Date/Time: Sat, 23 Nov 2024 14:16:07 +0000
New Chartbook loading in blank
View Count: 139
[2024-08-13 06:53:55]
User821986 - Posts: 9
I recently added a new chartbook but when I try to open it, it loads in blank.
https://www.sierrachart.com/image.php?Image=1723531923764.png
https://www.sierrachart.com/image.php?Image=1723532024848.png
[2024-08-13 13:24:00]
BillsSBC - Posts: 38
Try:
Edit - Translate Symbols to Current Service
If you pulled the chartbook from someone else, they are likely using different service settings.
[2024-08-14 13:04:09]
Sierra_Chart Engineering - Posts: 17145
Yes use this Edit menu command to Translate the symbols:
Edit Menu: Edit >> Translate Symbols To Current Service
