Date/Time: Sat, 23 Nov 2024 14:18:46 +0000
[User Discussion] - Chart Type 'Line on Close', autocolor based on +/-
View Count: 114
[2024-08-13 14:12:36]
User14953 - Posts: 235
Can Sierra chart display a chart window with the characteristics of the settings:
Chart Type 'Line on Close', 1)autocolor based on +/-?
Chart Type 'Line on Close', 2) autocolor based on slope?
Date Time Of Last Edit: 2024-08-13 14:15:50
[2024-08-13 15:18:43]
You can do this by using the "Study Subgraph Reference" and have it reference the Close of data and display it as a line. You can also enable the option for "Display as Main Price Graph". Refer to the following:
Otherwise, you could do what you want by using the "Color Bar Based on Alert Condition". Refer to the following:
