Date/Time: Sat, 23 Nov 2024 11:39:07 +0000
Alert
View Count: 95
[2024-08-19 19:02:15] |
User841161 - Posts: 221 |
I am trying to do an alert when in TICK-NYSE chart the bar is over 500. Trying to put formula inside of Color Bar Based on Alert Condition, but for some reason it is not triggering bar color change.
8-19-24.PNG / V - Attached On 2024-08-19 19:00:25 UTC - Size: 91.5 KB - 33 views 8-19-2024.PNG / V - Attached On 2024-08-19 19:00:40 UTC - Size: 64.39 KB - 36 views 081924.PNG / V - Attached On 2024-08-19 19:01:53 UTC - Size: 99.32 KB - 40 views |
[2024-08-19 20:59:43] |
It looks like there are some bars being colored. An item of note: - If you want to color any bar, regardless of whether it is an Up bar or a Down bar, then your formula needs be the following: = H >= 500 Where H is the High. Otherwise, since you are using the Close, you would only get a colored bar for Up bars where the Close is greater than 500. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
