Date/Time: Sat, 23 Nov 2024 11:37:57 +0000
Stop and Reverse Strategy Not Showing exit trades
View Count: 222
[2024-08-16 01:02:21] |
User769783 - Posts: 182 |
I have a stop and reverse automated strategy. It is buying at the moment, and when it exits, its because the sell entry was true. No matter whether it exits for profit or loss. Why is it not showing the exit trades? Is it something to do with my code and how the logic is executing?
[2024-08-19 13:35:36] |
Are you not seeing the Order Fill showing on the chart for the exit when you reverse? Or are you referring to something else? The order fill should definitely show, if you are displaying the order fills. Please get us an image of what you are seeing and let us know where the particular actions occurred. Follow these instructions to get us an image: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-19 22:56:08] |
Where the order size is 375, I set that because when the program restarted, that was the order size. I changed it, flattened the order, then it reset to 25 contracts. But you can see after it went back to 25 contracts that it made some buys, but where are the exit orders?
scpic25.PNG / V - Attached On 2024-08-19 22:52:29 UTC - Size: 104.53 KB - 35 views Attachment Deleted. |
[2024-08-20 14:28:58] |
We are not really understanding the question based on the image you gave. The image shows that all of the trades, except for the last one with a quantity of 25 are closed. The last position in the image which opened at 2024-08-19 14:54:53.610 is still open. Is there a problem with this last trade? Should it be closed? Also, you can better view the status of the orders by widening the "Exit DateTime" column so you can see where the EP (End Position) is noted. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-23 04:27:40] |
User61168 - Posts: 403 |
User769783 - looks like you are scaling in and out of your trades without flattening/closing all your trades. It appears you are doing a stop and reverse on partial open position quantity. Play around with some the available options under Edit menu to see if it makes any difference.
Date Time Of Last Edit: 2024-08-23 04:28:15
