Date/Time: Sat, 23 Nov 2024 14:02:30 +0000
Volume Rollover
View Count: 124
[2024-08-13 13:38:39]
User841161 - Posts: 221
Why is Volume Symbole needs Rollover popping up when current volume for this months contract is still higher than the next months contract.
Date Time Of Last Edit: 2024-08-13 13:41:07
image8-13-24.PNG / V - Attached On 2024-08-13 13:37:29 UTC - Size: 43.92 KB - 41 views
image8-13-2024.PNG / V - Attached On 2024-08-13 13:40:54 UTC - Size: 22.88 KB - 32 views
[2024-08-13 14:49:39]
Sierra_Chart Engineering - Posts: 17145
This notice is correct. The real-time volume must be higher in the next contract month. You can check the real-time volume for each contract month, in the Window >> Current Quote Window. Open a chart for the next contract month.
Date Time Of Last Edit: 2024-08-13 14:50:20
[2024-08-13 17:41:39]
U Contract still has more volume than V Contract.
image08-13-24.PNG / V - Attached On 2024-08-13 17:41:31 UTC - Size: 131.06 KB - 31 views
[2024-08-13 18:35:24]
At some point recently the volume of the V contract must have been larger.
[2024-08-13 19:21:52]
When and how often does it check?
[2024-08-14 17:38:47]
This is already in the documentation:
General Settings Window: Detect Rollover Of Current Futures Contracts Symbols Based On Real Time Volume (Global Settings >> General Settings >> Charts >> Symbol)
The check for determining if the symbol is expired based on volume is performed every 10 minutes and initially upon when the symbol is used.
