Date/Time: Sat, 23 Nov 2024 16:09:53 +0000
Crude Oil stopped ticking?
View Count: 189
[2024-08-16 18:51:55] |
User910963 - Posts: 80 |
Hi. CL stopped ticking?
Date Time Of Last Edit: 2024-08-16 18:52:07
[2024-08-16 19:00:44] |
Sierra_Chart Engineering - Posts: 17150 |
You may need to rollover to the next contract month. Chart >> Perform Futures Symbol Rollover.
[2024-08-16 19:08:49] |
Thank you. I rolled over to October not too long ago? This happened once before and it was because the symbol was updated for my CQG symbols. This one looks good on the chart symbol. Everything look good here? 😎 Date Time Of Last Edit: 2024-08-16 19:31:06
Screenshot 2024-08-16 121232.png / V - Attached On 2024-08-16 19:15:08 UTC - Size: 260.01 KB - 37 views |
[2024-08-16 20:08:50] |
Just make sure that you see the historical data and that you see the current prices within Window >> Current Quote Window. Then this means everything is good.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-08-16 20:09:01
[2024-08-16 20:23:25] |
Yes. I see it. That interface looks pretty cool too. My first time seeing it. 😎 Prices are moving on it but on the chart the price is at 79.10 all day?
Date Time Of Last Edit: 2024-08-16 20:39:27
[2024-08-19 14:17:42] |
Refer to the following: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
