encoding to Binary VLS 2024-08-24 09:05:32.221 | HD Request # 68 | Sending historical data logon request message. 2024-08-24 09:05:32.372 | HD Request # 68 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDXS202409_FUT_EUREX 2024-08-24 09:05:32.399 | HD Request # 68 | Decompressing data. 2024-08-24 09:05:32.424 | HD Request # 68 | Receiving Intraday data for F.US.FDXSU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:05:32.424 | Socket (3) | CloseSocket call. 2024-08-24 09:05:32.424 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:05:32.424 | Historical data download thread signaled to stop. 2024-08-24 09:05:32.424 | HD Request # 68 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.0 hours) and wrote 0 records for F.US.FDXSU24 2024-08-24 09:05:32.424 | HD Request # 68 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:05:32.424 | HD Request # 68 | Completion time: 0s. 2024-08-24 09:05:32.424 | HD Request # 68 | Intraday data download complete for F.US.FDXSU24. Unique request ID: 37 2024-08-24 09:05:32.424 | Removing historical data download ID 37. 2024-08-24 09:05:32.424 | Real-time Intraday chart data file updates started for F.US.FDXSU24 2024-08-24 09:05:32.424 | Intraday chart data file opened for F.US.FDXSU24 2024-08-24 09:05:32.424 | HD Request # 68 | Enabling Intraday chart updating for symbol. 2024-08-24 09:05:32.424 | 2024-08-24 09:05:32.424 | Triggering next historical data download in queue. 2024-08-24 09:05:32.424 | HD Request # 69 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:05:32.425 | HD Request # 69 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:05:32.425 | HD Request # 69 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:05:32.425 | Socket (4) | Creating socket. 2024-08-24 09:05:32.425 | Socket (4) | New receive buffer size: 0 2024-08-24 09:05:32.425 | Socket (4) | Connecting to IP: 149.11.224.18. 2024-08-24 09:05:32.450 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:05:32.450 | Socket (3) | Closed. 2024-08-24 09:05:32.453 | HD Request # 69 | Setting DTC encoding to Binary VLS 2024-08-24 09:05:32.453 | HD Request # 69 | Sending historical data logon request message. 2024-08-24 09:05:32.467 | Socket (4) | CloseSocket call. 2024-08-24 09:05:32.467 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 09:05:32.481 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 09:05:32.481 | Socket (4) | Closed. 2024-08-24 09:05:32.517 | HD Request # 69 | Error downloading historical Intraday data for F.US.DDU24. Historical data logon error: Serving data is disabled 2024-08-24 09:05:32.517 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:05:32.517 | Triggering next historical data download in queue. 2024-08-24 09:05:32.517 | Historical data download thread signaled to stop. 2024-08-24 09:05:32.517 | HD Request # 69 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DDU24 2024-08-24 09:05:32.517 | HD Request # 69 | Completion time: 0s. 2024-08-24 09:05:32.517 | 2024-08-24 09:05:32.517 | HD Request # 70 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:05:32.517 | HD Request # 70 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:05:32.517 | HD Request # 70 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:05:32.517 | Socket (3) | Creating socket. 2024-08-24 09:05:32.517 | Socket (3) | New receive buffer size: 0 2024-08-24 09:05:32.517 | Socket (3) | Connecting to IP: 176.9.9.252. 2024-08-24 09:05:32.573 | HD Request # 70 | Setting DTC encoding to Binary VLS 2024-08-24 09:05:32.573 | HD Request # 70 | Sending historical data logon request message. 2024-08-24 09:05:32.599 | HD Request # 70 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDAX202409_FUT_EUREX 2024-08-24 09:05:32.625 | HD Request # 70 | Decompressing data. 2024-08-24 09:05:32.650 | HD Request # 70 | Receiving Intraday data for F.US.DDU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:05:32.650 | Socket (3) | CloseSocket call. 2024-08-24 09:05:32.650 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:05:32.650 | Historical data download thread signaled to stop. 2024-08-24 09:05:32.650 | HD Request # 70 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.0 hours) and wrote 0 records for F.US.DDU24 2024-08-24 09:05:32.651 | HD Request # 70 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:05:32.651 | HD Request # 70 | Completion time: 0s. 2024-08-24 09:05:32.651 | HD Request # 70 | Intraday data download complete for F.US.DDU24. Unique request ID: 38 2024-08-24 09:05:32.651 | Removing historical data download ID 38. 2024-08-24 09:05:32.651 | Real-time Intraday chart data file updates started for F.US.DDU24 2024-08-24 09:05:32.651 | Intraday chart data file opened for F.US.DDU24 2024-08-24 09:05:32.651 | HD Request # 70 | Enabling Intraday chart updating for symbol. 2024-08-24 09:05:32.652 | 2024-08-24 09:05:32.652 | No download requests in the queue to start downloads for. 2024-08-24 09:05:32.680 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:05:32.680 | Socket (3) | Closed. 2024-08-24 09:05:32.815 | Chart #12 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:05:33.026 | Chart #2 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:05:33.026 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:05:33.026 | Chart #2 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:05:33.026 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:05:33.077 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:05:38.544 | Chart #25 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:05:38.562 | F.US.FDXSU24 [CBV][M] 100 Volume #14 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:05:38.779 | F.US.FDXSU24 [CBV][M] 1 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:07:44.178 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:07:44.178 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:07:44.178 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:07:44.229 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:07:50.992 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:07:54.024 | Circular chart reference detected. Charts: 25, 12. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-24 09:07:54.025 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:07:59.530 | Circular chart reference detected. Charts: 12, 25. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-24 09:07:59.531 | CQG WebSocket | Timeout waiting for pong message from server. 2024-08-24 09:07:59.531 | CQG WebAPI | WebSocket closed. 2024-08-24 09:07:59.531 | Connection to the external service has been lost. 2024-08-24 09:07:59.853 | CQG WebAPI | Sending Web API Logoff message. 2024-08-24 09:07:59.853 | CQG WebSocket socket (2) | CloseSocket call. 2024-08-24 09:07:59.853 | CQG WebSocket | WebSocket closed. 2024-08-24 09:07:59.853 | CQG WebAPI | WebSocket closed. 2024-08-24 09:07:59.853 | CQG WebAPI | Disconnected. 2024-08-24 09:07:59.853 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-08-24 09:07:59.853 | CQG WebSocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 2024-08-24 09:07:59.863 | CQG WebSocket socket (2) | Write has completed. Shutdown being performed. 2024-08-24 09:07:59.863 | CQG WebSocket socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 09:07:59.873 | CQG WebSocket socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:07:59.873 | CQG WebSocket socket (2) | Closed. 2024-08-24 09:08:01.887 | 2024-08-24 09:08:01.887 | CQG WebAPI | Connecting to server api.cqg.com 2024-08-24 09:08:01.887 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-08-24 09:08:02.001 | CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. 2024-08-24 09:08:02.002 | CQG WebSocket socket (2) | New receive buffer size: 0 2024-08-24 09:08:02.002 | CQG WebSocket socket (2) | Connecting to IP: 195.166.124.175. 2024-08-24 09:08:02.013 | CQG WebSocket | Opening WebSocket. 2024-08-24 09:08:02.013 | CQG WebSocket | Sending WebSocket handshake. 2024-08-24 09:08:02.045 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2024-08-24 09:08:02.045 | CQG WebSocket | Server header | Connection: Upgrade 2024-08-24 09:08:02.045 | CQG WebSocket | Server header | Sec-WebSocket-Accept: gq5GNZ8qgLKNzBOK/3Gu3fjFrxA= 2024-08-24 09:08:02.045 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2024-08-24 09:08:02.045 | CQG WebSocket | Server header | Upgrade: websocket 2024-08-24 09:08:02.045 | CQG WebSocket | Server header | 2024-08-24 09:08:02.045 | CQG WebSocket | Web socket state is now open. 2024-08-24 09:08:02.045 | CQG WebAPI | WebSocket connected. 2024-08-24 09:08:02.045 | CQG WebAPI | Sending market data logon message. 2024-08-24 09:08:02.266 | CQG WebAPI | Base Time: 2024-08-04T06:16:49. 2024-08-04 06:16:49 2024-08-24 09:08:02.266 | CQG WebAPI | Logon successful. Session Token = VgtmDQHebAnNQIpEpP4CpDgeOmgSO5ZknuW86MN1ipoNP73DXoCiZHeBsUNU3EFtjsnevIkzM2s 2024-08-24 09:08:02.266 | CQG WebAPI | Connected to server complete. 2024-08-24 09:08:02.266 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:08:02.267 | DTC Client socket (1) | CloseSocket call. 2024-08-24 09:08:02.267 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:08:02.267 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 09:08:02.268 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-24 09:08:02.268 | Updated verified funded futures trading account ending date to: 2024-09-23 07:08:02 2024-08-24 09:08:02.297 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-08-24 09:08:02.297 | DTC Client socket (1) | Closed. 2024-08-24 09:08:02.583 | CQG WebAPI | Sending Trade Accounts request message. 2024-08-24 09:08:02.584 | Mapping F.US.FDXSU24 to FDXS202409_FUT_EUREX. Service code: eurex 2024-08-24 09:08:02.584 | Using symbol data fast lookup vector 2024-08-24 09:08:02.584 | Denali Data Feed | Starting real-time market data updates for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 1 Service code: eurex 2024-08-24 09:08:02.584 | Denali Data Feed | Connecting to the server ds24.sierracharts.com. Port 443 2024-08-24 09:08:02.584 | CQG WebAPI | Sending symbol resolution request for F.US.FDXSU24. ID: 982665 2024-08-24 09:08:02.584 | Denali Data Feed | Requesting security definition data for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 1 2024-08-24 09:08:02.584 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:08:02.584 | Intraday data recording state for symbol F.US.FDXSU24 is set to download 'Pending'. 2024-08-24 09:08:02.584 | Triggering next historical data download in queue. 2024-08-24 09:08:02.584 | DTC Client socket (1) | Creating socket. 2024-08-24 09:08:02.584 | DTC Client socket (1) | New receive buffer size: 0 2024-08-24 09:08:02.584 | DTC Client socket (1) | Connecting to IP: 149.11.224.18. 2024-08-24 09:08:02.724 | Delaying start of download for F.US.FDXSU24. 2024-08-24 09:08:02.724 | CQG WebAPI | Received symbol resolution report for symbol F.US.FDXSU24. Search Symbol: F.US.FDXSU24. Request ID: 982665. Contract ID: 1. 2024-08-24 09:08:02.724 | CQG WebAPI | Brokerage name: WH Selfinvest France. Account Name: LWHF0931 2024-08-24 09:08:02.724 | Updated verified funded futures trading account ending date to: 2024-09-23 07:08:02 2024-08-24 09:08:02.724 | CQG WebAPI | Sending collateral subscribe request. 2024-08-24 09:08:02.724 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:08:02.724 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:08:02.724 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:08:02.798 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:08:02.798 | Denali Data Feed | Sending logon request message. 2024-08-24 09:08:02.829 | Mapping F.US.DDU24 to FDAX202409_FUT_EUREX. Service code: eurex 2024-08-24 09:08:02.830 | Denali Data Feed | Starting real-time market data updates for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 2 Service code: eurex 2024-08-24 09:08:02.830 | CQG WebAPI | Sending symbol resolution request for F.US.DDU24. ID: 982667 2024-08-24 09:08:02.830 | Denali Data Feed | Requesting security definition data for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 2 2024-08-24 09:08:02.830 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:08:02.830 | Intraday data recording state for symbol F.US.DDU24 is set to download 'Pending'. 2024-08-24 09:08:02.830 | Triggering next historical data download in queue. 2024-08-24 09:08:02.847 | Denali Data Feed | Received logon response. 2024-08-24 09:08:02.847 | Denali Data Feed | Server Name: RealTimeServer. 2024-08-24 09:08:02.847 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:08:02.847 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. 2024-08-24 09:08:02.847 | Denali Data Feed | Failed connections: 1 2024-08-24 09:08:02.847 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:08:02.848 | DTC Client socket (1) | CloseSocket call. 2024-08-24 09:08:02.848 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:08:02.848 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-08-24 09:08:02.848 | CQG WebAPI | Received symbol resolution report for symbol F.US.DDU24. Search Symbol: F.US.DDU24. Request ID: 982667. Contract ID: 2. 2024-08-24 09:08:02.848 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 09:08:02.865 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-08-24 09:08:02.865 | DTC Client socket (1) | Closed. 2024-08-24 09:08:02.875 | CQG WebAPI | Sending positions subscribe request. RequestID: 982668 2024-08-24 09:08:02.875 | CQG WebAPI | Sending orders subscribe request. RequestID: 982669 2024-08-24 09:08:05.849 | Denali Data Feed | Connecting to the server ds14.sierracharts.com. Port 10048 2024-08-24 09:08:05.850 | DTC Client socket (1) | Creating socket. 2024-08-24 09:08:05.850 | DTC Client socket (1) | New receive buffer size: 0 2024-08-24 09:08:05.850 | DTC Client socket (1) | Connecting to IP: 176.9.9.252. 2024-08-24 09:08:05.877 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:08:05.877 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:08:05.878 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:08:05.967 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:08:05.967 | Denali Data Feed | Sending logon request message. 2024-08-24 09:08:06.300 | Denali Data Feed | Received logon response. 2024-08-24 09:08:06.300 | Denali Data Feed | Server Name: SC Realtime Server. 2024-08-24 09:08:06.300 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:08:06.300 | Denali Data Feed | Successfully connected. 2024-08-24 09:08:06.300 | Denali Data Feed | Trading is not supported. 2024-08-24 09:08:06.300 | Denali Data Feed | MarketDepthIsSupported: 1 2024-08-24 09:08:06.300 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.DDU24 -> FDAX202409_FUT_EUREX 2024-08-24 09:08:06.300 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.FDXSU24 -> FDXS202409_FUT_EUREX 2024-08-24 09:08:06.475 | Denali Data Feed | Real-time data for symbol F.US.DDU24 is currently unavailable. 2024-08-24 09:08:06.475 | Denali Data Feed | Setting external service identifier for symbol F.US.DDU24 to 7296071 2024-08-24 09:08:06.475 | Denali Data Feed | Received security definition for symbol F.US.DDU24 2024-08-24 09:08:06.475 | Denali Data Feed | Real-time data for symbol F.US.FDXSU24 is currently unavailable. 2024-08-24 09:08:06.475 | Denali Data Feed | Setting external service identifier for symbol F.US.FDXSU24 to 10451688 2024-08-24 09:08:06.475 | Denali Data Feed | Received security definition for symbol F.US.FDXSU24 2024-08-24 09:08:11.971 | HD Request # 71 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:08:11.973 | HD Request # 71 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:08:11.973 | HD Request # 71 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:08:11.973 | Socket (3) | Creating socket. 2024-08-24 09:08:11.973 | Socket (3) | New receive buffer size: 0 2024-08-24 09:08:11.973 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:08:12.004 | HD Request # 71 | Setting DTC encoding to Binary VLS 2024-08-24 09:08:12.004 | HD Request # 71 | Sending historical data logon request message. 2024-08-24 09:08:12.018 | Socket (3) | CloseSocket call. 2024-08-24 09:08:12.018 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:08:12.032 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:08:12.032 | Socket (3) | Closed. 2024-08-24 09:08:12.064 | HD Request # 71 | Error downloading historical Intraday data for F.US.FDXSU24. Historical data logon error: Serving data is disabled 2024-08-24 09:08:12.064 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:08:12.064 | Triggering next historical data download in queue. 2024-08-24 09:08:12.064 | Historical data download thread signaled to stop. 2024-08-24 09:08:12.064 | HD Request # 71 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSU24 2024-08-24 09:08:12.064 | HD Request # 71 | Completion time: 1s. 2024-08-24 09:08:12.064 | 2024-08-24 09:08:12.064 | HD Request # 72 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:08:12.064 | HD Request # 72 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:08:12.064 | HD Request # 72 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:08:12.064 | Socket (3) | Creating socket. 2024-08-24 09:08:12.064 | Socket (3) | New receive buffer size: 0 2024-08-24 09:08:12.064 | Socket (3) | Connecting to IP: 176.9.9.252. 2024-08-24 09:08:12.119 | HD Request # 72 | Setting DTC encoding to Binary VLS 2024-08-24 09:08:12.119 | HD Request # 72 | Sending historical data logon request message. 2024-08-24 09:08:12.275 | HD Request # 72 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDXS202409_FUT_EUREX 2024-08-24 09:08:12.301 | HD Request # 72 | Decompressing data. 2024-08-24 09:08:12.325 | HD Request # 72 | Receiving Intraday data for F.US.FDXSU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:08:12.325 | Socket (3) | CloseSocket call. 2024-08-24 09:08:12.325 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:08:12.326 | Historical data download thread signaled to stop. 2024-08-24 09:08:12.326 | HD Request # 72 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.1 hours) and wrote 0 records for F.US.FDXSU24 2024-08-24 09:08:12.327 | HD Request # 72 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:08:12.327 | HD Request # 72 | Completion time: 0s. 2024-08-24 09:08:12.327 | HD Request # 72 | Intraday data download complete for F.US.FDXSU24. Unique request ID: 39 2024-08-24 09:08:12.327 | Removing historical data download ID 39. 2024-08-24 09:08:12.327 | Real-time Intraday chart data file updates started for F.US.FDXSU24 2024-08-24 09:08:12.327 | Intraday chart data file opened for F.US.FDXSU24 2024-08-24 09:08:12.327 | HD Request # 72 | Enabling Intraday chart updating for symbol. 2024-08-24 09:08:12.327 | 2024-08-24 09:08:12.327 | Triggering next historical data download in queue. 2024-08-24 09:08:12.327 | HD Request # 73 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:08:12.329 | HD Request # 73 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:08:12.329 | HD Request # 73 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:08:12.329 | Socket (4) | Creating socket. 2024-08-24 09:08:12.329 | Socket (4) | New receive buffer size: 0 2024-08-24 09:08:12.329 | Socket (4) | Connecting to IP: 149.11.224.18. 2024-08-24 09:08:12.351 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:08:12.351 | Socket (3) | Closed. 2024-08-24 09:08:12.383 | HD Request # 73 | Setting DTC encoding to Binary VLS 2024-08-24 09:08:12.383 | HD Request # 73 | Sending historical data logon request message. 2024-08-24 09:08:12.397 | Socket (4) | CloseSocket call. 2024-08-24 09:08:12.397 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 09:08:12.403 | HD Request # 73 | Error downloading historical Intraday data for F.US.DDU24. Historical data logon error: Serving data is disabled 2024-08-24 09:08:12.403 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:08:12.403 | Triggering next historical data download in queue. 2024-08-24 09:08:12.403 | Historical data download thread signaled to stop. 2024-08-24 09:08:12.403 | HD Request # 73 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DDU24 2024-08-24 09:08:12.403 | HD Request # 73 | Completion time: 0s. 2024-08-24 09:08:12.403 | 2024-08-24 09:08:12.403 | HD Request # 74 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:08:12.403 | HD Request # 74 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:08:12.403 | HD Request # 74 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:08:12.403 | Socket (3) | Creating socket. 2024-08-24 09:08:12.404 | Socket (3) | New receive buffer size: 0 2024-08-24 09:08:12.404 | Socket (3) | Connecting to IP: 176.9.9.252. 2024-08-24 09:08:12.411 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 09:08:12.411 | Socket (4) | Closed. 2024-08-24 09:08:12.456 | Chart #12 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:08:12.457 | HD Request # 74 | Setting DTC encoding to Binary VLS 2024-08-24 09:08:12.457 | HD Request # 74 | Sending historical data logon request message. 2024-08-24 09:08:12.481 | HD Request # 74 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDAX202409_FUT_EUREX 2024-08-24 09:08:12.505 | HD Request # 74 | Decompressing data. 2024-08-24 09:08:12.528 | HD Request # 74 | Receiving Intraday data for F.US.DDU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:08:12.528 | Socket (3) | CloseSocket call. 2024-08-24 09:08:12.529 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:08:12.554 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:08:12.554 | Socket (3) | Closed. 2024-08-24 09:08:12.602 | Chart #2 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:08:12.602 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:08:12.602 | Chart #2 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:08:12.602 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:08:12.602 | Historical data download thread signaled to stop. 2024-08-24 09:08:12.602 | HD Request # 74 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.1 hours) and wrote 0 records for F.US.DDU24 2024-08-24 09:08:12.602 | HD Request # 74 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:08:12.602 | HD Request # 74 | Completion time: 0s. 2024-08-24 09:08:12.602 | HD Request # 74 | Intraday data download complete for F.US.DDU24. Unique request ID: 40 2024-08-24 09:08:12.602 | Removing historical data download ID 40. 2024-08-24 09:08:12.602 | Real-time Intraday chart data file updates started for F.US.DDU24 2024-08-24 09:08:12.602 | Intraday chart data file opened for F.US.DDU24 2024-08-24 09:08:12.602 | HD Request # 74 | Enabling Intraday chart updating for symbol. 2024-08-24 09:08:12.602 | 2024-08-24 09:08:12.602 | No download requests in the queue to start downloads for. 2024-08-24 09:08:12.652 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:08:18.100 | Chart #25 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:08:18.117 | F.US.FDXSU24 [CBV][M] 100 Volume #14 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:08:18.335 | F.US.FDXSU24 [CBV][M] 1 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:10:23.439 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:10:23.439 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:10:23.439 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:10:23.615 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:10:30.228 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:10:33.211 | Circular chart reference detected. Charts: 25, 12. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-24 09:10:33.213 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:10:38.606 | Circular chart reference detected. Charts: 12, 25. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-24 09:10:38.607 | CQG WebSocket | Timeout waiting for pong message from server. 2024-08-24 09:10:38.607 | CQG WebAPI | WebSocket closed. 2024-08-24 09:10:38.607 | Connection to the external service has been lost. 2024-08-24 09:10:38.931 | CQG WebAPI | Sending Web API Logoff message. 2024-08-24 09:10:38.931 | CQG WebSocket socket (2) | CloseSocket call. 2024-08-24 09:10:38.931 | CQG WebSocket | WebSocket closed. 2024-08-24 09:10:38.931 | CQG WebAPI | WebSocket closed. 2024-08-24 09:10:38.931 | CQG WebAPI | Disconnected. 2024-08-24 09:10:38.931 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-08-24 09:10:38.931 | CQG WebSocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 2024-08-24 09:10:38.940 | CQG WebSocket socket (2) | Write has completed. Shutdown being performed. 2024-08-24 09:10:38.940 | CQG WebSocket socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 09:10:38.950 | CQG WebSocket socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:10:38.950 | CQG WebSocket socket (2) | Closed. 2024-08-24 09:10:40.933 | 2024-08-24 09:10:40.933 | CQG WebAPI | Connecting to server api.cqg.com 2024-08-24 09:10:40.933 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-08-24 09:10:40.934 | CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. 2024-08-24 09:10:40.934 | CQG WebSocket socket (2) | New receive buffer size: 0 2024-08-24 09:10:40.934 | CQG WebSocket socket (2) | Connecting to IP: 195.166.124.175. 2024-08-24 09:10:40.943 | CQG WebSocket | Opening WebSocket. 2024-08-24 09:10:40.943 | CQG WebSocket | Sending WebSocket handshake. 2024-08-24 09:10:40.977 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2024-08-24 09:10:40.977 | CQG WebSocket | Server header | Connection: Upgrade 2024-08-24 09:10:40.977 | CQG WebSocket | Server header | Sec-WebSocket-Accept: 8bL1gUUNlnRwTZsjtK7NWqR/r3g= 2024-08-24 09:10:40.977 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2024-08-24 09:10:40.977 | CQG WebSocket | Server header | Upgrade: websocket 2024-08-24 09:10:40.977 | CQG WebSocket | Server header | 2024-08-24 09:10:40.977 | CQG WebSocket | Web socket state is now open. 2024-08-24 09:10:40.977 | CQG WebAPI | WebSocket connected. 2024-08-24 09:10:40.977 | CQG WebAPI | Sending market data logon message. 2024-08-24 09:10:41.204 | CQG WebAPI | Base Time: 2024-08-04T06:16:49. 2024-08-04 06:16:49 2024-08-24 09:10:41.204 | CQG WebAPI | Logon successful. Session Token = AX0mq91c0SaoBX6x4O6BnzuDp0GEjSsFo7uU2uUAlekCo3fzDaqU1qdLAg//CL4VZjysgHJDdzp 2024-08-24 09:10:41.204 | CQG WebAPI | Connected to server complete. 2024-08-24 09:10:41.204 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:10:41.205 | DTC Client socket (1) | CloseSocket call. 2024-08-24 09:10:41.205 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:10:41.205 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 09:10:41.206 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-24 09:10:41.206 | Updated verified funded futures trading account ending date to: 2024-09-23 07:10:41 2024-08-24 09:10:41.231 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-08-24 09:10:41.232 | DTC Client socket (1) | Closed. 2024-08-24 09:10:41.522 | CQG WebAPI | Sending Trade Accounts request message. 2024-08-24 09:10:41.523 | Mapping F.US.DDU24 to FDAX202409_FUT_EUREX. Service code: eurex 2024-08-24 09:10:41.523 | Using symbol data fast lookup vector 2024-08-24 09:10:41.523 | Denali Data Feed | Starting real-time market data updates for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 1 Service code: eurex 2024-08-24 09:10:41.523 | Denali Data Feed | Connecting to the server ds24.sierracharts.com. Port 443 2024-08-24 09:10:41.523 | CQG WebAPI | Sending symbol resolution request for F.US.DDU24. ID: 982671 2024-08-24 09:10:41.523 | Denali Data Feed | Requesting security definition data for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 1 2024-08-24 09:10:41.523 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:10:41.523 | Intraday data recording state for symbol F.US.DDU24 is set to download 'Pending'. 