Date/Time: Sat, 23 Nov 2024 11:36:47 +0000
Trading strategies
View Count: 181
[2024-08-17 16:40:41] |
User674409 - Posts: 24 |
Hello, I'm trading with one simple take profit order and one stop loss order, but i also want to trade with 2 differents take profits orders and my stop loss. It's possible to have those strategies available at the same time, in the same chartbook and with a hotkey activate one of them, as i consider it, depending on markets conditions? So I don't lose time changing my settings before I place a trade. Thanks
[2024-08-18 20:46:10] |
ForgivingComputers.com - Posts: 960 |
Use the Trade Window and save the trade configurations, then they will be in the drop-down list at the top.
[2024-08-19 15:31:01] |
You can also set Control Bar and/or Keyboard Shortcuts to change between Trade Configurations. Refer to the following: Global Settings Menu: Customize Control Bars >> Control Bar 1-12 (Global Settings menu) Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-21 19:26:49] |
Sierra_Chart Engineering - Posts: 17145 |
Keyboard shortcuts can also be set up for Trade Window configurations.: Control Bar: Control Bar Trade Window Configuration Buttons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-08-21 19:27:04
