Date/Time: Sat, 23 Nov 2024 15:49:00 +0000
Sharing Chartbooks between 'File> New Instance
View Count: 151
[2024-08-16 00:28:01] |
User740271 - Posts: 11 |
Thank you for your time. Is it possible to share Chartbooks to a: 'File> New Instance?' If multiple brokers (each on a 'new instance') may I copy over Charbooks to another 'instance?' Thank you, |
[2024-08-16 22:52:07] |
I guess the other way is to use the chartbooks I use, and just have the trade doms open on the second broker's account. Is that about right? Thanks.
[2024-08-19 14:33:37] |
You can always copy the chartbooks between the different instances. You just need to ensure that Sierra Chart is not running in either instance when you do the copying. Keep in mind that a new instance started with "File >> New Instance" exists under a folder named 'SierraChartInstance_2', where the number at the end designates the particular instance. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