2024-08-24 09:10:41.523 | Triggering next historical data download in queue. 2024-08-24 09:10:41.523 | DTC Client socket (1) | Creating socket. 2024-08-24 09:10:41.523 | DTC Client socket (1) | New receive buffer size: 0 2024-08-24 09:10:41.523 | DTC Client socket (1) | Connecting to IP: 149.11.224.18. 2024-08-24 09:10:41.540 | Delaying start of download for F.US.DDU24. 2024-08-24 09:10:41.540 | CQG WebAPI | Received symbol resolution report for symbol F.US.DDU24. Search Symbol: F.US.DDU24. Request ID: 982671. Contract ID: 1. 2024-08-24 09:10:41.540 | CQG WebAPI | Brokerage name: WH Selfinvest France. Account Name: LWHF0931 2024-08-24 09:10:41.540 | Updated verified funded futures trading account ending date to: 2024-09-23 07:10:41 2024-08-24 09:10:41.540 | CQG WebAPI | Sending collateral subscribe request. 2024-08-24 09:10:41.541 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:10:41.541 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:10:41.541 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:10:41.541 | Mapping F.US.FDXSU24 to FDXS202409_FUT_EUREX. Service code: eurex 2024-08-24 09:10:41.541 | Denali Data Feed | Starting real-time market data updates for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 2 Service code: eurex 2024-08-24 09:10:41.541 | CQG WebAPI | Sending symbol resolution request for F.US.FDXSU24. ID: 982673 2024-08-24 09:10:41.541 | Denali Data Feed | Requesting security definition data for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 2 2024-08-24 09:10:41.541 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:10:41.541 | Intraday data recording state for symbol F.US.FDXSU24 is set to download 'Pending'. 2024-08-24 09:10:41.541 | Triggering next historical data download in queue. 2024-08-24 09:10:41.555 | CQG WebAPI | Received symbol resolution report for symbol F.US.FDXSU24. Search Symbol: F.US.FDXSU24. Request ID: 982673. Contract ID: 2. 2024-08-24 09:10:41.587 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:10:41.587 | Denali Data Feed | Sending logon request message. 2024-08-24 09:10:41.611 | Denali Data Feed | Received logon response. 2024-08-24 09:10:41.611 | Denali Data Feed | Server Name: RealTimeServer. 2024-08-24 09:10:41.611 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:10:41.611 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. 2024-08-24 09:10:41.611 | Denali Data Feed | Failed connections: 1 2024-08-24 09:10:41.611 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:10:41.611 | DTC Client socket (1) | CloseSocket call. 2024-08-24 09:10:41.611 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:10:41.611 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-08-24 09:10:41.611 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 09:10:41.625 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-08-24 09:10:41.625 | DTC Client socket (1) | Closed. 2024-08-24 09:10:41.875 | CQG WebAPI | Sending positions subscribe request. RequestID: 982674 2024-08-24 09:10:41.876 | CQG WebAPI | Sending orders subscribe request. RequestID: 982675 2024-08-24 09:10:44.612 | Denali Data Feed | Connecting to the server ds14.sierracharts.com. Port 10048 2024-08-24 09:10:44.613 | DTC Client socket (1) | Creating socket. 2024-08-24 09:10:44.614 | DTC Client socket (1) | New receive buffer size: 0 2024-08-24 09:10:44.614 | DTC Client socket (1) | Connecting to IP: 176.9.9.252. 2024-08-24 09:10:44.640 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:10:44.640 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:10:44.640 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:10:44.691 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:10:44.691 | Denali Data Feed | Sending logon request message. 2024-08-24 09:10:45.035 | Denali Data Feed | Received logon response. 2024-08-24 09:10:45.035 | Denali Data Feed | Server Name: SC Realtime Server. 2024-08-24 09:10:45.035 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:10:45.035 | Denali Data Feed | Successfully connected. 2024-08-24 09:10:45.035 | Denali Data Feed | Trading is not supported. 2024-08-24 09:10:45.035 | Denali Data Feed | MarketDepthIsSupported: 1 2024-08-24 09:10:45.035 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.DDU24 -> FDAX202409_FUT_EUREX 2024-08-24 09:10:45.035 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.FDXSU24 -> FDXS202409_FUT_EUREX 2024-08-24 09:10:45.160 | Denali Data Feed | Real-time data for symbol F.US.DDU24 is currently unavailable. 2024-08-24 09:10:45.160 | Denali Data Feed | Setting external service identifier for symbol F.US.DDU24 to 7296071 2024-08-24 09:10:45.160 | Denali Data Feed | Received security definition for symbol F.US.DDU24 2024-08-24 09:10:45.160 | Denali Data Feed | Real-time data for symbol F.US.FDXSU24 is currently unavailable. 2024-08-24 09:10:45.160 | Denali Data Feed | Setting external service identifier for symbol F.US.FDXSU24 to 10451688 2024-08-24 09:10:45.160 | Denali Data Feed | Received security definition for symbol F.US.FDXSU24 2024-08-24 09:10:50.434 | HD Request # 75 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:10:50.436 | HD Request # 75 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:10:50.436 | HD Request # 75 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:10:50.436 | Socket (3) | Creating socket. 2024-08-24 09:10:50.436 | Socket (3) | New receive buffer size: 0 2024-08-24 09:10:50.436 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:10:50.467 | HD Request # 75 | Setting DTC encoding to Binary VLS 2024-08-24 09:10:50.467 | HD Request # 75 | Sending historical data logon request message. 2024-08-24 09:10:50.480 | Socket (3) | CloseSocket call. 2024-08-24 09:10:50.481 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:10:50.493 | HD Request # 75 | Error downloading historical Intraday data for F.US.DDU24. Historical data logon error: Serving data is disabled 2024-08-24 09:10:50.493 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:10:50.493 | Triggering next historical data download in queue. 2024-08-24 09:10:50.493 | Historical data download thread signaled to stop. 2024-08-24 09:10:50.493 | HD Request # 75 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DDU24 2024-08-24 09:10:50.493 | HD Request # 75 | Completion time: 0s. 2024-08-24 09:10:50.493 | 2024-08-24 09:10:50.493 | HD Request # 76 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:10:50.494 | HD Request # 76 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:10:50.494 | HD Request # 76 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:10:50.494 | Socket (4) | Creating socket. 2024-08-24 09:10:50.494 | Socket (4) | New receive buffer size: 0 2024-08-24 09:10:50.494 | Socket (4) | Connecting to IP: 176.9.9.252. 2024-08-24 09:10:50.516 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:10:50.516 | Socket (3) | Closed. 2024-08-24 09:10:50.560 | HD Request # 76 | Setting DTC encoding to Binary VLS 2024-08-24 09:10:50.560 | HD Request # 76 | Sending historical data logon request message. 2024-08-24 09:10:50.716 | HD Request # 76 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDAX202409_FUT_EUREX 2024-08-24 09:10:50.741 | HD Request # 76 | Decompressing data. 2024-08-24 09:10:50.766 | HD Request # 76 | Receiving Intraday data for F.US.DDU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:10:50.766 | Socket (4) | CloseSocket call. 2024-08-24 09:10:50.766 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 09:10:50.766 | Historical data download thread signaled to stop. 2024-08-24 09:10:50.766 | HD Request # 76 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.1 hours) and wrote 0 records for F.US.DDU24 2024-08-24 09:10:50.767 | HD Request # 76 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:10:50.767 | HD Request # 76 | Completion time: 0s. 2024-08-24 09:10:50.767 | HD Request # 76 | Intraday data download complete for F.US.DDU24. Unique request ID: 41 2024-08-24 09:10:50.767 | Removing historical data download ID 41. 2024-08-24 09:10:50.767 | Real-time Intraday chart data file updates started for F.US.DDU24 2024-08-24 09:10:50.767 | Intraday chart data file opened for F.US.DDU24 2024-08-24 09:10:50.767 | HD Request # 76 | Enabling Intraday chart updating for symbol. 2024-08-24 09:10:50.767 | 2024-08-24 09:10:50.767 | Triggering next historical data download in queue. 2024-08-24 09:10:50.768 | HD Request # 77 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:10:50.769 | HD Request # 77 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:10:50.769 | HD Request # 77 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:10:50.769 | Socket (3) | Creating socket. 2024-08-24 09:10:50.769 | Socket (3) | New receive buffer size: 0 2024-08-24 09:10:50.770 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:10:50.792 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 09:10:50.792 | Socket (4) | Closed. 2024-08-24 09:10:50.800 | HD Request # 77 | Setting DTC encoding to Binary VLS 2024-08-24 09:10:50.800 | HD Request # 77 | Sending historical data logon request message. 2024-08-24 09:10:50.814 | Socket (3) | CloseSocket call. 2024-08-24 09:10:50.814 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:10:50.829 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:10:50.829 | Socket (3) | Closed. 2024-08-24 09:10:50.866 | HD Request # 77 | Error downloading historical Intraday data for F.US.FDXSU24. Historical data logon error: Serving data is disabled 2024-08-24 09:10:50.866 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:10:50.866 | Triggering next historical data download in queue. 2024-08-24 09:10:50.866 | Historical data download thread signaled to stop. 2024-08-24 09:10:50.866 | HD Request # 77 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSU24 2024-08-24 09:10:50.866 | HD Request # 77 | Completion time: 0s. 2024-08-24 09:10:50.866 | 2024-08-24 09:10:50.866 | HD Request # 78 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:10:50.866 | HD Request # 78 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:10:50.866 | HD Request # 78 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:10:50.866 | Socket (3) | Creating socket. 2024-08-24 09:10:50.866 | Socket (3) | New receive buffer size: 0 2024-08-24 09:10:50.867 | Socket (3) | Connecting to IP: 176.9.9.252. 2024-08-24 09:10:50.918 | HD Request # 78 | Setting DTC encoding to Binary VLS 2024-08-24 09:10:50.918 | HD Request # 78 | Sending historical data logon request message. 2024-08-24 09:10:50.943 | HD Request # 78 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDXS202409_FUT_EUREX 2024-08-24 09:10:50.967 | HD Request # 78 | Decompressing data. 2024-08-24 09:10:50.990 | HD Request # 78 | Receiving Intraday data for F.US.FDXSU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:10:50.990 | Socket (3) | CloseSocket call. 2024-08-24 09:10:50.990 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:10:50.991 | Historical data download thread signaled to stop. 2024-08-24 09:10:50.991 | HD Request # 78 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.1 hours) and wrote 0 records for F.US.FDXSU24 2024-08-24 09:10:50.991 | HD Request # 78 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:10:50.991 | HD Request # 78 | Completion time: 0s. 2024-08-24 09:10:50.991 | HD Request # 78 | Intraday data download complete for F.US.FDXSU24. Unique request ID: 42 2024-08-24 09:10:50.991 | Removing historical data download ID 42. 2024-08-24 09:10:50.991 | Real-time Intraday chart data file updates started for F.US.FDXSU24 2024-08-24 09:10:50.991 | Intraday chart data file opened for F.US.FDXSU24 2024-08-24 09:10:50.991 | HD Request # 78 | Enabling Intraday chart updating for symbol. 2024-08-24 09:10:50.991 | 2024-08-24 09:10:50.991 | No download requests in the queue to start downloads for. 2024-08-24 09:10:51.015 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:10:51.015 | Socket (3) | Closed. 2024-08-24 09:10:51.039 | Chart #12 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:10:51.177 | Chart #2 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:10:51.177 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:10:51.177 | Chart #2 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:10:51.177 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:10:51.438 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:10:56.915 | Chart #25 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:10:56.915 | F.US.FDXSU24 [CBV][M] 100 Volume #14 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:10:57.136 | F.US.FDXSU24 [CBV][M] 1 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:13:03.403 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:13:03.403 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:13:03.403 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:13:03.422 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:13:10.076 | File >> Disconnect selected. 2024-08-24 09:13:10.344 | CQG WebAPI | Sending Web API Logoff message. 2024-08-24 09:13:10.344 | CQG WebSocket socket (2) | CloseSocket call. 2024-08-24 09:13:10.344 | CQG WebSocket | WebSocket closed. 2024-08-24 09:13:10.344 | CQG WebAPI | WebSocket closed. 2024-08-24 09:13:10.344 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:13:10.344 | CQG WebSocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 2024-08-24 09:13:10.344 | DTC Client socket (1) | CloseSocket call. 2024-08-24 09:13:10.344 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:13:10.344 | CQG WebAPI | Disconnected. 2024-08-24 09:13:10.344 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 09:13:10.353 | CQG WebSocket socket (2) | Write has completed. Shutdown being performed. 2024-08-24 09:13:10.353 | CQG WebSocket socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 09:13:10.363 | CQG WebSocket socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:13:10.363 | CQG WebSocket socket (2) | Closed. 2024-08-24 09:13:10.369 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-08-24 09:13:10.369 | DTC Client socket (1) | Closed. 2024-08-24 09:13:10.410 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:13:13.332 | Circular chart reference detected. Charts: 25, 12. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-24 09:13:13.367 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:13:18.732 | Circular chart reference detected. Charts: 12, 25. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-24 09:13:41.293 | 2024-08-24 09:13:41.293 | CQG WebAPI | Connecting to server api.cqg.com 2024-08-24 09:13:41.293 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-08-24 09:13:41.394 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2024-08-24 09:13:41.394 | CQG WebSocket socket (1) | New receive buffer size: 0 2024-08-24 09:13:41.394 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2024-08-24 09:13:41.412 | CQG WebSocket | Opening WebSocket. 2024-08-24 09:13:41.412 | CQG WebSocket | Sending WebSocket handshake. 2024-08-24 09:13:41.443 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2024-08-24 09:13:41.443 | CQG WebSocket | Server header | Connection: Upgrade 2024-08-24 09:13:41.443 | CQG WebSocket | Server header | Sec-WebSocket-Accept: Aw92U7PLIdIp3MDYQjIrnHuMkTA= 2024-08-24 09:13:41.443 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2024-08-24 09:13:41.443 | CQG WebSocket | Server header | Upgrade: websocket 2024-08-24 09:13:41.443 | CQG WebSocket | Server header | 2024-08-24 09:13:41.443 | CQG WebSocket | Web socket state is now open. 2024-08-24 09:13:41.443 | CQG WebAPI | WebSocket connected. 2024-08-24 09:13:41.443 | CQG WebAPI | Sending market data logon message. 2024-08-24 09:13:41.661 | CQG WebAPI | Base Time: 2024-08-04T06:16:49. 2024-08-04 06:16:49 2024-08-24 09:13:41.661 | CQG WebAPI | Logon successful. Session Token = QsPGkQdPMRU/DdXbU/uFu4jR3D3YmyoumMeGvNMhg4MKAzdVW/zQNsEuYa24g1dvOWDm2IuZ5LS 2024-08-24 09:13:41.661 | CQG WebAPI | Connected to server complete. 2024-08-24 09:13:41.662 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-24 09:13:41.662 | Updated verified funded futures trading account ending date to: 2024-09-23 07:13:41 2024-08-24 09:13:41.981 | CQG WebAPI | Sending Trade Accounts request message. 2024-08-24 09:13:41.982 | Mapping F.US.DDU24 to FDAX202409_FUT_EUREX. Service code: eurex 2024-08-24 09:13:41.982 | Using symbol data fast lookup vector 2024-08-24 09:13:41.982 | Denali Data Feed | Starting real-time market data updates for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 1 Service code: eurex 2024-08-24 09:13:41.982 | Denali Data Feed | Connecting to the server ds24.sierracharts.com. Port 443 2024-08-24 09:13:41.982 | CQG WebAPI | Sending symbol resolution request for F.US.DDU24. ID: 982677 2024-08-24 09:13:41.982 | Denali Data Feed | Requesting security definition data for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 1 2024-08-24 09:13:41.982 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:13:41.982 | Intraday data recording state for symbol F.US.DDU24 is set to download 'Pending'. 2024-08-24 09:13:41.982 | Triggering next historical data download in queue. 2024-08-24 09:13:41.982 | DTC Client socket (2) | Creating socket. 2024-08-24 09:13:41.982 | DTC Client socket (2) | New receive buffer size: 0 2024-08-24 09:13:41.982 | DTC Client socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 09:13:42.000 | Delaying start of download for F.US.DDU24. 2024-08-24 09:13:42.000 | CQG WebAPI | Received symbol resolution report for symbol F.US.DDU24. Search Symbol: F.US.DDU24. Request ID: 982677. Contract ID: 1. 2024-08-24 09:13:42.000 | CQG WebAPI | Brokerage name: WH Selfinvest France. Account Name: LWHF0931 2024-08-24 09:13:42.000 | Updated verified funded futures trading account ending date to: 2024-09-23 07:13:42 2024-08-24 09:13:42.000 | CQG WebAPI | Sending collateral subscribe request. 2024-08-24 09:13:42.000 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:13:42.000 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:13:42.000 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:13:42.000 | Mapping F.US.FDXSU24 to FDXS202409_FUT_EUREX. Service code: eurex 2024-08-24 09:13:42.000 | Denali Data Feed | Starting real-time market data updates for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 2 Service code: eurex 2024-08-24 09:13:42.000 | CQG WebAPI | Sending symbol resolution request for F.US.FDXSU24. ID: 982679 2024-08-24 09:13:42.000 | Denali Data Feed | Requesting security definition data for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 2 2024-08-24 09:13:42.000 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:13:42.000 | Intraday data recording state for symbol F.US.FDXSU24 is set to download 'Pending'. 2024-08-24 09:13:42.000 | Triggering next historical data download in queue. 2024-08-24 09:13:42.035 | CQG WebAPI | Received symbol resolution report for symbol F.US.FDXSU24. Search Symbol: F.US.FDXSU24. Request ID: 982679. Contract ID: 2. 2024-08-24 09:13:42.035 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:13:42.035 | Denali Data Feed | Sending logon request message. 2024-08-24 09:13:42.077 | Denali Data Feed | Received logon response. 2024-08-24 09:13:42.077 | Denali Data Feed | Server Name: RealTimeServer. 2024-08-24 09:13:42.077 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:13:42.077 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. 2024-08-24 09:13:42.077 | Denali Data Feed | Failed connections: 1 2024-08-24 09:13:42.077 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:13:42.077 | DTC Client socket (2) | CloseSocket call. 2024-08-24 09:13:42.077 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:13:42.077 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-08-24 09:13:42.077 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 09:13:42.091 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:13:42.091 | DTC Client socket (2) | Closed. 2024-08-24 09:13:42.333 | CQG WebAPI | Sending positions subscribe request. RequestID: 982680 2024-08-24 09:13:42.333 | CQG WebAPI | Sending orders subscribe request. RequestID: 982681 2024-08-24 09:13:45.087 | Denali Data Feed | Connecting to the server ds14.sierracharts.com. Port 443 2024-08-24 09:13:45.088 | DTC Client socket (2) | Creating socket. 2024-08-24 09:13:45.088 | DTC Client socket (2) | New receive buffer size: 0 2024-08-24 09:13:45.088 | DTC Client socket (2) | Connecting to IP: 176.9.9.252. 2024-08-24 09:13:45.114 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:13:45.114 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:13:45.115 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:13:45.142 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:13:45.142 | Denali Data Feed | Sending logon request message. 2024-08-24 09:13:45.515 | Denali Data Feed | Received logon response. 2024-08-24 09:13:45.515 | Denali Data Feed | Server Name: SC Realtime Server. 2024-08-24 09:13:45.515 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:13:45.515 | Denali Data Feed | Successfully connected. 2024-08-24 09:13:45.515 | Denali Data Feed | Trading is not supported. 2024-08-24 09:13:45.515 | Denali Data Feed | MarketDepthIsSupported: 1 2024-08-24 09:13:45.515 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.DDU24 -> FDAX202409_FUT_EUREX 2024-08-24 09:13:45.515 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.FDXSU24 -> FDXS202409_FUT_EUREX 2024-08-24 09:13:45.642 | Denali Data Feed | Real-time data for symbol F.US.DDU24 is currently unavailable. 2024-08-24 09:13:45.642 | Denali Data Feed | Setting external service identifier for symbol F.US.DDU24 to 7296071 2024-08-24 09:13:45.642 | Denali Data Feed | Received security definition for symbol F.US.DDU24 2024-08-24 09:13:45.642 | Denali Data Feed | Real-time data for symbol F.US.FDXSU24 is currently unavailable. 2024-08-24 09:13:45.642 | Denali Data Feed | Setting external service identifier for symbol F.US.FDXSU24 to 10451688 2024-08-24 09:13:45.642 | Denali Data Feed | Received security definition for symbol F.US.FDXSU24 2024-08-24 09:13:50.276 | HD Request # 79 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:13:50.277 | HD Request # 79 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:13:50.278 | HD Request # 79 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:13:50.278 | Socket (3) | Creating socket. 2024-08-24 09:13:50.278 | Socket (3) | New receive buffer size: 0 2024-08-24 09:13:50.278 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:13:50.310 | HD Request # 79 | Setting DTC encoding to Binary VLS 2024-08-24 09:13:50.310 | HD Request # 79 | Sending historical data logon request message. 2024-08-24 09:13:50.324 | Socket (3) | CloseSocket call. 2024-08-24 09:13:50.325 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:13:50.325 | HD Request # 79 | Error downloading historical Intraday data for F.US.DDU24. Historical data logon error: Serving data is disabled 2024-08-24 09:13:50.325 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:13:50.325 | Triggering next historical data download in queue. 2024-08-24 09:13:50.325 | Historical data download thread signaled to stop. 2024-08-24 09:13:50.325 | HD Request # 79 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DDU24 2024-08-24 09:13:50.325 | HD Request # 79 | Completion time: 0s. 2024-08-24 09:13:50.325 | 2024-08-24 09:13:50.325 | HD Request # 80 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:13:50.327 | HD Request # 80 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:13:50.327 | HD Request # 80 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:13:50.327 | Socket (4) | Creating socket. 2024-08-24 09:13:50.327 | Socket (4) | New receive buffer size: 0 2024-08-24 09:13:50.327 | Socket (4) | Connecting to IP: 176.9.9.252. 2024-08-24 09:13:50.339 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:13:50.339 | Socket (3) | Closed. 2024-08-24 09:13:50.384 | HD Request # 80 | Setting DTC encoding to Binary VLS 2024-08-24 09:13:50.384 | HD Request # 80 | Sending historical data logon request message. 2024-08-24 09:13:50.538 | HD Request # 80 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDAX202409_FUT_EUREX 2024-08-24 09:13:50.564 | HD Request # 80 | Decompressing data. 2024-08-24 09:13:50.588 | HD Request # 80 | Receiving Intraday data for F.US.DDU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:13:50.588 | Socket (4) | CloseSocket call. 2024-08-24 09:13:50.588 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 09:13:50.591 | Historical data download thread signaled to stop. 2024-08-24 09:13:50.591 | HD Request # 80 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.2 hours) and wrote 0 records for F.US.DDU24 2024-08-24 09:13:50.591 | HD Request # 80 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:13:50.591 | HD Request # 80 | Completion time: 0s. 2024-08-24 09:13:50.591 | HD Request # 80 | Intraday data download complete for F.US.DDU24. Unique request ID: 43 2024-08-24 09:13:50.591 | Removing historical data download ID 43. 2024-08-24 09:13:50.591 | Real-time Intraday chart data file updates started for F.US.DDU24 2024-08-24 09:13:50.591 | Intraday chart data file opened for F.US.DDU24 2024-08-24 09:13:50.591 | HD Request # 80 | Enabling Intraday chart updating for symbol. 2024-08-24 09:13:50.591 | 2024-08-24 09:13:50.591 | Triggering next historical data download in queue. 2024-08-24 09:13:50.591 | HD Request # 81 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:13:50.591 | HD Request # 81 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:13:50.591 | HD Request # 81 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:13:50.591 | Socket (3) | Creating socket. 2024-08-24 09:13:50.591 | Socket (3) | New receive buffer size: 0 2024-08-24 09:13:50.591 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:13:50.616 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 09:13:50.616 | Socket (4) | Closed. 2024-08-24 09:13:50.621 | HD Request # 81 | Setting DTC encoding to Binary VLS 2024-08-24 09:13:50.621 | HD Request # 81 | Sending historical data logon request message. 2024-08-24 09:13:50.635 | Socket (3) | CloseSocket call. 2024-08-24 09:13:50.635 | HD Request # 81 | Error downloading historical Intraday data for F.US.FDXSU24. Historical data logon error: Serving data is disabled 2024-08-24 09:13:50.635 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:13:50.635 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:13:50.635 | Triggering next historical data download in queue. 2024-08-24 09:13:50.635 | Historical data download thread signaled to stop. 2024-08-24 09:13:50.635 | HD Request # 81 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSU24 2024-08-24 09:13:50.635 | HD Request # 81 | Completion time: 0s. 2024-08-24 09:13:50.635 | 2024-08-24 09:13:50.635 | HD Request # 82 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:13:50.635 | HD Request # 82 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:13:50.635 | HD Request # 82 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:13:50.635 | Socket (4) | Creating socket. 2024-08-24 09:13:50.635 | Socket (4) | New receive buffer size: 0 2024-08-24 09:13:50.635 | Socket (4) | Connecting to IP: 176.9.9.252. 2024-08-24 09:13:50.650 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:13:50.650 | Socket (3) | Closed. 2024-08-24 09:13:50.707 | HD Request # 82 | Setting DTC encoding to Binary VLS 2024-08-24 09:13:50.707 | HD Request # 82 | Sending historical data logon request message. 2024-08-24 09:13:50.732 | HD Request # 82 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDXS202409_FUT_EUREX 2024-08-24 09:13:50.758 | HD Request # 82 | Decompressing data. 2024-08-24 09:13:50.783 | HD Request # 82 | Receiving Intraday data for F.US.FDXSU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:13:50.783 | Socket (4) | CloseSocket call. 2024-08-24 09:13:50.783 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 09:13:50.783 | Historical data download thread signaled to stop. 2024-08-24 09:13:50.783 | HD Request # 82 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.2 hours) and wrote 0 records for F.US.FDXSU24 2024-08-24 09:13:50.784 | HD Request # 82 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:13:50.785 | HD Request # 82 | Completion time: 0s. 2024-08-24 09:13:50.785 | HD Request # 82 | Intraday data download complete for F.US.FDXSU24. Unique request ID: 44 2024-08-24 09:13:50.785 | Removing historical data download ID 44. 2024-08-24 09:13:50.785 | Real-time Intraday chart data file updates started for F.US.FDXSU24 2024-08-24 09:13:50.785 | Intraday chart data file opened for F.US.FDXSU24 2024-08-24 09:13:50.785 | HD Request # 82 | Enabling Intraday chart updating for symbol. 2024-08-24 09:13:50.785 | 2024-08-24 09:13:50.785 | No download requests in the queue to start downloads for. 2024-08-24 09:13:50.809 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 09:13:50.809 | Socket (4) | Closed. 2024-08-24 09:13:51.093 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:13:51.093 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:13:51.093 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:13:51.133 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:13:57.857 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:14:00.760 | Chart #12 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:14:00.898 | Chart #2 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:14:00.898 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:14:00.898 | Chart #2 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:14:00.898 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:14:00.949 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:14:06.402 | Chart #25 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:14:06.436 | F.US.FDXSU24 [CBV][M] 100 Volume #14 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:14:06.654 | F.US.FDXSU24 [CBV][M] 1 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:16:12.132 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:16:12.132 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:16:12.132 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:16:12.232 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:16:19.273 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:16:22.338 | Circular chart reference detected. Charts: 25, 12. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-24 09:16:22.352 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:16:27.891 | Circular chart reference detected. Charts: 12, 25. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-24 09:16:27.980 | CQG WebSocket | Timeout waiting for pong message from server. 2024-08-24 09:16:27.980 | CQG WebAPI | WebSocket closed. 2024-08-24 09:16:27.980 | Connection to the external service has been lost. 2024-08-24 09:16:28.329 | CQG WebAPI | Sending Web API Logoff message. 2024-08-24 09:16:28.329 | CQG WebSocket socket (1) | CloseSocket call. 2024-08-24 09:16:28.329 | CQG WebSocket | WebSocket closed. 2024-08-24 09:16:28.329 | CQG WebAPI | WebSocket closed. 2024-08-24 09:16:28.329 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2024-08-24 09:16:28.329 | CQG WebAPI | Disconnected. 2024-08-24 09:16:28.329 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-08-24 09:16:28.340 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2024-08-24 09:16:28.340 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 09:16:28.350 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2024-08-24 09:16:28.350 | CQG WebSocket socket (1) | Closed. 2024-08-24 09:16:30.334 | 2024-08-24 09:16:30.335 | CQG WebAPI | Connecting to server api.cqg.com 2024-08-24 09:16:30.335 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-08-24 09:16:30.336 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2024-08-24 09:16:30.336 | CQG WebSocket socket (1) | New receive buffer size: 0 2024-08-24 09:16:30.337 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2024-08-24 09:16:30.347 | CQG WebSocket | Opening WebSocket. 2024-08-24 09:16:30.348 | CQG WebSocket | Sending WebSocket handshake. 2024-08-24 09:16:30.380 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2024-08-24 09:16:30.380 | CQG WebSocket | Server header | Connection: Upgrade 2024-08-24 09:16:30.380 | CQG WebSocket | Server header | Sec-WebSocket-Accept: waNPgbxuPPah2IcjnA87H87Gfj0= 2024-08-24 09:16:30.380 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2024-08-24 09:16:30.380 | CQG WebSocket | Server header | Upgrade: websocket 2024-08-24 09:16:30.380 | CQG WebSocket | Server header | 2024-08-24 09:16:30.380 | CQG WebSocket | Web socket state is now open. 2024-08-24 09:16:30.380 | CQG WebAPI | WebSocket connected. 2024-08-24 09:16:30.380 | CQG WebAPI | Sending market data logon message. 2024-08-24 09:16:30.610 | CQG WebAPI | Base Time: 2024-08-04T06:16:49. 2024-08-04 06:16:49 2024-08-24 09:16:30.610 | CQG WebAPI | Logon successful. Session Token = f44fq/jFAvq1rliQ1PhePDdSMw82qQKBk1xeDGDfZ2k9JYHa2mpDz9nVyJGSa4feFKD6smWozOP 2024-08-24 09:16:30.610 | CQG WebAPI | Connected to server complete. 2024-08-24 09:16:30.610 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:16:30.610 | DTC Client socket (2) | CloseSocket call. 2024-08-24 09:16:30.610 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:16:30.610 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 09:16:30.610 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-24 09:16:30.610 | Updated verified funded futures trading account ending date to: 2024-09-23 07:16:30 2024-08-24 09:16:30.636 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:16:30.636 | DTC Client socket (2) | Closed. 2024-08-24 09:16:30.878 | CQG WebAPI | Sending Trade Accounts request message. 2024-08-24 09:16:30.880 | CQG WebAPI | Sending positions subscribe request. RequestID: 982683 2024-08-24 09:16:30.880 | CQG WebAPI | Sending orders subscribe request. RequestID: 982684 2024-08-24 09:16:30.889 | CQG WebAPI | Brokerage name: WH Selfinvest France. Account Name: LWHF0931 2024-08-24 09:16:30.889 | Updated verified funded futures trading account ending date to: 2024-09-23 07:16:30 2024-08-24 09:16:30.889 | CQG WebAPI | Sending collateral subscribe request. 2024-08-24 09:16:31.005 | Mapping F.US.DDU24 to FDAX202409_FUT_EUREX. Service code: eurex 2024-08-24 09:16:31.005 | Using symbol data fast lookup vector 2024-08-24 09:16:31.005 | Denali Data Feed | Starting real-time market data updates for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 1 Service code: eurex 2024-08-24 09:16:31.006 | Denali Data Feed | Connecting to the server ds24.sierracharts.com. Port 10048 2024-08-24 09:16:31.006 | CQG WebAPI | Sending symbol resolution request for F.US.DDU24. ID: 982686 2024-08-24 09:16:31.006 | Denali Data Feed | Requesting security definition data for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 1 2024-08-24 09:16:31.006 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:16:31.006 | Intraday data recording state for symbol F.US.DDU24 is set to download 'Pending'. 2024-08-24 09:16:31.006 | Triggering next historical data download in queue. 2024-08-24 09:16:31.006 | DTC Client socket (2) | Creating socket. 2024-08-24 09:16:31.006 | DTC Client socket (2) | New receive buffer size: 0 2024-08-24 09:16:31.006 | DTC Client socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 09:16:31.025 | Delaying start of download for F.US.DDU24. 2024-08-24 09:16:31.025 | CQG WebAPI | Received symbol resolution report for symbol F.US.DDU24. Search Symbol: F.US.DDU24. Request ID: 982686. Contract ID: 1. 2024-08-24 09:16:31.025 | Mapping F.US.FDXSU24 to FDXS202409_FUT_EUREX. Service code: eurex 2024-08-24 09:16:31.025 | Denali Data Feed | Starting real-time market data updates for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 2 Service code: eurex 2024-08-24 09:16:31.025 | CQG WebAPI | Sending symbol resolution request for F.US.FDXSU24. ID: 982687 2024-08-24 09:16:31.025 | Denali Data Feed | Requesting security definition data for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 2 2024-08-24 09:16:31.026 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:16:31.026 | Intraday data recording state for symbol F.US.FDXSU24 is set to download 'Pending'. 2024-08-24 09:16:31.026 | Triggering next historical data download in queue. 2024-08-24 09:16:31.027 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:16:31.027 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:16:31.027 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:16:31.062 | CQG WebAPI | Received symbol resolution report for symbol F.US.FDXSU24. Search Symbol: F.US.FDXSU24. Request ID: 982687. Contract ID: 2. 2024-08-24 09:16:31.062 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:16:31.062 | Denali Data Feed | Sending logon request message. 2024-08-24 09:16:31.089 | Denali Data Feed | Received logon response. 2024-08-24 09:16:31.089 | Denali Data Feed | Server Name: RealTimeServer. 2024-08-24 09:16:31.089 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:16:31.089 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. 2024-08-24 09:16:31.089 | Denali Data Feed | Failed connections: 1 2024-08-24 09:16:31.089 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:16:31.090 | DTC Client socket (2) | CloseSocket call. 2024-08-24 09:16:31.090 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:16:31.090 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-08-24 09:16:31.090 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 09:16:31.105 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:16:31.105 | DTC Client socket (2) | Closed. 2024-08-24 09:16:34.111 | Denali Data Feed | Connecting to the server ds14.sierracharts.com. Port 443 2024-08-24 09:16:34.111 | DTC Client socket (2) | Creating socket. 2024-08-24 09:16:34.111 | DTC Client socket (2) | New receive buffer size: 0 2024-08-24 09:16:34.111 | DTC Client socket (2) | Connecting to IP: 176.9.9.252. 2024-08-24 09:16:34.137 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:16:34.137 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:16:34.137 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:16:34.167 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:16:34.167 | Denali Data Feed | Sending logon request message. 2024-08-24 09:16:34.581 | Denali Data Feed | Received logon response. 2024-08-24 09:16:34.581 | Denali Data Feed | Server Name: SC Realtime Server. 2024-08-24 09:16:34.581 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:16:34.581 | Denali Data Feed | Successfully connected. 2024-08-24 09:16:34.581 | Denali Data Feed | Trading is not supported. 2024-08-24 09:16:34.581 | Denali Data Feed | MarketDepthIsSupported: 1 2024-08-24 09:16:34.581 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.DDU24 -> FDAX202409_FUT_EUREX 2024-08-24 09:16:34.581 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.FDXSU24 -> FDXS202409_FUT_EUREX 2024-08-24 09:16:34.698 | Denali Data Feed | Real-time data for symbol F.US.DDU24 is currently unavailable. 2024-08-24 09:16:34.698 | Denali Data Feed | Setting external service identifier for symbol F.US.DDU24 to 7296071 2024-08-24 09:16:34.698 | Denali Data Feed | Received security definition for symbol F.US.DDU24 2024-08-24 09:16:34.698 | Denali Data Feed | Real-time data for symbol F.US.FDXSU24 is currently unavailable. 2024-08-24 09:16:34.698 | Denali Data Feed | Setting external service identifier for symbol F.US.FDXSU24 to 10451688 2024-08-24 09:16:34.698 | Denali Data Feed | Received security definition for symbol F.US.FDXSU24 2024-08-24 09:16:39.858 | HD Request # 83 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:16:39.859 | HD Request # 83 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:16:39.860 | HD Request # 83 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:16:39.860 | Socket (3) | Creating socket. 2024-08-24 09:16:39.860 | Socket (3) | New receive buffer size: 0 2024-08-24 09:16:39.860 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:16:39.891 | HD Request # 83 | Setting DTC encoding to Binary VLS 2024-08-24 09:16:39.891 | HD Request # 83 | Sending historical data logon request message. 2024-08-24 09:16:39.904 | Socket (3) | CloseSocket call. 2024-08-24 09:16:39.904 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:16:39.905 | HD Request # 83 | Error downloading historical Intraday data for F.US.DDU24. Historical data logon error: Serving data is disabled 2024-08-24 09:16:39.905 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:16:39.905 | Triggering next historical data download in queue. 2024-08-24 09:16:39.905 | Historical data download thread signaled to stop. 2024-08-24 09:16:39.905 | HD Request # 83 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DDU24 2024-08-24 09:16:39.905 | HD Request # 83 | Completion time: 0s. 2024-08-24 09:16:39.905 | 2024-08-24 09:16:39.905 | HD Request # 84 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:16:39.907 | HD Request # 84 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:16:39.907 | HD Request # 84 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:16:39.907 | Socket (4) | Creating socket. 2024-08-24 09:16:39.908 | Socket (4) | New receive buffer size: 0 2024-08-24 09:16:39.908 | Socket (4) | Connecting to IP: 176.9.9.252. 2024-08-24 09:16:39.919 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:16:39.919 | Socket (3) | Closed. 2024-08-24 09:16:39.962 | HD Request # 84 | Setting DTC encoding to Binary VLS 2024-08-24 09:16:39.962 | HD Request # 84 | Sending historical data logon request message. 2024-08-24 09:16:40.117 | HD Request # 84 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDAX202409_FUT_EUREX 2024-08-24 09:16:40.142 | HD Request # 84 | Decompressing data. 2024-08-24 09:16:40.165 | HD Request # 84 | Receiving Intraday data for F.US.DDU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:16:40.165 | Socket (4) | CloseSocket call. 2024-08-24 09:16:40.165 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 09:16:40.190 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 09:16:40.190 | Socket (4) | Closed. 2024-08-24 09:16:40.192 | Historical data download thread signaled to stop. 2024-08-24 09:16:40.192 | HD Request # 84 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.2 hours) and wrote 0 records for F.US.DDU24 2024-08-24 09:16:40.192 | HD Request # 84 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:16:40.192 | HD Request # 84 | Completion time: 1s. 2024-08-24 09:16:40.192 | HD Request # 84 | Intraday data download complete for F.US.DDU24. Unique request ID: 45 2024-08-24 09:16:40.192 | Removing historical data download ID 45. 2024-08-24 09:16:40.192 | Real-time Intraday chart data file updates started for F.US.DDU24 2024-08-24 09:16:40.192 | Intraday chart data file opened for F.US.DDU24 2024-08-24 09:16:40.192 | HD Request # 84 | Enabling Intraday chart updating for symbol. 2024-08-24 09:16:40.192 | 2024-08-24 09:16:40.192 | Triggering next historical data download in queue. 2024-08-24 09:16:40.192 | HD Request # 85 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:16:40.193 | HD Request # 85 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:16:40.193 | HD Request # 85 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:16:40.193 | Socket (3) | Creating socket. 2024-08-24 09:16:40.193 | Socket (3) | New receive buffer size: 0 2024-08-24 09:16:40.193 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:16:40.222 | HD Request # 85 | Setting DTC encoding to Binary VLS 2024-08-24 09:16:40.222 | HD Request # 85 | Sending historical data logon request message. 2024-08-24 09:16:40.235 | Socket (3) | CloseSocket call. 2024-08-24 09:16:40.235 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:16:40.245 | HD Request # 85 | Error downloading historical Intraday data for F.US.FDXSU24. Historical data logon error: Serving data is disabled 2024-08-24 09:16:40.245 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:16:40.245 | Triggering next historical data download in queue. 2024-08-24 09:16:40.245 | Historical data download thread signaled to stop. 2024-08-24 09:16:40.245 | HD Request # 85 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSU24 2024-08-24 09:16:40.245 | HD Request # 85 | Completion time: 0s. 2024-08-24 09:16:40.245 | 2024-08-24 09:16:40.245 | HD Request # 86 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:16:40.245 | HD Request # 86 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:16:40.246 | HD Request # 86 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:16:40.246 | Socket (4) | Creating socket. 2024-08-24 09:16:40.246 | Socket (4) | New receive buffer size: 0 2024-08-24 09:16:40.246 | Socket (4) | Connecting to IP: 176.9.9.252. 2024-08-24 09:16:40.250 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:16:40.250 | Socket (3) | Closed. 2024-08-24 09:16:40.299 | HD Request # 86 | Setting DTC encoding to Binary VLS 2024-08-24 09:16:40.299 | HD Request # 86 | Sending historical data logon request message. 2024-08-24 09:16:40.323 | HD Request # 86 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDXS202409_FUT_EUREX 2024-08-24 09:16:40.347 | HD Request # 86 | Decompressing data. 2024-08-24 09:16:40.371 | HD Request # 86 | Receiving Intraday data for F.US.FDXSU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:16:40.371 | Socket (4) | CloseSocket call. 2024-08-24 09:16:40.371 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 09:16:40.371 | Historical data download thread signaled to stop. 2024-08-24 09:16:40.371 | HD Request # 86 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.2 hours) and wrote 0 records for F.US.FDXSU24 2024-08-24 09:16:40.372 | HD Request # 86 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:16:40.373 | HD Request # 86 | Completion time: 0s. 2024-08-24 09:16:40.373 | HD Request # 86 | Intraday data download complete for F.US.FDXSU24. Unique request ID: 46 2024-08-24 09:16:40.373 | Removing historical data download ID 46. 2024-08-24 09:16:40.373 | Real-time Intraday chart data file updates started for F.US.FDXSU24 2024-08-24 09:16:40.373 | Intraday chart data file opened for F.US.FDXSU24 2024-08-24 09:16:40.373 | HD Request # 86 | Enabling Intraday chart updating for symbol. 2024-08-24 09:16:40.373 | 2024-08-24 09:16:40.373 | No download requests in the queue to start downloads for. 2024-08-24 09:16:40.396 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 09:16:40.396 | Socket (4) | Closed. 2024-08-24 09:16:40.705 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:16:40.705 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:16:40.705 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:16:40.740 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:16:47.417 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:16:50.512 | Chart #12 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:16:50.656 | Chart #2 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:16:50.656 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:16:50.656 | Chart #2 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:16:50.656 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:16:50.709 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:16:56.109 | Chart #25 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:16:56.264 | F.US.FDXSU24 [CBV][M] 100 Volume #14 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:16:56.534 | F.US.FDXSU24 [CBV][M] 1 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:19:02.211 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:19:02.211 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:19:02.211 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:19:02.312 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:19:09.031 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:19:11.962 | Circular chart reference detected. Charts: 25, 12. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-24 09:19:11.962 | CQG WebSocket | Timeout waiting for pong message from server. 2024-08-24 09:19:11.962 | CQG WebAPI | WebSocket closed. 2024-08-24 09:19:11.962 | Connection to the external service has been lost. 2024-08-24 09:19:12.231 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:19:17.675 | Circular chart reference detected. Charts: 12, 25. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-24 09:19:17.746 | CQG WebAPI | Sending Web API Logoff message. 2024-08-24 09:19:17.746 | CQG WebSocket socket (1) | CloseSocket call. 2024-08-24 09:19:17.746 | CQG WebSocket socket (1) | Max send buffers used during socket life: 3 2024-08-24 09:19:17.746 | CQG WebSocket socket (1) | Max send buffer size during socket life: 309 2024-08-24 09:19:17.746 | CQG WebSocket | WebSocket closed. 2024-08-24 09:19:17.746 | CQG WebAPI | WebSocket closed. 2024-08-24 09:19:17.746 | CQG WebAPI | Disconnected. 2024-08-24 09:19:17.746 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-08-24 09:19:17.746 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2024-08-24 09:19:17.756 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2024-08-24 09:19:17.756 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 09:19:17.765 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2024-08-24 09:19:17.765 | CQG WebSocket socket (1) | Closed. 2024-08-24 09:19:19.752 | 2024-08-24 09:19:19.753 | CQG WebAPI | Connecting to server api.cqg.com 2024-08-24 09:19:19.753 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-08-24 09:19:19.868 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2024-08-24 09:19:19.869 | CQG WebSocket socket (1) | New receive buffer size: 0 2024-08-24 09:19:19.869 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2024-08-24 09:19:19.880 | CQG WebSocket | Opening WebSocket. 2024-08-24 09:19:19.880 | CQG WebSocket | Sending WebSocket handshake. 2024-08-24 09:19:19.940 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2024-08-24 09:19:19.940 | CQG WebSocket | Server header | Connection: Upgrade 2024-08-24 09:19:19.940 | CQG WebSocket | Server header | Sec-WebSocket-Accept: hj2HrvF6tNU1wV1Tgqo9GO96YPA= 2024-08-24 09:19:19.940 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2024-08-24 09:19:19.940 | CQG WebSocket | Server header | Upgrade: websocket 2024-08-24 09:19:19.940 | CQG WebSocket | Server header | 2024-08-24 09:19:19.940 | CQG WebSocket | Web socket state is now open. 2024-08-24 09:19:19.940 | CQG WebAPI | WebSocket connected. 2024-08-24 09:19:19.940 | CQG WebAPI | Sending market data logon message. 2024-08-24 09:19:20.162 | CQG WebAPI | Base Time: 2024-08-04T06:16:49. 2024-08-04 06:16:49 2024-08-24 09:19:20.162 | CQG WebAPI | Logon successful. Session Token = zQujAiXolzYn2zjW9qpzFa4eCUSMnl7hiYgHcapm3eYND7nG7+EjyyWAdkn1NuKbTPNyJEeQfXT 2024-08-24 09:19:20.162 | CQG WebAPI | Connected to server complete. 2024-08-24 09:19:20.162 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:19:20.163 | DTC Client socket (2) | CloseSocket call. 2024-08-24 09:19:20.163 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:19:20.163 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 09:19:20.163 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-24 09:19:20.163 | Updated verified funded futures trading account ending date to: 2024-09-23 07:19:20 2024-08-24 09:19:20.188 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:19:20.188 | DTC Client socket (2) | Closed. 2024-08-24 09:19:20.428 | CQG WebAPI | Sending Trade Accounts request message. 2024-08-24 09:19:20.429 | CQG WebAPI | Sending positions subscribe request. RequestID: 982689 2024-08-24 09:19:20.429 | CQG WebAPI | Sending orders subscribe request. RequestID: 982690 2024-08-24 09:19:20.438 | CQG WebAPI | Brokerage name: WH Selfinvest France. Account Name: LWHF0931 2024-08-24 09:19:20.438 | Updated verified funded futures trading account ending date to: 2024-09-23 07:19:20 2024-08-24 09:19:20.438 | CQG WebAPI | Sending collateral subscribe request. 2024-08-24 09:19:20.575 | Mapping F.US.DDU24 to FDAX202409_FUT_EUREX. Service code: eurex 2024-08-24 09:19:20.575 | Using symbol data fast lookup vector 2024-08-24 09:19:20.575 | Denali Data Feed | Starting real-time market data updates for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 1 Service code: eurex 2024-08-24 09:19:20.575 | Denali Data Feed | Connecting to the server ds24.sierracharts.com. Port 443 2024-08-24 09:19:20.575 | CQG WebAPI | Sending symbol resolution request for F.US.DDU24. ID: 982692 2024-08-24 09:19:20.575 | Denali Data Feed | Requesting security definition data for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 1 2024-08-24 09:19:20.575 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:19:20.575 | Intraday data recording state for symbol F.US.DDU24 is set to download 'Pending'. 2024-08-24 09:19:20.575 | Triggering next historical data download in queue. 2024-08-24 09:19:20.576 | DTC Client socket (2) | Creating socket. 2024-08-24 09:19:20.576 | DTC Client socket (2) | New receive buffer size: 0 2024-08-24 09:19:20.576 | DTC Client socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 09:19:20.629 | Delaying start of download for F.US.DDU24. 2024-08-24 09:19:20.629 | CQG WebAPI | Received symbol resolution report for symbol F.US.DDU24. Search Symbol: F.US.DDU24. Request ID: 982692. Contract ID: 1. 2024-08-24 09:19:20.629 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:19:20.629 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:19:20.629 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:19:20.629 | Mapping F.US.FDXSU24 to FDXS202409_FUT_EUREX. Service code: eurex 2024-08-24 09:19:20.629 | Denali Data Feed | Starting real-time market data updates for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 2 Service code: eurex 2024-08-24 09:19:20.629 | CQG WebAPI | Sending symbol resolution request for F.US.FDXSU24. ID: 982693 2024-08-24 09:19:20.629 | Denali Data Feed | Requesting security definition data for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 2 2024-08-24 09:19:20.629 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:19:20.629 | Intraday data recording state for symbol F.US.FDXSU24 is set to download 'Pending'. 2024-08-24 09:19:20.629 | Triggering next historical data download in queue. 2024-08-24 09:19:20.664 | CQG WebAPI | Received symbol resolution report for symbol F.US.FDXSU24. Search Symbol: F.US.FDXSU24. Request ID: 982693. Contract ID: 2. 2024-08-24 09:19:20.664 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:19:20.664 | Denali Data Feed | Sending logon request message. 2024-08-24 09:19:20.709 | Denali Data Feed | Received logon response. 2024-08-24 09:19:20.709 | Denali Data Feed | Server Name: RealTimeServer. 2024-08-24 09:19:20.709 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:19:20.709 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. 2024-08-24 09:19:20.709 | Denali Data Feed | Failed connections: 1 2024-08-24 09:19:20.709 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:19:20.709 | DTC Client socket (2) | CloseSocket call. 2024-08-24 09:19:20.709 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:19:20.709 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-08-24 09:19:20.710 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 09:19:20.724 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:19:20.724 | DTC Client socket (2) | Closed. 2024-08-24 09:19:23.703 | Denali Data Feed | Connecting to the server ds14.sierracharts.com. Port 10048 2024-08-24 09:19:23.704 | DTC Client socket (2) | Creating socket. 2024-08-24 09:19:23.704 | DTC Client socket (2) | New receive buffer size: 0 2024-08-24 09:19:23.704 | DTC Client socket (2) | Connecting to IP: 176.9.9.252. 2024-08-24 09:19:23.728 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:19:23.728 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:19:23.728 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:19:23.771 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:19:23.771 | Denali Data Feed | Sending logon request message. 2024-08-24 09:19:24.129 | Denali Data Feed | Received logon response. 2024-08-24 09:19:24.129 | Denali Data Feed | Server Name: SC Realtime Server. 2024-08-24 09:19:24.129 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:19:24.129 | Denali Data Feed | Successfully connected. 2024-08-24 09:19:24.129 | Denali Data Feed | Trading is not supported. 2024-08-24 09:19:24.129 | Denali Data Feed | MarketDepthIsSupported: 1 2024-08-24 09:19:24.129 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.DDU24 -> FDAX202409_FUT_EUREX 2024-08-24 09:19:24.129 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.FDXSU24 -> FDXS202409_FUT_EUREX 2024-08-24 09:19:24.239 | Denali Data Feed | Real-time data for symbol F.US.DDU24 is currently unavailable. 2024-08-24 09:19:24.239 | Denali Data Feed | Setting external service identifier for symbol F.US.DDU24 to 7296071 2024-08-24 09:19:24.239 | Denali Data Feed | Received security definition for symbol F.US.DDU24 2024-08-24 09:19:24.239 | Denali Data Feed | Real-time data for symbol F.US.FDXSU24 is currently unavailable. 2024-08-24 09:19:24.239 | Denali Data Feed | Setting external service identifier for symbol F.US.FDXSU24 to 10451688 2024-08-24 09:19:24.239 | Denali Data Feed | Received security definition for symbol F.US.FDXSU24 2024-08-24 09:19:29.462 | HD Request # 87 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:19:29.463 | HD Request # 87 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:19:29.463 | HD Request # 87 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:19:29.463 | Socket (3) | Creating socket. 2024-08-24 09:19:29.463 | Socket (3) | New receive buffer size: 0 2024-08-24 09:19:29.463 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:19:29.493 | HD Request # 87 | Setting DTC encoding to Binary VLS 2024-08-24 09:19:29.493 | HD Request # 87 | Sending historical data logon request message. 2024-08-24 09:19:29.506 | Socket (3) | CloseSocket call. 2024-08-24 09:19:29.506 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:19:29.506 | HD Request # 87 | Error downloading historical Intraday data for F.US.DDU24. Historical data logon error: Serving data is disabled 2024-08-24 09:19:29.506 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:19:29.506 | Triggering next historical data download in queue. 2024-08-24 09:19:29.507 | Historical data download thread signaled to stop. 2024-08-24 09:19:29.507 | HD Request # 87 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DDU24 2024-08-24 09:19:29.507 | HD Request # 87 | Completion time: 0s. 2024-08-24 09:19:29.507 | 2024-08-24 09:19:29.507 | HD Request # 88 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:19:29.508 | HD Request # 88 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:19:29.509 | HD Request # 88 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:19:29.509 | Socket (4) | Creating socket. 2024-08-24 09:19:29.509 | Socket (4) | New receive buffer size: 0 2024-08-24 09:19:29.509 | Socket (4) | Connecting to IP: 176.9.9.252. 2024-08-24 09:19:29.520 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:19:29.520 | Socket (3) | Closed. 2024-08-24 09:19:29.563 | HD Request # 88 | Setting DTC encoding to Binary VLS 2024-08-24 09:19:29.563 | HD Request # 88 | Sending historical data logon request message. 2024-08-24 09:19:29.718 | HD Request # 88 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDAX202409_FUT_EUREX 2024-08-24 09:19:29.742 | HD Request # 88 | Decompressing data. 2024-08-24 09:19:29.765 | HD Request # 88 | Receiving Intraday data for F.US.DDU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:19:29.765 | Socket (4) | CloseSocket call. 2024-08-24 09:19:29.765 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 09:19:29.785 | Historical data download thread signaled to stop. 2024-08-24 09:19:29.785 | HD Request # 88 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.3 hours) and wrote 0 records for F.US.DDU24 2024-08-24 09:19:29.786 | HD Request # 88 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:19:29.786 | HD Request # 88 | Completion time: 0s. 2024-08-24 09:19:29.786 | HD Request # 88 | Intraday data download complete for F.US.DDU24. Unique request ID: 47 2024-08-24 09:19:29.786 | Removing historical data download ID 47. 2024-08-24 09:19:29.786 | Real-time Intraday chart data file updates started for F.US.DDU24 2024-08-24 09:19:29.786 | Intraday chart data file opened for F.US.DDU24 2024-08-24 09:19:29.786 | HD Request # 88 | Enabling Intraday chart updating for symbol. 2024-08-24 09:19:29.786 | 2024-08-24 09:19:29.786 | Triggering next historical data download in queue. 2024-08-24 09:19:29.786 | HD Request # 89 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:19:29.786 | HD Request # 89 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:19:29.786 | HD Request # 89 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:19:29.786 | Socket (3) | Creating socket. 2024-08-24 09:19:29.786 | Socket (3) | New receive buffer size: 0 2024-08-24 09:19:29.786 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:19:29.792 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 09:19:29.792 | Socket (4) | Closed. 2024-08-24 09:19:29.815 | HD Request # 89 | Setting DTC encoding to Binary VLS 2024-08-24 09:19:29.815 | HD Request # 89 | Sending historical data logon request message. 2024-08-24 09:19:29.829 | Socket (3) | CloseSocket call. 2024-08-24 09:19:29.829 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:19:29.842 | HD Request # 89 | Error downloading historical Intraday data for F.US.FDXSU24. Historical data logon error: Serving data is disabled 2024-08-24 09:19:29.842 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:19:29.842 | Triggering next historical data download in queue. 2024-08-24 09:19:29.842 | Historical data download thread signaled to stop. 2024-08-24 09:19:29.842 | HD Request # 89 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSU24 2024-08-24 09:19:29.843 | HD Request # 89 | Completion time: 0s. 2024-08-24 09:19:29.843 | 2024-08-24 09:19:29.843 | HD Request # 90 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:19:29.843 | HD Request # 90 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:19:29.843 | HD Request # 90 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:19:29.843 | Socket (4) | Creating socket. 2024-08-24 09:19:29.843 | Socket (4) | New receive buffer size: 0 2024-08-24 09:19:29.843 | Socket (4) | Connecting to IP: 176.9.9.252. 2024-08-24 09:19:29.843 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:19:29.843 | Socket (3) | Closed. 2024-08-24 09:19:29.898 | HD Request # 90 | Setting DTC encoding to Binary VLS 2024-08-24 09:19:29.898 | HD Request # 90 | Sending historical data logon request message. 2024-08-24 09:19:29.924 | HD Request # 90 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDXS202409_FUT_EUREX 2024-08-24 09:19:29.950 | HD Request # 90 | Decompressing data. 2024-08-24 09:19:29.974 | HD Request # 90 | Receiving Intraday data for F.US.FDXSU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:19:29.974 | Socket (4) | CloseSocket call. 2024-08-24 09:19:29.974 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 09:19:29.974 | Historical data download thread signaled to stop. 2024-08-24 09:19:29.974 | HD Request # 90 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.3 hours) and wrote 0 records for F.US.FDXSU24 2024-08-24 09:19:29.976 | HD Request # 90 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:19:29.976 | HD Request # 90 | Completion time: 0s. 2024-08-24 09:19:29.976 | HD Request # 90 | Intraday data download complete for F.US.FDXSU24. Unique request ID: 48 2024-08-24 09:19:29.976 | Removing historical data download ID 48. 2024-08-24 09:19:29.976 | Real-time Intraday chart data file updates started for F.US.FDXSU24 2024-08-24 09:19:29.976 | Intraday chart data file opened for F.US.FDXSU24 2024-08-24 09:19:29.976 | HD Request # 90 | Enabling Intraday chart updating for symbol. 2024-08-24 09:19:29.976 | 2024-08-24 09:19:29.976 | No download requests in the queue to start downloads for. 2024-08-24 09:19:30.003 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 09:19:30.003 | Socket (4) | Closed. 2024-08-24 09:19:30.280 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:19:30.280 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:19:30.280 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:19:30.315 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:19:36.904 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:19:39.852 | Chart #12 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:19:39.989 | Chart #2 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:19:39.989 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:19:39.989 | Chart #2 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:19:39.989 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:19:40.041 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:19:45.440 | Chart #25 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:19:45.474 | F.US.FDXSU24 [CBV][M] 100 Volume #14 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:19:45.690 | F.US.FDXSU24 [CBV][M] 1 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:21:50.847 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:21:50.847 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:21:50.847 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:21:50.848 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:21:57.540 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:00.522 | Circular chart reference detected. Charts: 25, 12. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-24 09:22:00.522 | CQG WebSocket | Timeout waiting for pong message from server. 2024-08-24 09:22:00.522 | CQG WebAPI | WebSocket closed. 2024-08-24 09:22:00.522 | Connection to the external service has been lost. 2024-08-24 09:22:00.795 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:06.249 | Circular chart reference detected. Charts: 12, 25. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-24 09:22:06.314 | CQG WebAPI | Sending Web API Logoff message. 2024-08-24 09:22:06.314 | CQG WebSocket socket (1) | CloseSocket call. 2024-08-24 09:22:06.314 | CQG WebSocket | WebSocket closed. 2024-08-24 09:22:06.314 | CQG WebAPI | WebSocket closed. 2024-08-24 09:22:06.314 | CQG WebAPI | Disconnected. 2024-08-24 09:22:06.314 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-08-24 09:22:06.314 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2024-08-24 09:22:06.323 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2024-08-24 09:22:06.323 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 09:22:06.333 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2024-08-24 09:22:06.333 | CQG WebSocket socket (1) | Closed. 2024-08-24 09:22:08.325 | 2024-08-24 09:22:08.325 | CQG WebAPI | Connecting to server api.cqg.com 2024-08-24 09:22:08.325 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-08-24 09:22:08.326 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2024-08-24 09:22:08.326 | CQG WebSocket socket (1) | New receive buffer size: 0 2024-08-24 09:22:08.326 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2024-08-24 09:22:08.339 | CQG WebSocket | Opening WebSocket. 2024-08-24 09:22:08.339 | CQG WebSocket | Sending WebSocket handshake. 2024-08-24 09:22:08.386 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2024-08-24 09:22:08.386 | CQG WebSocket | Server header | Connection: Upgrade 2024-08-24 09:22:08.386 | CQG WebSocket | Server header | Sec-WebSocket-Accept: 0Cl8RasdWNdLOLo8dpopwpymWMc= 2024-08-24 09:22:08.386 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2024-08-24 09:22:08.386 | CQG WebSocket | Server header | Upgrade: websocket 2024-08-24 09:22:08.386 | CQG WebSocket | Server header | 2024-08-24 09:22:08.386 | CQG WebSocket | Web socket state is now open. 2024-08-24 09:22:08.386 | CQG WebAPI | WebSocket connected. 2024-08-24 09:22:08.386 | CQG WebAPI | Sending market data logon message. 2024-08-24 09:22:08.621 | CQG WebAPI | Base Time: 2024-08-04T06:16:49. 2024-08-04 06:16:49 2024-08-24 09:22:08.621 | CQG WebAPI | Logon successful. Session Token = buM/77VD3ycaOEl/zqgRpJ2oF8x9RNp3CmzNhuJvfQwPcpXOUDy3edorilyuhpeP9qSf4Q5YGGU 2024-08-24 09:22:08.621 | CQG WebAPI | Connected to server complete. 2024-08-24 09:22:08.621 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:22:08.621 | DTC Client socket (2) | CloseSocket call. 2024-08-24 09:22:08.621 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:22:08.621 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 09:22:08.621 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-24 09:22:08.621 | Updated verified funded futures trading account ending date to: 2024-09-23 07:22:08 2024-08-24 09:22:08.651 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:22:08.651 | DTC Client socket (2) | Closed. 2024-08-24 09:22:08.888 | CQG WebAPI | Sending Trade Accounts request message. 2024-08-24 09:22:08.889 | CQG WebAPI | Sending positions subscribe request. RequestID: 982695 2024-08-24 09:22:08.889 | CQG WebAPI | Sending orders subscribe request. RequestID: 982696 2024-08-24 09:22:08.898 | CQG WebAPI | Brokerage name: WH Selfinvest France. Account Name: LWHF0931 2024-08-24 09:22:08.898 | Updated verified funded futures trading account ending date to: 2024-09-23 07:22:08 2024-08-24 09:22:08.898 | CQG WebAPI | Sending collateral subscribe request. 2024-08-24 09:22:09.040 | Mapping F.US.DDU24 to FDAX202409_FUT_EUREX. Service code: eurex 2024-08-24 09:22:09.040 | Using symbol data fast lookup vector 2024-08-24 09:22:09.040 | Denali Data Feed | Starting real-time market data updates for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 1 Service code: eurex 2024-08-24 09:22:09.040 | Denali Data Feed | Connecting to the server ds24.sierracharts.com. Port 10048 2024-08-24 09:22:09.041 | CQG WebAPI | Sending symbol resolution request for F.US.DDU24. ID: 982698 2024-08-24 09:22:09.041 | Denali Data Feed | Requesting security definition data for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 1 2024-08-24 09:22:09.041 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:22:09.041 | Intraday data recording state for symbol F.US.DDU24 is set to download 'Pending'. 2024-08-24 09:22:09.041 | Triggering next historical data download in queue. 2024-08-24 09:22:09.041 | DTC Client socket (2) | Creating socket. 2024-08-24 09:22:09.042 | DTC Client socket (2) | New receive buffer size: 0 2024-08-24 09:22:09.042 | DTC Client socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 09:22:09.095 | Delaying start of download for F.US.DDU24. 2024-08-24 09:22:09.095 | CQG WebAPI | Received symbol resolution report for symbol F.US.DDU24. Search Symbol: F.US.DDU24. Request ID: 982698. Contract ID: 1. 2024-08-24 09:22:09.095 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:22:09.095 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:22:09.095 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:22:09.095 | Mapping F.US.FDXSU24 to FDXS202409_FUT_EUREX. Service code: eurex 2024-08-24 09:22:09.095 | Denali Data Feed | Starting real-time market data updates for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 2 Service code: eurex 2024-08-24 09:22:09.095 | CQG WebAPI | Sending symbol resolution request for F.US.FDXSU24. ID: 982699 2024-08-24 09:22:09.095 | Denali Data Feed | Requesting security definition data for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 2 2024-08-24 09:22:09.095 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:22:09.095 | Intraday data recording state for symbol F.US.FDXSU24 is set to download 'Pending'. 2024-08-24 09:22:09.095 | Triggering next historical data download in queue. 2024-08-24 09:22:09.129 | CQG WebAPI | Received symbol resolution report for symbol F.US.FDXSU24. Search Symbol: F.US.FDXSU24. Request ID: 982699. Contract ID: 2. 2024-08-24 09:22:09.130 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:22:09.130 | Denali Data Feed | Sending logon request message. 2024-08-24 09:22:09.171 | Denali Data Feed | Received logon response. 2024-08-24 09:22:09.171 | Denali Data Feed | Server Name: RealTimeServer. 2024-08-24 09:22:09.171 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:22:09.171 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. 2024-08-24 09:22:09.171 | Denali Data Feed | Failed connections: 1 2024-08-24 09:22:09.171 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:22:09.171 | DTC Client socket (2) | CloseSocket call. 2024-08-24 09:22:09.171 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:22:09.171 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-08-24 09:22:09.171 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 09:22:09.185 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:22:09.185 | DTC Client socket (2) | Closed. 2024-08-24 09:22:12.192 | Denali Data Feed | Connecting to the server ds14.sierracharts.com. Port 10048 2024-08-24 09:22:12.193 | DTC Client socket (2) | Creating socket. 2024-08-24 09:22:12.193 | DTC Client socket (2) | New receive buffer size: 0 2024-08-24 09:22:12.193 | DTC Client socket (2) | Connecting to IP: 176.9.9.252. 2024-08-24 09:22:12.219 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:22:12.219 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:22:12.219 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:22:12.260 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:22:12.260 | Denali Data Feed | Sending logon request message. 2024-08-24 09:22:12.604 | Denali Data Feed | Received logon response. 2024-08-24 09:22:12.604 | Denali Data Feed | Server Name: SC Realtime Server. 2024-08-24 09:22:12.604 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:22:12.604 | Denali Data Feed | Successfully connected. 2024-08-24 09:22:12.604 | Denali Data Feed | Trading is not supported. 2024-08-24 09:22:12.604 | Denali Data Feed | MarketDepthIsSupported: 1 2024-08-24 09:22:12.604 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.DDU24 -> FDAX202409_FUT_EUREX 2024-08-24 09:22:12.604 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.FDXSU24 -> FDXS202409_FUT_EUREX 2024-08-24 09:22:12.729 | Denali Data Feed | Real-time data for symbol F.US.DDU24 is currently unavailable. 2024-08-24 09:22:12.729 | Denali Data Feed | Setting external service identifier for symbol F.US.DDU24 to 7296071 2024-08-24 09:22:12.729 | Denali Data Feed | Received security definition for symbol F.US.DDU24 2024-08-24 09:22:12.729 | Denali Data Feed | Real-time data for symbol F.US.FDXSU24 is currently unavailable. 2024-08-24 09:22:12.729 | Denali Data Feed | Setting external service identifier for symbol F.US.FDXSU24 to 10451688 2024-08-24 09:22:12.729 | Denali Data Feed | Received security definition for symbol F.US.FDXSU24 2024-08-24 09:22:17.257 | HD Request # 91 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:22:17.258 | HD Request # 91 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:22:17.258 | HD Request # 91 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:22:17.258 | Socket (3) | Creating socket. 2024-08-24 09:22:17.258 | Socket (3) | New receive buffer size: 0 2024-08-24 09:22:17.258 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:22:17.288 | HD Request # 91 | Setting DTC encoding to Binary VLS 2024-08-24 09:22:17.288 | HD Request # 91 | Sending historical data logon request message. 2024-08-24 09:22:17.302 | Socket (3) | CloseSocket call. 2024-08-24 09:22:17.302 | HD Request # 91 | Error downloading historical Intraday data for F.US.DDU24. Historical data logon error: Serving data is disabled 2024-08-24 09:22:17.302 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:22:17.302 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:22:17.302 | Triggering next historical data download in queue. 2024-08-24 09:22:17.302 | Historical data download thread signaled to stop. 2024-08-24 09:22:17.302 | HD Request # 91 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DDU24 2024-08-24 09:22:17.302 | HD Request # 91 | Completion time: 0s. 2024-08-24 09:22:17.302 | 2024-08-24 09:22:17.302 | HD Request # 92 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:22:17.302 | HD Request # 92 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:22:17.303 | HD Request # 92 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:22:17.303 | Socket (4) | Creating socket. 2024-08-24 09:22:17.303 | Socket (4) | New receive buffer size: 0 2024-08-24 09:22:17.303 | Socket (4) | Connecting to IP: 176.9.9.252. 2024-08-24 09:22:17.317 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:22:17.317 | Socket (3) | Closed. 2024-08-24 09:22:17.359 | HD Request # 92 | Setting DTC encoding to Binary VLS 2024-08-24 09:22:17.360 | HD Request # 92 | Sending historical data logon request message. 2024-08-24 09:22:17.513 | HD Request # 92 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDAX202409_FUT_EUREX 2024-08-24 09:22:17.537 | HD Request # 92 | Decompressing data. 2024-08-24 09:22:17.561 | HD Request # 92 | Receiving Intraday data for F.US.DDU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:22:17.561 | Socket (4) | CloseSocket call. 2024-08-24 09:22:17.561 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 09:22:17.561 | Historical data download thread signaled to stop. 2024-08-24 09:22:17.561 | HD Request # 92 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.3 hours) and wrote 0 records for F.US.DDU24 2024-08-24 09:22:17.562 | HD Request # 92 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:22:17.562 | HD Request # 92 | Completion time: 0s. 2024-08-24 09:22:17.562 | HD Request # 92 | Intraday data download complete for F.US.DDU24. Unique request ID: 49 2024-08-24 09:22:17.562 | Removing historical data download ID 49. 2024-08-24 09:22:17.562 | Real-time Intraday chart data file updates started for F.US.DDU24 2024-08-24 09:22:17.562 | Intraday chart data file opened for F.US.DDU24 2024-08-24 09:22:17.562 | HD Request # 92 | Enabling Intraday chart updating for symbol. 2024-08-24 09:22:17.562 | 2024-08-24 09:22:17.562 | Triggering next historical data download in queue. 2024-08-24 09:22:17.563 | HD Request # 93 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:22:17.564 | HD Request # 93 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:22:17.564 | HD Request # 93 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:22:17.564 | Socket (3) | Creating socket. 2024-08-24 09:22:17.564 | Socket (3) | New receive buffer size: 0 2024-08-24 09:22:17.564 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:22:17.586 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 09:22:17.586 | Socket (4) | Closed. 2024-08-24 09:22:17.617 | HD Request # 93 | Setting DTC encoding to Binary VLS 2024-08-24 09:22:17.617 | HD Request # 93 | Sending historical data logon request message. 2024-08-24 09:22:17.630 | Socket (3) | CloseSocket call. 2024-08-24 09:22:17.630 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:22:17.640 | HD Request # 93 | Error downloading historical Intraday data for F.US.FDXSU24. Historical data logon error: Serving data is disabled 2024-08-24 09:22:17.640 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:22:17.640 | Triggering next historical data download in queue. 2024-08-24 09:22:17.640 | Historical data download thread signaled to stop. 2024-08-24 09:22:17.640 | HD Request # 93 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSU24 2024-08-24 09:22:17.640 | HD Request # 93 | Completion time: 0s. 2024-08-24 09:22:17.640 | 2024-08-24 09:22:17.640 | HD Request # 94 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:22:17.641 | HD Request # 94 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:22:17.641 | HD Request # 94 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:22:17.641 | Socket (4) | Creating socket. 2024-08-24 09:22:17.641 | Socket (4) | New receive buffer size: 0 2024-08-24 09:22:17.641 | Socket (4) | Connecting to IP: 176.9.9.252. 2024-08-24 09:22:17.644 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:22:17.644 | Socket (3) | Closed. 2024-08-24 09:22:17.697 | HD Request # 94 | Setting DTC encoding to Binary VLS 2024-08-24 09:22:17.697 | HD Request # 94 | Sending historical data logon request message. 2024-08-24 09:22:17.724 | HD Request # 94 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDXS202409_FUT_EUREX 2024-08-24 09:22:17.750 | HD Request # 94 | Decompressing data. 2024-08-24 09:22:17.775 | HD Request # 94 | Receiving Intraday data for F.US.FDXSU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:22:17.775 | Socket (4) | CloseSocket call. 2024-08-24 09:22:17.775 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 09:22:17.775 | Historical data download thread signaled to stop. 2024-08-24 09:22:17.775 | HD Request # 94 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.3 hours) and wrote 0 records for F.US.FDXSU24 2024-08-24 09:22:17.776 | HD Request # 94 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:22:17.776 | HD Request # 94 | Completion time: 0s. 2024-08-24 09:22:17.776 | HD Request # 94 | Intraday data download complete for F.US.FDXSU24. Unique request ID: 50 2024-08-24 09:22:17.776 | Removing historical data download ID 50. 2024-08-24 09:22:17.776 | Real-time Intraday chart data file updates started for F.US.FDXSU24 2024-08-24 09:22:17.776 | Intraday chart data file opened for F.US.FDXSU24 2024-08-24 09:22:17.776 | HD Request # 94 | Enabling Intraday chart updating for symbol. 2024-08-24 09:22:17.776 | 2024-08-24 09:22:17.776 | No download requests in the queue to start downloads for. 2024-08-24 09:22:17.802 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 09:22:17.802 | Socket (4) | Closed. 