Date/Time: Sat, 23 Nov 2024 12:48:56 +0000
Amending BE trigger while working order
View Count: 91
[2024-08-19 18:36:46] |
User538826 - Posts: 7 |
I was wondering once i have set the move to breakeven for a stop while the order is active. Would i be able to amend the trigger offset value while the order is live/working?
[2024-08-19 18:36:56] |
You can not adjust the trigger offset to a working order. You would need to remove the working orders and submit new ones using the "Send Attached Orders - Position/Price". Refer to the following: Order Types: Send Attached Orders - Position/Price For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
