Date/Time: Sat, 23 Nov 2024 16:11:31 +0000
Muliple trading systems
View Count: 122
[2024-08-16 09:22:50]
User138457 - Posts: 38
I use multiple instances of "trading system based on alert condition".
Is there a way to use different braket orders for those or a least differentiate
in the trade journal which trade came from which trading system?
thanks in advance
[2024-08-19 13:57:18]
There is not a way to do what you are wanting directly from that study as it is. The only way to get what you want would be to modify the code for the study so you could set the particular Trade Configuration as you want along with the "Text Tag" which can be used to differentiate the trades.
Refer to the following:
Basic Trading and the Trade Window: Set >> Text Tag
Automated Trading From an Advanced Custom Study: Programmatically Setting Trade Window Configuration
Automated Trading From an Advanced Custom Study: [Type: SCString] s_SCNewOrder::TextTag
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