2024-08-24 09:22:18.229 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:18.229 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:18.229 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:18.259 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:24.826 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:27.800 | Chart #12 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:27.946 | Chart #2 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:27.946 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:27.946 | Chart #2 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:27.946 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:28.000 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:33.513 | Chart #25 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:33.548 | F.US.FDXSU24 [CBV][M] 100 Volume #14 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:33.770 | F.US.FDXSU24 [CBV][M] 1 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:24:39.975 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:24:39.975 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:24:39.975 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:24:39.989 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:24:46.714 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:24:49.711 | Circular chart reference detected. Charts: 25, 12. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-24 09:24:49.716 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:24:55.114 | Circular chart reference detected. Charts: 12, 25. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-24 09:24:55.131 | CQG WebSocket | Timeout waiting for pong message from server. 2024-08-24 09:24:55.131 | CQG WebAPI | WebSocket closed. 2024-08-24 09:24:55.131 | Connection to the external service has been lost. 2024-08-24 09:24:55.470 | CQG WebAPI | Sending Web API Logoff message. 2024-08-24 09:24:55.470 | CQG WebSocket socket (1) | CloseSocket call. 2024-08-24 09:24:55.470 | CQG WebSocket socket (1) | Max send buffers used during socket life: 3 2024-08-24 09:24:55.470 | CQG WebSocket socket (1) | Max send buffer size during socket life: 309 2024-08-24 09:24:55.470 | CQG WebSocket | WebSocket closed. 2024-08-24 09:24:55.470 | CQG WebAPI | WebSocket closed. 2024-08-24 09:24:55.470 | CQG WebAPI | Disconnected. 2024-08-24 09:24:55.470 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-08-24 09:24:55.470 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2024-08-24 09:24:55.479 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2024-08-24 09:24:55.479 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 09:24:55.489 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2024-08-24 09:24:55.489 | CQG WebSocket socket (1) | Closed. 2024-08-24 09:24:57.482 | 2024-08-24 09:24:57.482 | CQG WebAPI | Connecting to server api.cqg.com 2024-08-24 09:24:57.482 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-08-24 09:24:57.584 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2024-08-24 09:24:57.585 | CQG WebSocket socket (1) | New receive buffer size: 0 2024-08-24 09:24:57.585 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2024-08-24 09:24:57.612 | CQG WebSocket | Opening WebSocket. 2024-08-24 09:24:57.612 | CQG WebSocket | Sending WebSocket handshake. 2024-08-24 09:24:57.643 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2024-08-24 09:24:57.643 | CQG WebSocket | Server header | Connection: Upgrade 2024-08-24 09:24:57.643 | CQG WebSocket | Server header | Sec-WebSocket-Accept: G6zAexBMbQpUiRZ4sZHYpUa9kKM= 2024-08-24 09:24:57.643 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2024-08-24 09:24:57.643 | CQG WebSocket | Server header | Upgrade: websocket 2024-08-24 09:24:57.643 | CQG WebSocket | Server header | 2024-08-24 09:24:57.643 | CQG WebSocket | Web socket state is now open. 2024-08-24 09:24:57.643 | CQG WebAPI | WebSocket connected. 2024-08-24 09:24:57.643 | CQG WebAPI | Sending market data logon message. 2024-08-24 09:24:57.885 | CQG WebAPI | Base Time: 2024-08-04T06:16:49. 2024-08-04 06:16:49 2024-08-24 09:24:57.885 | CQG WebAPI | Logon successful. Session Token = Zi5dLN5fOGzVjCTvrDWCxaKD+QwC+QWeDexpkjBmWv4xK93656L9aVfGOZnlkEhXZ0b9Lv+AkAl 2024-08-24 09:24:57.885 | CQG WebAPI | Connected to server complete. 2024-08-24 09:24:57.885 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:24:57.885 | DTC Client socket (2) | CloseSocket call. 2024-08-24 09:24:57.885 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:24:57.885 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 09:24:57.885 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-24 09:24:57.885 | Updated verified funded futures trading account ending date to: 2024-09-23 07:24:57 2024-08-24 09:24:57.916 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:24:57.916 | DTC Client socket (2) | Closed. 2024-08-24 09:24:58.158 | CQG WebAPI | Sending Trade Accounts request message. 2024-08-24 09:24:58.159 | CQG WebAPI | Sending positions subscribe request. RequestID: 982701 2024-08-24 09:24:58.159 | CQG WebAPI | Sending orders subscribe request. RequestID: 982702 2024-08-24 09:24:58.168 | CQG WebAPI | Brokerage name: WH Selfinvest France. Account Name: LWHF0931 2024-08-24 09:24:58.168 | Updated verified funded futures trading account ending date to: 2024-09-23 07:24:58 2024-08-24 09:24:58.168 | CQG WebAPI | Sending collateral subscribe request. 2024-08-24 09:24:58.306 | Mapping F.US.DDU24 to FDAX202409_FUT_EUREX. Service code: eurex 2024-08-24 09:24:58.306 | Using symbol data fast lookup vector 2024-08-24 09:24:58.306 | Denali Data Feed | Starting real-time market data updates for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 1 Service code: eurex 2024-08-24 09:24:58.306 | Denali Data Feed | Connecting to the server ds24.sierracharts.com. Port 10048 2024-08-24 09:24:58.306 | CQG WebAPI | Sending symbol resolution request for F.US.DDU24. ID: 982704 2024-08-24 09:24:58.306 | Denali Data Feed | Requesting security definition data for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 1 2024-08-24 09:24:58.306 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:24:58.306 | Intraday data recording state for symbol F.US.DDU24 is set to download 'Pending'. 2024-08-24 09:24:58.306 | Triggering next historical data download in queue. 2024-08-24 09:24:58.307 | DTC Client socket (2) | Creating socket. 2024-08-24 09:24:58.307 | DTC Client socket (2) | New receive buffer size: 0 2024-08-24 09:24:58.307 | DTC Client socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 09:24:58.342 | Delaying start of download for F.US.DDU24. 2024-08-24 09:24:58.342 | CQG WebAPI | Received symbol resolution report for symbol F.US.DDU24. Search Symbol: F.US.DDU24. Request ID: 982704. Contract ID: 1. 2024-08-24 09:24:58.342 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:24:58.342 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:24:58.342 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:24:58.343 | Mapping F.US.FDXSU24 to FDXS202409_FUT_EUREX. Service code: eurex 2024-08-24 09:24:58.343 | Denali Data Feed | Starting real-time market data updates for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 2 Service code: eurex 2024-08-24 09:24:58.343 | CQG WebAPI | Sending symbol resolution request for F.US.FDXSU24. ID: 982705 2024-08-24 09:24:58.343 | Denali Data Feed | Requesting security definition data for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 2 2024-08-24 09:24:58.343 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:24:58.343 | Intraday data recording state for symbol F.US.FDXSU24 is set to download 'Pending'. 2024-08-24 09:24:58.343 | Triggering next historical data download in queue. 2024-08-24 09:24:58.383 | CQG WebAPI | Received symbol resolution report for symbol F.US.FDXSU24. Search Symbol: F.US.FDXSU24. Request ID: 982705. Contract ID: 2. 2024-08-24 09:24:58.383 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:24:58.383 | Denali Data Feed | Sending logon request message. 2024-08-24 09:24:58.426 | Denali Data Feed | Received logon response. 2024-08-24 09:24:58.426 | Denali Data Feed | Server Name: RealTimeServer. 2024-08-24 09:24:58.426 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:24:58.426 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. 2024-08-24 09:24:58.426 | Denali Data Feed | Failed connections: 1 2024-08-24 09:24:58.426 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:24:58.426 | DTC Client socket (2) | CloseSocket call. 2024-08-24 09:24:58.426 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:24:58.426 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-08-24 09:24:58.426 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 09:24:58.440 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:24:58.440 | DTC Client socket (2) | Closed. 2024-08-24 09:25:01.437 | Denali Data Feed | Connecting to the server ds14.sierracharts.com. Port 10048 2024-08-24 09:25:01.438 | DTC Client socket (2) | Creating socket. 2024-08-24 09:25:01.438 | DTC Client socket (2) | New receive buffer size: 0 2024-08-24 09:25:01.438 | DTC Client socket (2) | Connecting to IP: 176.9.9.252. 2024-08-24 09:25:01.462 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:25:01.462 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:25:01.463 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:25:01.505 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:25:01.505 | Denali Data Feed | Sending logon request message. 2024-08-24 09:25:01.898 | Denali Data Feed | Received logon response. 2024-08-24 09:25:01.898 | Denali Data Feed | Server Name: SC Realtime Server. 2024-08-24 09:25:01.898 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:25:01.898 | Denali Data Feed | Successfully connected. 2024-08-24 09:25:01.898 | Denali Data Feed | Trading is not supported. 2024-08-24 09:25:01.898 | Denali Data Feed | MarketDepthIsSupported: 1 2024-08-24 09:25:01.898 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.DDU24 -> FDAX202409_FUT_EUREX 2024-08-24 09:25:01.898 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.FDXSU24 -> FDXS202409_FUT_EUREX 2024-08-24 09:25:02.005 | Denali Data Feed | Real-time data for symbol F.US.DDU24 is currently unavailable. 2024-08-24 09:25:02.005 | Denali Data Feed | Setting external service identifier for symbol F.US.DDU24 to 7296071 2024-08-24 09:25:02.005 | Denali Data Feed | Received security definition for symbol F.US.DDU24 2024-08-24 09:25:02.005 | Denali Data Feed | Real-time data for symbol F.US.FDXSU24 is currently unavailable. 2024-08-24 09:25:02.005 | Denali Data Feed | Setting external service identifier for symbol F.US.FDXSU24 to 10451688 2024-08-24 09:25:02.005 | Denali Data Feed | Received security definition for symbol F.US.FDXSU24 2024-08-24 09:25:07.065 | HD Request # 95 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:25:07.065 | HD Request # 95 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:25:07.065 | HD Request # 95 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:25:07.066 | Socket (3) | Creating socket. 2024-08-24 09:25:07.066 | Socket (3) | New receive buffer size: 0 2024-08-24 09:25:07.066 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:25:07.095 | HD Request # 95 | Setting DTC encoding to Binary VLS 2024-08-24 09:25:07.095 | HD Request # 95 | Sending historical data logon request message. 2024-08-24 09:25:07.109 | Socket (3) | CloseSocket call. 2024-08-24 09:25:07.109 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:25:07.109 | HD Request # 95 | Error downloading historical Intraday data for F.US.DDU24. Historical data logon error: Serving data is disabled 2024-08-24 09:25:07.109 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:25:07.109 | Triggering next historical data download in queue. 2024-08-24 09:25:07.109 | Historical data download thread signaled to stop. 2024-08-24 09:25:07.109 | HD Request # 95 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DDU24 2024-08-24 09:25:07.109 | HD Request # 95 | Completion time: 0s. 2024-08-24 09:25:07.109 | 2024-08-24 09:25:07.109 | HD Request # 96 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:25:07.110 | HD Request # 96 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:25:07.110 | HD Request # 96 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:25:07.110 | Socket (4) | Creating socket. 2024-08-24 09:25:07.110 | Socket (4) | New receive buffer size: 0 2024-08-24 09:25:07.110 | Socket (4) | Connecting to IP: 176.9.9.252. 2024-08-24 09:25:07.123 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:25:07.123 | Socket (3) | Closed. 2024-08-24 09:25:07.166 | HD Request # 96 | Setting DTC encoding to Binary VLS 2024-08-24 09:25:07.166 | HD Request # 96 | Sending historical data logon request message. 2024-08-24 09:25:07.316 | HD Request # 96 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDAX202409_FUT_EUREX 2024-08-24 09:25:07.341 | HD Request # 96 | Decompressing data. 2024-08-24 09:25:07.366 | HD Request # 96 | Receiving Intraday data for F.US.DDU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:25:07.366 | Socket (4) | CloseSocket call. 2024-08-24 09:25:07.366 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 09:25:07.366 | Historical data download thread signaled to stop. 2024-08-24 09:25:07.366 | HD Request # 96 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.4 hours) and wrote 0 records for F.US.DDU24 2024-08-24 09:25:07.366 | HD Request # 96 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:25:07.366 | HD Request # 96 | Completion time: 0s. 2024-08-24 09:25:07.366 | HD Request # 96 | Intraday data download complete for F.US.DDU24. Unique request ID: 51 2024-08-24 09:25:07.366 | Removing historical data download ID 51. 2024-08-24 09:25:07.366 | Real-time Intraday chart data file updates started for F.US.DDU24 2024-08-24 09:25:07.366 | Intraday chart data file opened for F.US.DDU24 2024-08-24 09:25:07.366 | HD Request # 96 | Enabling Intraday chart updating for symbol. 2024-08-24 09:25:07.366 | 2024-08-24 09:25:07.366 | Triggering next historical data download in queue. 2024-08-24 09:25:07.366 | HD Request # 97 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:25:07.366 | HD Request # 97 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:25:07.366 | HD Request # 97 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:25:07.366 | Socket (3) | Creating socket. 2024-08-24 09:25:07.366 | Socket (3) | New receive buffer size: 0 2024-08-24 09:25:07.366 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:25:07.392 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 09:25:07.392 | Socket (4) | Closed. 2024-08-24 09:25:07.396 | HD Request # 97 | Setting DTC encoding to Binary VLS 2024-08-24 09:25:07.396 | HD Request # 97 | Sending historical data logon request message. 2024-08-24 09:25:07.409 | Socket (3) | CloseSocket call. 2024-08-24 09:25:07.409 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:25:07.418 | HD Request # 97 | Error downloading historical Intraday data for F.US.FDXSU24. Historical data logon error: Serving data is disabled 2024-08-24 09:25:07.418 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:25:07.418 | Triggering next historical data download in queue. 2024-08-24 09:25:07.418 | Historical data download thread signaled to stop. 2024-08-24 09:25:07.418 | HD Request # 97 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSU24 2024-08-24 09:25:07.418 | HD Request # 97 | Completion time: 0s. 2024-08-24 09:25:07.418 | 2024-08-24 09:25:07.418 | HD Request # 98 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:25:07.419 | HD Request # 98 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:25:07.419 | HD Request # 98 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:25:07.419 | Socket (4) | Creating socket. 2024-08-24 09:25:07.419 | Socket (4) | New receive buffer size: 0 2024-08-24 09:25:07.419 | Socket (4) | Connecting to IP: 176.9.9.252. 2024-08-24 09:25:07.423 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:25:07.424 | Socket (3) | Closed. 2024-08-24 09:25:07.474 | HD Request # 98 | Setting DTC encoding to Binary VLS 2024-08-24 09:25:07.474 | HD Request # 98 | Sending historical data logon request message. 2024-08-24 09:25:07.499 | HD Request # 98 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDXS202409_FUT_EUREX 2024-08-24 09:25:07.525 | HD Request # 98 | Decompressing data. 2024-08-24 09:25:07.549 | HD Request # 98 | Receiving Intraday data for F.US.FDXSU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:25:07.549 | Socket (4) | CloseSocket call. 2024-08-24 09:25:07.549 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 09:25:07.549 | Historical data download thread signaled to stop. 2024-08-24 09:25:07.549 | HD Request # 98 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.4 hours) and wrote 0 records for F.US.FDXSU24 2024-08-24 09:25:07.549 | HD Request # 98 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:25:07.549 | HD Request # 98 | Completion time: 0s. 2024-08-24 09:25:07.549 | HD Request # 98 | Intraday data download complete for F.US.FDXSU24. Unique request ID: 52 2024-08-24 09:25:07.549 | Removing historical data download ID 52. 2024-08-24 09:25:07.549 | Real-time Intraday chart data file updates started for F.US.FDXSU24 2024-08-24 09:25:07.549 | Intraday chart data file opened for F.US.FDXSU24 2024-08-24 09:25:07.549 | HD Request # 98 | Enabling Intraday chart updating for symbol. 2024-08-24 09:25:07.549 | 2024-08-24 09:25:07.549 | No download requests in the queue to start downloads for. 2024-08-24 09:25:07.575 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 09:25:07.575 | Socket (4) | Closed. 2024-08-24 09:25:07.906 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:25:07.906 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:25:07.906 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:25:07.924 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:25:14.651 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:25:17.615 | Chart #12 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:25:17.754 | Chart #2 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:25:17.754 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:25:17.754 | Chart #2 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:25:17.754 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:25:17.804 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:25:23.247 | Chart #25 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:25:23.281 | F.US.FDXSU24 [CBV][M] 100 Volume #14 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:25:23.499 | F.US.FDXSU24 [CBV][M] 1 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:27:28.959 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:27:28.959 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:27:28.959 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:27:28.976 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:27:35.727 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:27:38.660 | CQG WebSocket | Timeout waiting for pong message from server. 2024-08-24 09:27:38.660 | CQG WebAPI | WebSocket closed. 2024-08-24 09:27:38.660 | Connection to the external service has been lost. 2024-08-24 09:27:38.928 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:27:44.451 | CQG WebAPI | Sending Web API Logoff message. 2024-08-24 09:27:44.451 | CQG WebSocket socket (1) | CloseSocket call. 2024-08-24 09:27:44.451 | CQG WebSocket | WebSocket closed. 2024-08-24 09:27:44.451 | CQG WebAPI | WebSocket closed. 2024-08-24 09:27:44.451 | CQG WebAPI | Disconnected. 2024-08-24 09:27:44.451 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-08-24 09:27:44.451 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2024-08-24 09:27:44.461 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2024-08-24 09:27:44.461 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 09:27:44.471 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2024-08-24 09:27:44.471 | CQG WebSocket socket (1) | Closed. 2024-08-24 09:27:46.453 | 2024-08-24 09:27:46.453 | CQG WebAPI | Connecting to server api.cqg.com 2024-08-24 09:27:46.453 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-08-24 09:27:46.454 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2024-08-24 09:27:46.454 | CQG WebSocket socket (1) | New receive buffer size: 0 2024-08-24 09:27:46.454 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2024-08-24 09:27:46.464 | CQG WebSocket | Opening WebSocket. 2024-08-24 09:27:46.464 | CQG WebSocket | Sending WebSocket handshake. 2024-08-24 09:27:46.495 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2024-08-24 09:27:46.495 | CQG WebSocket | Server header | Connection: Upgrade 2024-08-24 09:27:46.495 | CQG WebSocket | Server header | Sec-WebSocket-Accept: cv8LnOKKTx3xWxaDsnz0PFXlE18= 2024-08-24 09:27:46.495 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2024-08-24 09:27:46.495 | CQG WebSocket | Server header | Upgrade: websocket 2024-08-24 09:27:46.495 | CQG WebSocket | Server header | 2024-08-24 09:27:46.495 | CQG WebSocket | Web socket state is now open. 2024-08-24 09:27:46.495 | CQG WebAPI | WebSocket connected. 2024-08-24 09:27:46.495 | CQG WebAPI | Sending market data logon message. 2024-08-24 09:27:46.717 | CQG WebAPI | Base Time: 2024-08-04T06:16:49. 2024-08-04 06:16:49 2024-08-24 09:27:46.717 | CQG WebAPI | Logon successful. Session Token = 9BcucvUNy3tlU4bu0dva1W1/AdVj+YduzIlz+0+flhoVTdRfV3GjfkDC1GwoOJjYyqAXoIlsLqe 2024-08-24 09:27:46.717 | CQG WebAPI | Connected to server complete. 2024-08-24 09:27:46.717 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:27:46.718 | DTC Client socket (2) | CloseSocket call. 2024-08-24 09:27:46.718 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:27:46.718 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 09:27:46.718 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-24 09:27:46.718 | Updated verified funded futures trading account ending date to: 2024-09-23 07:27:46 2024-08-24 09:27:46.742 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:27:46.742 | DTC Client socket (2) | Closed. 2024-08-24 09:27:46.987 | CQG WebAPI | Sending Trade Accounts request message. 2024-08-24 09:27:46.987 | CQG WebAPI | Sending positions subscribe request. RequestID: 982707 2024-08-24 09:27:46.987 | CQG WebAPI | Sending orders subscribe request. RequestID: 982708 2024-08-24 09:27:46.997 | CQG WebAPI | Brokerage name: WH Selfinvest France. Account Name: LWHF0931 2024-08-24 09:27:46.997 | Updated verified funded futures trading account ending date to: 2024-09-23 07:27:46 2024-08-24 09:27:46.997 | CQG WebAPI | Sending collateral subscribe request. 2024-08-24 09:27:47.142 | Mapping F.US.DDU24 to FDAX202409_FUT_EUREX. Service code: eurex 2024-08-24 09:27:47.142 | Using symbol data fast lookup vector 2024-08-24 09:27:47.142 | Denali Data Feed | Starting real-time market data updates for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 1 Service code: eurex 2024-08-24 09:27:47.142 | Denali Data Feed | Connecting to the server ds24.sierracharts.com. Port 443 2024-08-24 09:27:47.142 | CQG WebAPI | Sending symbol resolution request for F.US.DDU24. ID: 982710 2024-08-24 09:27:47.142 | Denali Data Feed | Requesting security definition data for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 1 2024-08-24 09:27:47.142 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:27:47.142 | Intraday data recording state for symbol F.US.DDU24 is set to download 'Pending'. 2024-08-24 09:27:47.142 | Triggering next historical data download in queue. 2024-08-24 09:27:47.143 | DTC Client socket (2) | Creating socket. 2024-08-24 09:27:47.143 | DTC Client socket (2) | New receive buffer size: 0 2024-08-24 09:27:47.143 | DTC Client socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 09:27:47.189 | Delaying start of download for F.US.DDU24. 2024-08-24 09:27:47.189 | CQG WebAPI | Received symbol resolution report for symbol F.US.DDU24. Search Symbol: F.US.DDU24. Request ID: 982710. Contract ID: 1. 2024-08-24 09:27:47.189 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:27:47.189 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:27:47.189 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:27:47.189 | Mapping F.US.FDXSU24 to FDXS202409_FUT_EUREX. Service code: eurex 2024-08-24 09:27:47.189 | Denali Data Feed | Starting real-time market data updates for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 2 Service code: eurex 2024-08-24 09:27:47.189 | CQG WebAPI | Sending symbol resolution request for F.US.FDXSU24. ID: 982711 2024-08-24 09:27:47.189 | Denali Data Feed | Requesting security definition data for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 2 2024-08-24 09:27:47.189 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:27:47.189 | Intraday data recording state for symbol F.US.FDXSU24 is set to download 'Pending'. 2024-08-24 09:27:47.189 | Triggering next historical data download in queue. 2024-08-24 09:27:47.224 | CQG WebAPI | Received symbol resolution report for symbol F.US.FDXSU24. Search Symbol: F.US.FDXSU24. Request ID: 982711. Contract ID: 2. 2024-08-24 09:27:47.251 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:27:47.251 | Denali Data Feed | Sending logon request message. 2024-08-24 09:27:47.289 | Denali Data Feed | Received logon response. 2024-08-24 09:27:47.289 | Denali Data Feed | Server Name: RealTimeServer. 2024-08-24 09:27:47.289 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:27:47.289 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. 2024-08-24 09:27:47.289 | Denali Data Feed | Failed connections: 1 2024-08-24 09:27:47.289 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:27:47.289 | DTC Client socket (2) | CloseSocket call. 2024-08-24 09:27:47.289 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:27:47.289 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-08-24 09:27:47.289 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 09:27:47.303 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:27:47.303 | DTC Client socket (2) | Closed. 2024-08-24 09:27:50.314 | Denali Data Feed | Connecting to the server ds14.sierracharts.com. Port 443 2024-08-24 09:27:50.315 | DTC Client socket (2) | Creating socket. 2024-08-24 09:27:50.315 | DTC Client socket (2) | New receive buffer size: 0 2024-08-24 09:27:50.315 | DTC Client socket (2) | Connecting to IP: 176.9.9.252. 2024-08-24 09:27:50.340 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:27:50.340 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:27:50.340 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:27:50.386 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:27:50.386 | Denali Data Feed | Sending logon request message. 2024-08-24 09:27:50.729 | Denali Data Feed | Received logon response. 2024-08-24 09:27:50.729 | Denali Data Feed | Server Name: SC Realtime Server. 2024-08-24 09:27:50.729 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:27:50.729 | Denali Data Feed | Successfully connected. 2024-08-24 09:27:50.729 | Denali Data Feed | Trading is not supported. 2024-08-24 09:27:50.729 | Denali Data Feed | MarketDepthIsSupported: 1 2024-08-24 09:27:50.729 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.DDU24 -> FDAX202409_FUT_EUREX 2024-08-24 09:27:50.729 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.FDXSU24 -> FDXS202409_FUT_EUREX 2024-08-24 09:27:50.854 | Denali Data Feed | Real-time data for symbol F.US.DDU24 is currently unavailable. 2024-08-24 09:27:50.854 | Denali Data Feed | Setting external service identifier for symbol F.US.DDU24 to 7296071 2024-08-24 09:27:50.854 | Denali Data Feed | Received security definition for symbol F.US.DDU24 2024-08-24 09:27:50.854 | Denali Data Feed | Real-time data for symbol F.US.FDXSU24 is currently unavailable. 2024-08-24 09:27:50.854 | Denali Data Feed | Setting external service identifier for symbol F.US.FDXSU24 to 10451688 2024-08-24 09:27:50.854 | Denali Data Feed | Received security definition for symbol F.US.FDXSU24 2024-08-24 09:27:55.462 | HD Request # 99 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:27:55.463 | HD Request # 99 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:27:55.463 | HD Request # 99 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:27:55.463 | Socket (3) | Creating socket. 