Date/Time: Sat, 23 Nov 2024 13:49:40 +0000
OpenGL Windows 11 (2 instances)
View Count: 253
[2024-08-13 20:22:17]
skalaydzhiyski - Posts: 58
Hi guys, I have 2 instances running sierra (second one started with File->New Instance), the first being for my DOMs
the second for footpring + TPO + volume profile + 1 min chart. Ideally I would like the second instance to use opengl and leave the whole CPU for my first instance.
I tried ticking the box in Global Settings -> Graphics Settings and restarted Sierra Chart, but when I go to settings the box is unticked and nothing has changed. I tried changing the setting to both instances and then restarting, but to no effect.
Any ideas what I am doing wrong here ?
All the best
[2024-08-13 20:28:14]
If the option for OpenGL is not staying selected, then this would mean that your graphics card does not have support for OpenGL.
[2024-08-13 20:48:52]
I have Geforce RTX 4060 ti and have installed the latest driver from nvidia
Also GL Viewer says I have GL Version 4.6
[2024-08-13 21:42:01]
User695518 - Posts: 53
Do you have the option selected to always copy configuration files to new instances when started? I recall there was some setting to keep the configuration in sync between instances that caused me more harm than good...
Date Time Of Last Edit: 2024-08-13 21:43:14
[2024-08-13 23:01:30]
thank you that worked, I had the option to sync settings between the two instances.
All the best, we can close this one.
Date Time Of Last Edit: 2024-08-14 10:20:50
