Date/Time: Sat, 23 Nov 2024 13:54:12 +0000
Market Depth Data
View Count: 90
[2024-08-13 15:39:19]
User417302 - Posts: 67
I want to change around some of my market depth data. When should I do it in order for it to take place for the next month? I don't want to disrupt the data I have now.
Thanks,
[2024-08-13 16:26:02]
With regards to changing your exchange selections, you will want to "Deactivate" immediately, any exchanges that you do not want to automatically renew on the first day of the following month. You will still get the data from that exchange through the remainder of the current month. You are just setting it to not automatically renew. For the CME Group data, you do this at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
Then, on that first day of the next month (or your first day trading after the first day of the month), you will go to the same link above, and activate the exchanges for which you want the real-time data for that month and going forward.