2024-08-24 09:27:55.463 | Socket (3) | New receive buffer size: 0 2024-08-24 09:27:55.463 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:27:55.494 | HD Request # 99 | Setting DTC encoding to Binary VLS 2024-08-24 09:27:55.494 | HD Request # 99 | Sending historical data logon request message. 2024-08-24 09:27:55.507 | Socket (3) | CloseSocket call. 2024-08-24 09:27:55.507 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:27:55.507 | HD Request # 99 | Error downloading historical Intraday data for F.US.DDU24. Historical data logon error: Serving data is disabled 2024-08-24 09:27:55.507 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:27:55.507 | Triggering next historical data download in queue. 2024-08-24 09:27:55.508 | Historical data download thread signaled to stop. 2024-08-24 09:27:55.508 | HD Request # 99 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DDU24 2024-08-24 09:27:55.508 | HD Request # 99 | Completion time: 0s. 2024-08-24 09:27:55.508 | 2024-08-24 09:27:55.508 | HD Request # 100 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:27:55.508 | HD Request # 100 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:27:55.509 | HD Request # 100 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:27:55.509 | Socket (4) | Creating socket. 2024-08-24 09:27:55.509 | Socket (4) | New receive buffer size: 0 2024-08-24 09:27:55.509 | Socket (4) | Connecting to IP: 176.9.9.252. 2024-08-24 09:27:55.522 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:27:55.522 | Socket (3) | Closed. 2024-08-24 09:27:55.564 | HD Request # 100 | Setting DTC encoding to Binary VLS 2024-08-24 09:27:55.564 | HD Request # 100 | Sending historical data logon request message. 2024-08-24 09:27:55.718 | HD Request # 100 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDAX202409_FUT_EUREX 2024-08-24 09:27:55.742 | HD Request # 100 | Decompressing data. 2024-08-24 09:27:55.765 | HD Request # 100 | Receiving Intraday data for F.US.DDU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:27:55.765 | Socket (4) | CloseSocket call. 2024-08-24 09:27:55.766 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 09:27:55.766 | Historical data download thread signaled to stop. 2024-08-24 09:27:55.766 | HD Request # 100 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.4 hours) and wrote 0 records for F.US.DDU24 2024-08-24 09:27:55.767 | HD Request # 100 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:27:55.767 | HD Request # 100 | Completion time: 0s. 2024-08-24 09:27:55.767 | HD Request # 100 | Intraday data download complete for F.US.DDU24. Unique request ID: 53 2024-08-24 09:27:55.767 | Removing historical data download ID 53. 2024-08-24 09:27:55.767 | Real-time Intraday chart data file updates started for F.US.DDU24 2024-08-24 09:27:55.767 | Intraday chart data file opened for F.US.DDU24 2024-08-24 09:27:55.767 | HD Request # 100 | Enabling Intraday chart updating for symbol. 2024-08-24 09:27:55.767 | 2024-08-24 09:27:55.767 | Triggering next historical data download in queue. 2024-08-24 09:27:55.768 | HD Request # 101 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:27:55.769 | HD Request # 101 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:27:55.769 | HD Request # 101 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:27:55.769 | Socket (3) | Creating socket. 2024-08-24 09:27:55.769 | Socket (3) | New receive buffer size: 0 2024-08-24 09:27:55.769 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:27:55.791 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 09:27:55.791 | Socket (4) | Closed. 2024-08-24 09:27:55.798 | HD Request # 101 | Setting DTC encoding to Binary VLS 2024-08-24 09:27:55.798 | HD Request # 101 | Sending historical data logon request message. 2024-08-24 09:27:55.812 | Socket (3) | CloseSocket call. 2024-08-24 09:27:55.812 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:27:55.826 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:27:55.826 | Socket (3) | Closed. 2024-08-24 09:27:55.858 | HD Request # 101 | Error downloading historical Intraday data for F.US.FDXSU24. Historical data logon error: Serving data is disabled 2024-08-24 09:27:55.858 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:27:55.858 | Triggering next historical data download in queue. 2024-08-24 09:27:55.858 | Historical data download thread signaled to stop. 2024-08-24 09:27:55.858 | HD Request # 101 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSU24 2024-08-24 09:27:55.858 | HD Request # 101 | Completion time: 0s. 2024-08-24 09:27:55.858 | 2024-08-24 09:27:55.858 | HD Request # 102 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:27:55.858 | HD Request # 102 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:27:55.858 | HD Request # 102 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:27:55.859 | Socket (3) | Creating socket. 2024-08-24 09:27:55.859 | Socket (3) | New receive buffer size: 0 2024-08-24 09:27:55.859 | Socket (3) | Connecting to IP: 176.9.9.252. 2024-08-24 09:27:55.913 | HD Request # 102 | Setting DTC encoding to Binary VLS 2024-08-24 09:27:55.913 | HD Request # 102 | Sending historical data logon request message. 2024-08-24 09:27:55.939 | HD Request # 102 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDXS202409_FUT_EUREX 2024-08-24 09:27:55.964 | HD Request # 102 | Decompressing data. 2024-08-24 09:27:55.988 | HD Request # 102 | Receiving Intraday data for F.US.FDXSU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:27:55.988 | Socket (3) | CloseSocket call. 2024-08-24 09:27:55.988 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:27:55.988 | Historical data download thread signaled to stop. 2024-08-24 09:27:55.988 | HD Request # 102 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.4 hours) and wrote 0 records for F.US.FDXSU24 2024-08-24 09:27:55.989 | HD Request # 102 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:27:55.989 | HD Request # 102 | Completion time: 0s. 2024-08-24 09:27:55.989 | HD Request # 102 | Intraday data download complete for F.US.FDXSU24. Unique request ID: 54 2024-08-24 09:27:55.989 | Removing historical data download ID 54. 2024-08-24 09:27:55.989 | Real-time Intraday chart data file updates started for F.US.FDXSU24 2024-08-24 09:27:55.989 | Intraday chart data file opened for F.US.FDXSU24 2024-08-24 09:27:55.989 | HD Request # 102 | Enabling Intraday chart updating for symbol. 2024-08-24 09:27:55.989 | 2024-08-24 09:27:55.989 | No download requests in the queue to start downloads for. 2024-08-24 09:27:56.016 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:27:56.016 | Socket (3) | Closed. 2024-08-24 09:27:56.418 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:27:56.418 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:27:56.418 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:27:56.450 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:28:03.025 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:28:05.936 | Chart #12 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:28:06.074 | Chart #2 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:28:06.074 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:28:06.074 | Chart #2 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:28:06.074 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:28:06.125 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:28:11.489 | Chart #25 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:28:11.525 | F.US.FDXSU24 [CBV][M] 100 Volume #14 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:28:11.745 | F.US.FDXSU24 [CBV][M] 1 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:30:20.814 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:30:20.814 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:30:20.814 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:30:20.876 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:30:27.831 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:30:30.769 | File >> Disconnect selected. 2024-08-24 09:30:31.063 | CQG WebAPI | Sending Web API Logoff message. 2024-08-24 09:30:31.063 | CQG WebSocket socket (1) | CloseSocket call. 2024-08-24 09:30:31.063 | CQG WebSocket socket (1) | Max send buffers used during socket life: 3 2024-08-24 09:30:31.063 | CQG WebSocket socket (1) | Max send buffer size during socket life: 309 2024-08-24 09:30:31.063 | CQG WebSocket | WebSocket closed. 2024-08-24 09:30:31.063 | CQG WebAPI | WebSocket closed. 2024-08-24 09:30:31.063 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:30:31.063 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2024-08-24 09:30:31.063 | DTC Client socket (2) | CloseSocket call. 2024-08-24 09:30:31.063 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 09:30:31.063 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:30:31.063 | CQG WebAPI | Disconnected. 2024-08-24 09:30:31.065 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:30:31.072 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2024-08-24 09:30:31.072 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 09:30:31.082 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2024-08-24 09:30:31.082 | CQG WebSocket socket (1) | Closed. 2024-08-24 09:30:31.088 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:30:31.088 | DTC Client socket (2) | Closed. 2024-08-24 09:33:36.129 | 2024-08-24 09:33:36.129 | CQG WebAPI | Connecting to server api.cqg.com 2024-08-24 09:33:36.129 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-08-24 09:33:36.231 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2024-08-24 09:33:36.231 | CQG WebSocket socket (1) | New receive buffer size: 0 2024-08-24 09:33:36.231 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2024-08-24 09:33:36.243 | CQG WebSocket | Opening WebSocket. 2024-08-24 09:33:36.243 | CQG WebSocket | Sending WebSocket handshake. 2024-08-24 09:33:36.277 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2024-08-24 09:33:36.277 | CQG WebSocket | Server header | Connection: Upgrade 2024-08-24 09:33:36.277 | CQG WebSocket | Server header | Sec-WebSocket-Accept: gWEwBvgv5QMw7lnrw/eZDjT6TiM= 2024-08-24 09:33:36.277 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2024-08-24 09:33:36.277 | CQG WebSocket | Server header | Upgrade: websocket 2024-08-24 09:33:36.277 | CQG WebSocket | Server header | 2024-08-24 09:33:36.277 | CQG WebSocket | Web socket state is now open. 2024-08-24 09:33:36.277 | CQG WebAPI | WebSocket connected. 2024-08-24 09:33:36.277 | CQG WebAPI | Sending market data logon message. 2024-08-24 09:33:36.496 | CQG WebAPI | Base Time: 2024-08-04T06:16:49. 2024-08-04 06:16:49 2024-08-24 09:33:36.496 | CQG WebAPI | Logon successful. Session Token = MGEc+73ffuyhaq3sRwzMbgPyf3QmNceUdSDsEezsmpQkoJV9QGvbSYGxPa8beuPW9pdThLtVf0K 2024-08-24 09:33:36.496 | CQG WebAPI | Connected to server complete. 2024-08-24 09:33:36.497 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-24 09:33:36.497 | Updated verified funded futures trading account ending date to: 2024-09-23 07:33:36 2024-08-24 09:33:36.820 | CQG WebAPI | Sending Trade Accounts request message. 2024-08-24 09:33:36.822 | Mapping F.US.FDXSU24 to FDXS202409_FUT_EUREX. Service code: eurex 2024-08-24 09:33:36.822 | Using symbol data fast lookup vector 2024-08-24 09:33:36.822 | Denali Data Feed | Starting real-time market data updates for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 1 Service code: eurex 2024-08-24 09:33:36.822 | Denali Data Feed | Connecting to the server ds24.sierracharts.com. Port 10048 2024-08-24 09:33:36.822 | CQG WebAPI | Sending symbol resolution request for F.US.FDXSU24. ID: 982713 2024-08-24 09:33:36.822 | Denali Data Feed | Requesting security definition data for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 1 2024-08-24 09:33:36.822 | DTC Client socket (2) | Creating socket. 2024-08-24 09:33:36.822 | DTC Client socket (2) | New receive buffer size: 0 2024-08-24 09:33:36.822 | DTC Client socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 09:33:36.826 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:33:36.826 | Intraday data recording state for symbol F.US.FDXSU24 is set to download 'Pending'. 2024-08-24 09:33:36.826 | Triggering next historical data download in queue. 2024-08-24 09:33:36.844 | Delaying start of download for F.US.FDXSU24. 2024-08-24 09:33:36.844 | CQG WebAPI | Received symbol resolution report for symbol F.US.FDXSU24. Search Symbol: F.US.FDXSU24. Request ID: 982713. Contract ID: 1. 2024-08-24 09:33:36.844 | CQG WebAPI | Brokerage name: WH Selfinvest France. Account Name: LWHF0931 2024-08-24 09:33:36.844 | Updated verified funded futures trading account ending date to: 2024-09-23 07:33:36 2024-08-24 09:33:36.844 | CQG WebAPI | Sending collateral subscribe request. 2024-08-24 09:33:36.844 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:33:36.844 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:33:36.844 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:33:37.059 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:33:37.059 | Denali Data Feed | Sending logon request message. 2024-08-24 09:33:37.092 | Mapping F.US.DDU24 to FDAX202409_FUT_EUREX. Service code: eurex 2024-08-24 09:33:37.092 | Denali Data Feed | Starting real-time market data updates for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 2 Service code: eurex 2024-08-24 09:33:37.092 | CQG WebAPI | Sending symbol resolution request for F.US.DDU24. ID: 982715 2024-08-24 09:33:37.092 | Denali Data Feed | Requesting security definition data for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 2 2024-08-24 09:33:37.092 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:33:37.092 | Intraday data recording state for symbol F.US.DDU24 is set to download 'Pending'. 2024-08-24 09:33:37.092 | Triggering next historical data download in queue. 2024-08-24 09:33:37.110 | Denali Data Feed | Received logon response. 2024-08-24 09:33:37.110 | Denali Data Feed | Server Name: RealTimeServer. 2024-08-24 09:33:37.110 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:33:37.110 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. 2024-08-24 09:33:37.110 | Denali Data Feed | Failed connections: 1 2024-08-24 09:33:37.110 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:33:37.110 | DTC Client socket (2) | CloseSocket call. 2024-08-24 09:33:37.110 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:33:37.110 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-08-24 09:33:37.110 | CQG WebAPI | Received symbol resolution report for symbol F.US.DDU24. Search Symbol: F.US.DDU24. Request ID: 982715. Contract ID: 2. 2024-08-24 09:33:37.110 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 09:33:37.124 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:33:37.125 | DTC Client socket (2) | Closed. 2024-08-24 09:33:37.175 | CQG WebAPI | Sending positions subscribe request. RequestID: 982716 2024-08-24 09:33:37.175 | CQG WebAPI | Sending orders subscribe request. RequestID: 982717 2024-08-24 09:33:40.105 | Denali Data Feed | Connecting to the server ds14.sierracharts.com. Port 10048 2024-08-24 09:33:40.106 | DTC Client socket (2) | Creating socket. 2024-08-24 09:33:40.106 | DTC Client socket (2) | New receive buffer size: 0 2024-08-24 09:33:40.106 | DTC Client socket (2) | Connecting to IP: 176.9.9.252. 2024-08-24 09:33:40.132 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:33:40.132 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:33:40.133 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:33:40.167 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:33:40.167 | Denali Data Feed | Sending logon request message. 2024-08-24 09:33:40.511 | Denali Data Feed | Received logon response. 2024-08-24 09:33:40.511 | Denali Data Feed | Server Name: SC Realtime Server. 2024-08-24 09:33:40.511 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:33:40.511 | Denali Data Feed | Successfully connected. 2024-08-24 09:33:40.511 | Denali Data Feed | Trading is not supported. 2024-08-24 09:33:40.511 | Denali Data Feed | MarketDepthIsSupported: 1 2024-08-24 09:33:40.511 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.DDU24 -> FDAX202409_FUT_EUREX 2024-08-24 09:33:40.511 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.FDXSU24 -> FDXS202409_FUT_EUREX 2024-08-24 09:33:40.636 | Denali Data Feed | Real-time data for symbol F.US.DDU24 is currently unavailable. 2024-08-24 09:33:40.636 | Denali Data Feed | Setting external service identifier for symbol F.US.DDU24 to 7296071 2024-08-24 09:33:40.636 | Denali Data Feed | Received security definition for symbol F.US.DDU24 2024-08-24 09:33:40.636 | Denali Data Feed | Real-time data for symbol F.US.FDXSU24 is currently unavailable. 2024-08-24 09:33:40.636 | Denali Data Feed | Setting external service identifier for symbol F.US.FDXSU24 to 10451688 2024-08-24 09:33:40.636 | Denali Data Feed | Received security definition for symbol F.US.FDXSU24 2024-08-24 09:33:45.437 | HD Request # 103 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:33:45.438 | HD Request # 103 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:33:45.438 | HD Request # 103 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:33:45.438 | Socket (3) | Creating socket. 2024-08-24 09:33:45.438 | Socket (3) | New receive buffer size: 0 2024-08-24 09:33:45.438 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:33:45.467 | HD Request # 103 | Setting DTC encoding to Binary VLS 2024-08-24 09:33:45.467 | HD Request # 103 | Sending historical data logon request message. 2024-08-24 09:33:45.481 | Socket (3) | CloseSocket call. 2024-08-24 09:33:45.481 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:33:45.481 | HD Request # 103 | Error downloading historical Intraday data for F.US.FDXSU24. Historical data logon error: Serving data is disabled 2024-08-24 09:33:45.481 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:33:45.481 | Triggering next historical data download in queue. 2024-08-24 09:33:45.481 | Historical data download thread signaled to stop. 2024-08-24 09:33:45.481 | HD Request # 103 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSU24 2024-08-24 09:33:45.481 | HD Request # 103 | Completion time: 0s. 2024-08-24 09:33:45.481 | 2024-08-24 09:33:45.481 | HD Request # 104 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:33:45.481 | HD Request # 104 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:33:45.481 | HD Request # 104 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:33:45.482 | Socket (4) | Creating socket. 2024-08-24 09:33:45.482 | Socket (4) | New receive buffer size: 0 2024-08-24 09:33:45.482 | Socket (4) | Connecting to IP: 176.9.9.252. 2024-08-24 09:33:45.495 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:33:45.495 | Socket (3) | Closed. 2024-08-24 09:33:45.537 | HD Request # 104 | Setting DTC encoding to Binary VLS 2024-08-24 09:33:45.537 | HD Request # 104 | Sending historical data logon request message. 2024-08-24 09:33:45.691 | HD Request # 104 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDXS202409_FUT_EUREX 2024-08-24 09:33:45.717 | HD Request # 104 | Decompressing data. 2024-08-24 09:33:45.741 | HD Request # 104 | Receiving Intraday data for F.US.FDXSU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:33:45.741 | Socket (4) | CloseSocket call. 2024-08-24 09:33:45.741 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 09:33:45.741 | Historical data download thread signaled to stop. 2024-08-24 09:33:45.741 | HD Request # 104 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.5 hours) and wrote 0 records for F.US.FDXSU24 2024-08-24 09:33:45.742 | HD Request # 104 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:33:45.743 | HD Request # 104 | Completion time: 0s. 2024-08-24 09:33:45.743 | HD Request # 104 | Intraday data download complete for F.US.FDXSU24. Unique request ID: 55 2024-08-24 09:33:45.743 | Removing historical data download ID 55. 2024-08-24 09:33:45.743 | Real-time Intraday chart data file updates started for F.US.FDXSU24 2024-08-24 09:33:45.743 | Intraday chart data file opened for F.US.FDXSU24 2024-08-24 09:33:45.743 | HD Request # 104 | Enabling Intraday chart updating for symbol. 2024-08-24 09:33:45.743 | 2024-08-24 09:33:45.743 | Triggering next historical data download in queue. 2024-08-24 09:33:45.743 | HD Request # 105 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:33:45.744 | HD Request # 105 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:33:45.744 | HD Request # 105 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:33:45.744 | Socket (3) | Creating socket. 2024-08-24 09:33:45.745 | Socket (3) | New receive buffer size: 0 2024-08-24 09:33:45.745 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:33:45.767 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 09:33:45.767 | Socket (4) | Closed. 2024-08-24 09:33:45.774 | HD Request # 105 | Setting DTC encoding to Binary VLS 2024-08-24 09:33:45.774 | HD Request # 105 | Sending historical data logon request message. 2024-08-24 09:33:45.787 | Socket (3) | CloseSocket call. 2024-08-24 09:33:45.787 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:33:45.801 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:33:45.801 | Socket (3) | Closed. 2024-08-24 09:33:45.826 | HD Request # 105 | Error downloading historical Intraday data for F.US.DDU24. Historical data logon error: Serving data is disabled 2024-08-24 09:33:45.826 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:33:45.826 | Triggering next historical data download in queue. 2024-08-24 09:33:45.826 | Historical data download thread signaled to stop. 2024-08-24 09:33:45.826 | HD Request # 105 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DDU24 2024-08-24 09:33:45.826 | HD Request # 105 | Completion time: 0s. 2024-08-24 09:33:45.826 | 2024-08-24 09:33:45.826 | HD Request # 106 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:33:45.826 | HD Request # 106 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:33:45.826 | HD Request # 106 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:33:45.826 | Socket (3) | Creating socket. 2024-08-24 09:33:45.826 | Socket (3) | New receive buffer size: 0 2024-08-24 09:33:45.826 | Socket (3) | Connecting to IP: 176.9.9.252. 2024-08-24 09:33:45.855 | Chart #12 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:33:45.882 | HD Request # 106 | Setting DTC encoding to Binary VLS 2024-08-24 09:33:45.882 | HD Request # 106 | Sending historical data logon request message. 2024-08-24 09:33:45.909 | HD Request # 106 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDAX202409_FUT_EUREX 2024-08-24 09:33:45.935 | HD Request # 106 | Decompressing data. 2024-08-24 09:33:45.959 | HD Request # 106 | Receiving Intraday data for F.US.DDU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:33:45.960 | Socket (3) | CloseSocket call. 2024-08-24 09:33:45.960 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:33:45.986 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:33:45.986 | Socket (3) | Closed. 2024-08-24 09:33:45.992 | Chart #2 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:33:45.992 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:33:45.992 | Chart #2 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:33:45.992 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:33:45.992 | Historical data download thread signaled to stop. 2024-08-24 09:33:45.992 | HD Request # 106 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.5 hours) and wrote 0 records for F.US.DDU24 2024-08-24 09:33:45.992 | HD Request # 106 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:33:45.992 | HD Request # 106 | Completion time: 0s. 2024-08-24 09:33:45.992 | HD Request # 106 | Intraday data download complete for F.US.DDU24. Unique request ID: 56 2024-08-24 09:33:45.992 | Removing historical data download ID 56. 2024-08-24 09:33:45.992 | Real-time Intraday chart data file updates started for F.US.DDU24 2024-08-24 09:33:45.992 | Intraday chart data file opened for F.US.DDU24 2024-08-24 09:33:45.992 | HD Request # 106 | Enabling Intraday chart updating for symbol. 2024-08-24 09:33:45.992 | 2024-08-24 09:33:45.992 | No download requests in the queue to start downloads for. 2024-08-24 09:33:46.043 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:33:51.383 | Chart #25 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:33:51.400 | F.US.FDXSU24 [CBV][M] 100 Volume #14 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:33:51.616 | F.US.FDXSU24 [CBV][M] 1 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:35:57.446 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:35:57.446 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:35:57.446 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:35:57.598 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:36:04.429 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:36:07.351 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:36:12.804 | CQG WebSocket | Timeout waiting for pong message from server. 2024-08-24 09:36:12.804 | CQG WebAPI | WebSocket closed. 2024-08-24 09:36:12.804 | Connection to the external service has been lost. 2024-08-24 09:36:13.123 | CQG WebAPI | Sending Web API Logoff message. 2024-08-24 09:36:13.123 | CQG WebSocket socket (1) | CloseSocket call. 2024-08-24 09:36:13.123 | CQG WebSocket | WebSocket closed. 2024-08-24 09:36:13.123 | CQG WebAPI | WebSocket closed. 2024-08-24 09:36:13.123 | CQG WebAPI | Disconnected. 2024-08-24 09:36:13.123 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-08-24 09:36:13.123 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2024-08-24 09:36:13.132 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2024-08-24 09:36:13.132 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 09:36:13.141 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2024-08-24 09:36:13.141 | CQG WebSocket socket (1) | Closed. 2024-08-24 09:36:15.143 | 2024-08-24 09:36:15.143 | CQG WebAPI | Connecting to server api.cqg.com 2024-08-24 09:36:15.143 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-08-24 09:36:15.144 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2024-08-24 09:36:15.145 | CQG WebSocket socket (1) | New receive buffer size: 0 2024-08-24 09:36:15.145 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2024-08-24 09:36:15.155 | CQG WebSocket | Opening WebSocket. 2024-08-24 09:36:15.155 | CQG WebSocket | Sending WebSocket handshake. 2024-08-24 09:36:15.205 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2024-08-24 09:36:15.205 | CQG WebSocket | Server header | Connection: Upgrade 2024-08-24 09:36:15.205 | CQG WebSocket | Server header | Sec-WebSocket-Accept: laGghwWgQlEof1IgVXEx6WVPv5I= 2024-08-24 09:36:15.205 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2024-08-24 09:36:15.205 | CQG WebSocket | Server header | Upgrade: websocket 2024-08-24 09:36:15.205 | CQG WebSocket | Server header | 2024-08-24 09:36:15.205 | CQG WebSocket | Web socket state is now open. 2024-08-24 09:36:15.205 | CQG WebAPI | WebSocket connected. 2024-08-24 09:36:15.205 | CQG WebAPI | Sending market data logon message. 2024-08-24 09:36:15.438 | CQG WebAPI | Base Time: 2024-08-04T06:16:49. 