Date/Time: Sat, 23 Nov 2024 15:24:20 +0000
[User Discussion] - Loading Sierra Charts on an ipad
View Count: 255
[2024-08-12 20:29:25]
User157189 - Posts: 1
Can Sierra Charts be loaded on an iPad.... If yes what are the steps?
[2024-08-12 20:30:20]
Not officially. Sierra Chart is only setup to be run on a Windows system.
There are people that have posted on the this board stating that they have used Remote Desktop with other devices. We have set this post as a User Discussion, in case others want to comment on their experiences.
You should also search this board to see what you can find.
[2024-08-13 05:03:54]
Tony - Posts: 516
not sure how you define "loaded"
Sierra doesn't run directly in any Apple's OS.
I was managed to use the approach John mentioned, by install a VNC server on the desktop where Sierra is running and install a VNC viewer on iPad. I stop using it now due to the concern of safety.
