Date/Time: Sat, 23 Nov 2024 11:39:54 +0000
Odd lot candles on intraday chart
View Count: 124
[2024-08-17 18:09:48] |
User496120 - Posts: 1 |
Can you confirm if odd lot candles will display on a SPY intraday 1 minute chart? I am using the trial version and was not able to access the SPY intraday chart on it - I have a screenshot from another program of this chart from 8/12/24 that shows those candles - was hoping to replicate this view in Sierra. Please let me know. Thanks.
[2024-08-20 01:03:01] |
Sierra_Chart Engineering - Posts: 17145 |
Yes. However, refer to the information here for this: Data/Trade Service Settings: Process Known Odd Lot Equity Trades for DTC Services (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings) There are two options necessary for this and re-downloading of the data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