2024-08-04 06:16:49 2024-08-24 09:36:15.438 | CQG WebAPI | Logon successful. Session Token = IKJgohMr5PE3IJ3dleCJtg087pD1LysOaR6JN5yBCaoNVWavyICF1jvjYB8uHsSeozQCOER8rpp 2024-08-24 09:36:15.438 | CQG WebAPI | Connected to server complete. 2024-08-24 09:36:15.438 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:36:15.438 | DTC Client socket (2) | CloseSocket call. 2024-08-24 09:36:15.438 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:36:15.438 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 09:36:15.438 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-24 09:36:15.438 | Updated verified funded futures trading account ending date to: 2024-09-23 07:36:15 2024-08-24 09:36:15.464 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:36:15.464 | DTC Client socket (2) | Closed. 2024-08-24 09:36:15.746 | CQG WebAPI | Sending Trade Accounts request message. 2024-08-24 09:36:15.747 | CQG WebAPI | Sending positions subscribe request. RequestID: 982719 2024-08-24 09:36:15.747 | CQG WebAPI | Sending orders subscribe request. RequestID: 982720 2024-08-24 09:36:15.756 | CQG WebAPI | Brokerage name: WH Selfinvest France. Account Name: LWHF0931 2024-08-24 09:36:15.756 | Updated verified funded futures trading account ending date to: 2024-09-23 07:36:15 2024-08-24 09:36:15.756 | CQG WebAPI | Sending collateral subscribe request. 2024-08-24 09:36:15.815 | Mapping F.US.DDU24 to FDAX202409_FUT_EUREX. Service code: eurex 2024-08-24 09:36:15.815 | Using symbol data fast lookup vector 2024-08-24 09:36:15.815 | Denali Data Feed | Starting real-time market data updates for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 1 Service code: eurex 2024-08-24 09:36:15.815 | Denali Data Feed | Connecting to the server ds24.sierracharts.com. Port 10048 2024-08-24 09:36:15.815 | CQG WebAPI | Sending symbol resolution request for F.US.DDU24. ID: 982722 2024-08-24 09:36:15.816 | Denali Data Feed | Requesting security definition data for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 1 2024-08-24 09:36:15.816 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:36:15.816 | Intraday data recording state for symbol F.US.DDU24 is set to download 'Pending'. 2024-08-24 09:36:15.816 | Triggering next historical data download in queue. 2024-08-24 09:36:15.816 | DTC Client socket (2) | Creating socket. 2024-08-24 09:36:15.817 | DTC Client socket (2) | New receive buffer size: 0 2024-08-24 09:36:15.817 | DTC Client socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 09:36:15.862 | Delaying start of download for F.US.DDU24. 2024-08-24 09:36:15.862 | CQG WebAPI | Received symbol resolution report for symbol F.US.DDU24. Search Symbol: F.US.DDU24. Request ID: 982722. Contract ID: 1. 2024-08-24 09:36:15.862 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:36:15.862 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:36:15.862 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:36:15.862 | Mapping F.US.FDXSU24 to FDXS202409_FUT_EUREX. Service code: eurex 2024-08-24 09:36:15.862 | Denali Data Feed | Starting real-time market data updates for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 2 Service code: eurex 2024-08-24 09:36:15.862 | CQG WebAPI | Sending symbol resolution request for F.US.FDXSU24. ID: 982723 2024-08-24 09:36:15.862 | Denali Data Feed | Requesting security definition data for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 2 2024-08-24 09:36:15.862 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:36:15.862 | Intraday data recording state for symbol F.US.FDXSU24 is set to download 'Pending'. 2024-08-24 09:36:15.862 | Triggering next historical data download in queue. 2024-08-24 09:36:15.898 | CQG WebAPI | Received symbol resolution report for symbol F.US.FDXSU24. Search Symbol: F.US.FDXSU24. Request ID: 982723. Contract ID: 2. 2024-08-24 09:36:15.899 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:36:15.899 | Denali Data Feed | Sending logon request message. 2024-08-24 09:36:15.940 | Denali Data Feed | Received logon response. 2024-08-24 09:36:15.940 | Denali Data Feed | Server Name: RealTimeServer. 2024-08-24 09:36:15.940 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:36:15.940 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. 2024-08-24 09:36:15.940 | Denali Data Feed | Failed connections: 1 2024-08-24 09:36:15.940 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:36:15.940 | DTC Client socket (2) | CloseSocket call. 2024-08-24 09:36:15.940 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:36:15.940 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-08-24 09:36:15.940 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 09:36:15.954 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:36:15.954 | DTC Client socket (2) | Closed. 2024-08-24 09:36:18.942 | Denali Data Feed | Connecting to the server ds14.sierracharts.com. Port 10048 2024-08-24 09:36:18.943 | DTC Client socket (2) | Creating socket. 2024-08-24 09:36:18.943 | DTC Client socket (2) | New receive buffer size: 0 2024-08-24 09:36:18.943 | DTC Client socket (2) | Connecting to IP: 176.9.9.252. 2024-08-24 09:36:18.970 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:36:18.970 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:36:18.970 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:36:19.004 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:36:19.004 | Denali Data Feed | Sending logon request message. 2024-08-24 09:36:19.390 | Denali Data Feed | Received logon response. 2024-08-24 09:36:19.390 | Denali Data Feed | Server Name: SC Realtime Server. 2024-08-24 09:36:19.390 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:36:19.390 | Denali Data Feed | Successfully connected. 2024-08-24 09:36:19.390 | Denali Data Feed | Trading is not supported. 2024-08-24 09:36:19.390 | Denali Data Feed | MarketDepthIsSupported: 1 2024-08-24 09:36:19.390 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.DDU24 -> FDAX202409_FUT_EUREX 2024-08-24 09:36:19.390 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.FDXSU24 -> FDXS202409_FUT_EUREX 2024-08-24 09:36:19.505 | Denali Data Feed | Real-time data for symbol F.US.DDU24 is currently unavailable. 2024-08-24 09:36:19.505 | Denali Data Feed | Setting external service identifier for symbol F.US.DDU24 to 7296071 2024-08-24 09:36:19.505 | Denali Data Feed | Received security definition for symbol F.US.DDU24 2024-08-24 09:36:19.505 | Denali Data Feed | Real-time data for symbol F.US.FDXSU24 is currently unavailable. 2024-08-24 09:36:19.505 | Denali Data Feed | Setting external service identifier for symbol F.US.FDXSU24 to 10451688 2024-08-24 09:36:19.505 | Denali Data Feed | Received security definition for symbol F.US.FDXSU24 2024-08-24 09:36:24.711 | HD Request # 107 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:36:24.712 | HD Request # 107 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:36:24.713 | HD Request # 107 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:36:24.713 | Socket (3) | Creating socket. 2024-08-24 09:36:24.713 | Socket (3) | New receive buffer size: 0 2024-08-24 09:36:24.713 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:36:24.744 | HD Request # 107 | Setting DTC encoding to Binary VLS 2024-08-24 09:36:24.744 | HD Request # 107 | Sending historical data logon request message. 2024-08-24 09:36:24.758 | Socket (3) | CloseSocket call. 2024-08-24 09:36:24.759 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:36:24.759 | HD Request # 107 | Error downloading historical Intraday data for F.US.DDU24. Historical data logon error: Serving data is disabled 2024-08-24 09:36:24.759 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:36:24.759 | Triggering next historical data download in queue. 2024-08-24 09:36:24.759 | Historical data download thread signaled to stop. 2024-08-24 09:36:24.759 | HD Request # 107 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DDU24 2024-08-24 09:36:24.759 | HD Request # 107 | Completion time: 0s. 2024-08-24 09:36:24.759 | 2024-08-24 09:36:24.760 | HD Request # 108 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:36:24.761 | HD Request # 108 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:36:24.761 | HD Request # 108 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:36:24.761 | Socket (4) | Creating socket. 2024-08-24 09:36:24.761 | Socket (4) | New receive buffer size: 0 2024-08-24 09:36:24.761 | Socket (4) | Connecting to IP: 176.9.9.252. 2024-08-24 09:36:24.773 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:36:24.773 | Socket (3) | Closed. 2024-08-24 09:36:24.820 | HD Request # 108 | Setting DTC encoding to Binary VLS 2024-08-24 09:36:24.820 | HD Request # 108 | Sending historical data logon request message. 2024-08-24 09:36:24.988 | HD Request # 108 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDAX202409_FUT_EUREX 2024-08-24 09:36:25.018 | HD Request # 108 | Decompressing data. 2024-08-24 09:36:25.043 | HD Request # 108 | Receiving Intraday data for F.US.DDU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:36:25.043 | Socket (4) | CloseSocket call. 2024-08-24 09:36:25.043 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 09:36:25.043 | Historical data download thread signaled to stop. 2024-08-24 09:36:25.043 | HD Request # 108 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.5 hours) and wrote 0 records for F.US.DDU24 2024-08-24 09:36:25.044 | HD Request # 108 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:36:25.044 | HD Request # 108 | Completion time: 1s. 2024-08-24 09:36:25.044 | HD Request # 108 | Intraday data download complete for F.US.DDU24. Unique request ID: 57 2024-08-24 09:36:25.044 | Removing historical data download ID 57. 2024-08-24 09:36:25.044 | Real-time Intraday chart data file updates started for F.US.DDU24 2024-08-24 09:36:25.044 | Intraday chart data file opened for F.US.DDU24 2024-08-24 09:36:25.044 | HD Request # 108 | Enabling Intraday chart updating for symbol. 2024-08-24 09:36:25.044 | 2024-08-24 09:36:25.044 | Triggering next historical data download in queue. 2024-08-24 09:36:25.044 | HD Request # 109 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:36:25.044 | HD Request # 109 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:36:25.044 | HD Request # 109 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:36:25.044 | Socket (3) | Creating socket. 2024-08-24 09:36:25.044 | Socket (3) | New receive buffer size: 0 2024-08-24 09:36:25.044 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:36:25.070 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 09:36:25.070 | Socket (4) | Closed. 2024-08-24 09:36:25.077 | HD Request # 109 | Setting DTC encoding to Binary VLS 2024-08-24 09:36:25.077 | HD Request # 109 | Sending historical data logon request message. 2024-08-24 09:36:25.090 | Socket (3) | CloseSocket call. 2024-08-24 09:36:25.090 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:36:25.090 | HD Request # 109 | Error downloading historical Intraday data for F.US.FDXSU24. Historical data logon error: Serving data is disabled 2024-08-24 09:36:25.090 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:36:25.090 | Triggering next historical data download in queue. 2024-08-24 09:36:25.090 | Historical data download thread signaled to stop. 2024-08-24 09:36:25.090 | HD Request # 109 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSU24 2024-08-24 09:36:25.091 | HD Request # 109 | Completion time: 0s. 2024-08-24 09:36:25.091 | 2024-08-24 09:36:25.091 | HD Request # 110 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:36:25.091 | HD Request # 110 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:36:25.091 | HD Request # 110 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:36:25.091 | Socket (4) | Creating socket. 2024-08-24 09:36:25.091 | Socket (4) | New receive buffer size: 0 2024-08-24 09:36:25.091 | Socket (4) | Connecting to IP: 176.9.9.252. 2024-08-24 09:36:25.104 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:36:25.104 | Socket (3) | Closed. 2024-08-24 09:36:25.148 | HD Request # 110 | Setting DTC encoding to Binary VLS 2024-08-24 09:36:25.148 | HD Request # 110 | Sending historical data logon request message. 2024-08-24 09:36:25.174 | HD Request # 110 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDXS202409_FUT_EUREX 2024-08-24 09:36:25.201 | HD Request # 110 | Decompressing data. 2024-08-24 09:36:25.226 | HD Request # 110 | Receiving Intraday data for F.US.FDXSU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:36:25.226 | Socket (4) | CloseSocket call. 2024-08-24 09:36:25.226 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 09:36:25.226 | Historical data download thread signaled to stop. 2024-08-24 09:36:25.226 | HD Request # 110 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.5 hours) and wrote 0 records for F.US.FDXSU24 2024-08-24 09:36:25.227 | HD Request # 110 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:36:25.228 | HD Request # 110 | Completion time: 0s. 2024-08-24 09:36:25.228 | HD Request # 110 | Intraday data download complete for F.US.FDXSU24. Unique request ID: 58 2024-08-24 09:36:25.228 | Removing historical data download ID 58. 2024-08-24 09:36:25.228 | Real-time Intraday chart data file updates started for F.US.FDXSU24 2024-08-24 09:36:25.228 | Intraday chart data file opened for F.US.FDXSU24 2024-08-24 09:36:25.228 | HD Request # 110 | Enabling Intraday chart updating for symbol. 2024-08-24 09:36:25.228 | 2024-08-24 09:36:25.228 | No download requests in the queue to start downloads for. 2024-08-24 09:36:25.252 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 09:36:25.253 | Socket (4) | Closed. 2024-08-24 09:36:25.547 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:36:25.547 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:36:25.547 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:36:25.582 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:36:32.138 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:36:35.098 | Chart #12 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:36:35.237 | Chart #2 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:36:35.237 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:36:35.237 | Chart #2 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:36:35.237 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:36:35.287 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:36:40.729 | Chart #25 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:36:40.762 | F.US.FDXSU24 [CBV][M] 100 Volume #14 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:36:40.976 | F.US.FDXSU24 [CBV][M] 1 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:38:46.633 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:38:46.633 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:38:46.633 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:38:46.745 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:38:53.429 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:38:56.354 | CQG WebSocket | Timeout waiting for pong message from server. 2024-08-24 09:38:56.354 | CQG WebAPI | WebSocket closed. 2024-08-24 09:38:56.354 | Connection to the external service has been lost. 2024-08-24 09:38:56.620 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:39:02.156 | CQG WebAPI | Sending Web API Logoff message. 2024-08-24 09:39:02.156 | CQG WebSocket socket (1) | CloseSocket call. 2024-08-24 09:39:02.157 | CQG WebSocket socket (1) | Max send buffers used during socket life: 3 2024-08-24 09:39:02.157 | CQG WebSocket socket (1) | Max send buffer size during socket life: 309 2024-08-24 09:39:02.157 | CQG WebSocket | WebSocket closed. 2024-08-24 09:39:02.157 | CQG WebAPI | WebSocket closed. 2024-08-24 09:39:02.157 | CQG WebAPI | Disconnected. 2024-08-24 09:39:02.157 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-08-24 09:39:02.157 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2024-08-24 09:39:02.165 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2024-08-24 09:39:02.165 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 09:39:02.175 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2024-08-24 09:39:02.175 | CQG WebSocket socket (1) | Closed. 2024-08-24 09:39:04.173 | 2024-08-24 09:39:04.173 | CQG WebAPI | Connecting to server api.cqg.com 2024-08-24 09:39:04.173 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-08-24 09:39:04.287 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2024-08-24 09:39:04.287 | CQG WebSocket socket (1) | New receive buffer size: 0 2024-08-24 09:39:04.287 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2024-08-24 09:39:04.298 | CQG WebSocket | Opening WebSocket. 2024-08-24 09:39:04.298 | CQG WebSocket | Sending WebSocket handshake. 2024-08-24 09:39:04.330 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2024-08-24 09:39:04.330 | CQG WebSocket | Server header | Connection: Upgrade 2024-08-24 09:39:04.330 | CQG WebSocket | Server header | Sec-WebSocket-Accept: OaBmLjdGzMHkXLs8KZ7x40vCcX8= 2024-08-24 09:39:04.330 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2024-08-24 09:39:04.330 | CQG WebSocket | Server header | Upgrade: websocket 2024-08-24 09:39:04.330 | CQG WebSocket | Server header | 2024-08-24 09:39:04.330 | CQG WebSocket | Web socket state is now open. 2024-08-24 09:39:04.330 | CQG WebAPI | WebSocket connected. 2024-08-24 09:39:04.330 | CQG WebAPI | Sending market data logon message. 2024-08-24 09:39:04.551 | CQG WebAPI | Base Time: 2024-08-04T06:16:49. 2024-08-04 06:16:49 2024-08-24 09:39:04.551 | CQG WebAPI | Logon successful. Session Token = SYPvkrK2FjWBgA64uzb5HJ1ASpPGaDJpXu8MY1KYw2IL67MRQyX0VDQr3VArwj+vGg0DKyUyfJx 2024-08-24 09:39:04.551 | CQG WebAPI | Connected to server complete. 2024-08-24 09:39:04.551 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:39:04.552 | DTC Client socket (2) | CloseSocket call. 2024-08-24 09:39:04.552 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:39:04.552 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 09:39:04.552 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-24 09:39:04.553 | Updated verified funded futures trading account ending date to: 2024-09-23 07:39:04 2024-08-24 09:39:04.578 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:39:04.578 | DTC Client socket (2) | Closed. 2024-08-24 09:39:04.861 | CQG WebAPI | Sending Trade Accounts request message. 2024-08-24 09:39:04.861 | CQG WebAPI | Sending positions subscribe request. RequestID: 982725 2024-08-24 09:39:04.861 | CQG WebAPI | Sending orders subscribe request. RequestID: 982726 2024-08-24 09:39:04.870 | CQG WebAPI | Brokerage name: WH Selfinvest France. Account Name: LWHF0931 2024-08-24 09:39:04.870 | Updated verified funded futures trading account ending date to: 2024-09-23 07:39:04 2024-08-24 09:39:04.870 | CQG WebAPI | Sending collateral subscribe request. 2024-08-24 09:39:04.893 | Mapping F.US.DDU24 to FDAX202409_FUT_EUREX. Service code: eurex 2024-08-24 09:39:04.893 | Using symbol data fast lookup vector 2024-08-24 09:39:04.893 | Denali Data Feed | Starting real-time market data updates for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 1 Service code: eurex 2024-08-24 09:39:04.893 | Denali Data Feed | Connecting to the server ds24.sierracharts.com. Port 443 2024-08-24 09:39:04.893 | CQG WebAPI | Sending symbol resolution request for F.US.DDU24. ID: 982728 2024-08-24 09:39:04.893 | Denali Data Feed | Requesting security definition data for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 1 2024-08-24 09:39:04.893 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:39:04.893 | Intraday data recording state for symbol F.US.DDU24 is set to download 'Pending'. 2024-08-24 09:39:04.893 | Triggering next historical data download in queue. 2024-08-24 09:39:04.894 | DTC Client socket (2) | Creating socket. 2024-08-24 09:39:04.894 | DTC Client socket (2) | New receive buffer size: 0 2024-08-24 09:39:04.894 | DTC Client socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 09:39:04.911 | Delaying start of download for F.US.DDU24. 2024-08-24 09:39:04.911 | CQG WebAPI | Received symbol resolution report for symbol F.US.DDU24. Search Symbol: F.US.DDU24. Request ID: 982728. Contract ID: 1. 2024-08-24 09:39:04.911 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:39:04.911 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:39:04.911 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:39:04.911 | Mapping F.US.FDXSU24 to FDXS202409_FUT_EUREX. Service code: eurex 2024-08-24 09:39:04.911 | Denali Data Feed | Starting real-time market data updates for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 2 Service code: eurex 2024-08-24 09:39:04.912 | CQG WebAPI | Sending symbol resolution request for F.US.FDXSU24. ID: 982729 2024-08-24 09:39:04.912 | Denali Data Feed | Requesting security definition data for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 2 2024-08-24 09:39:04.912 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:39:04.912 | Intraday data recording state for symbol F.US.FDXSU24 is set to download 'Pending'. 2024-08-24 09:39:04.912 | Triggering next historical data download in queue. 2024-08-24 09:39:04.946 | CQG WebAPI | Received symbol resolution report for symbol F.US.FDXSU24. Search Symbol: F.US.FDXSU24. Request ID: 982729. Contract ID: 2. 2024-08-24 09:39:04.972 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:39:04.972 | Denali Data Feed | Sending logon request message. 2024-08-24 09:39:05.010 | Denali Data Feed | Received logon response. 2024-08-24 09:39:05.010 | Denali Data Feed | Server Name: RealTimeServer. 2024-08-24 09:39:05.010 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:39:05.010 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. 2024-08-24 09:39:05.010 | Denali Data Feed | Failed connections: 1 2024-08-24 09:39:05.010 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:39:05.010 | DTC Client socket (2) | CloseSocket call. 2024-08-24 09:39:05.010 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:39:05.010 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-08-24 09:39:05.010 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 09:39:05.024 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:39:05.024 | DTC Client socket (2) | Closed. 2024-08-24 09:39:08.018 | Denali Data Feed | Connecting to the server ds14.sierracharts.com. Port 10048 2024-08-24 09:39:08.018 | DTC Client socket (2) | Creating socket. 2024-08-24 09:39:08.018 | DTC Client socket (2) | New receive buffer size: 0 2024-08-24 09:39:08.018 | DTC Client socket (2) | Connecting to IP: 176.9.9.252. 2024-08-24 09:39:08.044 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:39:08.044 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:39:08.044 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:39:08.072 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:39:08.072 | Denali Data Feed | Sending logon request message. 2024-08-24 09:39:08.447 | Denali Data Feed | Received logon response. 2024-08-24 09:39:08.447 | Denali Data Feed | Server Name: SC Realtime Server. 2024-08-24 09:39:08.447 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:39:08.447 | Denali Data Feed | Successfully connected. 2024-08-24 09:39:08.447 | Denali Data Feed | Trading is not supported. 2024-08-24 09:39:08.447 | Denali Data Feed | MarketDepthIsSupported: 1 2024-08-24 09:39:08.447 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.DDU24 -> FDAX202409_FUT_EUREX 2024-08-24 09:39:08.447 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.FDXSU24 -> FDXS202409_FUT_EUREX 2024-08-24 09:39:08.571 | Denali Data Feed | Real-time data for symbol F.US.DDU24 is currently unavailable. 2024-08-24 09:39:08.571 | Denali Data Feed | Setting external service identifier for symbol F.US.DDU24 to 7296071 2024-08-24 09:39:08.571 | Denali Data Feed | Received security definition for symbol F.US.DDU24 2024-08-24 09:39:08.571 | Denali Data Feed | Real-time data for symbol F.US.FDXSU24 is currently unavailable. 2024-08-24 09:39:08.571 | Denali Data Feed | Setting external service identifier for symbol F.US.FDXSU24 to 10451688 2024-08-24 09:39:08.571 | Denali Data Feed | Received security definition for symbol F.US.FDXSU24 2024-08-24 09:39:13.368 | HD Request # 111 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:39:13.387 | HD Request # 111 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:39:13.388 | HD Request # 111 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:39:13.388 | Socket (3) | Creating socket. 2024-08-24 09:39:13.388 | Socket (3) | New receive buffer size: 0 2024-08-24 09:39:13.388 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:39:13.418 | HD Request # 111 | Setting DTC encoding to Binary VLS 2024-08-24 09:39:13.418 | HD Request # 111 | Sending historical data logon request message. 2024-08-24 09:39:13.432 | Socket (3) | CloseSocket call. 2024-08-24 09:39:13.432 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:39:13.432 | HD Request # 111 | Error downloading historical Intraday data for F.US.DDU24. Historical data logon error: Serving data is disabled 2024-08-24 09:39:13.432 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:39:13.432 | Triggering next historical data download in queue. 2024-08-24 09:39:13.432 | Historical data download thread signaled to stop. 2024-08-24 09:39:13.432 | HD Request # 111 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DDU24 2024-08-24 09:39:13.433 | HD Request # 111 | Completion time: 0s. 2024-08-24 09:39:13.433 | 2024-08-24 09:39:13.433 | HD Request # 112 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:39:13.434 | HD Request # 112 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:39:13.434 | HD Request # 112 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:39:13.434 | Socket (4) | Creating socket. 2024-08-24 09:39:13.434 | Socket (4) | New receive buffer size: 0 2024-08-24 09:39:13.434 | Socket (4) | Connecting to IP: 176.9.9.252. 2024-08-24 09:39:13.446 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:39:13.446 | Socket (3) | Closed. 2024-08-24 09:39:13.491 | HD Request # 112 | Setting DTC encoding to Binary VLS 2024-08-24 09:39:13.491 | HD Request # 112 | Sending historical data logon request message. 2024-08-24 09:39:13.650 | HD Request # 112 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDAX202409_FUT_EUREX 2024-08-24 09:39:13.676 | HD Request # 112 | Decompressing data. 2024-08-24 09:39:13.700 | HD Request # 112 | Receiving Intraday data for F.US.DDU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:39:13.700 | Socket (4) | CloseSocket call. 2024-08-24 09:39:13.700 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 09:39:13.700 | Historical data download thread signaled to stop. 2024-08-24 09:39:13.700 | HD Request # 112 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.6 hours) and wrote 0 records for F.US.DDU24 2024-08-24 09:39:13.701 | HD Request # 112 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:39:13.702 | HD Request # 112 | Completion time: 0s. 2024-08-24 09:39:13.702 | HD Request # 112 | Intraday data download complete for F.US.DDU24. Unique request ID: 59 2024-08-24 09:39:13.702 | Removing historical data download ID 59. 2024-08-24 09:39:13.702 | Real-time Intraday chart data file updates started for F.US.DDU24 2024-08-24 09:39:13.702 | Intraday chart data file opened for F.US.DDU24 2024-08-24 09:39:13.702 | HD Request # 112 | Enabling Intraday chart updating for symbol. 2024-08-24 09:39:13.702 | 2024-08-24 09:39:13.702 | Triggering next historical data download in queue. 