Date/Time: Sat, 23 Nov 2024 14:11:01 +0000
TPO Volume Count
View Count: 92
[2024-08-14 12:17:19]
User131975 - Posts: 78
Hello, I currently have the numbers for the volume profile on the far right of the rank (it is basically an extra VP for the day where you can only see the numbers)
Is there a way to display these numbers next to the VP and possibly adjust the colors of the numbers?
I currently have it this way because otherwise these numbers are directly above the volume profile
imageScreenshot 2024-08-14 141458.png / V - Attached On 2024-08-14 12:16:06 UTC - Size: 235.68 KB - 36 views
[2024-08-14 15:02:35]
If you are asking if these can be displayed offset from the profile, the answer is no. There is an option to display the values either at the end of the bars, or at the base of the bars, but in both cases the value displayed is always within the profile itself. Refer to the following:
Volume By Price Study: Align Volume Numbers to Base of Volume Bars
If you are asking something else, then we need more information, as we are not understanding.
The coloring of the numbers drawn within the profile is controlled by subgraph 7. Refer to the following:
Volume By Price Study: Volume Numbers Text Color and Size (SG7)
