Date/Time: Sat, 23 Nov 2024 16:27:39 +0000
New Chart Drawing Properties Window
View Count: 110
[2024-08-17 05:10:59] |
nicktrader - Posts: 709 |
I have been using this platform for a long time, but I have big problems with the handling of the new ‘Chart Drawing Properties Window’. Is there perhaps the possibility of creating a comprehensive video specifically for this? - What are the individual steps for creating a configuration, even if TC>12. - A configuration with text. It would be a great help to me. Many thanks |
[2024-08-19 14:47:35] |
The process for setting/modifying the configurations has not really changed, it is just on a different page with a different look, but the general instructions are still correct. For instance, to select a configuration greater than 12, you need to use the Tool Configuration List to select the particular configuration you want to save/restore from, which is how it has been. Refer to the following: Chart Drawing Tools: Using Multiple Drawing Tool Configurations For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
