Date/Time: Sat, 23 Nov 2024 11:54:21 +0000
[Locked] - New OC d Login Used
View Count: 180
[2024-08-17 13:26:12]
User360283 - Posts: 504
Not getting my previous chart files
URGENT HELP LEASE THANKS
[2024-08-19 12:27:44]
All of my chart files and codes have VANISHED!
URGENT HELP PLEASE
THANKS
[2024-08-19 15:32:07]
HELP PLEASE URGENT
NEW PC SO i INSTALLED SIERRA
LOGGED IN USING EXISTING ACCOUNT AND PASSWORD
BUT FILE OEN DOES NOT SHOW ANY SHOW ANY CHART FILES
MEAS I HAVE LOST 7 YEARS OF WORK!!!
URGENT HELP PLEASE THANKS
[2024-08-19 16:36:22]
All your files are located on your local computer. So when you install Sierra Chart on a new computer, you will NOT have any of the files from the other computer. You would need to copy the files from the old computer to the new computer. Refer to the following:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
[2024-08-19 18:42:08]
The old computer went up in smoke and fire !!!
So I will need a lot of your help Please
1. I used to have a stand stand alone DOM with Bid Ask prices, Current P*L and charts
How do I get this back?
Thnaks
[2024-08-19 20:49:08]
If you did not back up that information yourself, then it is gone. All of the data is located on the local computer. We do not store anything for you.
If you still have the computer, then you can always try a disk recovery service to see if they are able to recover the files for you.
[2024-08-19 22:29:01]
it really burned up and disk drive DOA not recoverable 7 years of work gone
please near with my manual recover
one more thing
I am now bling in one eye so reading documentation is a challenge Ugly me
[2024-08-20 09:29:38]
I have rebuilt all charts and studies. Whew!
I need your help om
1. How to create a few space between the chart last bar and the right edge.
2. How to recreate the Standalone DOM so I can trade from it as before
I want to display buy & sell chart, P&L, and studies.
Please point me how to begin doing this
[2024-08-20 15:39:27]
1. Set the chart as you want then select "Chart >> Lock Fill Space". Refer to the following:
Chart Menu: Lock Fill Space (Chart menu)
2. Select "File >> Open Trading DOM for Chart" (or "File >> Open Trading DOM" if you do not have a chart already open for the symbol). Then modify the DOM as you want. In particular, refer to the following:
Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific)
[2024-08-20 18:33:29]
Thanks very much
Almost done
But on the Quote Board I am not getting data for the Dow and Nas futures.
YMU24E and NQU24E
Help please UThanks
[2024-08-20 19:54:09]
YMU24E and NQU24E are not valid symbols. You need to enter the symbols as they are for the service you are connected to. This will be the same symbol as you use for a chart.
[2024-08-21 13:10:25]
What are the correct symbols?
[2024-08-21 15:50:21]
Sierra_Chart Engineering - Posts: 17145
You will find them in File >> Find Symbol:
File Menu: Find Symbol (File)
Date Time Of Last Edit: 2024-08-21 15:50:29
