Date/Time: Sat, 23 Nov 2024 14:29:01 +0000
VWAP dotted vertical line between ETH & RTH
View Count: 121
[2024-08-14 19:02:38] |
Dorel - Posts: 5 |
Hello, Where can I activate on the VWAP charts the vertical dotted line between the end of ETH and start of RTH? This is what I had and today I pressed something wrong and now it`s gone and I don't know how to activate it again. Screenshot attached. Regards, |
Vertical dotted line between ETH and RTH.png / V - Attached On 2024-08-14 19:02:32 UTC - Size: 39.8 KB - 40 views |
[2024-08-14 19:08:58] |
We can not say for sure, as there are a number of ways to get a line like that. The first thing to check is the Vertical Grid. See if the option for "Chart >> Vertical Grid" is enabled (has a checkmark next to it). If not, then select this and see if that restores your line If this option was already enabled, then most likely the color of the line was changed. Refer to the following setting that controls this: Graphics Settings: Chart Grid Another possibility is the "Date Time Line" study. Refer to the following and see if this might have been something you were using: Date-Time Line For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
