Date/Time: Sat, 23 Nov 2024 14:44:53 +0000
[User Discussion] - Modified, renamed Study Collections Names index
View Count: 114
[2024-08-13 02:05:09]
User14953 - Posts: 235
Can Sierra running on a Removable Disc G save edited, newly titled studies in alphabetical sequence when listed in the Study_Collection_Names index, the same way it does when running on a Local Disc C?
Attached images demonstrate the issue
On Local Disc C: - Edited, newly titled and saved studies are listed in alphabetical sequence when listed in the Study_Collection_Names index.
To avoid the attachment limit more images follow.
On Removable Disc G: - they are added out of sequence, at the end of the index.
imagesc_1studiesIndex_On Removable Disc G_image1 Before.jpg / V - Attached On 2024-08-13 02:04:37 UTC - Size: 649.13 KB - 41 views
imagesc_2studiesIndex_On Removable Disc G_image2 After(.jpg / V - Attached On 2024-08-13 02:04:42 UTC - Size: 651.93 KB - 41 views
[2024-08-13 02:06:14]
continued
imagesc_3studiesIndex_On_Local_Disc_C_image1 Before.jpg / V - Attached On 2024-08-13 02:05:52 UTC - Size: 57.36 KB - 37 views
imagesc_4studiesIndex_On_Local_Disc_C_image2 After(.jpg / V - Attached On 2024-08-13 02:05:56 UTC - Size: 59.38 KB - 36 views
imagesc_5studiesIndex_3Folders side by side.jpg / V - Attached On 2024-08-13 02:06:05 UTC - Size: 76.22 KB - 38 views
[2024-08-13 14:16:03]
We do not know and it is not something we will spend time looking into. We do not recommend running Sierra Chart on a removable drive.
[2024-08-13 23:21:53]
Thanks for taking a look John.
Can this thread be turned into a user discussion?
Over time, somebody'll puzzle it out.
Attached are a couple of images showing paths.
imagesc_6studiesIndex_GenSettingsFileAndFolderPaths_G-unit1.jpg / V - Attached On 2024-08-13 23:21:17 UTC - Size: 82.51 KB - 31 views
imagesc_7studiesIndex_GenSettingsFileAndFolderPaths_F-unit2.jpg / V - Attached On 2024-08-13 23:21:23 UTC - Size: 76.82 KB - 31 views
