Date/Time: Sat, 23 Nov 2024 11:43:10 +0000
multiple instruments on same chart
View Count: 125
[2024-08-19 16:53:42] |
User449884 - Posts: 155 |
I have 4 different instruments' USDJPY-ES-NQ-ZB on one chart one above the other, using the study overlay study. However, besides the original chart (usdjpy) the other markets dont have the price label on the right.
[2024-08-19 16:59:44] |
First, we recommend using the "Add Additional Symbol" study rather than the "Study/Price Overlay" for what you are doing. Refer to the following: Add Additional Symbol But in either case, you should see the prices on the right along with the current price for each instrument. First, try to reset the scales for each region by right-clicking and selecting "Reset". Refer to the following: Chart Scale and Scale Adjusting: Resetting the Scale If you continue to have an issue, then we would need to see an image of your chart by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-19 22:32:49] |
ive tried the add additional symbol, but the scales for price dont work
[2024-08-20 14:21:27] |
Please get us an image by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