2024-08-24 09:39:13.702 | HD Request # 113 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:39:13.720 | HD Request # 113 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:39:13.720 | HD Request # 113 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:39:13.720 | Socket (3) | Creating socket. 2024-08-24 09:39:13.721 | Socket (3) | New receive buffer size: 0 2024-08-24 09:39:13.721 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:39:13.726 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 09:39:13.726 | Socket (4) | Closed. 2024-08-24 09:39:13.751 | HD Request # 113 | Setting DTC encoding to Binary VLS 2024-08-24 09:39:13.751 | HD Request # 113 | Sending historical data logon request message. 2024-08-24 09:39:13.764 | Socket (3) | CloseSocket call. 2024-08-24 09:39:13.764 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:39:13.778 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:39:13.778 | Socket (3) | Closed. 2024-08-24 09:39:13.787 | HD Request # 113 | Error downloading historical Intraday data for F.US.FDXSU24. Historical data logon error: Serving data is disabled 2024-08-24 09:39:13.787 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:39:13.787 | Triggering next historical data download in queue. 2024-08-24 09:39:13.787 | Historical data download thread signaled to stop. 2024-08-24 09:39:13.787 | HD Request # 113 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSU24 2024-08-24 09:39:13.787 | HD Request # 113 | Completion time: 0s. 2024-08-24 09:39:13.787 | 2024-08-24 09:39:13.787 | HD Request # 114 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:39:13.787 | HD Request # 114 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:39:13.787 | HD Request # 114 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:39:13.787 | Socket (3) | Creating socket. 2024-08-24 09:39:13.787 | Socket (3) | New receive buffer size: 0 2024-08-24 09:39:13.787 | Socket (3) | Connecting to IP: 176.9.9.252. 2024-08-24 09:39:13.843 | HD Request # 114 | Setting DTC encoding to Binary VLS 2024-08-24 09:39:13.843 | HD Request # 114 | Sending historical data logon request message. 2024-08-24 09:39:13.868 | HD Request # 114 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDXS202409_FUT_EUREX 2024-08-24 09:39:13.893 | HD Request # 114 | Decompressing data. 2024-08-24 09:39:13.918 | HD Request # 114 | Receiving Intraday data for F.US.FDXSU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:39:13.918 | Socket (3) | CloseSocket call. 2024-08-24 09:39:13.918 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:39:13.918 | Historical data download thread signaled to stop. 2024-08-24 09:39:13.918 | HD Request # 114 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.6 hours) and wrote 0 records for F.US.FDXSU24 2024-08-24 09:39:13.919 | HD Request # 114 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:39:13.920 | HD Request # 114 | Completion time: 0s. 2024-08-24 09:39:13.920 | HD Request # 114 | Intraday data download complete for F.US.FDXSU24. Unique request ID: 60 2024-08-24 09:39:13.920 | Removing historical data download ID 60. 2024-08-24 09:39:13.920 | Real-time Intraday chart data file updates started for F.US.FDXSU24 2024-08-24 09:39:13.920 | Intraday chart data file opened for F.US.FDXSU24 2024-08-24 09:39:13.920 | HD Request # 114 | Enabling Intraday chart updating for symbol. 2024-08-24 09:39:13.920 | 2024-08-24 09:39:13.920 | No download requests in the queue to start downloads for. 2024-08-24 09:39:13.945 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:39:13.945 | Socket (3) | Closed. 2024-08-24 09:39:14.081 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:39:14.081 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:39:14.081 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:39:14.118 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:39:20.695 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:39:23.616 | Chart #12 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:39:23.755 | Chart #2 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:39:23.755 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:39:23.755 | Chart #2 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:39:23.755 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:39:23.807 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:39:29.275 | Chart #25 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:39:29.309 | F.US.FDXSU24 [CBV][M] 100 Volume #14 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:39:29.525 | F.US.FDXSU24 [CBV][M] 1 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:41:33.854 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:41:33.854 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:41:33.854 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:41:33.855 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:41:40.592 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:41:43.513 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:41:48.954 | CQG WebSocket | Timeout waiting for pong message from server. 2024-08-24 09:41:48.954 | CQG WebAPI | WebSocket closed. 2024-08-24 09:41:48.954 | Connection to the external service has been lost. 2024-08-24 09:41:49.283 | CQG WebAPI | Sending Web API Logoff message. 2024-08-24 09:41:49.283 | CQG WebSocket socket (1) | CloseSocket call. 2024-08-24 09:41:49.283 | CQG WebSocket socket (1) | Max send buffers used during socket life: 3 2024-08-24 09:41:49.283 | CQG WebSocket socket (1) | Max send buffer size during socket life: 309 2024-08-24 09:41:49.283 | CQG WebSocket | WebSocket closed. 2024-08-24 09:41:49.283 | CQG WebAPI | WebSocket closed. 2024-08-24 09:41:49.283 | CQG WebAPI | Disconnected. 2024-08-24 09:41:49.283 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-08-24 09:41:49.283 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2024-08-24 09:41:49.293 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2024-08-24 09:41:49.293 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2024-08-24 09:41:49.303 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2024-08-24 09:41:49.303 | CQG WebSocket socket (1) | Closed. 2024-08-24 09:41:51.274 | 2024-08-24 09:41:51.274 | CQG WebAPI | Connecting to server api.cqg.com 2024-08-24 09:41:51.274 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2024-08-24 09:41:51.274 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2024-08-24 09:41:51.275 | CQG WebSocket socket (1) | New receive buffer size: 0 2024-08-24 09:41:51.275 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2024-08-24 09:41:51.285 | CQG WebSocket | Opening WebSocket. 2024-08-24 09:41:51.285 | CQG WebSocket | Sending WebSocket handshake. 2024-08-24 09:41:51.355 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2024-08-24 09:41:51.355 | CQG WebSocket | Server header | Connection: Upgrade 2024-08-24 09:41:51.355 | CQG WebSocket | Server header | Sec-WebSocket-Accept: annom9G9yRIoYjvV4z9HU9qSdGo= 2024-08-24 09:41:51.355 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2024-08-24 09:41:51.355 | CQG WebSocket | Server header | Upgrade: websocket 2024-08-24 09:41:51.355 | CQG WebSocket | Server header | 2024-08-24 09:41:51.355 | CQG WebSocket | Web socket state is now open. 2024-08-24 09:41:51.355 | CQG WebAPI | WebSocket connected. 2024-08-24 09:41:51.355 | CQG WebAPI | Sending market data logon message. 2024-08-24 09:41:51.595 | CQG WebAPI | Base Time: 2024-08-04T06:16:49. 2024-08-04 06:16:49 2024-08-24 09:41:51.595 | CQG WebAPI | Logon successful. Session Token = 9K+fw5NIuFKIhi14osANwkizzCAC0TuvF2l15gDxNY0292IpTnFRz9IOq8mdwFuwwR3geQf3nco 2024-08-24 09:41:51.595 | CQG WebAPI | Connected to server complete. 2024-08-24 09:41:51.595 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:41:51.596 | DTC Client socket (2) | CloseSocket call. 2024-08-24 09:41:51.596 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:41:51.596 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 09:41:51.597 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-08-24 09:41:51.597 | Updated verified funded futures trading account ending date to: 2024-09-23 07:41:51 2024-08-24 09:41:51.622 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:41:51.622 | DTC Client socket (2) | Closed. 2024-08-24 09:41:51.918 | CQG WebAPI | Sending Trade Accounts request message. 2024-08-24 09:41:51.919 | Mapping F.US.FDXSU24 to FDXS202409_FUT_EUREX. Service code: eurex 2024-08-24 09:41:51.919 | Using symbol data fast lookup vector 2024-08-24 09:41:51.919 | Denali Data Feed | Starting real-time market data updates for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 1 Service code: eurex 2024-08-24 09:41:51.919 | Denali Data Feed | Connecting to the server ds24.sierracharts.com. Port 10048 2024-08-24 09:41:51.919 | CQG WebAPI | Sending symbol resolution request for F.US.FDXSU24. ID: 982731 2024-08-24 09:41:51.919 | Denali Data Feed | Requesting security definition data for: F.US.FDXSU24 (FDXS202409_FUT_EUREX). ID: 1 2024-08-24 09:41:51.920 | DTC Client socket (2) | Creating socket. 2024-08-24 09:41:51.920 | DTC Client socket (2) | New receive buffer size: 0 2024-08-24 09:41:51.920 | DTC Client socket (2) | Connecting to IP: 149.11.224.18. 2024-08-24 09:41:51.921 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:41:51.921 | Intraday data recording state for symbol F.US.FDXSU24 is set to download 'Pending'. 2024-08-24 09:41:51.921 | Triggering next historical data download in queue. 2024-08-24 09:41:52.057 | Delaying start of download for F.US.FDXSU24. 2024-08-24 09:41:52.057 | CQG WebAPI | Received symbol resolution report for symbol F.US.FDXSU24. Search Symbol: F.US.FDXSU24. Request ID: 982731. Contract ID: 1. 2024-08-24 09:41:52.057 | CQG WebAPI | Brokerage name: WH Selfinvest France. Account Name: LWHF0931 2024-08-24 09:41:52.057 | Updated verified funded futures trading account ending date to: 2024-09-23 07:41:52 2024-08-24 09:41:52.057 | CQG WebAPI | Sending collateral subscribe request. 2024-08-24 09:41:52.057 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:41:52.057 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:41:52.057 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:41:52.090 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:41:52.090 | Denali Data Feed | Sending logon request message. 2024-08-24 09:41:52.134 | Denali Data Feed | Received logon response. 2024-08-24 09:41:52.134 | Denali Data Feed | Server Name: RealTimeServer. 2024-08-24 09:41:52.134 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:41:52.134 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. 2024-08-24 09:41:52.134 | Denali Data Feed | Failed connections: 1 2024-08-24 09:41:52.134 | Denali Data Feed | Waiting for socket receive thread to end 2024-08-24 09:41:52.134 | DTC Client socket (2) | CloseSocket call. 2024-08-24 09:41:52.134 | Denali Data Feed | Disconnected from the server. 2024-08-24 09:41:52.134 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-08-24 09:41:52.134 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-08-24 09:41:52.148 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-08-24 09:41:52.148 | DTC Client socket (2) | Closed. 2024-08-24 09:41:52.169 | Mapping F.US.DDU24 to FDAX202409_FUT_EUREX. Service code: eurex 2024-08-24 09:41:52.169 | Denali Data Feed | Starting real-time market data updates for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 2 Service code: eurex 2024-08-24 09:41:52.169 | CQG WebAPI | Sending symbol resolution request for F.US.DDU24. ID: 982733 2024-08-24 09:41:52.169 | Denali Data Feed | Requesting security definition data for: F.US.DDU24 (FDAX202409_FUT_EUREX). ID: 2 2024-08-24 09:41:52.169 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:41:52.169 | Intraday data recording state for symbol F.US.DDU24 is set to download 'Pending'. 2024-08-24 09:41:52.169 | Triggering next historical data download in queue. 2024-08-24 09:41:52.187 | CQG WebAPI | Received symbol resolution report for symbol F.US.DDU24. Search Symbol: F.US.DDU24. Request ID: 982733. Contract ID: 2. 2024-08-24 09:41:52.275 | CQG WebAPI | Sending positions subscribe request. RequestID: 982734 2024-08-24 09:41:52.275 | CQG WebAPI | Sending orders subscribe request. RequestID: 982735 2024-08-24 09:41:55.143 | Denali Data Feed | Connecting to the server ds14.sierracharts.com. Port 443 2024-08-24 09:41:55.144 | DTC Client socket (2) | Creating socket. 2024-08-24 09:41:55.144 | DTC Client socket (2) | New receive buffer size: 0 2024-08-24 09:41:55.144 | DTC Client socket (2) | Connecting to IP: 176.9.9.252. 2024-08-24 09:41:55.169 | Denali Data Feed | Network connection to server complete. 2024-08-24 09:41:55.169 | Denali Data Feed | Starting socket receive thread. 2024-08-24 09:41:55.169 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-08-24 09:41:55.207 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-08-24 09:41:55.207 | Denali Data Feed | Sending logon request message. 2024-08-24 09:41:55.582 | Denali Data Feed | Received logon response. 2024-08-24 09:41:55.582 | Denali Data Feed | Server Name: SC Realtime Server. 2024-08-24 09:41:55.582 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-08-24 09:41:55.582 | Denali Data Feed | Successfully connected. 2024-08-24 09:41:55.582 | Denali Data Feed | Trading is not supported. 2024-08-24 09:41:55.582 | Denali Data Feed | MarketDepthIsSupported: 1 2024-08-24 09:41:55.582 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.DDU24 -> FDAX202409_FUT_EUREX 2024-08-24 09:41:55.582 | Denali Data Feed | Restarting real-time data updates for symbol: F.US.FDXSU24 -> FDXS202409_FUT_EUREX 2024-08-24 09:41:55.707 | Denali Data Feed | Real-time data for symbol F.US.DDU24 is currently unavailable. 2024-08-24 09:41:55.707 | Denali Data Feed | Setting external service identifier for symbol F.US.DDU24 to 7296071 2024-08-24 09:41:55.707 | Denali Data Feed | Received security definition for symbol F.US.DDU24 2024-08-24 09:41:55.707 | Denali Data Feed | Real-time data for symbol F.US.FDXSU24 is currently unavailable. 2024-08-24 09:41:55.707 | Denali Data Feed | Setting external service identifier for symbol F.US.FDXSU24 to 10451688 2024-08-24 09:41:55.707 | Denali Data Feed | Received security definition for symbol F.US.FDXSU24 2024-08-24 09:42:00.150 | HD Request # 115 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:42:00.151 | HD Request # 115 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:42:00.151 | HD Request # 115 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:42:00.151 | Socket (4) | Creating socket. 2024-08-24 09:42:00.152 | Socket (4) | New receive buffer size: 0 2024-08-24 09:42:00.152 | Socket (4) | Connecting to IP: 149.11.224.18. 2024-08-24 09:42:00.181 | HD Request # 115 | Setting DTC encoding to Binary VLS 2024-08-24 09:42:00.181 | HD Request # 115 | Sending historical data logon request message. 2024-08-24 09:42:00.195 | Socket (4) | CloseSocket call. 2024-08-24 09:42:00.195 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 09:42:00.209 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 09:42:00.209 | Socket (4) | Closed. 2024-08-24 09:42:00.235 | HD Request # 115 | Error downloading historical Intraday data for F.US.FDXSU24. Historical data logon error: Serving data is disabled 2024-08-24 09:42:00.235 | Added historical Intraday data request for F.US.FDXSU24 to the queue. 2024-08-24 09:42:00.235 | Triggering next historical data download in queue. 2024-08-24 09:42:00.235 | Historical data download thread signaled to stop. 2024-08-24 09:42:00.235 | HD Request # 115 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FDXSU24 2024-08-24 09:42:00.235 | HD Request # 115 | Completion time: 0s. 2024-08-24 09:42:00.235 | 2024-08-24 09:42:00.235 | HD Request # 116 | Downloading Intraday chart data for F.US.FDXSU24 to the file F.US.FDXSU24.scid. Service: eurex 2024-08-24 09:42:00.235 | HD Request # 116 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:42:00.235 | HD Request # 116 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:42:00.236 | Socket (4) | Creating socket. 2024-08-24 09:42:00.236 | Socket (4) | New receive buffer size: 0 2024-08-24 09:42:00.236 | Socket (4) | Connecting to IP: 176.9.9.252. 2024-08-24 09:42:00.290 | HD Request # 116 | Setting DTC encoding to Binary VLS 2024-08-24 09:42:00.290 | HD Request # 116 | Sending historical data logon request message. 2024-08-24 09:42:00.446 | HD Request # 116 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDXS202409_FUT_EUREX 2024-08-24 09:42:00.472 | HD Request # 116 | Decompressing data. 2024-08-24 09:42:00.521 | HD Request # 116 | Receiving Intraday data for F.US.FDXSU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:42:00.522 | Socket (4) | CloseSocket call. 2024-08-24 09:42:00.522 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 09:42:00.530 | Historical data download thread signaled to stop. 2024-08-24 09:42:00.530 | HD Request # 116 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.6 hours) and wrote 0 records for F.US.FDXSU24 2024-08-24 09:42:00.530 | HD Request # 116 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:42:00.530 | HD Request # 116 | Completion time: 0s. 2024-08-24 09:42:00.530 | HD Request # 116 | Intraday data download complete for F.US.FDXSU24. Unique request ID: 61 2024-08-24 09:42:00.530 | Removing historical data download ID 61. 2024-08-24 09:42:00.530 | Real-time Intraday chart data file updates started for F.US.FDXSU24 2024-08-24 09:42:00.530 | Intraday chart data file opened for F.US.FDXSU24 2024-08-24 09:42:00.530 | HD Request # 116 | Enabling Intraday chart updating for symbol. 2024-08-24 09:42:00.530 | 2024-08-24 09:42:00.530 | Triggering next historical data download in queue. 2024-08-24 09:42:00.530 | HD Request # 117 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:42:00.531 | HD Request # 117 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:42:00.531 | HD Request # 117 | Using server: ds24.sierracharts.com port 10150 2024-08-24 09:42:00.531 | Socket (3) | Creating socket. 2024-08-24 09:42:00.531 | Socket (3) | New receive buffer size: 0 2024-08-24 09:42:00.531 | Socket (3) | Connecting to IP: 149.11.224.18. 2024-08-24 09:42:00.563 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 09:42:00.564 | Socket (4) | Closed. 2024-08-24 09:42:00.577 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:42:00.577 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:42:00.577 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:42:00.579 | HD Request # 117 | Setting DTC encoding to Binary VLS 2024-08-24 09:42:00.579 | HD Request # 117 | Sending historical data logon request message. 2024-08-24 09:42:00.593 | Socket (3) | CloseSocket call. 2024-08-24 09:42:00.593 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-08-24 09:42:00.595 | HD Request # 117 | Error downloading historical Intraday data for F.US.DDU24. Historical data logon error: Serving data is disabled 2024-08-24 09:42:00.595 | Added historical Intraday data request for F.US.DDU24 to the queue. 2024-08-24 09:42:00.595 | Triggering next historical data download in queue. 2024-08-24 09:42:00.595 | Historical data download thread signaled to stop. 2024-08-24 09:42:00.595 | HD Request # 117 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DDU24 2024-08-24 09:42:00.595 | HD Request # 117 | Completion time: 0s. 2024-08-24 09:42:00.595 | 2024-08-24 09:42:00.595 | HD Request # 118 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex 2024-08-24 09:42:00.595 | HD Request # 118 | Download start date-time: 2024-08-23 22:03:41.000000. File last date-time: 2024-08-23 22:03:41.805000 2024-08-24 09:42:00.595 | HD Request # 118 | Using server: ds14.sierracharts.com port 10149 2024-08-24 09:42:00.595 | Socket (4) | Creating socket. 2024-08-24 09:42:00.595 | Socket (4) | New receive buffer size: 0 2024-08-24 09:42:00.595 | Socket (4) | Connecting to IP: 176.9.9.252. 2024-08-24 09:42:00.596 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:42:00.607 | Socket (3) | Socket gracefully closed by remote side. 2024-08-24 09:42:00.608 | Socket (3) | Closed. 2024-08-24 09:42:00.649 | HD Request # 118 | Setting DTC encoding to Binary VLS 2024-08-24 09:42:00.649 | HD Request # 118 | Sending historical data logon request message. 2024-08-24 09:42:00.674 | HD Request # 118 | Requesting Intraday data. Start date-time: 2024-08-23 22:03:41. Record interval: 0. Symbol: FDAX202409_FUT_EUREX 2024-08-24 09:42:00.698 | HD Request # 118 | Decompressing data. 2024-08-24 09:42:00.721 | HD Request # 118 | Receiving Intraday data for F.US.DDU24 starting at 2024-08-23 22:03:41.805000 2024-08-24 09:42:00.721 | Socket (4) | CloseSocket call. 2024-08-24 09:42:00.721 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-08-24 09:42:00.746 | Socket (4) | Socket gracefully closed by remote side. 2024-08-24 09:42:00.746 | Socket (4) | Closed. 2024-08-24 09:42:07.304 | Historical data download thread signaled to stop. 2024-08-24 09:42:07.304 | HD Request # 118 | Received 1 Intraday data record from 2024-08-23 22:03:41.805000 to 2024-08-23 22:03:41.805000 (0.0 seconds. Delay: 11.6 hours) and wrote 0 records for F.US.DDU24 2024-08-24 09:42:07.304 | HD Request # 118 | Add time&sales data | Remembered last file record date-time: 2024-08-23 20:03:41.805000 2024-08-24 09:42:07.304 | HD Request # 118 | Completion time: 7s. 2024-08-24 09:42:07.304 | HD Request # 118 | Intraday data download complete for F.US.DDU24. Unique request ID: 62 2024-08-24 09:42:07.304 | Removing historical data download ID 62. 2024-08-24 09:42:07.304 | Real-time Intraday chart data file updates started for F.US.DDU24 2024-08-24 09:42:07.304 | Intraday chart data file opened for F.US.DDU24 2024-08-24 09:42:07.304 | HD Request # 118 | Enabling Intraday chart updating for symbol. 2024-08-24 09:42:07.304 | 2024-08-24 09:42:07.304 | No download requests in the queue to start downloads for. 2024-08-24 09:42:07.327 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:42:10.288 | Chart #12 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:42:10.459 | Chart #2 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:42:10.459 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:42:10.459 | Chart #2 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:42:10.459 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:42:10.508 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:42:15.953 | Chart #25 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht Date Time Of Last Edit: 2024-08-26 01:29:51
Private File |
[2024-08-26 14:43:57] |
We see this: 2024-08-24 09:10:38.607 | CQG WebSocket | Timeout waiting for pong message from server.
2024-08-24 09:10:38.607 | CQG WebAPI | WebSocket closed. 2024-08-24 09:10:38.607 | Connection to the external service has been lost. 2024-08-24 09:10:38.931 | CQG WebAPI | Sending Web API Logoff message. It looks as though that Sierra Chart could be freezing due to too much processing. You need to solve these circular references and all of these continuous recalculations: 2024-08-24 09:22:18.229 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht
2024-08-24 09:22:18.229 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:18.229 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:18.259 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:24.826 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:27.800 | Chart #12 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:27.946 | Chart #2 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:27.946 | Chart #2 has tagged chart #14 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:27.946 | Chart #2 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:27.946 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:28.000 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:33.513 | Chart #25 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:33.548 | F.US.FDXSU24 [CBV][M] 100 Volume #14 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:22:33.770 | F.US.FDXSU24 [CBV][M] 1 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:24:39.975 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:24:39.975 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:24:39.975 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:24:39.989 | F.US.FDXSU24 [CBV][M] 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:24:46.714 | F.US.FDXSU24 [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:24:49.711 | Circular chart reference detected. Charts: 25, 12. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. 2024-08-24 09:24:49.716 | F.US.FDXSU24 [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht 2024-08-24 09:24:55.114 | Circular chart reference detected. Charts: 12, 25. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. Refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.9 References to Other Charts / Continuous Full Recalculation of Charts And reduce the amount of data you have in the charts: 2024-08-24 08:57:13.218 | The F.US.FDXSH17.dly symbol may not be the active contract month.
2024-08-24 08:57:13.218 | Unable to determine transition date based on volume from files: F.US.FDXSH17.dly, F.US.FDXSM17.dly 2024-08-24 08:57:13.218 | The F.US.FDXSM17.dly symbol may not be the active contract month. 2024-08-24 08:57:13.218 | Unable to determine transition date based on volume from files: F.US.FDXSM17.dly, F.US.FDXSU17.dly 2024-08-24 08:57:13.218 | The F.US.FDXSU17.dly symbol may not be the active contract month. 2024-08-24 08:57:13.218 | Unable to determine transition date based on volume from files: F.US.FDXSU17.dly, F.US.FDXSZ17.dly 2024-08-24 08:57:13.218 | The F.US.FDXSZ17.dly symbol may not be the active contract month. Refer to: Continuous Futures Contract Charts: Preventing Error Messages by Reducing Days to Load in Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-08-26 14:44:53
[2024-08-28 15:25:30] |
LionelTrad - Posts: 7 |
i John, I do not understand : how can I find this line below : Circular chart reference detected. Charts: 1, 2. Chartbook: Chartbook253.Cht. How to stop Circular References ? Thx |
[2024-08-28 16:52:50] |
A Circular Reference means that you have a study on Chart #1 that references information from Chart #2 and you have a study on Chart #2 that references information from Chart #1. As such, each chart is waiting for the other to update so they can get the data, but neither can update since they are both waiting for the other. You need to find the studies that are doing this on at least one of the charts and remove it. You will have to find a way around whatever it is that you were trying to do that created this situation. From your log, we see at least the following lines: 2024-08-24 09:24:49.711 | Circular chart reference detected. Charts: 25, 12. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht.
2024-08-24 09:24:55.114 | Circular chart reference detected. Charts: 12, 25. Chartbook: LeTradingFr_CB_Eurex_DAX_Trading_V2.Cht. There may be others, and it is also possible that you have a circular reference that has not been detected by the software. The fact that you have a lot of messages stating "Chart # has tagged chart # for full recalculation" implies that you are trying to get a lot of information from other charts, which has the possibility of creating a circular reference. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-02 06:19:00] |
Hi John, It seems to work now. thx very much for your patience ! Best regards |
