Date/Time: Sat, 23 Nov 2024 15:52:29 +0000
Running 4th Installation receiving data as a DTC-subinstance from another Installation?
View Count: 136
[2024-08-18 21:17:21]
Khas - Posts: 2
Hello!
I currently use Denali data feed across 3 installations of SierraChart. I want to add a 4th installation that also needs Denali data (which only allows 3 connections per device).
My idea is to set up the entire 4th installation (main and any subinstances) to receive data from one of my other 3 installations. Two of the existing installations already run as DTC servers to service their subinstances.
I understand the recommended method is to open more subinstances in my 3 existing installations but my experience has been that multiple installations noticeably outperforms multiple instances in the same installation (i.e. 3 main instances with 1 subinstance each seems significantly faster / smoother than 1 main instance with 5 subinstances).
1. How would I set this up?
2. Would this cause a decrease in performance for either the DTC server installation or the 4th installation?
[2024-08-19 15:34:05]
The only way you could get data to 4 separate installations of Sierra Chart is to have the 4th installation on a separate computer. You then have to pay a second set of exchange fees in order to allow the data to be used on two separate computers at the same time. Refer to the following regarding connections to the Denali Exchange Data Feed:
Denali Exchange Data Feed: Connections
