Date/Time: Sat, 23 Nov 2024 14:33:54 +0000
TPO Show Volume in Periods
View Count: 102
[2024-08-14 09:18:32]
User131975 - Posts: 78
Hello, I would like to have the possibility to display the volume in e.g. the first 30 minute period.
I have already tried to do it with the “Chart Calc” tool but I get wrong values from the TPO chart when I compare it with the candlestick chart.
I have also tried to display the RVOL Indicator via Price Study Overlay and another chart but that doesn't work either. I somehow need an RVOl indicator in the TPO chart
[2024-08-14 14:41:30]
There is not an option for this within the TPO study. You would have to have a separate chart set to a 30 minute bar period and then look at the particular volume for a particular sub-period within that chart.
If you want to display the first 30 minute volume, then you could use a Spreadsheet to get the volume from that first period and then use the "Text Display for Study From Chart" to display that information on the TPO chart. Refer to the following:
Using the Spreadsheet Study
Text Display For Study from Chart
The Chart Calculator tool will not work properly in a TPO chart, since the TPO chart does not have the typical time data.
